  • 6281阅读
  • 10回复
[SandForce]SF2281报错Process exited with code 0 [复制链接]
离线chen7610386
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2014-10-08
我贴8片acmf3
Starting command:[/root/soft/SF_Genesis-v1.5.21.20110919-fc14-32bit/SF_Genesis -PROCESS_SSD 2:0:0:0 "/root/fw/FW_SF-2000_MP_5-0-7_Client--12345600/FW_SF-2000_MP_5-0-7_Client.12345600.mfp" "/root/fw/FW_SF-2000_MP_5-0-7_Client--12345600/22373.12345600.driveconfig" 2 2  LOG="/root/fw/FW_SF-2000_MP_5-0-7_Client--12345600/2_localhost.localdomain_DATETIMESTAMP_2.0.0.0_PROCESS_SSD_RESULT.log" ]...
SandForce Genesis Utility v1.5.21.20110919-fc14-32bit
SF_Core Library: v1.7.0.20110919-fc14-32bit
Copyright 2010-2011, SandForce Inc., All Rights Reserved Worldwide.
[Thu 02/17/2011 05:41:31] - SF_Genesis has been invoked with the following parameters:
                      argv[1]: -PROCESS_SSD
                      argv[2]: 2:0:0:0
                      argv[3]: /root/fw/FW_SF-2000_MP_5-0-7_Client--12345600/FW_SF-2000_MP_5-0-7_Client.12345600.mfp
                      argv[4]: /root/fw/FW_SF-2000_MP_5-0-7_Client--12345600/22373.12345600.driveconfig
                      argv[5]: 2
                      argv[6]: 2
                      argv[7]: LOG=/root/fw/FW_SF-2000_MP_5-0-7_Client--12345600/2_localhost.localdomain_DATETIMESTAMP_2.0.0.0_PROCESS_SSD_RESULT.log
[Thu 02/17/2011 05:41:31] - Instructing the operating system to purge any existing cached data for device: '2:0:0:0'
[Thu 02/17/2011 05:41:36] - Issuing a discovery command for device: '2:0:0:0'
[Thu 02/17/2011 05:41:41] - Discovery command completed...
[Thu 02/17/2011 05:41:41] - Waiting 5 seconds for the system to settle...
[Thu 02/17/2011 05:41:46] - Device designation string '2:0:0:0' is mapped to node '/dev/sg0'
[Thu 02/17/2011 05:41:46] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg0
    MFP Package Filename = /root/fw/FW_SF-2000_MP_5-0-7_Client--12345600/FW_SF-2000_MP_5-0-7_Client.12345600.mfp
      Configuration File = /root/fw/FW_SF-2000_MP_5-0-7_Client--12345600/22373.12345600.driveconfig
              Serial No. = 2
         World Wide Name = 2
[Thu 02/17/2011 05:41:46] - Successfully received the IDENTIFY data from the drive...
SF_Internal_PackageManager::OpenExisting:
                     HeaderCRC32: -1161260662,(BAC8918A)
     _Package.Header.HeaderCRC32: -1161260662,(BAC8918A)
                    OverallCRC32:  864041271,(33803937)
    _Package.Header.OverallCRC32:  864041271,(33803937)
本帖最近打赏记录:共1条打赏M币+5
离线chen7610386
只看该作者 1楼 发表于: 2014-10-08
本帖最近打赏记录:共1条打赏M币+5
离线huakun888
只看该作者 2楼 发表于: 2014-10-08
离线549314048
只看该作者 3楼 发表于: 2014-10-08
本帖最近打赏记录:共1条打赏M币+3
离线剧毒
只看该作者 4楼 发表于: 2014-10-09
离线ufoa
只看该作者 5楼 发表于: 2015-01-30
本帖最近打赏记录:共1条打赏M币+3
离线chen7610386
只看该作者 6楼 发表于: 2015-01-30
回 ufoa 的帖子
离线ufoa
只看该作者 7楼 发表于: 2015-01-30
回 chen7610386 的帖子
本帖最近打赏记录:共1条打赏M币+3
离线subwoofer123
只看该作者 8楼 发表于: 2015-01-31
本帖最近打赏记录:共1条打赏M币+3
离线涛娃子
只看该作者 9楼 发表于: 2015-01-31
本帖最近打赏记录:共1条打赏M币+3
