一、
Chipgenus4.0检测结果(量产后):
拆开后闪存号码:FT32G08UCT1,应该为东芝flash,
故障:不能格式化,3s量产错误61。不能取得cardinfo
解决办法:短接29,30脚插入,断开短接,打开3s 2162量产软件,选择6691,d2量产成功。
量产结果:
---------------- Device 1------------------
MP Tool Version : V2.162
INI File Name : Random
Format Date : 2012-02-29 22:45:18
Flash Part No : Toshiba 3xnm D2 MLC
CE-0, Flash ID=98-D7-94-32-76-55-0C
VID : 0x0C76
PID : 0x0005
Vendor Name = 3SYSTEM
Product Name = USB Flash Disk
Serial Number = 00306730E642F221DE7914DC
Volume Label =
F/W Version : 0xB3
ISP Version : VA1.0F00
Flash R/W Timing : 25ns
Channel : Byte Mode
Homogeneous Mode : On
HID Function : Disable
Planes(F/W) : 2
Pages/Block : 128 pages
Max Current : 100 mA
Total Blocks : 4100
Bad Blocks : 11
Capacity : 7818112 Sectors, 4002873344 Bytes
3909056 KBytes, 3817.44 MBytes, 3.73 GBytes
Device 1:0xB3
MP Version:2.162
INI_File_Name:
Random delay 0 msec
--- Download MP ISP ---
CE-0, Flash ID=98-D7-94-32-76-55-0C-00
Found BACKUP Table (000000BB-0001)
Defect Table (00000200-0004)
Original Bad Block - 0:0x014B
Original Bad Block - 0:0x014D
Original Bad Block - 0:0x019E
Original Bad Block - 0:0x02FB
Original Bad Block - 0:0x02FD
Original Bad Block - 0:0x08E6
Original Bad Block - 0:0x0D8C
Original Bad Block - 0:0x0D8E
Original Bad Block - 0:0x0DB2
Original Bad Block - 0:0x0FD5
Original Bad Block - 0:0x0FF9
Defect Table shows 4089 Good blocks, 11 Bad blocks
SafeErase (0,4100)
Erase failed Block - 0:0:0x014B
Erase failed Block - 0:0:0x014D
Erase failed Block - 0:0:0x019E
Erase failed Block - 0:0:0x02FB
Erase failed Block - 0:0:0x02FD
Erase failed Block - 0:0:0x08E6
Erase failed Block - 0:0:0x0D8C
Erase failed Block - 0:0:0x0D8E
Erase failed Block - 0:0:0x0DB2
Erase failed Block - 0:0:0x0FD5
Erase failed Block - 0:0:0x0FF9
---> Max Bad of Plane (3,3)
---> Max BAD/DIE = 3
Total good blocks after SCAN: 4089 / 4100, Bad block=11
==> 2-Plane mode
Max. Bad Block Allowed = 183(11)
Adjust Max LBA = 7823360, 7823296
MaxWindows=2/1910, MaxLBA=7823296, Size=3819 MB
Max BAD of one plane is 3 (45),4100,1,1
RootSector=0xF4B,Sec/Cluster=32, SuperPage=32 ---> Alignment=21
Boot Block=0x0001,0x0002
Lun0(7823296), Lun1(0), Public=7823296, Secure=0, CDROM=0
Special FE Config = 54-0B-00
Defect Table Block=0x0004
--- Download ISP Code:F:\BACKUP\磁盘工具\U盘量产\6691量产MP_VER2162_ALL\ISP_CODE\6691_B3-A_20100331_VA10F00_9083.BIN---
--- ISP Code installed.
Public,Secure,CDROM = 7823296,0,0
SN=00306730E642F221DE7914DC
=== Preformat Done ===
Low Level Format DONE
Store INI/ERROR MSG to Block-0x0001:79.
Total=7823296,CDROM=0, PublicArea=7823168, SecureArea=0
Create SECURE(CDROM=0,Public=3819 MB,Secure=0 MB)
--- T2 start ---
FW version is: 0xB3
Vendor ID is:0x0C76
Product ID is:0x0005
Vendor=3SYSTEM
Product=USB Flash Disk
Device capacity : 0 > 39116 > 0
DOS Volume=
Device is formatted.
--- T2 is done ---
Total Capacity: 7823296 sectors, 3819 MBytes
Elasped Time = 00:00:24
