  • 7530阅读
  • 12回复
由13个LED组成的自行车后座安全灯 [复制链接]
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2008-08-11
Flashing 13 LED unit, 3V supply
Also suitable for jogger/walkers
Circuit diagram:
Parts:
R1_____________10K   1/4W Resistor
R2,R9,R10_____100K   1/4W Resistors
R3-R8,R11-R16__10R   1/4W Resistors
R17___________150R   1/4W Resistor
C1_____________1µF  63V Polyester Capacitor
C2_____________10nF  63V Polyester Capacitor
C3____________100µF  25V Electrolytic Capacitor
D1-D13_____Red LEDs  5mm. or bigger, high efficiency
IC1,IC2________7555  or TS555CN CMos Timer IC
SW1___________SPST  Slider Switch
B1_____________3V  Battery (2 AA 1.5V Cells in series)
Device purpose:
This circuit has been designed to provide a clearly visible light, formed by 13 high efficiency flashing LEDs arranged in a pseudo-rotating order. Due to low voltage, low drain battery operation and small size, the device is suitable for mounting on bicycles as a back light, or to put on by jogger/walkers.
Circuit operation:
IC1 is a CMos version of the 555 IC wired as an astable multivibrator generating a 50% duty-cycle square wave at about 4Hz frequency. At 3V supply, 555 output (pin 3) sinking current operation is far better than sourcing, then LEDs D1-D6 are connected to the positive supply rail. In order to obtain an alternate flashing operation, a second 555 IC is provided, acting as a trigger plus inverter and driving LEDs D7-D12. D13 is permanently on.
The LEDs are arranged in a two series display as shown below, with a center LED permanently on. This arrangement and the alternate flashing of the two series of LEDs provide a pseudo-rotating appearance.
LED arrangement:
Notes:
Flashing frequency can be varied changing C1 value.
High efficiency LEDs are essential.
本帖最近打赏记录:共1条打赏
萍聚 M币 +5 - 2018-04-12
离线hellokite
只看该作者 1楼 发表于: 2008-08-12
离线lg27152856
只看该作者 2楼 发表于: 2008-08-12
离线检修地球
只看该作者 3楼 发表于: 2008-08-12
离线willcom
只看该作者 4楼 发表于: 2008-08-13
离线wzsky88
只看该作者 5楼 发表于: 2008-08-13
只看该作者 6楼 发表于: 2008-08-15
离线lh0577
只看该作者 7楼 发表于: 2008-08-18
只看该作者 8楼 发表于: 2008-08-18
离线kinneng
只看该作者 9楼 发表于: 2008-08-18
