  • 5460阅读
  • 20回复
[鑫创]金士顿DdtdTrdveler G3量产成功容量变小求恢复回4G [复制链接]
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2013-01-07
量产工具:鑫创SSS6692 V2.182 量产CDROM支持海力士,镁光,东芝,因特尔闪存
INI配置文本:6692_Toshiba 43nm D2 Flash 3.89G
成功量产报告如下:
---------------- Device 1------------------
  MP Tool Version : V2.182
  INI File Name : 6692_Toshiba
  Format Date : 2013-01-07 15:04:50
  Flash Part No : Toshiba 3xnm D2 MLC
  CE-0, Flash ID=98-D7-94-32-76-55-0D
  VID : 0x0951
  PID : 0x1643
  Vendor Name = Kingston
  Product Name = DataTraveler G3
  Serial Number = 50E54981B7AFFD107F0A204B
  Volume Label =
  F/W Version : 0xB5
  ISP Version : VB1.0000
  Flash R/W Timing : 25ns
  Channel : Byte Mode
  Homogeneous Mode : On
  HID Function : Disable
  Planes(F/W) : 2
  Pages/Block : 128 pages
  Max Current : 100 mA
  Total Blocks : 4100
  Bad Blocks : 930
  Capacity : 6065056 Sectors, 3105308672 Bytes
                   3032528 KBytes, 2961.45 MBytes, 2.89 GBytes
Device 1:0xB5
MP Version:2.182
INI_File_Name:6692_Toshiba 43nm D2 Flash 3.89G.INI
Random delay 0 msec
--- Download MP ISP ---
### No support [SCAN_RDY_BSY-0xFF 0x30] !
CE-0, Flash ID=98-D7-94-32-76-55-0D-00
Found BACKUP Table (000000BB-0001)
Defect Table (00000400-0008)
  Original Bad Block - 0:0x0002
  Original Bad Block - 0:0x0003
  Original Bad Block - 0:0x0006
  Original Bad Block - 0:0x0007
  Original Bad Block - 0:0x000A
  Original Bad Block - 0:0x000B
  Original Bad Block - 0:0x000D
  Original Bad Block - 0:0x000F
  Original Bad Block - 0:0x0010
  Original Bad Block - 0:0x0011
  Original Bad Block - 0:0x0012
  Original Bad Block - 0:0x0013
  Original Bad Block - 0:0x0014
  Original Bad Block - 0:0x0016
  Original Bad Block - 0:0x0017
  Original Bad Block - 0:0x0018
  Original Bad Block - 0:0x001A
  Original Bad Block - 0:0x001B
  Original Bad Block - 0:0x001E
  Original Bad Block - 0:0x001F
  Original Bad Block - 0:0x0020
  Original Bad Block - 0:0x0021
  Original Bad Block - 0:0x0022
  Original Bad Block - 0:0x0023
  Original Bad Block - 0:0x0026
  Original Bad Block - 0:0x0027
  Original Bad Block - 0:0x0029
  Original Bad Block - 0:0x002A
  Original Bad Block - 0:0x002E
  Original Bad Block - 0:0x002F
  Original Bad Block - 0:0x0031
  Original Bad Block - 0:0x0032
  Original Bad Block - 0:0x0033
  Original Bad Block - 0:0x0036
  Original Bad Block - 0:0x0037
  Original Bad Block - 0:0x0038
  Original Bad Block - 0:0x0039
  Original Bad Block - 0:0x003A
  Original Bad Block - 0:0x003B
  Original Bad Block - 0:0x003C
  Original Bad Block - 0:0x003E
  Original Bad Block - 0:0x003F
  Original Bad Block - 0:0x0040
  Original Bad Block - 0:0x0041
  Original Bad Block - 0:0x0043
  Original Bad Block - 0:0x0044
  Original Bad Block - 0:0x0045
  Original Bad Block - 0:0x0047
  Original Bad Block - 0:0x0049
  Original Bad Block - 0:0x004B
  Original Bad Block - 0:0x004C
  Original Bad Block - 0:0x004D
  Original Bad Block - 0:0x004F
  Original Bad Block - 0:0x0050
  Original Bad Block - 0:0x0053
  Original Bad Block - 0:0x0054
  Original Bad Block - 0:0x0055
  Original Bad Block - 0:0x0057
  Original Bad Block - 0:0x0059
  Original Bad Block - 0:0x005B
  Original Bad Block - 0:0x005C
太多省掉
  Original Bad Block - 0:0x0E9D
  Original Bad Block - 0:0x0E9E
  Original Bad Block - 0:0x0E9F
  Original Bad Block - 0:0x1002
  Original Bad Block - 0:0x1003
Defect Table shows 3170 Good blocks, 930 Bad blocks
SafeErase (0,4100)
  Erase failed Block - 0:0:0x0002
  Erase failed Block - 0:0:0x0003
  Erase failed Block - 0:0:0x0006
  Erase failed Block - 0:0:0x0007
  Erase failed Block - 0:0:0x000A
  Erase failed Block - 0:0:0x000B
  Erase failed Block - 0:0:0x000D
  Erase failed Block - 0:0:0x000F
  Erase failed Block - 0:0:0x0010
  Erase failed Block - 0:0:0x0011
  Erase failed Block - 0:0:0x0012
  Erase failed Block - 0:0:0x0013
  Erase failed Block - 0:0:0x0E9C
  Erase failed Block - 0:0:0x0E9D
  Erase failed Block - 0:0:0x0E9E
  Erase failed Block - 0:0:0x0E9F
  Erase failed Block - 0:0:0x1002
  Erase failed Block - 0:0:0x1003
  ---> Max Bad of Plane (209,257)
  ---> Max BAD/DIE = 257
Total good blocks after SCAN: 3170 / 4100, Bad block=930
==> 2-Plane mode
Adjust Max LBA = 6293504, 6070208
MaxWindows=2/1482, MaxLBA=6070208, Size=2963 MB
Max BAD of one plane is 257 (259),4100,1,1
RootSector=0xBF3,Sec/Cluster=32, SuperPage=32 ---> Alignment=13
Boot Block=0x0001,0x0004
Lun0(6070208), Lun1(0), Public=6070208, Secure=0, CDROM=0
Special FE Config = 54-0B-00
Defect Table Block=0x0008
--- Download ISP Code:G:\软件单文件版\金士顿量产工具\鑫创SSS6692 V2.182 量产CDROM支持海力士,镁光,东芝,因特尔闪存\ISP_CODE\6692_B5-A_20100916_VB10000_63E2.BIN---
--- ISP Code installed.
Public,Secure,CDROM = 6070208,0,0
PHY: E2/E4/E6=72h/36h/04h,  D0/C0/CFG10=DFh/0Bh/87h
SN=50E54981B7AFFD1074EC204E
=== Preformat Done ===
Low Level Format DONE
Store INI/ERROR MSG to Block-0x0001:79.
LBATest 10M activate
Total=6070208,CDROM=0, PublicArea=6070080, SecureArea=0
Create SECURE(CDROM=0,Public=2963 MB,Secure=0 MB)
--- T2 start ---
FW version is: 0xB5
Vendor ID is:0x0951
Product ID is:0x1643
Vendor=Kingston
Product=DataTraveler G3
Device capacity : 0 > 30351 > 0
DOS Volume=
Device is formatted.
--- T2 is done ---
Total Capacity: 6070208 sectors, 2963 MBytes
Elasped Time = 00:00:23
问题错在哪呢  汗  求指教
[ 此帖被爱在星空下在2013-01-07 21:36重新编辑 ]
本帖最近打赏记录:共1条打赏M币+3
离线kohna
只看该作者 1楼 发表于: 2013-01-07
只看该作者 2楼 发表于: 2013-01-07
只看该作者 3楼 发表于: 2013-01-07
回 1楼(kohna) 的帖子
离线shuishou
只看该作者 4楼 发表于: 2013-01-07
回 楼主(爱在星空下) 的帖子
本帖最近打赏记录:共1条打赏M币+5
只看该作者 5楼 发表于: 2013-01-07
回 4楼(shuishou) 的帖子
只看该作者 6楼 发表于: 2013-01-08
只看该作者 7楼 发表于: 2013-01-08
本帖最近打赏记录:共1条打赏M币+5
只看该作者 8楼 发表于: 2013-01-08
回 7楼(机器娃娃小雨) 的帖子
只看该作者 9楼 发表于: 2013-01-08
回 7楼(机器娃娃小雨) 的帖子
