  • 9170阅读
  • 17回复
[SandForce]求救下,帮看看开卡的问题出在哪边。 [复制链接]
离线ddk2001
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2014-09-28
开卡失败,焊接放大镜检查过了,没有虚焊  没有短路.SF2281的主控,用的是29f64g08cbaaawp的F,准备先焊4片开个32G的试试看的。一直失败中。配置中,电源保护开了,温度选项选择的TM75的。
下面是开卡的log
Starting command:[/root/soft/SF_Genesis-v1.7.0.01020130612-fc14-32bit/SF_Genesis -PROCESS_SSD 2:0:0:0 "/root/mpt/FW_SF-2000_MP_5-0-7_Client--123456/FW_SF-2000_MP_5-0-7_Client.123456.mfp" "/root/mpt/22454.123456.driveconfig" 2281 2281  LOG="/root/mpt/FW_SF-2000_MP_5-0-7_Client--123456/2281_ddk_DATETIMESTAMP_2.0.0.0_PROCESS_SSD_RESULT.log"   ]...
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Sun 09/28/2014 08:46:05] - SF_Genesis has been invoked with the following parameters:
                      argv[1]: -PROCESS_SSD
                      argv[2]: 2:0:0:0
                      argv[3]: /root/mpt/FW_SF-2000_MP_5-0-7_Client--123456/FW_SF-2000_MP_5-0-7_Client.123456.mfp
                      argv[4]: /root/mpt/22454.123456.driveconfig
                      argv[5]: 2281
                      argv[6]: 2281
                      argv[7]: LOG=/root/mpt/FW_SF-2000_MP_5-0-7_Client--123456/2281_ddk_DATETIMESTAMP_2.0.0.0_PROCESS_SSD_RESULT.log
[Sun 09/28/2014 08:46:05] - Instructing the operating system to purge any existing cached data for device: '2:0:0:0'
[Sun 09/28/2014 08:46:10] - Issuing a discovery command for device: '2:0:0:0'
[Sun 09/28/2014 08:46:16] - Discovery command completed...
[Sun 09/28/2014 08:46:16] - Waiting 5 seconds for the system to settle...
[Sun 09/28/2014 08:46:21] - Device designation string '2:0:0:0' is mapped to node '/dev/sg2'
[Sun 09/28/2014 08:46:21] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg2
    MFP Package Filename = /root/mpt/FW_SF-2000_MP_5-0-7_Client--123456/FW_SF-2000_MP_5-0-7_Client.123456.mfp
      Configuration File = /root/mpt/22454.123456.driveconfig
              Serial No. = 2281
         World Wide Name = 2281
[Sun 09/28/2014 08:46:21] - Successfully received the IDENTIFY data from the drive...
[Sun 09/28/2014 08:46:21] - Validating Manufacturing Firmware Package: /root/mpt/FW_SF-2000_MP_5-0-7_Client--123456/FW_SF-2000_MP_5-0-7_Client.123456.mfp
[Sun 09/28/2014 08:46:29] - Successfully opened the package: /root/mpt/FW_SF-2000_MP_5-0-7_Client--123456/FW_SF-2000_MP_5-0-7_Client.123456.mfp
[Sun 09/28/2014 08:46:29] - file  /root/mpt/22454.123456.driveconfig Loaded successfully
[Sun 09/28/2014 08:46:29] - Warning:  Unable to query diagnostics information to perform power management settings check
[Sun 09/28/2014 08:46:29] - B01 Power Management configuration request detected
[Sun 09/28/2014 08:46:29] - Successfully extracted *.DriveConfig file: /root/mpt/22454.123456.driveconfig
[Sun 09/28/2014 08:46:29] - Extracted Config_ID: 1 (22454) in DriveConfig file: /root/mpt/22454.123456.driveconfig
[Sun 09/28/2014 08:46:29] - Extracted SerialOutputControl: 0
[Sun 09/28/2014 08:46:29] - Searching for flashware image for configuration 22454
[Sun 09/28/2014 08:46:29] - Manifest found for configuration 22454
[Sun 09/28/2014 08:46:29] - Flashware image extracted: 22454_fw_cl_mlc_Micron_64Gb_MT29F64G08CBAAAWP_1Q_1C_1D_PP_R00819_s512.vic
[Sun 09/28/2014 08:46:29] - Searching for manufacturing image for configuration 22454
[Sun 09/28/2014 08:46:29] - Manufacturing image extracted: 22454_mf_mlc_Micron_64Gb_MT29F64G08CBAAAWP_1Q_1C_1D_PP_R00819_s512.vic
[Sun 09/28/2014 08:46:29] - Proceeding in ROM mode, download feature 3...
[Sun 09/28/2014 08:47:35] - FATAL_ERROR: Could not download MFB to the drive...(0x11000001:SF_SG_DEVICE_CHECK_CONDITION_ERROR)
Extended Error data:
          ATA COMMAND : 0x0092  (146)
          ATA FEATURE : 0x0003  (3)
         Device Status: 0x0001  (1)
         Driver Status: 0x0000  (0)
           Host Status: 0x0008  (8)
Sense Data:
  0 -         No Sense: 114 (0x72)    OK
  1 -  Recovered Error:  11 (0x0B)    FAIL
  2 -        Not Ready:   0 (0x00)    OK
  3 -     Medium Error:   0 (0x00)    OK
  4 -   Hardware Error:   0 (0x00)    OK
  5 -  Illegal Request:   0 (0x00)    OK
  6 -   Unit Attention:   0 (0x00)    OK
  7 -     Data Protect:  14 (0x0E)    OK
  8 -      Blank Check:   9 (0x09)    OK
  9 -  Vendor Specific:  12 (0x0C)    OK
10 -     Copy Aborted:   0 (0x00)    OK
11 -  Aborted Command:   0 (0x00)    OK
12 - Equal Comparison:   0 (0x00)    NA
13 -  Volume Overflow:   0 (0x00)    NA
14 -       Miscompare:   0 (0x00)    OK
15 -         Reserved: 128 (0x80)    NA
System Trace:
[  174.460470] ata3.00: failed command: STANDBY IMMEDIATE
[  174.460474] ata3.00: cmd e0/00:00:00:00:00/00:00:00:00:00/a0 tag 0
[  174.460475]          res 51/04:00:00:00:00/00:00:00:00:00/a0 Emask 0x1 (device error)
[  174.460477] ata3.00: status: { DRDY ERR }
[  174.460479] ata3.00: error: { ABRT }
[  174.460485] ata3.00: device reported invalid CHS sector 0
[  174.460495] sd 2:0:0:0: [sdc] START_STOP FAILED
[  174.460497] sd 2:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[  174.460500] sd 2:0:0:0: [sdc] Sense Key : Aborted Command [current] [descriptor]
[  174.460503] sd 2:0:0:0: [sdc] Add. Sense: No additional sense information
[  174.460527] ata3.00: disabled
[  179.462687] ata3: hard resetting link
[  179.918050] ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[  179.918261] ata3.00: ATA-8: SandForce{200026BB}, 20DABBR0, max UDMA/133
[  179.918264] ata3.00: 64 sectors, multi 0: LBA48 NCQ (depth 0/32)
[  179.921244] ata3.00: configured for UDMA/133
[  179.921249] ata3: EH complete
[  179.921323] scsi 2:0:0:0: Direct-Access     ATA      SandForce{200026 20DA PQ: 0 ANSI: 5
[  179.923781] sd 2:0:0:0: Attached scsi generic sg2 type 0
[  179.924822] sd 2:0:0:0: [sdc] 64 512-byte logical blocks: (32.7 kB/32.0 KiB)
[  179.924824] sd 2:0:0:0: [sdc] 4096-byte physical blocks
[  179.924866] sd 2:0:0:0: [sdc] Write Protect is off
[  179.924868] sd 2:0:0:0: [sdc] Mode Sense: 00 3a 00 00
[  179.924887] sd 2:0:0:0: [sdc] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[  179.925490]  sdc: unknown partition table
[  179.931693] sd 2:0:0:0: [sdc] Attached SCSI disk
[  203.712150] ata3.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 frozen
[  203.712154] ata3.00: failed command: DOWNLOAD MICROCODE
[  203.712159] ata3.00: cmd 92/03:66:00:80:01/00:00:00:00:00/00 tag 0 pio 52224 out
[  203.712160]          res 40/00:00:80:00:00/00:00:00:00:00/e0 Emask 0x4 (timeout)
[  203.712162] ata3.00: status: { DRDY }
[  203.712169] ata3: hard resetting link
[  209.217015] ata3: link is slow to respond, please be patient (ready=0)
[  213.756014] ata3: SRST failed (errno=-16)
[  213.756023] ata3: hard resetting link
[  219.261014] ata3: link is slow to respond, please be patient (ready=0)
[  223.800011] ata3: SRST failed (errno=-16)
[  223.800020] ata3: hard resetting link
[  229.305012] ata3: link is slow to respond, please be patient (ready=0)
[  258.834012] ata3: SRST failed (errno=-16)
[  258.834021] ata3: limiting SATA link speed to 1.5 Gbps
[  258.834028] ata3: hard resetting link
[  263.880013] ata3: SRST failed (errno=-16)
[  263.880018] ata3: reset failed, giving up
[  263.880021] ata3.00: disabled
[  263.880039] ata3: EH complete
[Sun 09/28/2014 08:47:35] - End of Genesis manufacturing log.
[Sun 09/28/2014 08:47:35] - Exiting...
[Sun 09/28/2014 08:47:35] - Overall Result for Device: /dev/sg2 ****** FAIL ******
Process exited with code 20
本帖最近打赏记录:共3条打赏M币+16
离线qas999
只看该作者 1楼 发表于: 2014-09-28
本帖最近打赏记录:共1条打赏M币+5
离线ddk2001
只看该作者 2楼 发表于: 2014-09-28
回 qas999 的帖子
本帖最近打赏记录:共2条打赏M币+8
离线emmod
只看该作者 3楼 发表于: 2014-09-28
本帖最近打赏记录:共1条打赏M币+5
离线ddk2001
只看该作者 4楼 发表于: 2014-09-28
回 emmod 的帖子
本帖最近打赏记录:共1条打赏M币+3
离线emmod
只看该作者 5楼 发表于: 2014-09-28
本帖最近打赏记录:共1条打赏M币+5
离线nfy123
只看该作者 6楼 发表于: 2014-09-28
本帖最近打赏记录:共2条打赏M币+8
离线qas999
只看该作者 7楼 发表于: 2014-09-28
本帖最近打赏记录:共1条打赏M币+5
离线ddk2001
只看该作者 8楼 发表于: 2014-09-28
回 qas999 的帖子
本帖最近打赏记录:共1条打赏M币+5
离线ddk2001
只看该作者 9楼 发表于: 2014-09-28
回 nfy123 的帖子
本帖最近打赏记录:共1条打赏M币+5
