Starting Time: 18:36:20
Device 1:0xB3
MP Version:2.162
INI_File_Name:
Random delay 0 msec
--- Download MP ISP ---
CE-0, Flash ID=98-D7-94-32-76-54-0C-00
Found BACKUP Table (000000BB-0001)
Defect Table (00000200-0004)
Original Bad Block - 0:0x0000
Original Bad Block - 0:0x0059
Original Bad Block - 0:0x0078
Original Bad Block - 0:0x00DA
Original Bad Block - 0:0x016B
Original Bad Block - 0:0x016D
Original Bad Block - 0:0x0251
Original Bad Block - 0:0x028F
Original Bad Block - 0:0x030E
Original Bad Block - 0:0x0310
Original Bad Block - 0:0x03AE
Original Bad Block - 0:0x03B8
Original Bad Block - 0:0x03BA
Original Bad Block - 0:0x03BC
Original Bad Block - 0:0x03BE
Original Bad Block - 0:0x03C0
Original Bad Block - 0:0x03C2
Original Bad Block - 0:0x03C4
Original Bad Block - 0:0x03C6
Original Bad Block - 0:0x03C8
Original Bad Block - 0:0x03CC
Original Bad Block - 0:0x03CE
Original Bad Block - 0:0x03D0
Original Bad Block - 0:0x03D2
Original Bad Block - 0:0x03D4
Original Bad Block - 0:0x03D6
Original Bad Block - 0:0x03D8
Original Bad Block - 0:0x03DA
Original Bad Block - 0:0x03DC
Original Bad Block - 0:0x03DE
Original Bad Block - 0:0x03E0
Original Bad Block - 0:0x03E2
Original Bad Block - 0:0x03E4
Original Bad Block - 0:0x03E6
Original Bad Block - 0:0x03E8
Original Bad Block - 0:0x03EA
Original Bad Block - 0:0x03EC
Original Bad Block - 0:0x03EE
Original Bad Block - 0:0x03F0
Original Bad Block - 0:0x03F2
Original Bad Block - 0:0x03F4
Original Bad Block - 0:0x03F6
Original Bad Block - 0:0x03F8
Original Bad Block - 0:0x03FA
Original Bad Block - 0:0x03FC
Original Bad Block - 0:0x03FE
Original Bad Block - 0:0x0400
Original Bad Block - 0:0x0402
Original Bad Block - 0:0x0404
Original Bad Block - 0:0x0406
Original Bad Block - 0:0x0408
Original Bad Block - 0:0x040A
Original Bad Block - 0:0x040C
Original Bad Block - 0:0x040E
Original Bad Block - 0:0x0410
Original Bad Block - 0:0x0412
Original Bad Block - 0:0x0414
Original Bad Block - 0:0x0416
Original Bad Block - 0:0x0418
Original Bad Block - 0:0x041A
Original Bad Block - 0:0x041C
Original Bad Block - 0:0x041E
Original Bad Block - 0:0x0420
Original Bad Block - 0:0x0422
Original Bad Block - 0:0x0424
Original Bad Block - 0:0x0426
Original Bad Block - 0:0x0428
Original Bad Block - 0:0x042A
Original Bad Block - 0:0x042C
Original Bad Block - 0:0x042E
Original Bad Block - 0:0x0430
Original Bad Block - 0:0x0432
Original Bad Block - 0:0x0434
Original Bad Block - 0:0x0436
Original Bad Block - 0:0x0438
Original Bad Block - 0:0x043A
Original Bad Block - 0:0x043C
Original Bad Block - 0:0x043E
Original Bad Block - 0:0x0440
Original Bad Block - 0:0x0442
Original Bad Block - 0:0x0444
Original Bad Block - 0:0x0446
Original Bad Block - 0:0x0448
Original Bad Block - 0:0x044A
Original Bad Block - 0:0x044C
Original Bad Block - 0:0x044E
Original Bad Block - 0:0x0450
Original Bad Block - 0:0x0454
Original Bad Block - 0:0x0458
Original Bad Block - 0:0x045C
Original Bad Block - 0:0x0460
Original Bad Block - 0:0x0548
Original Bad Block - 0:0x05BC
Original Bad Block - 0:0x0697
Original Bad Block - 0:0x073C
Original Bad Block - 0:0x08B1
Original Bad Block - 0:0x097D
Original Bad Block - 0:0x0989
Original Bad Block - 0:0x09A7
Original Bad Block - 0:0x09D6
Original Bad Block - 0:0x0C4F
Original Bad Block - 0:0x0C93
Original Bad Block - 0:0x0E48
Original Bad Block - 0:0x0F71
Original Bad Block - 0:0x0F83
Original Bad Block - 0:0x0F94
Original Bad Block - 0:0x1030
Original Bad Block - 0:0x1031
Original Bad Block - 0:0x1032
Original Bad Block - 0:0x1033
Defect Table shows 4038 Good blocks, 110 Bad blocks
SafeErase (0,4148)
Erase failed Block - 0:0:0x0000
Erase failed Block - 0:0:0x0059
Erase failed Block - 0:0:0x0078
Erase failed Block - 0:0:0x00DA
Erase failed Block - 0:0:0x016B
Erase failed Block - 0:0:0x016D
Erase failed Block - 0:0:0x0251
Erase failed Block - 0:0:0x028F
Erase failed Block - 0:0:0x030E
Erase failed Block - 0:0:0x0310
Erase failed Block - 0:0:0x03AE
Erase failed Block - 0:0:0x03B8
Erase failed Block - 0:0:0x03BA
Erase failed Block - 0:0:0x03BC
Erase failed Block - 0:0:0x03BE
Erase failed Block - 0:0:0x03C0
Erase failed Block - 0:0:0x03C2
Erase failed Block - 0:0:0x03C4
Erase failed Block - 0:0:0x03C6
Erase failed Block - 0:0:0x03C8
Erase failed Block - 0:0:0x03CC
Erase failed Block - 0:0:0x03CE
Erase failed Block - 0:0:0x03D0
Erase failed Block - 0:0:0x03D2
Erase failed Block - 0:0:0x03D4
Erase failed Block - 0:0:0x03D6
Erase failed Block - 0:0:0x03D8
Erase failed Block - 0:0:0x03DA
Erase failed Block - 0:0:0x03DC
Erase failed Block - 0:0:0x03DE
Erase failed Block - 0:0:0x03E0
Erase failed Block - 0:0:0x03E2
Erase failed Block - 0:0:0x03E4
Erase failed Block - 0:0:0x03E6
Erase failed Block - 0:0:0x03E8
Erase failed Block - 0:0:0x03EA
Erase failed Block - 0:0:0x03EC
Erase failed Block - 0:0:0x03EE
Erase failed Block - 0:0:0x03F0
Erase failed Block - 0:0:0x03F2
Erase failed Block - 0:0:0x03F4
Erase failed Block - 0:0:0x03F6
Erase failed Block - 0:0:0x03F8
Erase failed Block - 0:0:0x03FA
Erase failed Block - 0:0:0x03FC
Erase failed Block - 0:0:0x03FE
Erase failed Block - 0:0:0x0400
Erase failed Block - 0:0:0x0402
Erase failed Block - 0:0:0x0404
Erase failed Block - 0:0:0x0406
Erase failed Block - 0:0:0x0408
Erase failed Block - 0:0:0x040A
Erase failed Block - 0:0:0x040C
Erase failed Block - 0:0:0x040E
Erase failed Block - 0:0:0x0410
Erase failed Block - 0:0:0x0412
Erase failed Block - 0:0:0x0414
Erase failed Block - 0:0:0x0416
Erase failed Block - 0:0:0x0418
Erase failed Block - 0:0:0x041A
Erase failed Block - 0:0:0x041C
Erase failed Block - 0:0:0x041E
Erase failed Block - 0:0:0x0420
Erase failed Block - 0:0:0x0422
Erase failed Block - 0:0:0x0424
Erase failed Block - 0:0:0x0426
Erase failed Block - 0:0:0x0428
Erase failed Block - 0:0:0x042A
Erase failed Block - 0:0:0x042C
Erase failed Block - 0:0:0x042E
Erase failed Block - 0:0:0x0430
Erase failed Block - 0:0:0x0432
Erase failed Block - 0:0:0x0434
Erase failed Block - 0:0:0x0436
Erase failed Block - 0:0:0x0438
Erase failed Block - 0:0:0x043A
Erase failed Block - 0:0:0x043C
Erase failed Block - 0:0:0x043E
Erase failed Block - 0:0:0x0440
Erase failed Block - 0:0:0x0442
Erase failed Block - 0:0:0x0444
Erase failed Block - 0:0:0x0446
Erase failed Block - 0:0:0x0448
Erase failed Block - 0:0:0x044A
Erase failed Block - 0:0:0x044C
Erase failed Block - 0:0:0x044E
Erase failed Block - 0:0:0x0450
Erase failed Block - 0:0:0x0454
Erase failed Block - 0:0:0x0458
Erase failed Block - 0:0:0x045C
Erase failed Block - 0:0:0x0460
Erase failed Block - 0:0:0x0548
Erase failed Block - 0:0:0x05BC
Erase failed Block - 0:0:0x0697
Erase failed Block - 0:0:0x073C
Erase failed Block - 0:0:0x08B1
Erase failed Block - 0:0:0x097D
Erase failed Block - 0:0:0x0989
Erase failed Block - 0:0:0x09A7
Erase failed Block - 0:0:0x09D6
Erase failed Block - 0:0:0x0C4F
Erase failed Block - 0:0:0x0C93
Erase failed Block - 0:0:0x0E48
Erase failed Block - 0:0:0x0F71
Erase failed Block - 0:0:0x0F83
Erase failed Block - 0:0:0x0F94
Erase failed Block - 0:0:0x1030
Erase failed Block - 0:0:0x1031
Erase failed Block - 0:0:0x1032
Erase failed Block - 0:0:0x1033
---> Max Bad of Plane (47,8)
---> Max BAD/DIE = 47
Total good blocks after SCAN: 4038 / 4148, Bad block=110
==> 2-Plane mode
Max. Bad Block Allowed = 231(110)
Adjust Max LBA = 7823360, 7823296
MaxWindows=2/1910, MaxLBA=7823296, Size=3819 MB
Max BAD of one plane is 47 (57),4148,1,1
RootSector=0xF4B,Sec/Cluster=32, SuperPage=32 ---> Alignment=21
Boot Block=0x0001,0x0002
Lun0(7823296), Lun1(0), Public=7823296, Secure=0, CDROM=0
Special FE Config = 54-0B-00
Defect Table Block=0x0004
--- Download ISP Code:C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\桌面\MP_VER2162_ALL\ISP_CODE\6691_B3-A_20100331_VA10F00_9083.BIN---
--- ISP Code installed.
Public,Secure,CDROM = 7823296,0,0
SN=90E6BAF25019F2205AB414DC
=== Preformat Done ===
Low Level Format DONE
Store INI/ERROR MSG to Block-0x0001:79.
Total=7823296,CDROM=0, PublicArea=7823168, SecureArea=0
### Err: SECURE failed(32).
Ending Time: 18:36:38
