那位大神帮忙看看什么回事每20%左右就卡住报错。焊接应该没有什么问题,平时都做BGA主板的
Starting command:[/2281/soft/SF_Genesis -PROCESS_SSD 4:0:0:0 "/2281/mpt/FW_SF-2000_MP_3-3-0_Client--123456/FW_SF-2000_MP_3-3-0_Client.123456.mfp" "/2281/22073.12345600.driveconfig" 3548654 66655 LOG="//3548654_fg_DATETIMESTAMP_4.0.0.0_PROCESS_SSD_RESULT.log" ]...
SandForce Genesis Utility v1.5.21.20110919-fc14-32bit
SF_Core Library: v1.7.0.20110919-fc14-32bit
Copyright 2010-2011, SandForce Inc., All Rights Reserved Worldwide.
[Fri 09/14/2018 10:46:15] - SF_Genesis has been invoked with the following parameters:
argv[1]: -PROCESS_SSD
argv[2]: 4:0:0:0
argv[3]: /2281/mpt/FW_SF-2000_MP_3-3-0_Client--123456/FW_SF-2000_MP_3-3-0_Client.123456.mfp
argv[4]: /2281/22073.12345600.driveconfig
argv[5]: 3548654
argv[6]: 66655
argv[7]: LOG=//3548654_fg_DATETIMESTAMP_4.0.0.0_PROCESS_SSD_RESULT.log
[Fri 09/14/2018 10:46:15] - Instructing the operating system to purge any existing cached data for device: '4:0:0:0'
[Fri 09/14/2018 10:46:20] - Issuing a discovery command for device: '4:0:0:0'
[Fri 09/14/2018 10:46:25] - Discovery command completed...
[Fri 09/14/2018 10:46:25] - Waiting 5 seconds for the system to settle...
[Fri 09/14/2018 10:46:30] - Device designation string '4:0:0:0' is mapped to node '/dev/sg1'
[Fri 09/14/2018 10:46:30] - Proceeding to process SSD device with the following parameters:
DeviceName = /dev/sg1
MFP Package Filename = /2281/mpt/FW_SF-2000_MP_3-3-0_Client--123456/FW_SF-2000_MP_3-3-0_Client.123456.mfp
Configuration File = /2281/22073.12345600.driveconfig
Serial No. = 3548654
World Wide Name = 66655
[Fri 09/14/2018 10:46:30] - Successfully received the IDENTIFY data from the drive...
SF_Internal_PackageManager::OpenExisting:
HeaderCRC32: -378568224,(E96F81E0)
_Package.Header.HeaderCRC32: -378568224,(E96F81E0)
OverallCRC32: 263335293,(0FB22D7D)
_Package.Header.OverallCRC32: 263335293,(0FB22D7D)
[Fri 09/14/2018 10:46:33] - Successfully opened the package: /2281/mpt/FW_SF-2000_MP_3-3-0_Client--123456/FW_SF-2000_MP_3-3-0_Client.123456.mfp
[Fri 09/14/2018 10:46:33] - Successfully extracted *.DriveConfig file: /2281/22073.12345600.driveconfig
[Fri 09/14/2018 10:46:33] - Extracted Config_ID: 1 (22073) in DriveConfig file: /2281/22073.12345600.driveconfig
[Fri 09/14/2018 10:46:33] - Extracted SerialOutputControl: 0
[Fri 09/14/2018 10:46:33] - Successfully extracted Config record: 22073
[Fri 09/14/2018 10:46:33] - Successfully extracted flashware image: 22073_fw_cl_ccmlc_Intel_64Gb_JS29F32B08JCME2_2Q_4C_1D_S_PP_R00490_s512.vic
[Fri 09/14/2018 10:46:33] - Successfully extracted manufacturing image: 22073_mf_ccmlc_Intel_64Gb_JS29F32B08JCME2_2Q_4C_1D_S_PP_R00490_s512.vic
[Fri 09/14/2018 10:46:33] - Proceeding in ROM mode, download feature 1...
[Fri 09/14/2018 10:49:04] - Successfully downloaded MFB to the drive...
[Fri 09/14/2018 10:49:04] - Waiting (5 sec) for the drive to settle...
[Fri 09/14/2018 10:49:09] - FATAL_ERROR: Could not get the IDENTIFY data from the drive... (0x12000004:SF_SG_HOST_BAD_TARGET_ERROR)
[Fri 09/14/2018 10:49:09] - End of Genesis manufacturing log.
[Fri 09/14/2018 10:49:09] - Exiting...
[Fri 09/14/2018 10:49:09] - Overall Result for Device: /dev/sg1 ****** FAIL ******
Process exited with code 18
