  • 7362阅读
  • 9回复
[其他]Dir-665路由器启动信息 [复制链接]
离线zhuzhubaby
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2013-12-17
从易老板那里抢到了DIR-665路由器,国外版本做工就是好啊,而且路由器很稳定。配置也很强大
                CPU1: Marvell 88F6281 (1.2 GHz)
                FLA1: 16 MB (Macronix MX25L12805DMI-20G)
                RAM1: 128 MB (ProMOS V59C1G01168QBJ3 x 1)
拆机具体见:http://bbs.mydigit.cn/read.php?tid=710165
现在附上启动信息,昨天焊上TTL插针,具体中间两根为RX和TX,GND用万用表量一下就指导了
启动信息为:
1.中断自启动为:
U-Boot 1.1.4-1a32d6c5b32c4a2a3f36dd7c739f8691914a3416 (Dec  7 2009 - 12:31:34) Marvell version: 3.4.16
U-Boot code: 00600000 -> 0062E310  BSS: -> 0063DCD8
Soc: 88F6281 A0 (DDR2)
CPU running @ 1000Mhz L2 running @ 333Mhz
SysClock = 333Mhz , TClock = 200Mhz
DRAM CAS Latency = 5 tRP = 4 tRAS = 14 tRCD=4
DRAM CS[0] base 0x00000000   size 128MB
DRAM Total size 128MB  16bit width
[16384kB@f8000000] Flash: 16 MB
Addresses 8M - 0M are saved for the U-Boot usage.
Mem malloc Initialization (8M - 7M): Done
CPU : Marvell Feroceon (Rev 1)
Energy Detect Mode 2 Enabled
Streaming disabled
Write allocate disabled
Module 0 is TDM
Module 1 is AUDIO
USB 0: device mode
PCI 0: PCI Express Root Complex Interface
PEX interface detected Link X1
Net:   egiga0, egiga1
Hit any key to stop autoboot:  0
Marvell>>
2:自启动信息为:
Streaming disabled
Module 0 is TDM
Module 1 is AUDIO
USB 0: device mode
Net:   egiga0, egiga1
## Booting image at 06400000 ...
   Image Name:   Linux Kernel Image
   Image Type:   ARM Linux Kernel Image (lzma  compressed)
   Data Size:    1107781 Bytes =  1.1 MB
   Load Address: 00008000
   Entry Point:  00008000
   Verifying Checksum ... OK
   LZMA Umcompressing Kernel Image ...    Image loaded from 00008000-002f0f20
OK
Starting kernel ...
Linux version 2.6.29-107c03779180ba463cd78a07a53875ba9da5c3a1 (root@macpaul-desktop) (gcc version 4.2.1) #1 Fri Feb 12 10:31:16 CST 2010
CPU: Feroceon 88FR131 [56251311] revision 1 (ARMv5TE), cr=00053977
CPU: VIVT data cache, VIVT instruction cache
Machine: Marvell 88F6281 AMBER Board
Memory policy: ECC disabled, Data cache writeback
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 32512
Kernel command line: console=ttyS0,115200 mtdparts=spi0.0:192k(uboot),64k@192k(nvram),1536k@256k(kernel),14m@1792k(rootfs),64k@16128k(cal_data),192k@16192k(lang_pack) root=/dev/mtdblock3 ro rootfstype=squashfs
PID hash table entries: 512 (order: 9, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 128MB = 128MB total
Memory: 126704KB available (2724K code, 224K data, 112K init)
Calibrating delay loop... 992.87 BogoMIPS (lpj=4964352)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
net_namespace: 504 bytes
NET: Registered protocol family 16
Kirkwood: MV88F6281-A0, TCLK=200000000.
Feroceon L2: Enabling L2
Feroceon L2: Cache support initialised.
PCI: bus0: Fast back to back transfers disabled
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
squashfs: version 4.0 (2009/01/31) Phillip Lougher
JFFS2 version 2.2. (NAND) 漏 2001-2006 Red Hat, Inc.
msgmni has been set to 247
alg: No test for stdrng (krng)
io scheduler noop registered (default)
HDLC line discipline: version $Revision: 1.1.1.1 $, maxframe=4096
N_HDLC line discipline registered.
Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0xf1012000 (irq = 33) is a 16550A
console [ttyS0] enabled
MV-643xx 10/100/1000 ethernet driver version 1.4
mv643xx_eth smi: probed
net eth0: port 0 with MAC address 1c:bd:b9:d4:04:0c
net eth1: port 0 with MAC address 00:00:00:00:00:00
PPP generic driver version 2.4.2
PPP Deflate Compression module registered
PPP MPPE Compression module registered
NET: Registered protocol family 24
<pppoe_device_event:306>:event:5
PPPoL2TP kernel driver, V1.0
usbcore: registered new interface driver asix
Driver 'sd' needs updating - please use bus_type methods
m25p80 spi0.0: mx25l12805d (16384 Kbytes)
6 cmdlinepart partitions found on MTD device spi0.0
Creating 6 MTD partitions on "spi0.0":
0x000000000000-0x000000030000 : "uboot"
0x000000030000-0x000000040000 : "nvram"
0x000000040000-0x0000001c0000 : "kernel"
0x0000001c0000-0x000000fc0000 : "rootfs"
0x000000fc0000-0x000000fd0000 : "cal_data"
0x000000fd0000-0x000001000000 : "lang_pack"
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
orion-ehci orion-ehci.0: Marvell Orion EHCI
orion-ehci orion-ehci.0: new USB bus registered, assigned bus number 1
orion-ehci orion-ehci.0: irq 19, io mem 0xf1050000
orion-ehci orion-ehci.0: USB 2.0 started, EHCI 1.00
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
input: gpio-keys as /devices/platform/gpio-keys/input/input0
watchdog_init:142
Registered led device: gtw:blue:USB
Registered led device: gtw:blue:Internet
Registered led device: gtw:amber:Internet
Registered led device: gtw:blue:5G
Registered led device: gtw:blue:Status
Registered led device: gtw:blue:WPS
Registered led device: gtw:amber:Status
Registered led device: gtw:blue:2.4G
mv_xor_shared mv_xor_shared.0: Marvell shared XOR driver
mv_xor_shared mv_xor_shared.1: Marvell shared XOR driver
mv_xor mv_xor.0: Marvell XOR: ( xor cpy )
mv_xor mv_xor.1: Marvell XOR: ( xor fill cpy )
mv_xor mv_xor.2: Marvell XOR: ( xor cpy )
mv_xor mv_xor.3: Marvell XOR: ( xor fill cpy )
NET: Registered protocol family 26
GACT probability on
Mirror/redirect action on
Simple TC action Loaded
netem: version 1.2
u32 classifier
    Performance counters on
    input device check on
    Actions configured
Netfilter messages via NETLINK v0.30.
nf_conntrack version 0.5.0 (2048 buckets, 8192 max)
CONFIG_NF_CT_ACCT is deprecated and will be removed soon. Please use
nf_conntrack.acct=1 kernel paramater, acct=1 nf_conntrack module option or
sysctl net.netfilter.nf_conntrack_acct=1 to enable it.
ctnetlink v0.93: registering with nfnetlink.
nf_conntrack_rtsp v0.6.21 loading
NF_TPROXY: Transparent proxy support initialized, version 4.1.0
NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
nf_nat_rtsp v0.6.21 loading
ip_tables: (C) 2000-2006 Netfilter Core Team
ipt_time loading
ClusterIP Version 0.8 loaded successfully
init->444
arp_tables: (C) 2002 David S. Miller
TCP cubic registered
NET: Registered protocol family 17
Distributed Switch Architecture driver version 0.1
eth0: detected a Marvell 88E6171 switch
eth0: using ip header offset of 22
dsa slave smi: probed
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
VFP support v0.3: not present
VFS: Mounted root (squashfs filesystem) readonly on device 31:3.
Freeing init memory: 112K
init started:  BusyBox v1.01 (2010.02.12-02:37+0000) multi-call binary
PPTP driver version 0.8.2
init NVRAM_SPACE from mtdblock size
init nvram memory map size: 0x10000 order of pages: 0x4
nvram module init:
        /dev/nvram major number 225 glues to mtd: "nvram" size: 0x00010000
        nvram_space: 0x00010000 mapped via mmap(2)
Entry gpio_ioctl init_module !!
gpio:WPS_BUTTON
WatchDog enabled timeout:10.
wdt_heartbeat:64
wdt_heartbeat:67, wdt_timeout:10
enable_watchdog:90
Please press Enter to activate this console. insmod: cannot insert `/lib/devnvram.ko': File exists (-1): File exists
openfile :/var/etc/nvram.default
eth1: Cannot assign requested address
<pppoe_device_event:306>:event:8
eth1: using ip header offset of 14
eth1: link up, 1000 Mb/s, full duplex, flow control disabled
<pppoe_device_event:306>:event:1
<pppoe_device_event:306>:event:4
lan1: Cannot ass<pppoe_device_event:306>:event:1
ign requested ad<pppoe_device_event:306>:event:1
dress
lan2: Can<pppoe_device_event:306>:event:1
not assign requeeth0: link up, 1000 Mb/s, full duplex, flow control disabled
sted address
la<pppoe_device_event:306>:event:1
n3: Cannot assign requested address
lan4: Cannot assign requested address
eth0: Cannot assign <pppoe_device_event:306>:event:5
requested address
device lan1 entered promiscuous mode
device eth0 entered promiscuous mode
device lan2 entered promiscuous mode
device lan3 entered promiscuous mode
device lan4 entered promiscuous mode
br0: topology change detected, propagating
br0: port 5(eth0) entering forwarding state
sh: ./etc/rc.d/pre_customer.sh: not found
Wed Dec  1 15:39:00 UTC 2010
insmod: cannot insert `/lib/modules/2.6.29/net/gpio_mod.ko': File exists (-1): File exists
sh: modprobe: not found
insmod: cannot open module `/lib/modules/2.6.15--LSDK-7.1.2.27/kernel/drivers/usb/core/usbcore.ko': No such file or directory
insmod: cannot open module `/lib/modules/2.6.15--LSDK-7.1.2.27/kernel/drivers/usb/host/ehci-hcd.ko': No such file or directory
rc is BUSY now!
sh: cannot create /proc/sys/net/ipv6/conf/default/accept_ra: Directory nonexistent
sh: cannot create /proc/sys/net/ipv6/conf/all/accept_ra: Directory nonexistent
dhcpd_enabled::::::
domain empty
DHCP server start.
device_lan_ip=10.0.0.1 , device_lan_subnet_mask=255.255.255.0
max_leases value (254) not sane, setting to 9 instead
Unable to open /var/misc/udhcpd.leases for reading
ap8x: module license 'Proprietary' taints kernel.
PCI: enabling device 0000:00:01.0 (0140 -> 0142)
wantimer: wan_state: test Cable again !!
Error for wireless request "Set Fragmentation Threshold" (8B24) :
    SET failed on device wdev0 ; Cannot allocate memory.
WLAN(wdev0): MLME - Disconnecting (deauth) wireless client: ffffffffffff Reason 3
WLAN(wdev0ap0): MLME - Disconnecting (deauth) wireless client: ffffffffffff Reason 3
device wdev0ap0 entered promiscuous mode
br0: port 6(wdev0ap0) entering forwarding state
Stop client netdev = 0
WLAN(wdev0ap1): MLME - Disconnecting (deauth) wireless client: ffffffffffff Reason 3
WLAN(wdev0ap2): MLME - Disconnecting (deauth) wireless client: ffffffffffff Reason 3
WLAN(wdev0ap3): MLME - Disconnecting (deauth) wireless client: ffffffffffff Reason 3
WLAN(wdev0ap4): MLME - Disconnecting (deauth) wireless client: ffffffffffff Reason 3
WLAN(wdev0ap5): MLME - Disconnecting (deauth) wireless client: ffffffffffff Reason 3
WLAN(wdev0ap6): MLME - Disconnecting (deauth) wireless client: ffffffffffff Reason 3
WLAN(wdev0ap7): MLME - Disconnecting (deauth) wireless client: ffffffffffff Reason 3
nvram_readfile at pid 321:app.c->start_ssh_server:225
Will output 1024 bit rsa secret key to '/tmp/dropbear_key'
Generating key, this may take a while...
Public key portion is:
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAAAgwDBLaPoRs1569SLBdygX+iHWXTqv6ymfQ3hpDjmXZsDlAif2RVyZY/G/23xvfbk0sZQiMnD1UTD472Zz20eIfgTDT9PtojADM8L2vX3jfqpykNK2GuCRTBGKowMsrvhosu2typH2dy7B9sRPoIxmGFcfXpYzftP/4ypJ0ahPVEFU2zx @DIR-665
Fingerprint: md5 18:05:61:f3:99:83:9f:6b:ad:e5:5f:77:cd:fa:d3:a5
TFTP main
standard_tftp_server launched on port 69.
usbcore: registered new interface driver sxuptp_driver
start_pppoe_relay:
start_pppoe_relay: pppoe_pass_through
killall: crowdcontrol: no process killed
killall: wakeOnLanProxy: no process killed
Start Firewall Setting
sh: cannot create /proc/sys/net/ipv4/ip_conntrack_max: Directory nonexistent
sh: cannot create /proc/sys/net/ipv4/spi_enable: Directory nonexistent
rc is IDLE now!
sh: ./etc/rc.d/post_customer.sh: not found
ntp1.dlink.com: Host name lookup failure
离线邪恶海盗
只看该作者 1楼 发表于: 2013-12-17
离线our420
只看该作者 2楼 发表于: 2013-12-17
离线需要番
只看该作者 3楼 发表于: 2013-12-17
离线zhizai100
只看该作者 4楼 发表于: 2013-12-17
离线吸铁石
只看该作者 5楼 发表于: 2013-12-17
离线tjpzero
只看该作者 6楼 发表于: 2013-12-17
离线rocky123
只看该作者 7楼 发表于: 2013-12-17
离线cltnet
只看该作者 8楼 发表于: 2014-09-22
离线rain6510
只看该作者 9楼 发表于: 2017-10-12
