  • 10429阅读
  • 16回复
[SandForce]求救,开卡错误,原板开卡成功的,换了F就不行了 [复制链接]
离线huangxunjie
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2014-10-08
以下是日志,看看哪里有问题。
Startingcommand:[/root/soft/SF_Genesis-v1.7.0.01020130612-fc14-32bit/SF_Genesis-PROCESS_SSD 1:0:0:0"/root/mpt/FW_SF-2000_MP_5-0-7_Client--123456/FW_SF-2000_MP_5-0-7_Client.123456.mfp""/root/mpt/22077.123456.driveconfig" 19791123 0LOG="/root/mpt/FW_SF-2000_MP_5-0-7_Client--123456/19791123_localhost.localdomain_DATETIMESTAMP_1.0.0.0_PROCESS_SSD_RESULT.log"]...
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Wed 10/08/2014 10:13:07] - SF_Genesis has been invoked with the followingparameters:
argv[1]: -PROCESS_SSD
argv[2]: 1:0:0:0
argv[3]:/root/mpt/FW_SF-2000_MP_5-0-7_Client--123456/FW_SF-2000_MP_5-0-7_Client.123456.mfp
argv[4]: /root/mpt/22077.123456.driveconfig
argv[5]: 19791123
argv[6]: 0
argv[7]:LOG=/root/mpt/FW_SF-2000_MP_5-0-7_Client--123456/19791123_localhost.localdomain_DATETIMESTAMP_1.0.0.0_PROCESS_SSD_RESULT.log
[Wed 10/08/2014 10:13:07] - Instructing the operating system topurge any existing cached data for device: '1:0:0:0'
[Wed 10/08/2014 10:13:12] - Issuing a discovery command for device:'1:0:0:0'
[Wed 10/08/2014 10:13:18] - Discovery command completed...
[Wed 10/08/2014 10:13:18] - Waiting 5 seconds for the system tosettle...
[Wed 10/08/2014 10:13:23] - Device designation string '1:0:0:0' ismapped to node '/dev/sg1'
[Wed 10/08/2014 10:13:23] - Proceeding to process SSD device withthe following parameters:
DeviceName = /dev/sg1
MFP Package Filename =/root/mpt/FW_SF-2000_MP_5-0-7_Client--123456/FW_SF-2000_MP_5-0-7_Client.123456.mfp
Configuration File = /root/mpt/22077.123456.driveconfig
Serial No. = 19791123
World Wide Name = 0
[Wed 10/08/2014 10:13:23] - Successfully received the IDENTIFY datafrom the drive...
[Wed 10/08/2014 10:13:23] - Validating Manufacturing FirmwarePackage:/root/mpt/FW_SF-2000_MP_5-0-7_Client--123456/FW_SF-2000_MP_5-0-7_Client.123456.mfp
[Wed 10/08/2014 10:13:25] - Successfully opened the package:/root/mpt/FW_SF-2000_MP_5-0-7_Client--123456/FW_SF-2000_MP_5-0-7_Client.123456.mfp
[Wed 10/08/2014 10:13:25] - file /root/mpt/22077.123456.driveconfigLoaded successfully
[Wed 10/08/2014 10:13:25] - Warning: Unable to query diagnosticsinformation to perform power management settings check
[Wed 10/08/2014 10:13:25] - B01 Power Management configurationrequest detected
[Wed 10/08/2014 10:13:25] - Successfully extracted *.DriveConfigfile: /root/mpt/22077.123456.driveconfig
[Wed 10/08/2014 10:13:25] - Extracted Config_ID: 1 (22077) inDriveConfig file: /root/mpt/22077.123456.driveconfig
[Wed 10/08/2014 10:13:25] - Extracted SerialOutputControl: 0
[Wed 10/08/2014 10:13:25] - Searching for flashware image forconfiguration 22077
[Wed 10/08/2014 10:13:25] - Manifest found for configuration 22077
[Wed 10/08/2014 10:13:25] - Flashware image extracted:22077_fw_cl_ccmlc_Intel_64Gb_JS29F32B08JCME2_2Q_4C_1D_PP_R00430_s512.vic
[Wed 10/08/2014 10:13:25] - Searching for manufacturing image forconfiguration 22077
[Wed 10/08/2014 10:13:25] - Manufacturing image extracted:22077_mf_ccmlc_Intel_64Gb_JS29F32B08JCME2_2Q_4C_1D_PP_R00430_s512.vic
[Wed 10/08/2014 10:13:25] - Proceeding in ROM mode, download feature3...
[Wed 10/08/2014 10:14:31] - FATAL_ERROR: Could not download MFB tothe drive...(0x11000001:SF_SG_DEVICE_CHECK_CONDITION_ERROR)
Extended Error data:
ATA COMMAND : 0x0092 (146)
ATA FEATURE : 0x0003 (3)
Device Status: 0x0001 (1)
Driver Status: 0x0000 (0)
Host Status: 0x0008 (8)
Sense Data:
0 - No Sense: 114 (0x72) OK
1 - Recovered Error: 11 (0x0B) FAIL
2 - Not Ready: 0 (0x00) OK
3 - Medium Error: 0 (0x00) OK
4 - Hardware Error: 0 (0x00) OK
5 - Illegal Request: 0 (0x00) OK
6 - Unit Attention: 0 (0x00) OK
7 - Data Protect: 14 (0x0E) OK
8 - Blank Check: 9 (0x09) OK
9 - Vendor Specific: 12 (0x0C) OK
10 - Copy Aborted: 0 (0x00) OK
11 - Aborted Command: 0 (0x00) OK
12 - Equal Comparison: 0 (0x00) NA
13 - Volume Overflow: 0 (0x00) NA
14 - Miscompare: 0 (0x00) OK
15 - Reserved: 128 (0x80) NA
System Trace:
[ 498.785154] sd 1:0:0:0: [sdb]
[ 498.785156] Sense Key : Aborted Command [current] [descriptor]
[ 498.785159] sd 1:0:0:0: [sdb]
[ 498.785161] Add. Sense: No additional sense information
[ 498.785384] ata2.00: disabled
[ 503.788123] ata2: hard resetting link
[ 504.092746] ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 504.092908] ACPI Error: [DSSP] Namespace lookup failure,AE_NOT_FOUND (20130517/psargs-359)
[ 504.092914] ACPI Error: Method parse/execution failed [\_SB_.PCI0.SAT0.SPT1._GTF](Node f3443450), AE_NOT_FOUND (20130517/psparse-536)
[ 504.093752] ata2.00: ATA-8: SandForce{200026BB}, 20DABBR0, maxUDMA/133
[ 504.093756] ata2.00: 64 sectors, multi 0: LBA48 NCQ (depth 31/32),AA
[ 504.097295] ACPI Error: [DSSP] Namespace lookup failure,AE_NOT_FOUND (20130517/psargs-359)
[ 504.097301] ACPI Error: Method parse/execution failed[\_SB_.PCI0.SAT0.SPT1._GTF] (Node f3443450), AE_NOT_FOUND(20130517/psparse-536)
[ 504.099438] ata2.00: configured for UDMA/133
[ 504.099446] ata2: EH complete
[ 504.099538] scsi 1:0:0:0: Direct-Access ATA SandForce{200026 20DAPQ: 0 ANSI: 5
[ 504.099709] sd 1:0:0:0: [sdb] 64 512-byte logical blocks: (32.7kB/32.0 KiB)
[ 504.099712] sd 1:0:0:0: [sdb] 4096-byte physical blocks
[ 504.099758] sd 1:0:0:0: [sdb] Write Protect is off
[ 504.099761] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 504.099782] sd 1:0:0:0: [sdb] Write cache: disabled, read cache:enabled, doesn't support DPO or FUA
[ 504.101709] sd 1:0:0:0: Attached scsi generic sg1 type 0
[ 504.111187] sdb: unknown partition table
[ 504.111421] sd 1:0:0:0: [sdb] Attached SCSI disk
[ 521.995325] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action0x6 frozen
[ 521.995331] ata2.00: failed command: DOWNLOAD MICROCODE
[ 521.995338] ata2.00: cmd 92/03:69:00:80:01/00:00:00:00:00/00 tag 0pio 53760 out
res 40/00:00:80:00:00/00:00:00:00:00/e0 Emask 0x4 (timeout)
[ 521.995349] ata2.00: status: { DRDY }
[ 521.995353] ata2: hard resetting link
[ 527.349137] ata2: link is slow to respond, please be patient(ready=0)
[ 532.041032] ata2: COMRESET failed (errno=-16)
[ 532.041039] ata2: hard resetting link
[ 537.394881] ata2: link is slow to respond, please be patient(ready=0)
[ 542.086759] ata2: COMRESET failed (errno=-16)
[ 542.086766] ata2: hard resetting link
[ 547.440624] ata2: link is slow to respond, please be patient(ready=0)
[ 577.121843] ata2: COMRESET failed (errno=-16)
[ 577.121850] ata2: limiting SATA link speed to 1.5 Gbps
[ 577.121852] ata2: hard resetting link
[ 582.169714] ata2: COMRESET failed (errno=-16)
[ 582.169721] ata2: reset failed, giving up
[ 582.169723] ata2.00: disabled
[ 582.169740] ata2: EH complete
[Wed 10/08/2014 10:14:31] - End of Genesis manufacturing log.
[Wed 10/08/2014 10:14:31] - Exiting...
[Wed 10/08/2014 10:14:31] - Overall Result for Device: /dev/sg1****** FAIL ******Process exited with code 20
本帖最近打赏记录:共1条打赏M币+3
只看该作者 1楼 发表于: 2014-10-08
离线qas999
只看该作者 2楼 发表于: 2014-10-08
本帖最近打赏记录:共5条打赏M币+15
离线青衣侯
只看该作者 3楼 发表于: 2014-10-08
离线john_chuck
只看该作者 4楼 发表于: 2014-10-08
离线huangxunjie
只看该作者 5楼 发表于: 2014-10-08
只看该作者 6楼 发表于: 2014-10-08
本帖最近打赏记录:共1条打赏M币+3
离线john_chuck
只看该作者 7楼 发表于: 2014-10-08
回 huangxunjie 的帖子
离线qas999
只看该作者 8楼 发表于: 2014-10-08
离线chen7610386
只看该作者 9楼 发表于: 2014-10-08
