King ston 8G U
DataTrare Ler G2
SSS6690
VID=0951 PID=1624
直接看U盘里面的芯
6690
V2 - M6C
HLJ87 - 001C
0917
后面
TOSHIBA 1A7414
TAIWAN 09209AE
TH58NVG6T2ETA2A
量产最新的
sss6690 V2.159最新量产固件发布, 东芝TLC可量产USB-CDROM(亲测有效,绝对独家首发) 失败
Starting Time: 18:51:44
Device 1:0xB1
MP Version:2.159
INI_File_Name:6690_D3.INI
Random delay 0 msec
--- Download MP ISP ---
CE-0, Flash ID=98-D7-99-B2-7A-54-0B-04
CE-1, Flash ID=98-D7-99-B2-7A-54-0B-04
Found BACKUP Table (00000159-0001)
Found BACKUP Table (00000259-0002)
Original Bad Block - 0:0x0436
Original Bad Block - 0:0x0541
Original Bad Block - 0:0x0908
Original Bad Block - 0:0x0BF4
Original Bad Block - 0:0x0CA9
Original Bad Block - 0:0x0CF5
Original Bad Block - 1:0x02EA
Original Bad Block - 1:0x0436
Original Bad Block - 1:0x0496
Original Bad Block - 1:0x04FD
Original Bad Block - 1:0x09F3
Defect Table shows 5605 Good blocks, 11 Bad blocks
SafeErase (0,2808)
Erase failed Block - 0:0:0x0436
Erase failed Block - 0:0:0x0541
---> Max Bad of Plane (1,1)
Erase failed Block - 0:1:0x0908
Erase failed Block - 0:1:0x0BF4
Erase failed Block - 0:1:0x0CA9
Erase failed Block - 0:1:0x0CF5
---> Max Bad of Plane (2,2)
SafeErase (1,2808)
Erase failed Block - 1:0:0x02EA
Erase failed Block - 1:0:0x0436
Erase failed Block - 1:0:0x0496
Erase failed Block - 1:0:0x04FD
---> Max Bad of Plane (3,1)
Erase failed Block - 1:1:0x09F3
---> Max Bad of Plane (0,1)
---> Max BAD/DIE = 3
Total good blocks after SCAN: 5605 / 5616, Bad block=11
==> 2-Plane mode
Max. Bad Block Allowed = 332(11)
Adjust Max LBA = 15654912, 15654848
MaxWindows=4/1274, MaxLBA=15654848, Size=7643 MB
Max BAD of one plane is 3 (41),5616,2,2
RootSector=0x1B85,Sec/Cluster=32, SuperPage=32 ---> Alignment=27
Boot Block=0x0001,0x0002
Lun0(14238556), Lun1(1416292), Public=14238556, Secure=0, CDROM=1416292
Special FE Config = 56-0B-00
--- Download ISP Code:D:\UM\6690_TSBD3_MP_V2159\ISP_CODE\6690_B1-D3_20110910_V221B_BEFA.BIN---
--- ISP Code installed.
Public,Secure,CDROM = 14238556,0,1416292
SN=001A4D66FB46F1A169A2202E
=== Preformat Done ===
Low Level Format DONE
Store INI/ERROR MSG to Block-0x0001:119.
LBATest 10M activate
### Error: CopyTest Fail(Compare LBA=0x000017C0, 4A00=71,00)
### CopyTest 10M fail ###
Ending Time: 18:52:04
求各位大哥大姐 看看那出错了
