设备描述: [G:]USB 大容量存储设备(3SYSTEM USB Flash Disk)
设备类型: 大容量存储设备
协议版本: USB 2.00
当前速度: 高速(HighSpeed)
电力消耗: 100mA
USB设备ID: VID = 0C76 PID = 0005
设备序列号: 001E101FB681F2C14ACF14DC
设备供应商: Kingston
设备名称: DataTraveler G3
设备修订版: 0100
产品制造商: 3SYSTEM
产品型号: USB Flash Disk
产品修订版: 1.00
芯片厂商: SSS(鑫创)
芯片型号: SSS6691-B3
闪存识别码: 98D79432 - Toshiba(东芝) - 2CE/单通道 [MLC-8K] -> 总容量 = 8GBMP Tool Version : V2.173
INI File Name : 99C4300-340.A00LF.INI
Format Date : 2010-12-21 18:49:40
Flash Part No : Toshiba 3xnm D2 MLC
CE-0, Flash ID=98-D7-94-32-76-55-0C
CE-1, Flash ID=98-D7-94-32-76-55-0C
VID : 0x0951
PID : 0x1643
Vendor Name = Kingston
Product Name = DataTraveler G3
Serial Number = 001CC07CEDA4FAC1592912E6
Volume Label =
F/W Version : 0xB3
ISP Version : VA3.1000
Flash R/W Timing : 33.3ns
Channel : Byte Mode
Homogeneous Mode : On
HID Function : Disable
Planes(F/W) : 1
Pages/Block : 128 pages
Max Current : 100 mA
Total Blocks : 8200
Bad Blocks : 42
Capacity : 15133376 Sectors, 7748288512 Bytes
7566688 KBytes, 7389.34 MBytes, 7.22 GBytes
量产报告
Starting Time: 00:36:04
Device 1:0xB3
MP Version:2.162
INI_File_Name:
Random delay 0 msec
--- Download MP ISP ---
CE-0, Flash ID=98-D7-94-32-76-55-0C-00
CE-1, Flash ID=98-D7-94-32-76-55-0C-00
Found BACKUP Table (000000BB-0001)
Defect Table (00000200-0004)
Original Bad Block - 0:0x0000
Original Bad Block - 0:0x0292
Original Bad Block - 0:0x0642
Original Bad Block - 0:0x0718
Original Bad Block - 0:0x07C2
Original Bad Block - 0:0x0824
Original Bad Block - 0:0x0907
Original Bad Block - 0:0x0929
Original Bad Block - 0:0x09A0
Original Bad Block - 0:0x0B0B
Original Bad Block - 0:0x0BF2
Original Bad Block - 1:0x0000
Original Bad Block - 1:0x025E
Original Bad Block - 1:0x0290
Original Bad Block - 1:0x02A5
Original Bad Block - 1:0x02D8
Original Bad Block - 1:0x0818
Original Bad Block - 1:0x081A
Original Bad Block - 1:0x0822
Original Bad Block - 1:0x0912
Original Bad Block - 1:0x097C
Original Bad Block - 1:0x0A04
Original Bad Block - 1:0x0A10
Original Bad Block - 1:0x0A1A
Original Bad Block - 1:0x0A1E
Original Bad Block - 1:0x0A30
Original Bad Block - 1:0x0AC8
Original Bad Block - 1:0x0B2A
Original Bad Block - 1:0x0BF0
Original Bad Block - 1:0x0C08
Original Bad Block - 1:0x0C14
Original Bad Block - 1:0x0C24
Original Bad Block - 1:0x0D7C
Original Bad Block - 1:0x0DB8
Original Bad Block - 1:0x0DEE
Original Bad Block - 1:0x0E26
Original Bad Block - 1:0x0E80
Original Bad Block - 1:0x0E9C
Original Bad Block - 1:0x0F30
Original Bad Block - 1:0x0F32
Original Bad Block - 1:0x0F48
Original Bad Block - 1:0x0FA6
Defect Table shows 8158 Good blocks, 42 Bad blocks
SafeErase (0,4100)
Erase failed Block - 0:0:0x0000
Erase failed Block - 0:0:0x0292
Erase failed Block - 0:0:0x0642
Erase failed Block - 0:0:0x0718
Erase failed Block - 0:0:0x07C2
Erase failed Block - 0:0:0x0824
Erase failed Block - 0:0:0x0907
Erase failed Block - 0:0:0x0929
Erase failed Block - 0:0:0x09A0
Erase failed Block - 0:0:0x0B0B
Erase failed Block - 0:0:0x0BF2
---> Max Bad of Plane (4,2)
SafeErase (1,4100)
Erase failed Block - 1:0:0x0000
Erase failed Block - 1:0:0x025E
Erase failed Block - 1:0:0x0290
Erase failed Block - 1:0:0x02A5
Erase failed Block - 1:0:0x02D8
Erase failed Block - 1:0:0x0818
Erase failed Block - 1:0:0x081A
Erase failed Block - 1:0:0x0822
Erase failed Block - 1:0:0x0912
Erase failed Block - 1:0:0x097C
Erase failed Block - 1:0:0x0A04
Erase failed Block - 1:0:0x0A10
Erase failed Block - 1:0:0x0A1A
Erase failed Block - 1:0:0x0A1E
Erase failed Block - 1:0:0x0A30
Erase failed Block - 1:0:0x0AC8
Erase failed Block - 1:0:0x0B2A
Erase failed Block - 1:0:0x0BF0
Erase failed Block - 1:0:0x0C08
Erase failed Block - 1:0:0x0C14
Erase failed Block - 1:0:0x0C24
Erase failed Block - 1:0:0x0D7C
Erase failed Block - 1:0:0x0DB8
Erase failed Block - 1:0:0x0DEE
Erase failed Block - 1:0:0x0E26
Erase failed Block - 1:0:0x0E80
Erase failed Block - 1:0:0x0E9C
Erase failed Block - 1:0:0x0F30
Erase failed Block - 1:0:0x0F32
Erase failed Block - 1:0:0x0F48
Erase failed Block - 1:0:0x0FA6
---> Max Bad of Plane (15,1)
---> Max BAD/DIE = 15
Total good blocks after SCAN: 8158 / 8200, Bad block=42
==> 2-Plane mode
Max. Bad Block Allowed = 371(42)
Adjust Max LBA = 15646720, 15646656
MaxWindows=4/1910, MaxLBA=15646656, Size=7639 MB
Max BAD of one plane is 15 (46),8200,1,2
RootSector=0x1E35,Sec/Cluster=32, SuperPage=32 ---> Alignment=11
Boot Block=0x0001,0x0002
Lun0(15646656), Lun1(0), Public=15646656, Secure=0, CDROM=0
Special FE Config = 54-0B-00
Defect Table Block=0x0004
--- Download ISP Code:E:\MP_ALL\ISP_CODE\6691_B3-A_20100331_VA10F00_9083.BIN---
--- ISP Code installed.
[ 此帖被wydfz在2012-12-22 08:06重新编辑 ]
