  • 2926阅读
  • 9回复
[SandForce]4贴可以过8贴不能过 [复制链接]
离线75106zxs
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2016-04-12
我的4贴可以用2141的固件可以开卡。但是用2281的过不了。是什么原因。求高手解答
<?xml version = "1.0"?>
<Genesis_Log>
    <Log_Body>
Overall Summary:
                Start Time: Tue, 04/12/2016 @ 16:05:02
                  End Time: Tue, 04/12/2016 @ 16:06:37
             OverallResult: PASS
                  ExitCode: (0x00000000:SF_SCT (0000h): Command complete without error)
Environment Settings:
          Input Parameters:
                  argv[1]: -PROCESS_SSD
                  argv[2]: 2:0:0:0
                  argv[3]: /root/mpt/FW_PPRO_5_4_1_Release.750509.release--123456/FW_PPRO_5_4_1_Release.750509.release.123456.mfp
                  argv[4]: /root/mpt/FW_PPRO_5_4_1_Release.750509.release--123456/20027.123456.driveconfig
                  argv[5]: 11
                  argv[6]: 22
                  argv[7]: LOG=/root/mpt/FW_PPRO_5_4_1_Release.750509.release--123456/11_localhost.localdomain_DATETIMESTAMP_2.0.0.0_PROCESS_SSD_RESULT.log
                  Log File: /root/mpt/FW_PPRO_5_4_1_Release.750509.release--123456/11_localhost.localdomain_DATETIMESTAMP_2.0.0.0_PROCESS_SSD_RESULT.log
                  Hostname: localhost.localdomain
           Host IP Address: 127.0.0.1
               Port Number: 2
                DeviceName: /dev/sg2
        SF_Genesis Version: v1.7.0.01020130612-fc14-32bit
   SF_Core Library Version: v1.7.1.20130612-fc14-32bit
         SF_OS_Information: Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686
Post Processing Device Information:
                   WWN OUI: 200000
              WWN UniqueID: 000000000
                Serial No.: 11
                 Model No.: SandForce[750509]
         Firmware Revision: 541ABBF0
              ROM Revision: 20D
            NAND Page Size: 8640
     Number Of Chip Enable: 4
           Logical Sectors: 8
                   NAND ID: 0x000000A927206889
        Flash Manufacturer: UNKNOWN
              Flash Device: UNKNOWN
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Tue 04/12/2016 16:05:02] - SF_Genesis has been invoked with the following parameters:
                      argv[2]: 2:0:0:0
                      argv[5]: 11
                      argv[6]: 22
[Tue 04/12/2016 16:05:02] - Instructing the operating system to purge any existing cached data for device: '2:0:0:0'
[Tue 04/12/2016 16:05:07] - Issuing a discovery command for device: '2:0:0:0'
[Tue 04/12/2016 16:05:12] - Discovery command completed...
[Tue 04/12/2016 16:05:12] - Waiting 5 seconds for the system to settle...
[Tue 04/12/2016 16:05:18] - Device designation string '2:0:0:0' is mapped to node '/dev/sg2'
[Tue 04/12/2016 16:05:18] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg2
    MFP Package Filename = /root/mpt/FW_PPRO_5_4_1_Release.750509.release--123456/FW_PPRO_5_4_1_Release.750509.release.123456.mfp
      Configuration File = /root/mpt/FW_PPRO_5_4_1_Release.750509.release--123456/20027.123456.driveconfig
              Serial No. = 11
         World Wide Name = 22
[Tue 04/12/2016 16:05:18] - Successfully received the IDENTIFY data from the drive...
[Tue 04/12/2016 16:05:18] - Validating Manufacturing Firmware Package: /root/mpt/FW_PPRO_5_4_1_Release.750509.release--123456/FW_PPRO_5_4_1_Release.750509.release.123456.mfp
[Tue 04/12/2016 16:05:23] - Successfully opened the package: /root/mpt/FW_PPRO_5_4_1_Release.750509.release--123456/FW_PPRO_5_4_1_Release.750509.release.123456.mfp
[Tue 04/12/2016 16:05:23] - file  /root/mpt/FW_PPRO_5_4_1_Release.750509.release--123456/20027.123456.driveconfig Loaded successfully
[Tue 04/12/2016 16:05:24] - B01 Power Management configuration request detected
[Tue 04/12/2016 16:05:24] - B01 Power Management conforms to hardware version 0x200026BB
[Tue 04/12/2016 16:05:24] - Successfully extracted *.DriveConfig file: /root/mpt/FW_PPRO_5_4_1_Release.750509.release--123456/20027.123456.driveconfig
[Tue 04/12/2016 16:05:24] - Extracted Config_ID: 1 (20027) in DriveConfig file: /root/mpt/FW_PPRO_5_4_1_Release.750509.release--123456/20027.123456.driveconfig
[Tue 04/12/2016 16:05:24] - Extracted SerialOutputControl: 0
[Tue 04/12/2016 16:05:24] - Searching for flashware image for configuration 20027
[Tue 04/12/2016 16:05:24] - Manifest found for configuration 20027
[Tue 04/12/2016 16:05:24] - Flashware image extracted: 20027_fw_cl_slc_Intel_64Gb_PF29F16B16NCNE_1Q_4C_1D_PP_R00797_s512.vic
[Tue 04/12/2016 16:05:24] - Searching for manufacturing image for configuration 20027
[Tue 04/12/2016 16:05:24] - Manufacturing image extracted: 20027_mf_slc_Intel_64Gb_PF29F16B16NCNE_1Q_4C_1D_PP_R00797_s512.vic
[Tue 04/12/2016 16:05:24] - Proceeding in non-ROM mode, Download feature 3...
[Tue 04/12/2016 16:05:25] - Successfully downloaded MFB to the drive...
[Tue 04/12/2016 16:05:25] - Waiting (5 sec) for the drive to settle...
[Tue 04/12/2016 16:05:30] - Successfully received the IDENTIFY data from the drive...
[Tue 04/12/2016 16:05:30] - Firmware revision reported to be: '541ABBM0'.  This indicates MFB download was successful.
[Tue 04/12/2016 16:05:30] - Successfully enabled SMART capabilities...
[Tue 04/12/2016 16:05:32] - Successfully issued a diagnostic unlock...
[Tue 04/12/2016 16:05:33] - Performing the flash test of block 0 (0x0000)...
[Tue 04/12/2016 16:05:35] - Flash Test Results:
Flash Test Parameters:
               Block Count: 0
                Page Count: 1
                 Bus Count: 1
        Chip Enabled Count: 4
                 Die Count: 1
                Lane Count: 4
               Plane Count: 2
Results Notes:
   N1 - At least one page tested and passed with no bit errors.
   N2 - No test data available.  Test may have aborted, or failed during the testing.
   N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
   N4 - At least  one erased page tested had bit error rate greater than half the correction power.
   N5 - Walking zeros test failed.
   N6 - Walking ones test failed.
   N7 - Block contained factory bad block markings and testing was skipped.
   N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
   N9 - Block in plane 0 was marked as a factory bad block.
  N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
  N11 - Block in plane 1 was marked as a factory bad block.
| Bus  | CE   | Die  | Lane | Value  | Result Notes                               | Overall |
| 0    | 0    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 0    | 2    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 2    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 2    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 2    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 0    | 3    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 3    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 3    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 3    | 0    | 3    | 0x0001 | N1                                         |    PASS |
  Total Number of test results: 16
            Number of failures: 0
         Number of Passed with warnings: 0
      No. Passed without warnings: 16
[Tue 04/12/2016 16:05:35] - Performing the FORMAT Command with the following parameters:
         MemoryWearCycleCapability = 0
              CurrentPE_CycleCount = 0
                     LifeInSeconds = 0
                   LogicalCapacity = 125045424
                        SectorSize = 512
             SectorAlignmentOffset = 0
                  ExpectedMemoryID = 26761 (0x6889)
                   ExpectedNumDies = 0
               SerialOutputControl = 0
                           Time[8] = 0x0000000000000000
            MiscFlag_Erase_R_Block = 0
     MiscFlag_PanicHandlingEnabled = 0
        MiscFlag_PanicOnSATA_Error = 0
  MiscFlag_WriteThrottlingTestMode = 0
      MiscFlag_DisableUserBandECCX = 1
                        L_PageSize = 0
                        E_PageSize = 0
              ErrorCorrectionPower = 0
      ConfigDeviceReadDisturbCount = 0
   ConfigDeviceReadDisturbCountLow = 0
                  ExtraOptions_0_1 = 0
[Tue 04/12/2016 16:05:50] - FORMAT command completed...
[Tue 04/12/2016 16:05:50] - Waiting (2 sec) for the drive to settle...
[Tue 04/12/2016 16:05:52] - Setting up the stamp information through CDU command...
[Tue 04/12/2016 16:05:55] - Waiting (2 sec) for the drive to settle...
[Tue 04/12/2016 16:05:57] - Downloading the flashware to the drive... feature 3
[Tue 04/12/2016 16:05:59] - Successfully downloaded flashware to the drive...
[Tue 04/12/2016 16:05:59] - Waiting (15 sec) for the drive to settle...
[Tue 04/12/2016 16:06:14] - Successfully received the IDENTIFY data from the drive...
[Tue 04/12/2016 16:06:14] - Firmware revision reported to be: '541ABBF0'
[Tue 04/12/2016 16:06:14] - Enabling SMART support...
[Tue 04/12/2016 16:06:14] - Issuing a diagnostic unlock to the drive...
[Tue 04/12/2016 16:06:16] - Setting up Max LBA settings...
[Tue 04/12/2016 16:06:19] - Change of sector size is not required, sector size is already set to 512
[Tue 04/12/2016 16:06:20] - Setting the serial number of the drive to: 11
[Tue 04/12/2016 16:06:23] - Setting the World Wide Name (WWN) of the drive to: 22
[Tue 04/12/2016 16:06:26] - Processing completed for device: 11
[Tue 04/12/2016 16:06:26] - Begin collecting the device post-process log/information
SandForce Consolidate Log Bundle
         SandForce Core Library: v1.7.1.
                        Created: Tue 04/12/2016 16:06:26
                         Device: /dev/sg2
[Tue 04/12/2016 16:06:26] - Creating the Log Bundle...
<TEXT_IDENTIFY_RECORD>
    General Configuration For Device: /dev/sg2
                                           Reserved0: 1
                                           Reserved1: 0
                                 Response Incomplete: NO
                                           Reserved2: 1
                                           Obsolete1: 12
                                           Reserved3: 3
                                         Device Type: ATA
    1 - Obsolete #1:                                  3162  (0x0C5A)
    2 - Specific Configuration:                       16383 (0x3FFF)
    3 - Obsolete #2:                                  51255 (0xC837)
    4 - Reserved #1:                                  16    (0x0010)
    5 - Obsolete #3:                                  0     (0x0000)
    6 - Reserved_CompactFlash1:                       0     (0x0000)
    7 - Reserved_CompactFlash2:                       63    (0x003F)
    8 - Reserved #2:                                  0     (0x0000)
    9 - Serial No.:          11
   19 - Reserved #3:                            159500544 (0x0981C900)
   21 - Obsolete #4:                                  0     (0x0000)
   22 - Firmware Revision:                            541ABBF0
   26 - Model No.:           SandForce[750509]
   46 - Read/Write Multiple Command:
                        Max Sectors Per Data Request: 1
                                            Reserved: 128
   47 - Trusted Computing Features:
                                        TC Supported: NO
                                            Reserved: 0
                                            Set Flag: 1
                                          Clear Flag: 0
   48 - Capabilities/Features #1:
                                            Reserved: 0
                                       DMA Supported: YES
                                       LBA Supported: YES
                                    IO Ready Disable: YES
                                  IO Ready Supported: YES
                    Identify Packet Device Reserved1: 0
                    Standby Timers Managed By Device: NO
                    Identify Packet Device Reserved2: 0
   49 - Capabilities/Features #2:
   50 - Obsolete #5:                                  12032 (0x2F00)
   51 - Obsolete #6:                                  16385 (0x4001)
   52 - Validity Flags:
                                            Obsolete: 1
                       Words 64 Through 70 Are Valid: YES
                                 Word At 88 Is Valid: YES
                                            Reserved: 0
                                 Free Fall CTL Sense: 0
   53 - Obsolete #7:                            159512365 (0x0981F72D)
   55 - Obsolete #8:                                    1 (0x00000001)
   57 - Obsolete #9:                                  63    (0x003F)
   58 - Hardware Reset Results:
                         Current No. Sectors Per DRQ: 1
                    Multiple Sector Setting Is Valid: YES
                                            Reserved: 0
   59 - Total No. User Logical Sectors:          12697588 (0x00C1BFF4)
   61 - Obsolete #10:                                 2736  (0x0AB0)
   62 - DMA Information:
                      Multiword DMA Mode 0 Supported: YES
                      Multiword DMA Mode 1 Supported: YES
                      Multiword DMA Mode 2 Supported: YES
                                            Reserved: 0
                       Multiword DMA Mode 0 Selected: NO
                       Multiword DMA Mode 1 Selected: NO
                       Multiword DMA Mode 2 Selected: NO
                                            Reserved: 0
   63 - PIO:
                                 PIO Modes Supported: 3 (0x0003)
                                            Reserved: 0
   64 - Minimum MW DMA:                                 7 (0x00000007)
   65 - Recomended MW DMA Time:                         3 (0x00000003)
   66 - Min PIO Time without Flow CTL:                120 (0x00000078)
   67 - Min PIO Time with IORDY Flow CTL:             120 (0x00000078)
   68 - Reserved #4:                                  120   (0x0078)
   69 - Reserved #5:                                  120   (0x0078)
   70 - Reserved Identify Packet Device #1:           3848  (0x0F08)
   71 - Reserved Identify Packet Device #2:           0     (0x0000)
   72 - Reserved Identify Packet Device #3:           0     (0x0000)
   73 - Reserved Identify Packet Device #4:           0     (0x0000)
   74 - Command Queue:
                                     Depth Supported: 31 (0x001F)
                                            Reserved: 0
   75 - Serial ATA Capabilities:
                                               Clear: NO
                      Generation 1 (1.5 Gbs) Support: YES
                      Generation 2 (3.0 Gbs) Support: YES
                                   SATA Gen Reserved: 0
                    Native Command Queuing Supported: YES
                 Host Initiated Power Mgmt Supported: NO
                         Supports Phy Event Counters: YES
                                            Reserved: 1
   76 -  Reserved SATA Capabilities:                  31    (0x001F)
   77 - Serial ATA Supported Features:
                                               Clear: NO
                   Non-Zero Offsets in DMA Setup FIS: NO
                DMA Setup Auto-Activate Optimization: YES
                    Device Initiate Power Management: YES
                              In-order Data Delivery: NO
                                           Reserved1: 1
                      Software Settings Preservation: YES
                                           Reserved2: 1
   78 - Serial ATA Enabled Features:
                                               Clear: NO
                DMA Setup Auto-Activate Optimization: NO
                    Device Initiate Power Management: NO
                                           Reserved1: 0
                                           Reserved2: 0
   79 - Major Version No.:
                                           Reserved1: 0
                                            Obsolete: 6
                                     ATA-4 Supported: YES
                                     ATA-5 Supported: YES
                                     ATA-6 Supported: YES
                                     ATA-7 Supported: YES
                                     ATA-8 Supported: YES
                                           Reserved2: 0
   80 - Minor Version No.:                            64    (0x0040)
   81 - Command/Feature Support #1:
                                   SMART Feature Set: YES
                                       Security Mode: YES
                                           Obsolete1: 0
                          Mandatory Power Management: YES
                                  Packet Feature Set: NO
                                         Write Cache: YES
                                          Look-Ahead: YES
                                   Release Interrupt: NO
                                   Service Interrupt: NO
                                Device Reset Command: NO
                                 Host Protected Area: YES
                                           Obsolete2: 0
                                 Wite Buffer command: YES
                                 Read Buffer command: YES
                                         NOP Command: YES
                                           Obsolete3: 0
   82 - Command/Feature Support #2:
                          Download MicroCode Command: YES
                               Read/Write DMA Queued: NO
                                     CFA Feature Set: NO
                           Advanced Power Management: YES
                                            Obsolete: 0
                                 Power-Up In Standby: YES
               Set Feature To Spin-Up After Power-Up: YES
                                            Reserved: 0
                          Set Max Security Extension: YES
                       Automatic Acoustic Management: NO
                                      48-bit Address: YES
                        Device Configuration Overlay: NO
                                  Manual Flush Cache: YES
                                     Flush Cache Ext: YES
                              Read/Write DMA Queued : YES
                                  Download MicroCode: NO
   83 - Command/Feature Support #3:
                                 SMART Error Logging: YES
                                     SMART Self-Test: YES
                                    Media Serial No.: NO
                      Media Card Passthrough Command: NO
                                           Streaming: NO
                             General Purpose Logging: YES
           Write DMA FUA Ext and Write Multi FUA Ext: YES
                            Write DMA Queued FUA Ext: NO
                              64-Bit World Wide Name: YES
                                            Obsolete: 0
                                            Reserved: 0
                          Idle Immediate With Unload: YES
                                                 Set: YES
                                               Clear: NO
   84 - Command/Feature Support #4:
                                        SMART Enaled: YES
                                Security Mode Enaled: NO
                                           Obsolete1: 0
                   Mandatory Power Management Enaled: YES
                                      Packet Support: NO
                                  Write Cache Enaled: YES
                             Read Look-Ahead Enabled: YES
                           Release Interrupt Enabled: NO
                           Service Interrupt Enabled: NO
                                Device Reset Support: NO
                         Host Protected Area Enabled: YES
                                           Obsolete2: 0
                                Write Buffer Support: YES
                                 Read Buffer Support: YES
                                         NOP Support: YES
                                           Obsolete3: 0
   85 - Command/Feature Support #5:
                                  Download MicroCode: YES
                                          Queued DMA: NO
                                     CFA Feature Set: NO
                            Advance Power Management: YES
                                            Obsolete: 0
                                 Power-Up In Standby: NO
                    SubCommand To Spinup On Power-up: YES
                                           Reserved1: 0
                           Set Max Security Password: NO
               Automatic Acoustic Management Enabled: NO
                           48-Bit Addressing Support: YES
                                     DCO Feature Set: NO
                                         Flush Cache: YES
                                           Reserved2: 0
                             Words 119-120 Are Valid: YES
离线75106zxs
只看该作者 1楼 发表于: 2016-04-12
离线75106zxs
只看该作者 2楼 发表于: 2016-04-12
离线75106zxs
只看该作者 3楼 发表于: 2016-04-12
离线527945545
只看该作者 4楼 发表于: 2016-04-12
离线75106zxs
只看该作者 5楼 发表于: 2016-04-12
离线75106zxs
只看该作者 6楼 发表于: 2016-04-13
离线2017shuma
只看该作者 7楼 发表于: 2017-04-25
离线527945545
只看该作者 8楼 发表于: 2017-04-25
离线毛毛豆
只看该作者 9楼 发表于: 2017-04-26
