  • 45113阅读
  • 130回复
UT165 MP Tool Release Note-V1.65.19.00 [复制链接]
离线ylp18348
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2009-05-20
— 本帖被 发骚友 从 U盘存储技术 移动到本区(2010-01-29) —
Ver 1.65.1.0
1. First formal release
2. Support Samsung 50nm flash only
Ver 1.65.2.0
1. Fix power cycling 0 issue
2. Update F/W
Ver 1.65.5.0
1. Modify format size of K9LAG08U0A Dual channel.
2. Fix some 2k flash 0x88 issue.
3. Solved Power cycling issue.
4. Solved K9HCG08U1M 16CE MP error.
5. Add no read status function for UT165.
6. Improve Readdy Boost performance for Intel flash 29F16G08AAMC1.
7. Disable cache program function for MLC flash.
8. Close "F10 quicktest" function.
Ver 1.65.6.0
1. Delete "F1"select device UT163 function
Ver 1.65.8.0
1. Fix issue: LED idle mode abnormal after loading ERP file.
2. Add MBR support(Default is no-MBR).
Ver 1.65.10.0
1. Improve Micron Readyboost read Performance.
2. Show smooth progress when reverting flash.
3. Public is allowed to set as 0MB if hidden area exist.
4. Add force single channel, force single plane and force single channel + force single plane.
5. Adjust tolerance for Micron MLC flash.
6. Improve small files copy speed.
7. Improve random write performance.
8. Add No_Read_Status function.
9. Add LED Mode blink function.
10. Fix capacity display error of disk check option .
11. Fix status disaply error when erase blk for >=16GB flash.
12. Solved Toshiba 4D4C Burn-In fail (f/w issue).
13. Toshiba 3D4C force single plane 0X48.
14. Fix ReBuild TBL Option.
Ver 1.65.11.0
1. Fixed: Hynix 27UW08CGFM flash dual channel at UT165 BurnInTest fail.
2. Fixed: Micron 29F64G08TAA Dual MP 0X88.
3. Add: MP tool version in the top of MP tool.
4. Fixed Multi ports MP 0x28 Error.
5. Remove AGAND block from MP tool.
6. Hynix 60nm flash R/W cycle timing 83ns and 66ns firmware bug.
7. Add a new option of disk format  ¨Format as Windows Size〃
8. Add active write image function.
9. 4CE and 2CE dual channel change R/W cycle to 50ns.
10. Fixed NTFS format issue.
11. Fixed force single plane + single channel MP fail Issue.
12. Impreved Power cycling.
13. Improved small files copy speed.
14. Improved flash quick format speed at WinXP.
15. Fixed: security issue for one disk autorun.
Ver 1.65.12.0
F/W
1. Fixed Hynix 83ns copy/compare error.
2. 0X28 error.
3. Fixed small files copy/compare fail under win2k.
4. Improved WinSAT performance.
5. Read only disk login security can not ready issue.
6. Fixed media change error when write-protect was enable.
MP
1. Korean O.S Display issue.
2. Chinese version not completely.
3. Modify bad block tolerance and BinSelect text.
4. Remove ¨F10〃Function.
5. Capacity check add 64GB.
6. Modify R/W Cycle Option .  4CE set to "default timming", 8CE set to 50ns and 16CE set to 66ns.
7. Modify Intel / Micron MLC R/W Cycle time to 30ns.
8. Modify MP tool halt when one of device fail.
9. Add running&erase time in log file for Aristech
10.Fix QFN dialog issue
11. Add HubScan to fix D-link Hub location.
12. Remove usb mode setting function.
13. Remove QFN function.
Ver 1.65.13.0
F/W
1. Support Toshiba 43nm flash.
MP
1. Fixed English/Korea/China OS Display issue.
2. Hynix 48nm will not do erase good blk at normal MP.
3. Modify Intel/Micron 50nm MLC R/W Cycle time to 30ns.
4. Add [Fixed serial number generation] option.
Ver 1.65.14.0
F/W
1. Fixed : Hidden area write speed too slow at WinXP.
2. Fixed : Hynix 60nm flash force single plane security area copy fail . (HY27UV08BG5A Dual / copy small file too slow)
3. Fixed : Hynix 60nm flash force single plane + 100% stress had 0X28 .
4. Fixed : default秨Ч,ぃ暗erase good ノforce single plane秨穦祇ネ锣mode ,UFD穦瞷0X28单拜肈.
5. Add: Support Toshiba TH58NVG6D2ETA20 (F/W=us9.bin)
MP
1. Fixed: MPtool had 0x94 bug.
2. Fixed: Rebuild function fail if import eep file.
3. Fixed: PFC flash MP 0x28 issue.
4. Fixed: Build ISO Image Volume Label 礚猭瞷岿粇.
5. Fixed: maximum devices  20/24/28/32础UFD杆竚穦狡瞷岿粇.
6. Fixed: 更獶杆ヘ魁 erp  Rebuild BAD Block 穦旧璓 hang岿粇.
7. Fixed: Write Image  虫郎禬筁4096MB ( 4GB ) 穦旧璓糶岿粇.
8. Fixed: 虏砰いゅ "腹 ㏕﹚" の "眏︽蛮硄笵" 礚猭陪ボ
9. Fixed: 更 .erp  Security Area Hint, Password 礚猭 Refresh.
10. Add: Display flash ID on the MPtool.
11. Add: Flash Id 8k page 陪ボ".
Ver 1.65.15.0
1. Add: MP tool support native driver (Win2K still need install driver).
2. Add: MP tool can take partial device out without conflict other device.
3. Add: Display "SearchBlk" message in status bar.
4. Add: MP tool add (MP + erase good) option.
5. Add: Support single device MP.
6. Add: Support interleave function, please reference flash support list version 22.
MPTool v1.65.15.77
1. Support OTP function.
Ver 1.65.16.0
[F/W Update]
1. Improved interleave small file performance
[MP Tool Update]
1. Add NTFS format function
Ver 1.65.16.80
[MP Tool Update]
1. 糤杆匡拒 ITE FABULK driver option.
Ver 1.65.17.0
[F/W Update]
1.Fixed: R/W performance unstable issue.
2.Fixed: MPTool display error when ISP find checksum error.
3.Fixed: Samsung K9L8G MP error.
[MP Tool Update]
1.э穝 Revert 祘Α絏
2.祘Α挡睲埃杆竚 Registry
3.穝糤 QFN Monitor
4.穝糤弄 CDROM ずぇ .erp
5.Flash Parameter 穝糤interleave disable 匡兜
6.Improve sorting timing.
7.Fixed: Process is running issue.
8.Logfile 穝糤 Start Date
Ver 1.65.18.0
[F/W Update]
  1.Fixed sorting error 0x58 issue.
  2.Support L63A/B, L62A and Hynix EF-NAND.
  3.Add the "Config Flash" function for special ID.
  4.Enable UT165 A1B.
[MP Tool Update]
  4.俱も代 MP tool .
  5.Enable UT165 A1B.
  6.Add 8K page flash sorting(Toshiba flash).
  7.Fixed preload file error.
  8.Modify QFN monitor function.
  9.Add L62A sorting tool.
10.Format size error when enable bin select.
11.Modify format size.
12.Update re-build function.
13.Add Rebuild+MP+Erase system block,Erase good+MP+Erase system block and RestoreBADBlk+MP in prescan option.
14.Support Toshiba VCI_X2 SLC 8K Page Flash (Flash Parameter select "VCI_X2").
Ver 1.65.19.0
[F/W Update]
    1.Support Hynix 41nm H27UAG8T2A, H27UBG8T2M series
    2.Support Hynix 48nm H2EUBG8M1MYR series
[MP Tool Update]
    1.Add CDROM TOC minutes/seconds/fractions やタ autorun  Mac OS 甧秖弄岿粇
    2.Fixed FAT32 Master Boot Record 0x1C2 System ID  0x06 / 0x0C, э到琘ㄇキ礚猭秨诀
    3.Fixed Product Name error.
    4.Fixed sorting error 0x72 issue.
本帖最近打赏记录:共3条打赏
fassada M币 +9 零分儿最光荣 2018-06-30
有点发烧 专家 +1 以資鼓勵 2018-06-12
离线renxueyi
只看该作者 1楼 发表于: 2009-05-23
离线renxueyi
只看该作者 2楼 发表于: 2009-05-23
离线yanghuigu
只看该作者 3楼 发表于: 2009-05-23
离线cooler88
只看该作者 4楼 发表于: 2009-05-25
离线cooler88
只看该作者 5楼 发表于: 2009-05-25
离线午木
只看该作者 6楼 发表于: 2009-05-25
离线tegl
只看该作者 7楼 发表于: 2009-05-25
离线robin.luo
只看该作者 8楼 发表于: 2009-05-26
离线al1120
只看该作者 9楼 发表于: 2009-05-27
