  • 7269阅读
  • 3回复
[群联]求助UP25 PS2251-68量产失败,量产的速度很慢! [复制链接]
离线xuzhou_zzs
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2014-11-12
如题,看了网上的教程,8G U盘一次量产要1个半小时,总是在最后99%的时候失败,信息如下,请各位大大给看看什么原因?
[ 2014-11-12 11:30:27 ]
  OS Version: Win XP
  MP Version: 2.070 (2013.06.18)
  PC Name   :  []
  DUT Slot: 4
  Driver  : G
  IC Type : 1E-0
  ISP Type: 0
  F-Slot  : 1
   0:00.0 -------------------------------------
   0:00.0 New Flow Initial ... 2070
   0:00.0 + INQ:........        2268 PRAM       1.00PMAP1234
   0:00.0 + Install ISP : ISP68.BIN
   0:00.0 + Jump ISP:
   0:00.0    - INQ:........        2268 PRAM       1.00
   0:00.0    - Stage: ROM code.
   0:03.5    - INQ:........        2268 SORTER V1.01.00
   0:03.5 + ISP Version : OS68 Ver 1.06k (2013.06.18)
   0:03.6 + Flash Unit Index = 305 / (913) / 316
   0:03.6    - ID:   89-84-64-3C-A5-00 x 1
   0:03.6    - Mask: FF-FF-FF-FF-1F-FF
   0:03.6    - Flash Parameters : 20nm,x8,2048,512,32, HW.ECC=39,822
   0:03.6      Flash Notes: Intel 20nm (L85)
   0:03.6 + New CE Mode_3=00, CEMask=01
   0:03.8 + ECC setting : 39, 39, 29
   0:03.8 * Model=1E-0-0
   0:03.8    - UP25,           29F128G08CBCAB(MLC.16K)
   0:03.8 + Total effective blocks = 1 x 1 x 2048 = 2048
   0:03.8 -------------------------------------
   0:03.8 Test & Scan Stage ... 1 FSlot mode
   0:03.8 [ Low Level Format + TestMode=7 ]
   0:03.8   >> SmartEcc=1, Ecc=0
   0:03.8   >> Mode=21, Optimize=1, SizeMode=2
   0:03.8 + Smart Test ... 0000-0000
   0:03.8 + INQ:........        2268 SORTER V1.01.00PMAP1234
   0:03.8 + ISP Version : OS68 Ver 1.06k (2013.06.18)
   0:03.8 + GPIO = FF,06,FF,FF
   0:03.9 + New CE Mode_3=00, CEMask=01
   0:04.1 + ECC setting : 39, 39, 29
   0:04.1 + Set Retry Table (IM D2).
   0:04.1 + CE=1, Page Layout Mode = 8, MaxWL=260
   0:04.1 + Total effective blocks = 1 x 1 x 2048 = 2048
   0:04.1 +-----------------------------------------------------+
   0:08.1 * Erase takes 00:00:04, (Found 0 NoResponse Blocks)
   1:32.1 + Smart Flash Pin Check takes 00:01:24, 512 Pages are OK, 0 Pages Error
   1:42.6 + Smart Test-0 (368849,369889,369521,369570,369083,370181), Select=0
   1:42.6 + ECC setting : 39, 39, 29
   1:54.8    + Parameter Test-0 takes 00:00:12, <63><63><0><0><0><0><0><0>
   1:54.8 --- Advance OBC Test (C1,D1) -----------------------------------------------------------
   3:60.0 + SecGood[]=0/2501,1/2518,2/2512,3/2518,4/2515,5/2503,6/2518,7/2493,8/2518,9/2480,10/2518,11/2490,12/2518,13/2492,14/2518,15/2518,
   4:17.4    - SecMask=FFFF, Paramters=39872,836,40130
   5:09.0 * Adv OBC Test takes 00:00:51, [0] Find Blk=8 / Page=387 / Sec=8
   5:47.1 * Adv OBC Test takes 00:00:38, [0] Find Blk=8 / Page=387 / Sec=8
   5:47.1    - OPA[]=40-44-44-44-44-44-44-44-44-44-44-44-44-44-44-44-44-44-44-44-44-44-44-44-44-44-44-44-44-44-44-44-44-44-44-44-44-44-44-44-44-44-44-44-44-44-44-44-44-44-44-44-44-44-44-44-44-44-44-44-44-44-44-00-00-
   5:47.1    - Good=0-0001,0-0003,0-0005,0-0007,0-0011,0-0013,0-0015,0-0017,0-0089,0-008B,0-008D,0-008F,0-0101,0-0103,0-0105,0-0107,
   5:47.1 + F0: Advance OBC Test Result: IBTmode=4D, IBSkip=00, Good Block:IB=12+CP=3
   5:47.1 ------------------------------------------------------------------------------------
   5:47.1 < Enable MBC + 2BC=00 + ECC=29/39/39 >
   7:52.3 + SecGood[]=0/2518,1/2518,2/2518,3/2517,4/2518,5/2517,6/2518,7/2518,8/2518,9/2518,10/2518,11/2518,12/2518,13/2518,14/2518,15/2518,
   8:09.8    - SecMask=FFFF, Paramters=40244,839,40286
   8:09.8 + Free PC RAM: 1707/2047 MB
   8:15.0    + Parameter Test-1 takes 00:00:05, Select 3 (2848,2840,2840,2832,2824)
   8:17.8    + Parameter Test-2 takes 00:00:02, Select 1 (2832,2792,2760,2752) 12
   8:22.4    + Parameter Test-3 takes 00:00:04, Select 2 (-,2360+3072,2176+3072,2192,3072)
   8:33.7    + Parameter Test-4 takes 00:00:11, Find 42 better, Find 24 worse, And Full=512
   8:33.7    + Enable Fill-Full-Block mode
   8:33.7 + D2 PreTest Takes 0.00 sec, Find 512 pages / 8 blocks.
  32:10.4 * Write/Read takes 00:23:36, Find 964048 UnCorrectable Sectors
  32:10.4 + Calculate_GoodBlocks: (Mode=0, Mask=FFFF,29+29+29), Flag=0002
  32:10.5    - Good Blocks=1022, Bad Blocks=1026
  36:34.8 * Read/Erase  takes 00:04:24, (Found 3 Bad blocks)
  36:34.8 + Calculate_GoodBlocks: (Mode=0, Mask=FFFF,29+29+29), Flag=0002
  36:34.8    - Good Blocks=1019, Bad Blocks=1029
  73:47.9 * Write 3 takes 00:37:13, Found 0 UnCorrectable
  82:07.1 * Read/Erase with RR takes 00:08:19, (Found 3 Bad blocks), RR Pass=0
  82:07.1 + Calculate_GoodBlocks: (Mode=0, Mask=FFFF,29+29+29), Flag=0002
  82:07.2    - Good Blocks=1016, Bad Blocks=1032
  82:07.4 + Finding Best Mode  ... M=0,E=29,P=512,S=FFFF,Opt=00 --> 1016(8323072)
  82:07.7 + Finding Best Mode2 ... M=0,E=29,P=512,S=FFFF,Opt=00 --> 1016(8323072)
  82:07.7 + [Find Best Mode] Pickup-1, 8323072>=8323072, Mode=0, 1:[8323072,512,FFFF,0.219], 2:[8323072,512,FFFF,0.234]
  82:07.7 + Calculate_GoodBlocks: (Mode=0, Mask=FFFF,29+29+29), Flag=0002
  82:07.8    - Good Blocks=1016, Bad Blocks=1032
  82:07.8    - 0 changed, 0 AB all failed
  82:07.8 * F0: Special ScreenOut-1 3 takes 00:00:00, 0 Blocks been revised
  82:07.8 ro.PA[]=OOOOOO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OOOO
  82:07.8 + Calculate_GoodBlocks: (Mode=0, Mask=FFFF,29+29+29), Flag=0006
  82:07.8 + Smart Test Result: TestMode=1, Page=512, IBSkip=00, Good Block=1016
  82:07.8    - Flash RAW Capacity = 1016 x 512 x (16-0) = 8128 MB
  82:07.8 +-----------------------------------------------------+
  82:07.8 + Reverse Test ... ... (FFFF), DWL=0, Tm=40, Page=0
  82:16.9    + 1016 Block been tested, 0 New Error Block
  82:16.9 + Double Check Block Scan ... 0-0(FFFF), Marker=E2
  82:17.1    + 0-0-0000: X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.
  82:17.3    + 0-0-0040: X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.
  82:17.5    + 0-0-0080: X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.
  82:17.8    + 0-0-00C0: X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.
  82:18.0    + 0-0-0100: X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.
  82:18.2    + 0-0-0140: X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.
  82:18.4    + 0-0-0180: X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.
  82:18.7    + 0-0-01C0: X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.
  82:18.8    + 0-0-0200: X.X.X.X.X.X.X.X.X.X.X.X.XXX.X.X.X.X.X.X.X.X.XXXXXXX.X.X.X.X.X.X.
  82:19.1    + 0-0-0240: X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.
  82:19.3    + 0-0-0280: X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.
  82:19.5    + 0-0-02C0: X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.
  82:19.7    + 0-0-0300: X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.
  82:20.0    + 0-0-0340: X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.
  82:20.2    + 0-0-0380: X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.XXX.X.X.X.X.X.X.
  82:20.4    + 0-0-03C0: X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.
  82:20.6    + 0-0-0400: X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.
  82:20.8    + 0-0-0440: X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.
  82:21.0    + 0-0-0480: X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.
  82:21.3    + 0-0-04C0: X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.
  82:21.5    + 0-0-0500: X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.
  82:21.7    + 0-0-0540: X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.
  82:21.9    + 0-0-0580: X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.
  82:22.1    + 0-0-05C0: X.X.X.X.X.X.X.XXX.XXX.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.
  82:22.4    + 0-0-0600: X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.
  82:22.6    + 0-0-0640: X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.XXX.X.X.X.X.X.X.X.X.X.X.
  82:22.8    + 0-0-0680: X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.
  82:23.0    + 0-0-06C0: X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.
  82:23.3    + 0-0-0700: X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.
  82:23.5    + 0-0-0740: X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.
  82:23.7    + 0-0-0780: X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.
  82:23.9    + 0-0-07C0: X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.
  82:23.9    - 1016 Block been scanned, 0 New Error Block
  82:31.9 * Erase takes 00:00:08, (Found 0 NoResponse Blocks)
  82:31.9 + F0 - Still Has 16 good blocks
  82:31.9 + New ISP to Save IB Table.
  82:31.9 + Free PC RAM: 1696/2047 MB
  82:31.9 [OBC Good Block]
  82:32.0 + CE-0:0001,0003,0005,0007,0011,0013,0015,0017,0089,008B,008D,008F,0101,0103,0105,0107,
  82:32.0    - Total 16 Good Blocks
  82:32.0 [DefectBlock] .. E2
  82:32.0 + CE-0:0000,0002,0004,0006,0008,000A,000C,000E,0010,0012,0014,0016,0018,001A,001C,001E,
  82:32.0        0020,0022,0024,0026,0028,002A,002C,002E,0030,0032,0034,0036,0038,003A,003C,003E,
  82:32.0        0040,0042,0044,0046,0048,004A,004C,004E,0050,0052,0054,0056,0058,005A,005C,005E,
  82:32.0        0060,0062,0064,0066,0068,006A,006C,006E,0070,0072,0074,0076,0078,007A,007C,007E,
  82:32.0        0080,0082,0084,0086,0088,008A,008C,008E,0090,0092,0094,0096,0098,009A,009C,009E,
  82:32.0        00A0,00A2,00A4,00A6,00A8,00AA,00AC,00AE,00B0,00B2,00B4,00B6,00B8,00BA,00BC,00BE,
  82:32.0        00C0,00C2,00C4,00C6,00C8,00CA,00CC,00CE,00D0,00D2,00D4,00D6,00D8,00DA,00DC,00DE,
  82:32.0        00E0,00E2,00E4,00E6,00E8,00EA,00EC,00EE,00F0,00F2,00F4,00F6,00F8,00FA,00FC,00FE,
  82:32.0        0100,0102,0104,0106,0108,010A,010C,010E,0110,0112,0114,0116,0118,011A,011C,011E,
  82:32.0        0120,0122,0124,0126,0128,012A,012C,012E,0130,0132,0134,0136,0138,013A,013C,013E,
  82:32.0        0140,0142,0144,0146,0148,014A,014C,014E,0150,0152,0154,0156,0158,015A,015C,015E,
  82:32.0        0160,0162,0164,0166,0168,016A,016C,016E,0170,0172,0174,0176,0178,017A,017C,017E,
  82:32.0        0180,0182,0184,0186,0188,018A,018C,018E,0190,0192,0194,0196,0198,019A,019C,019E,
  82:32.0        01A0,01A2,01A4,01A6,01A8,01AA,01AC,01AE,01B0,01B2,01B4,01B6,01B8,01BA,01BC,01BE,
  82:32.0        01C0,01C2,01C4,01C6,01C8,01CA,01CC,01CE,01D0,01D2,01D4,01D6,01D8,01DA,01DC,01DE,
  82:32.0        01E0,01E2,01E4,01E6,01E8,01EA,01EC,01EE,01F0,01F2,01F4,01F6,01F8,01FA,01FC,01FE,
  82:32.0        0200,0202,0204,0206,0208,020A,020C,020E,0210,0212,0214,0216,0218,0219,021A,021C,
  82:32.0        021E,0220,0222,0224,0226,0228,022A,022C,022D,022E,022F,0230,0231,0232,0234,0236,
  82:32.0        0238,023A,023C,023E,0240,0242,0244,0246,0248,024A,024C,024E,0250,0252,0254,0256,
  82:32.0        0258,025A,025C,025E,0260,0262,0264,0266,0268,026A,026C,026E,0270,0272,0274,0276,
  82:32.0        0278,027A,027C,027E,0280,0282,0284,0286,0288,028A,028C,028E,0290,0292,0294,0296,
  82:32.0        0298,029A,029C,029E,02A0,02A2,02A4,02A6,02A8,02AA,02AC,02AE,02B0,02B2,02B4,02B6,
  82:32.0        02B8,02BA,02BC,02BE,02C0,02C2,02C4,02C6,02C8,02CA,02CC,02CE,02D0,02D2,02D4,02D6,
  82:32.0        02D8,02DA,02DC,02DE,02E0,02E2,02E4,02E6,02E8,02EA,02EC,02EE,02F0,02F2,02F4,02F6,
  82:32.0        02F8,02FA,02FC,02FE,0300,0302,0304,0306,0308,030A,030C,030E,0310,0312,0314,0316,
  82:32.0        0318,031A,031C,031E,0320,0322,0324,0326,0328,032A,032C,032E,0330,0332,0334,0336,
  82:32.0        0338,033A,033C,033E,0340,0342,0344,0346,0348,034A,034C,034E,0350,0352,0354,0356,
  82:32.0        0358,035A,035C,035E,0360,0362,0364,0366,0368,036A,036C,036E,0370,0372,0374,0376,
  82:32.0        0378,037A,037C,037E,0380,0382,0384,0386,0388,038A,038C,038E,0390,0392,0394,0396,
  82:32.0        0398,039A,039C,039E,03A0,03A2,03A4,03A6,03A8,03AA,03AC,03AE,03B0,03B1,03B2,03B4,
  82:32.0        03B6,03B8,03BA,03BC,03BE,03C0,03C2,03C4,03C6,03C8,03CA,03CC,03CE,03D0,03D2,03D4,
  82:32.0        03D6,03D8,03DA,03DC,03DE,03E0,03E2,03E4,03E6,03E8,03EA,03EC,03EE,03F0,03F2,03F4,
  82:32.0        03F6,03F8,03FA,03FC,03FE,0400,0402,0404,0406,0408,040A,040C,040E,0410,0412,0414,
  82:32.0        0416,0418,041A,041C,041E,0420,0422,0424,0426,0428,042A,042C,042E,0430,0432,0434,
  82:32.0        0436,0438,043A,043C,043E,0440,0442,0444,0446,0448,044A,044C,044E,0450,0452,0454,
  82:32.0        0456,0458,045A,045C,045E,0460,0462,0464,0466,0468,046A,046C,046E,0470,0472,0474,
  82:32.0        0476,0478,047A,047C,047E,0480,0482,0484,0486,0488,048A,048C,048E,0490,0492,0494,
  82:32.0        0496,0498,049A,049C,049E,04A0,04A2,04A4,04A6,04A8,04AA,04AC,04AE,04B0,04B2,04B4,
  82:32.0        04B6,04B8,04BA,04BC,04BE,04C0,04C2,04C4,04C6,04C8,04CA,04CC,04CE,04D0,04D2,04D4,
  82:32.0        04D6,04D8,04DA,04DC,04DE,04E0,04E2,04E4,04E6,04E8,04EA,04EC,04EE,04F0,04F2,04F4,
  82:32.0        04F6,04F8,04FA,04FC,04FE,0500,0502,0504,0506,0508,050A,050C,050E,0510,0512,0514,
  82:32.0        0516,0518,051A,051C,051E,0520,0522,0524,0526,0528,052A,052C,052E,0530,0532,0534,
  82:32.0        0536,0538,053A,053C,053E,0540,0542,0544,0546,0548,054A,054C,054E,0550,0552,0554,
  82:32.0        0556,0558,055A,055C,055E,0560,0562,0564,0566,0568,056A,056C,056E,0570,0572,0574,
  82:32.0        0576,0578,057A,057C,057E,0580,0582,0584,0586,0588,058A,058C,058E,0590,0592,0594,
  82:32.0        0596,0598,059A,059C,059E,05A0,05A2,05A4,05A6,05A8,05AA,05AC,05AE,05B0,05B2,05B4,
  82:32.0        05B6,05B8,05BA,05BC,05BE,05C0,05C2,05C4,05C6,05C8,05CA,05CC,05CE,05CF,05D0,05D2,
  82:32.0        05D3,05D4,05D6,05D8,05DA,05DC,05DE,05E0,05E2,05E4,05E6,05E8,05EA,05EC,05EE,05F0,
  82:32.0        05F2,05F4,05F6,05F8,05FA,05FC,05FE,0600,0602,0604,0606,0608,060A,060C,060E,0610,
  82:32.0        0612,0614,0616,0618,061A,061C,061E,0620,0622,0624,0626,0628,062A,062C,062E,0630,
  82:32.0        0632,0634,0636,0638,063A,063C,063E,0640,0642,0644,0646,0648,064A,064C,064E,0650,
  82:32.0        0652,0654,0656,0658,065A,065C,065E,0660,0662,0664,0666,0668,0669,066A,066C,066E,
  82:32.0        0670,0672,0674,0676,0678,067A,067C,067E,0680,0682,0684,0686,0688,068A,068C,068E,
  82:32.0        0690,0692,0694,0696,0698,069A,069C,069E,06A0,06A2,06A4,06A6,06A8,06AA,06AC,06AE,
  82:32.0        06B0,06B2,06B4,06B6,06B8,06BA,06BC,06BE,06C0,06C2,06C4,06C6,06C8,06CA,06CC,06CE,
  82:32.0        06D0,06D2,06D4,06D6,06D8,06DA,06DC,06DE,06E0,06E2,06E4,06E6,06E8,06EA,06EC,06EE,
  82:32.0        06F0,06F2,06F4,06F6,06F8,06FA,06FC,06FE,0700,0702,0704,0706,0708,070A,070C,070E,
  82:32.0        0710,0712,0714,0716,0718,071A,071C,071E,0720,0722,0724,0726,0728,072A,072C,072E,
  82:32.0        0730,0732,0734,0736,0738,073A,073C,073E,0740,0742,0744,0746,0748,074A,074C,074E,
  82:32.0        0750,0752,0754,0756,0758,075A,075C,075E,0760,0762,0764,0766,0768,076A,076C,076E,
  82:32.0        0770,0772,0774,0776,0778,077A,077C,077E,0780,0782,0784,0786,0788,078A,078C,078E,
  82:32.0        0790,0792,0794,0796,0798,079A,079C,079E,07A0,07A2,07A4,07A6,07A8,07AA,07AC,07AE,
  82:32.0        07B0,07B2,07B4,07B6,07B8,07BA,07BC,07BE,07C0,07C2,07C4,07C6,07C8,07CA,07CC,07CE,
  82:32.0        07D0,07D2,07D4,07D6,07D8,07DA,07DC,07DE,07E0,07E2,07E4,07E6,07E8,07EA,07EC,07EE,
  82:32.0        07F0,07F2,07F4,07F6,07F8,07FA,07FC,07FE,
  82:32.0    - Total 1032 Bad Blocks
  82:32.0 O.PA[]=OOOOOO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OOOO
  82:32.0 O.SA[]=OOOOOOOOOOOOOOOO
  82:32.0 M.PA[]=OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
  82:32.0 M.SA[]=OOOOOOOOOOOOOOOO
  82:32.0 M.BC[0]=0141,0150,0151,0160,0391,065F,0875,0941,0950,0951,0960,0A98,0B89,0CCA,0CFF,10C7,1141,1150,1151,1160,11B8,1398,1721,17A8,183E,188E,1941,1950,1951,19F9,1E98,1F58,1FE8,213E,2140,2141,2150,2151,282E,2940,2941,2950,2951,2B86,2BD6,2CE0,2ED9,3140,3141,3150,3151,35E0,389F,3940,3941,3950,3951,39B6,3A58,3B7A,3B7E,3BD8,3EB1,
  82:32.0 M.BC[1]=013F,015F,01F8,0369,0379,0386,0391,0485,0493,0509,0623,0690,06F1,07F1,08AF,0ACE,0B16,0C2E,0C3E,0C4A,0CAF,0D07,0EC7,0FC2,0FD0,0FF0,105F,10BF,11A6,123E,12DD,1815,183F,1861,1863,1878,1896,18AC,1AEC,1C36,1DB6,1F8B,1F99,215E,219B,24B2,284D,286E,2889,28CF,2B32,2C76,2F3D,30E7,37F0,3816,3A48,3F21,403F,4170,4254,4298,4341,
  82:32.0 + Calculate User BIN ... CE(0-0)
  82:32.0    - FW Spare = 16,28
  82:32.0    - Good Page=512, Bad Page=0
  82:32.0    - ce:0,DIE:0, Size= 8093696 =(1016<1016>-28) x (512) x (16-0) /  1.00
  82:32.0    + Total Size = 7904
  82:32.0 <Auto BIN-3> Physical Size=7904 (MB), Selected Size=7600 (MB)
  82:32.0 + Revised Original BC ... Skip=0000, Mode=4D
  82:32.0 + Setup Parameters for IB-Table ... Slot-0
  82:32.0 PA[]=OOOOOO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OOOO
  82:32.0 SA[]=OOOOOOOOOOOOOOOO
  82:32.0    - F0: Total Sector=8, Pages for IB=1
  82:32.0    - EvenZonePage[]=0,1,2,3, OddZonePage[]=0,1,2,3
  82:32.0 + 4D(00) / MBC:40(00) / OBC:4D(00)
  82:32.0 + Not found OLD IB, Save a newer
  82:32.0 -------------------------------------------
  82:32.0 + Install IB-Table ... Page=16 K, Skip=0000, TM=40, MBC=0
  82:32.0    - SecMapping :0(0),1(1),2(2),3(3),4(4),5(5),6(6),7(7),8(8),9(9),10(10),11(11),12(12),13(13),14(14),15(15),
  82:32.0    - Good/Plane=0(0),1015,
  82:32.2    --> IB-block verified Pass (0-0001).
  82:32.2 --------------------------------------------------------------------------------
  82:32.2 DoPreFormat ... ... BurnerMode=1
  82:32.2    - TestMode=1, D3Mode=0, Dummy=0, Full=1, Skip=0000(0000), IBTMode=4D(40)
  82:32.2    - FW(5)=<226X-D2FW-130603-SVN159-FASTRN.BIN>
  82:32.2 + Burner Process 2 Start ...
  82:32.2 + INQ:........        2268 SORTER V1.01.00PMAP1234
  82:32.2 + Smart Test ISP Version : OS68 Ver 1.06k (2013.06.18)
  82:32.3 + New CE Mode_3=00, CEMask=01
  82:32.5 + Set Flash Timing = 66 ns
  82:32.5 + ECC setting : 39, 39, 29
  82:32.5 R.PA[]=POOOOO..OO..OO..OO..OO..OO..OO..OO..OO..OO..PO..PO..OO..OO..OO..PO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..PO..PO..OO..OO..OO..PO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..PO..PO..OO..OO..OO..PO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..PO..PO..OO..OO..OO..PO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..PO..PO..OO..OO..OO..PO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..PO..PO..OO..OO..OO..PO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..PO..PO..OO..OO..OO..PO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..PO..PO..OO..OO..OOOO
  82:32.5    - 8 / 8 Sector Available for CZ block, CZ Page= 1.
  82:32.5    - FileSize=98816, 96 Sectors, 12 Pages
  82:32.5    - Common:16, Bank=8, No=10
  82:32.5 + NewBurnerPage[]=PZFFFF..FF..FF..FF..FF..OO..OO..OO..OO..OO..PO..PO..OO..OO..OO..PO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..PO..PO..OO..OO..OO..PO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..PO..PO..OO..OO..OO..PO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..PO..PO..OO..OO..OO..PO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..PO..PO..OO..OO..OO..PO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..PO..PO..OO..OO..OO..PO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..PO..PO..OO..OO..OO..PO..OO..OO..OO..OO..OO..OO..OO..OO..OO..OO..PO..PO..OO..OO..OOOO
  82:32.5 + Searching ... CP/CZ Table 1,1,2048
  82:35.9    - Found 0 CP/CZ blocks
  82:35.9 + Erase All Good Block 1x2048... (PairBlock=0), Mask=01
  82:36.1    - Total 2048 blocks, 15 blocks been erased. 0 blocks report failed
  82:36.1 + Erase All Good Block 1x2048... (PairBlock=0), Mask=06
  82:44.1    - Total 2048 blocks, 1015 blocks been erased. 0 blocks report failed
  82:44.1    - FW Spare = 16,28
  82:44.2    - 67BC CP(0) = 0-0-0x0003:0
  82:44.2    - CP-0: 0-0-0003/0-0003, S=0, Good=1
  82:44.2    - 67BC CP(2) = 0-0-0x0003:0
  82:44.2    - CP-1: 0-0-0003/0-0003, S=0, Good=1
  82:44.2 + Install-2 F/W : 226X-D2FW-130603-SVN159-FASTRN.BIN
  82:44.3    - 0 (0-0003)/(0-0003): Good Count (CP=57, CZ=7, FW=12/12)
  82:44.3    - System Block Installed.
  82:44.3 + Install-2 F/W : 226X-D2FW-130603-SVN159-FASTRN.BIN
  82:44.5    - 0 (0-0003)/(0-0003): Good Count (CP=57, CZ=7, FW=12/12)
  82:44.5    - System Block Installed.
  82:44.5 + BC[79=00,7E=00]:
  82:44.5    - Wait 2 sec.
  82:46.5    - Jump ISP ...
  82:48.3    - ISP Jump is OK, And Wait 2 sec to check INQ.
  82:51.3 - INQ:........        USB DISK 30X    1.00PMAP1234
  82:51.3 -------------------------------------
  82:51.3 + RunTest ... ...
  82:51.3    - Class(68)
  82:51.4    + <NO INFO>
  82:51.4    - FW: 0606-35 - 2013/06/03
  82:51.4    - RO[] = ( 07F0+0000 ) * 4000
  82:51.4 + BC_Run()...
  82:51.4    + <NO INFO>
  82:51.4 -------------------------------------
  82:51.4 + BC-DoPreformat( Disk-G:)
  82:51.4    + <NO INFO>
  82:51.4 + Update Total Sector = 1015 x 16384 = 16629760
  82:51.4 + Find 1 Available Good Table / 1
  82:51.4    - Good/DIE = 03F7-
  82:51.4 + Init PreFormat ...
  82:51.5 *** No Timing Data in the Database-1, use default ***
  82:51.5 + OrgDiskSize=16629760, Unit=16384/1, Desired Size=7600MB, F/W Spare=16
  82:51.5    - Total L.Block=2048, Spare=1098/1098 (P=1,BT=1)
  82:51.5    - Spare[]=1082,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
  82:51.5 -------------------------------------
  82:51.5 + PreFormat Start ...
  82:51.5    - PreFormatType=7, HadINFO=0
  82:51.5    - PreformatBuf[]=0001,043A-
  82:56.0 + Disk Size = 15564800 (7600 MB)
  82:56.0 + PreFormat Finished
  82:56.0 + Special Delay 5 sec for HV2.
  83:01.0    + <                >
  83:01.0    + <                >
  83:01.0 - BC-DoPreformat(done)
  83:01.0    + <                >
  83:01.0    - RO[] = ( 03B6+0000 ) * 4000
  83:01.0    - INFO-block is available.
  83:01.0 + Disk Size = 15564800 (7600 MB)
  83:01.0 -------------------------------------
  83:01.0 + Do <F1> ...
  83:01.0 + AdjustBoundarySize ... Mode-21
  83:01.0    - Initial: FlashUnitSize=16384, CDROM=327104, Hidden=0, PartitionBoundary=0
  83:01.0    - Boundary = 327104(159 MB), 0(0 MB), CD=327104, Hidden=0
  83:01.0 + Mode=21, Alignment=2
  83:01.0 + DOS Format ...
  83:01.0 + Build Device ...
  83:01.0 + Mode=21 (Total Sector=00ED8000)
  83:01.0 + Partition-0: 0-327104(159 MB) PreCopy from (C:\Documents and Settings\Administrator\桌面\xz_zzs.iso).
  83:27.1 + Partition-1: 327104-15237696 (7440 MB)
  83:27.1    + Build FAT32 ... S=327104,L=15237696 (7440 MB),Label=1, Cluster=16, MBR=0
  83:27.1    + Write BS (0004FDC0,00000008)
  83:27.2    + Write SEC (0004FDC8,00000008)...
  83:29.0 + Prepare <INFO-BLOCK> ... Flag=0F
  83:29.0 *** No Timing Data in the Database-1, use default ***
  83:29.0    - VID=1567, PID=8902
  83:29.0    - Vendor  String:
  83:29.0    - Product String: USB 2.0
  83:29.0    - SCSI Vendor  String:
  83:29.0    - SCSI Product String: USB 2.0
  83:29.0    - SCSI Revision: 1.00
  83:29.0    - SN=201411121253564000001095
  83:29.0    - Timing Value: 0F-01-02,11-A1-A2
  83:29.0    - UPTool Ver 2.070 (2013.06.18)
  83:29.0    - ISP: ISP68.bin
  83:29.0    - BNR: BN61V114u-9.bin
  83:29.0    - F/W: 226X-D2FW-130603-SVN159-FASTRN.BIN
  83:29.0 + Write INFO-BLOCK (Disk-G:)...
  83:29.0 + Read Back <INFO-BLOCK> and check ...
  83:29.0    - <INFO-BLOCK> is double checked.
  83:29.0 + Disk Size = 15564800 sectors (7600 MB), MP estimated Size = (7600 MB)
  83:29.0 [RESULT] ErrorCode : 0000
  83:29.0 + Static Summary: B=1   ,P=0   ,S=0   ,Others=0   ,D1B=0   ,D1P=0   ,D1S=0   ,D1Others=0   ,
[ 2014-11-12 12:53:56 ]
[ UPTool takes 01:23:29 ]
离线549314048
只看该作者 1楼 发表于: 2014-11-12
离线shuishou
只看该作者 2楼 发表于: 2014-11-12
离线xtxcjkj
只看该作者 3楼 发表于: 2015-08-25
