  • 3135阅读
  • 0回复
[鑫创]sss6692-b4 量产求助 ERROR 8 [复制链接]
离线yuu8888
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2013-05-14
看了好多帖子,具体操作按照这个帖子来的http://bbs.mydigit.cn/read.php?tid=477165 用的6692_HY26_256P_8KB.INI 量产一直是error8 查了下应该是容量不匹配的意思,想问下这个要怎么办?为什么同样的u盘我的就不能量产成功啊,求各位帮看下能不能量产成功。
report 如下:
Device 1:0xB4
    MP Version:2.182
    INI_File_Name:6692_HY26_256P_8KB.INI
    Random delay 0 msec
    --- Download MP ISP ---
    Auto CE: 0x00 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF
    CE-0, Flash ID=98-DE-94-82-76-56-04-20
    Page/Block=256
    Searching SORTING BOARD table ...
    --> Not Found
    Found BACKUP Table (0000023A-0002)
    Found BACKUP Table (0000033A-0003)
        Original Bad Block - 0:0x0002
        Original Bad Block - 0:0x0003
        .......中间太多省略了.....
        Original Bad Block - 0:0x1018
        Original Bad Block - 0:0x101A
        Original Bad Block - 0:0x101B
    Defect Table shows 3178 Good blocks, 946 Bad blocks
    SafeErase (0,4124)
        Erase failed Block - 0:0:0x0002
        Erase failed Block - 0:0:0x0003
        .......中间太多省略了.....
        Erase failed Block - 0:0:0x1017
        Erase failed Block - 0:0:0x1018
        Erase failed Block - 0:0:0x101A
        Erase failed Block - 0:0:0x101B
        ---> Max Bad of Plane (246,264)
        ---> Max BAD/DIE = 264
    Total good blocks after SCAN: 3105 / 4124, Bad block=1019
    ==> 2-Plane mode
    Max. Bad Block Allowed = 202(1019)
    ### Error: Too many bad block.
    ### Error: Low level format failed ###
    SafeErase (0,4124)
        Erase failed Block - 0:0:0x0006
        Erase failed Block - 0:0:0x0007
        Erase failed Block - 0:0:0x000A
        Erase failed Block - 0:0:0x000B
        .......中间太多省略了.....
芯片信息这些:
