  • 3467阅读
  • 8回复
[综合]断电掉固件的intel520 240G 2281开卡求解。。 [复制链接]
离线重锤军士
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2018-04-16
折腾两天了,实在搞不明白。求大神指点迷津。。。
<?xml version = "1.0"?>
<Genesis_Log>
    <Log_Body>
Overall Summary:
                Start Time: Mon, 04/16/2018 @ 23:04:09
                  End Time: Mon, 04/16/2018 @ 23:05:54
             OverallResult: FAIL
                  ExitCode: (0x10090008:SF_GENESIS_FORMAT_ERROR)
Environment Settings:
          Input Parameters:
                  argv[1]: -PROCESS_SSD
                  argv[2]: 5:0:0:0
                  argv[3]: /root/文档/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
                  argv[4]: /root/文档/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release--0/Configuration_Files/22673.0.driveconfig
                  argv[5]: 123
                  argv[6]: 456
                  argv[7]: LOG=/root/音乐/123_123_DATETIMESTAMP_5.0.0.0_PROCESS_SSD_RESULT.log
                  Log File: /root/音乐/123_123_DATETIMESTAMP_5.0.0.0_PROCESS_SSD_RESULT.log
                  Hostname: 123
           Host IP Address: 0.0.0.123
               Port Number: 0
                DeviceName: /dev/sg0
        SF_Genesis Version: v1.7.0.01020130612-fc14-32bit
   SF_Core Library Version: v1.7.1.20130612-fc14-32bit
         SF_OS_Information: Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686
Post Processing Device Information:
                   WWN OUI: UNKNOWN
              WWN UniqueID: UNKNOWN
                Serial No.: UNKNOWN
                 Model No.: UNKNOWN
         Firmware Revision: UNKNOWN
              ROM Revision: UNKNOWN
            NAND Page Size: UNKNOWN
     Number Of Chip Enable: UNKNOWN
           Logical Sectors: UNKNOWN
                   NAND ID: UNKNOWN
        Flash Manufacturer: UNKNOWN
              Flash Device: UNKNOWN
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Mon 04/16/2018 23:04:09] - SF_Genesis has been invoked with the following parameters:
                      argv[2]: 5:0:0:0
                      argv[5]: 123
                      argv[6]: 456
[Mon 04/16/2018 23:04:09] - Instructing the operating system to purge any existing cached data for device: '5:0:0:0'
[Mon 04/16/2018 23:04:14] - Issuing a discovery command for device: '5:0:0:0'
[Mon 04/16/2018 23:04:19] - Discovery command completed...
[Mon 04/16/2018 23:04:19] - Waiting 5 seconds for the system to settle...
[Mon 04/16/2018 23:04:24] - Device designation string '5:0:0:0' is mapped to node '/dev/sg0'
[Mon 04/16/2018 23:04:24] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg0
    MFP Package Filename = /root/文档/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
      Configuration File = /root/文档/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release--0/Configuration_Files/22673.0.driveconfig
              Serial No. = 123
         World Wide Name = 456
[Mon 04/16/2018 23:04:24] - Successfully received the IDENTIFY data from the drive...
[Mon 04/16/2018 23:04:24] - Validating Manufacturing Firmware Package: /root/文档/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
[Mon 04/16/2018 23:04:30] - Successfully opened the package: /root/文档/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
[Mon 04/16/2018 23:04:30] - file  /root/文档/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release--0/Configuration_Files/22673.0.driveconfig Loaded successfully
[Mon 04/16/2018 23:04:30] - Warning:  Unable to query diagnostics information to perform power management settings check
[Mon 04/16/2018 23:04:30] - B01 Power Management configuration request detected
[Mon 04/16/2018 23:04:30] - Successfully extracted *.DriveConfig file: /root/文档/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release--0/Configuration_Files/22673.0.driveconfig
[Mon 04/16/2018 23:04:30] - Extracted Config_ID: 1 (22673) in DriveConfig file: /root/文档/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release--0/Configuration_Files/22673.0.driveconfig
[Mon 04/16/2018 23:04:30] - Extracted SerialOutputControl: 0
[Mon 04/16/2018 23:04:30] - Searching for flashware image for configuration 22673
[Mon 04/16/2018 23:04:30] - Manifest found for configuration 22673
[Mon 04/16/2018 23:04:31] - Flashware image extracted: 22673_fw_cl_ccmlc_Intel_64Gb_JS29F32B08JCME2_2Q_4C_1D_S_PP_R00490_s512.vic
[Mon 04/16/2018 23:04:31] - Searching for manufacturing image for configuration 22673
[Mon 04/16/2018 23:04:31] - Manifest found for configuration 22673
[Mon 04/16/2018 23:04:31] - Manufacturing image extracted: 22673_mf_ccmlc_Intel_64Gb_JS29F32B08JCME2_2Q_4C_1D_S_PP_R00490_s512.vic
[Mon 04/16/2018 23:04:31] - Proceeding in ROM mode, download feature 3...
[Mon 04/16/2018 23:04:31] - Successfully downloaded MFB to the drive...
[Mon 04/16/2018 23:04:31] - Waiting (5 sec) for the drive to settle...
[Mon 04/16/2018 23:04:36] - Successfully received the IDENTIFY data from the drive...
[Mon 04/16/2018 23:04:36] - Firmware revision reported to be: '522ABBM0'.  This indicates MFB download was successful.
[Mon 04/16/2018 23:04:36] - Successfully enabled SMART capabilities...
[Mon 04/16/2018 23:04:38] - Successfully issued a diagnostic unlock...
[Mon 04/16/2018 23:04:39] - Performing the flash test of block 0 (0x0000)...
[Mon 04/16/2018 23:04:42] - Flash Test Results:
Flash Test Parameters:
               Block Count: 0
                Page Count: 1
                 Bus Count: 2
        Chip Enabled Count: 4
                 Die Count: 1
                Lane Count: 4
               Plane Count: 2
Results Notes:
   N1 - At least one page tested and passed with no bit errors.
   N2 - No test data available.  Test may have aborted, or failed during the testing.
   N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
   N4 - At least  one erased page tested had bit error rate greater than half the correction power.
   N5 - Walking zeros test failed.
   N6 - Walking ones test failed.
   N7 - Block contained factory bad block markings and testing was skipped.
   N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
   N9 - Block in plane 0 was marked as a factory bad block.
  N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
  N11 - Block in plane 1 was marked as a factory bad block.
| Bus  | CE   | Die  | Lane | Value  | Result Notes                               | Overall |
| 0    | 0    | 0    | 0    | 0x0022 | N3,N5                                      | WARNING |
| 0    | 0    | 0    | 1    | 0x0002 | N3                                         | WARNING |
| 0    | 0    | 0    | 2    | 0x0002 | N3                                         | WARNING |
| 0    | 0    | 0    | 3    | 0x0002 | N3                                         | WARNING |
| 0    | 1    | 0    | 0    | 0x0002 | N3                                         | WARNING |
| 0    | 1    | 0    | 1    | 0x0002 | N3                                         | WARNING |
| 0    | 1    | 0    | 2    | 0x0002 | N3                                         | WARNING |
| 0    | 1    | 0    | 3    | 0x0002 | N3                                         | WARNING |
| 0    | 2    | 0    | 0    | 0x0022 | N3,N5                                      | WARNING |
| 0    | 2    | 0    | 1    | 0x0002 | N3                                         | WARNING |
| 0    | 2    | 0    | 2    | 0x0022 | N3,N5                                      | WARNING |
| 0    | 2    | 0    | 3    | 0x0002 | N3                                         | WARNING |
| 0    | 3    | 0    | 0    | 0x0022 | N3,N5                                      | WARNING |
| 0    | 3    | 0    | 1    | 0x0022 | N3,N5                                      | WARNING |
| 0    | 3    | 0    | 2    | 0x0002 | N3                                         | WARNING |
| 0    | 3    | 0    | 3    | 0x0022 | N3,N5                                      | WARNING |
| 1    | 0    | 0    | 0    | 0x0002 | N3                                         | WARNING |
| 1    | 0    | 0    | 1    | 0x0002 | N3                                         | WARNING |
| 1    | 0    | 0    | 2    | 0x0002 | N3                                         | WARNING |
| 1    | 0    | 0    | 3    | 0x0002 | N3                                         | WARNING |
| 1    | 1    | 0    | 0    | 0x0022 | N3,N5                                      | WARNING |
| 1    | 1    | 0    | 1    | 0x0002 | N3                                         | WARNING |
| 1    | 1    | 0    | 2    | 0x0002 | N3                                         | WARNING |
| 1    | 1    | 0    | 3    | 0x0002 | N3                                         | WARNING |
| 1    | 2    | 0    | 0    | 0x0002 | N3                                         | WARNING |
| 1    | 2    | 0    | 1    | 0x0002 | N3                                         | WARNING |
| 1    | 2    | 0    | 2    | 0x0002 | N3                                         | WARNING |
| 1    | 2    | 0    | 3    | 0x0022 | N3,N5                                      | WARNING |
| 1    | 3    | 0    | 0    | 0x0002 | N3                                         | WARNING |
| 1    | 3    | 0    | 1    | 0x0022 | N3,N5                                      | WARNING |
| 1    | 3    | 0    | 2    | 0x0002 | N3                                         | WARNING |
| 1    | 3    | 0    | 3    | 0x0022 | N3,N5                                      | WARNING |
  Total Number of test results: 32
            Number of failures: 0
         Number of Passed with warnings: 32
      No. Passed without warnings: 0
[Mon 04/16/2018 23:04:42] - Performing the FORMAT Command with the following parameters:
         MemoryWearCycleCapability = 0
              CurrentPE_CycleCount = 0
                     LifeInSeconds = 0
                   LogicalCapacity = 468862128
                        SectorSize = 512
             SectorAlignmentOffset = 0
                  ExpectedMemoryID = 34953 (0x8889)
                   ExpectedNumDies = 0
               SerialOutputControl = 0
                           Time[8] = 0x0000000000000000
            MiscFlag_Erase_R_Block = 0
     MiscFlag_PanicHandlingEnabled = 0
        MiscFlag_PanicOnSATA_Error = 0
  MiscFlag_WriteThrottlingTestMode = 0
      MiscFlag_DisableUserBandECCX = 0
                        L_PageSize = 0
                        E_PageSize = 0
              ErrorCorrectionPower = 0
      ConfigDeviceReadDisturbCount = 0
   ConfigDeviceReadDisturbCountLow = 0
                  ExtraOptions_0_1 = 0
[Mon 04/16/2018 23:05:54] - FATAL_ERROR: Could not perform the FORMAT() operation on the drive... (0x0000C048:SF_SCT (C048h): Root Creation Failed (MFB format))
[Mon 04/16/2018 23:05:54] - End of Genesis manufacturing log.
[Mon 04/16/2018 23:05:54] - Exiting...
    </Log_Body>
    <Overall_Summary>
        <Start_Time> Mon, 04/16/2018 @ 23:04:09 </Start_Time>
        <End_Time> Mon, 04/16/2018 @ 23:05:54 </End_Time>
        <Overall_Result> FAIL </Overall_Result>
        <Exit_Code> (0x10090008:SF_GENESIS_FORMAT_ERROR) </Exit_Code>
    </Overall_Summary>
    <Environment_Settings>
        <Input_Parameters>
                  argv[2]: 5:0:0:0
                  argv[5]: 123
                  argv[6]: 456
        </Input_Parameters>
        <Log_File> /root/音乐/123_123_DATETIMESTAMP_5.0.0.0_PROCESS_SSD_RESULT.log </Log_File>
        <Hostname> 123 </Hostname>
        <Host_IP_Address> 0.0.0.123 </Host_IP_Address>
        <Port_Number> 0 </Port_Number>
        <Device_Name> /dev/sg0 </Device_Name>
        <SF_Genesis_Version> v1.7.0.01020130612-fc14-32bit </SF_Genesis_Version>
        <SF_Core_Library_Version> v1.7.1.20130612-fc14-32bit </SF_Core_Library_Version>
        <SF_OS_Information> Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686 </SF_OS_Information>
    </Environment_Settings>
    <Post_Processing_Device_Info>
        <WWN_OUI> UNKNOWN </WWN_OUI>
        <WWN_UniqueID> UNKNOWN </WWN_UniqueID>
        <Serial_Number> UNKNOWN </Serial_Number>
        <Model_Number> UNKNOWN </Model_Number>
        <Firmware_Revision> UNKNOWN </Firmware_Revision>
        <ROM_Revision> UNKNOWN </ROM_Revision>
        <NAND_Page_Size> UNKNOWN </NAND_Page_Size>
        <Number_Of_Chip_Enable> UNKNOWN </Number_Of_Chip_Enable>
        <Logical_Sectors> UNKNOWN </Logical_Sectors>
        <NAND_ID> UNKNOWN </NAND_ID>
        <Flash_Manufacturer> UNKNOWN </Flash_Manufacturer>
        <Flash_Device> UNKNOWN </Flash_Device>
    </Post_Processing_Device_Info>
</Genesis_Log>
[Mon 04/16/2018 23:05:54] - Overall Result for Device: /dev/sg0 ****** FAIL ******
离线perter
只看该作者 1楼 发表于: 2018-04-16
离线重锤军士
只看该作者 2楼 发表于: 2018-04-16
回 perter 的帖子
离线perter
只看该作者 3楼 发表于: 2018-04-16
离线k1503
只看该作者 4楼 发表于: 2018-04-16
离线重锤军士
只看该作者 5楼 发表于: 2018-04-16
回 k1503 的帖子
离线重锤军士
只看该作者 6楼 发表于: 2018-04-16
回 perter 的帖子
离线likechair
只看该作者 7楼 发表于: 2018-04-16
离线重锤军士
只看该作者 8楼 发表于: 2018-04-16
回 likechair 的帖子
