  • 2687阅读
  • 7回复
[鑫创]金士顿 DT101 G2 闪存怪事 [复制链接]
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2013-03-30
最近该U盘老是拷贝进去东西不完整(非扩容问题)
然后用工具检测了一下,坏块很多
想起用量产工具处理一下,无法完成处理,无奈,想看下存储芯片,找块换上
打开盖子,和平时使用的存储芯片不太一样,难道买到假货了!?求大虾指点
以下是量产工具的错误报告
Date : 2013-03-30 13:43:35
Tools: USB OnCardSorting 5.024 [2009.10.06] (Solid State System)
Device 1:0xB1
Disk=H, Handle: 0x00000160
   $$$ Type-2 $$$
     Flash=0, CE index=0, ForceID=0
     Type=2, Method=13, Pattern=1
     PageMode=0, ECC=12, Timing=5
     Disk Prefer=0, EmableSN=1
     Option4=00, DiskSize=0, ShowBIN=1
     EraseAll=0, UseOldTable=1, LEDDuty=100
     VID=0C76, PID=0004, IO(Current,Delay)=0,0
     StringDesc=1, SN Index=1, Secure=0
   [2090 CM]
   --- Download MP ISP(6690_B1-CM_20090929_V308_4F95.BIN) ---
   CE-0, Flash ID=98-D7-94-32-76-54-0C-00
   Searching SORTING BOARD table ...
   --> Not Found
   ### 6690 Sorting Method(1,1,1)-2, MP(1,1,1), ECC=12, Time=5 ###
   Download ISP:E:\下载\3S_USB6690_OnCardSorting_V5     1D.024\3S_USB6690_OnCardSorting_V5.024\ISP_CODE\SORTINGISP.BIN
   ### 6690 Sorting ISP:SORTING 1.9 ###
   Total Block=0x1034, total page=0x00081A00, Page/Block=128(128), Sector/Page=16
   *** Original Bad Block in DISK are 0 blocks ***
   PreTest Result: (H=132, F=132, A=0)
   $$$ Select Mode=1, Group PreTest takes     69 sec $$$
   --- SortingBoard Method-S ---
   $$$ SortingBoard Test-1 takes     13 sec $$$
   $$$ SortingBoard Test-2 takes    155 sec $$$
   $$$ SortingBoard Test-3 takes    103 sec, (10) $$$
   [ECC=12] -->  4138/ 4148 Block are Good, 99%
   --- SortingBoard Method-L ---
   $$$ SortingBoard Test-2 takes    621 sec $$$
   $$$ SortingBoard Test-3 takes    414 sec, (0) $$$
   $$$ Test-1 takes     13 sec $$$
   $$$ SortingBoard Test-2 takes    619 sec $$$
   Checking (Full-Page) or (Half-Page)
   (Full-Page)    4138/ 4148 Block are Good, 99%
   Total Block=0x1034(4148)
   Sorting result: 4138/4148, 10 bad
   Max Error block in plane (8)
   E00=3324   E01=0      E02=813    E03=1      E04=0
   E05=0      E06=0      E07=0      E08=0      E09=0
   E10=0      E11=0      E12=0      E13=0      E14=0
   E15=0      E16=0      E17=0      E18=0      E19=0
   E20=0      E21=0      E22=0      E23=0      E24=10
   *** Sorting takes 00:40:38 ***
   Total good blocks after SCAN: 4138 / 4148, Bad block=10
   DataBlock=4042, MaxLBA=8278016
   RootSector=0x3F77,Sec/Cluster=8, SuperPage=32 ---> Alignment=1
   Boot Block=0x0001,0x0002
   Lun0(8278016), Lun1(0), Public=8278016, Secure=0, CDROM=0
   Special FE Config = 54-0B-00
   --- Download ISP Code:6690_B1-CM_20090929_V308_4F95.BIN---
   --- ISP Code installed.
   (MaxLBA: 007E5000 < 005E3FDF)
   Lun0(6176735), Lun1(0), Public=6176735, Secure=0, CDROM=0
   Public,Secure,CDROM = 6176735,0,0
   SN=48B61F516D9A6
   === CM Preformat Done ===
   Low Level Format DONE
   Store INI/ERROR MSG to Block-0x0001:79.
   *** LLF done ***
   >>> DUT is ready ? <<<
   >>> Disk=3015 MB <<<
   >>> DOS Format <<<.
   Total=6176735,PublicArea=6176607, SecureArea=0, CD=0
   Create Partition(CDROM=0,Public=3015 MB,Secure=0 MB)
   ### Err: DOS Format failed(41).
   Testing stop at 2013-03-30 14:24:17
本帖最近打赏记录:共2条打赏M币+4
离线u盘狂人
只看该作者 1楼 发表于: 2013-03-31
离线qsav
只看该作者 2楼 发表于: 2013-03-31
离线sxw061
只看该作者 3楼 发表于: 2013-03-31
离线wyyyzyq
只看该作者 4楼 发表于: 2013-04-01
只看该作者 5楼 发表于: 2013-04-01
回 1楼(u盘狂人) 的帖子
只看该作者 6楼 发表于: 2013-04-01
回 4楼(wyyyzyq) 的帖子
只看该作者 7楼 发表于: 2013-04-01
回 1楼(u盘狂人) 的帖子
