  • 9595阅读
  • 0回复
sandisk Cruzer Contour 16G Chips:20-99-00136-3 [复制链接]
离线mymo
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2008-12-22
I have the following:
- Flash type (USB, CF, SD...)USB
- Controller name sandisk 20-99-00136-3
- Flash chips amount- 1
- Flash chip name - SDTNLLCHSM-8192
- Config file content (Show config)SDTNKLAHSM
- Dumps amount1
- Do you found FAT?Yes
- Is there mix?Yes
- Do you remove mix?Partially.
I dumped the flash and then swapped by one.
I can then find the fat, but not the beginning. (F8FFFF).
Am I missing something else to remove the mix?
What am I doing wrong?
关键词: SanDisk
