量产后
Device 1:0xB5
MP Version:2.173
INI_File_Name:6691_Kingston G3 CDROM Flash.INI
Random delay 0 msec
--- Download MP ISP ---
CE-0, Flash ID=98-D7-94-32-76-55-0D-00
Found BACKUP Table (000000BB-0001)
Defect Table (00000200-0004)
Original Bad Block - 0:0x0000
Original Bad Block - 0:0x0038
Original Bad Block - 0:0x01C9
Original Bad Block - 0:0x02F3
Original Bad Block - 0:0x03B6
Original Bad Block - 0:0x062B
Original Bad Block - 0:0x06BC
Original Bad Block - 0:0x06D0
Original Bad Block - 0:0x06D2
Original Bad Block - 0:0x06E5
Original Bad Block - 0:0x06E7
Original Bad Block - 0:0x07BD
Original Bad Block - 0:0x086E
Original Bad Block - 0:0x0884
Original Bad Block - 0:0x0941
Original Bad Block - 0:0x0A04
Original Bad Block - 0:0x0A06
Original Bad Block - 0:0x0A17
Original Bad Block - 0:0x0BD1
Original Bad Block - 0:0x0BD3
Original Bad Block - 0:0x0C15
Original Bad Block - 0:0x0E64
Original Bad Block - 0:0x0E66
Original Bad Block - 0:0x0EC2
Defect Table shows 4076 Good blocks, 24 Bad blocks
SafeErase (0,4100)
Erase failed Block - 0:0:0x0000
Erase failed Block - 0:0:0x0038
Erase failed Block - 0:0:0x01C9
Erase failed Block - 0:0:0x02F3
Erase failed Block - 0:0:0x03B6
Erase failed Block - 0:0:0x062B
Erase failed Block - 0:0:0x06BC
Erase failed Block - 0:0:0x06D0
Erase failed Block - 0:0:0x06D2
Erase failed Block - 0:0:0x06E5
Erase failed Block - 0:0:0x06E7
Erase failed Block - 0:0:0x07BD
Erase failed Block - 0:0:0x086E
Erase failed Block - 0:0:0x0884
Erase failed Block - 0:0:0x0941
Erase failed Block - 0:0:0x0A04
Erase failed Block - 0:0:0x0A06
Erase failed Block - 0:0:0x0A17
Erase failed Block - 0:0:0x0BD1
Erase failed Block - 0:0:0x0BD3
Erase failed Block - 0:0:0x0C15
Erase failed Block - 0:0:0x0E64
Erase failed Block - 0:0:0x0E66
Erase failed Block - 0:0:0x0EC2
---> Max Bad of Plane (7,6)
---> Max BAD/DIE = 7
Total good blocks after SCAN: 4076 / 4100, Bad block=24
==> 2-Plane mode
Max. Bad Block Allowed = 183(24)
Adjust Max LBA = 7823360, 7823296
MaxWindows=2/1910, MaxLBA=7823296, Size=3819 MB
Max BAD of one plane is 7 (45),4100,1,1
RootSector=0xE13,Sec/Cluster=32, SuperPage=32 ---> Alignment=13
Boot Block=0x0001,0x0002
Lun0(7184184), Lun1(639112), Public=7184184, Secure=0, CDROM=639112
Special FE Config = 56-0B-00
Defect Table Block=0x0004
--- Download ISP Code:D:\KINSTON G3 6692\ISP_CODE\6692_B5-A_20100916_VB10000_63E2.BIN---
--- ISP Code installed.
Public,Secure,CDROM = 7184184,0,639112
SN=00E04CECEF35FC209C2914F9
=== Preformat Done ===
Low Level Format DONE
Store INI/ERROR MSG to Block-0x0001:79.
LBATest 10M activate
CDROM image:E:\MyFeng.ISO
Total=7823296,CDROM=639112, PublicArea=7184056, SecureArea=0
Create SECURE(CDROM=1,Public=3507 MB,Secure=0 MB)
--- T2 start ---
FW version is: 0xB5
Vendor ID is:0x0951
Product ID is:0x1643
Vendor=Kingston
Product=DataTraveler G3
Device capacity : 0 > 39116 > 0
--- T2 is done ---
Total Capacity: 7823296 sectors, 3819 MBytes
Elasped Time = 00:12:58
为什么量化的CDROM像是一个坏掉的光驱 u盘正常可以存取,ISO文件不行吗|?
[ 此帖被cuibaoxi在2012-02-09 11:23重新编辑 ]
