  • 5304阅读
  • 3回复
Another Reference for restore firmware of MP4 ANYKA Chip [复制链接]
离线okba
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2009-06-22
Hello
severals months ago i posted a problem whit my MP4 iPOD Clone ANYKA Chip.
iPod Video like Model
If this looks like your player, well i have founded. a solution
I extracted the firmware using nothing but my hands.
well lets go to repair your player.
VERY IMPORTANT: some features, like camera, radio will be or not disabled, TRY WHIT THE FIRMWARES PROVIDED FOR OPTIMAL RESULTS,
but remember its better than nothing.
this is what you need in order to repair, to extract see the note below:
* USB cable (named "USB Line" too).
* full charge batery of the player (minimum 10 mins. conected to the power supply )
* Download this firmware.
OR THIS THANKS to LONTU for provifde. (best font, CAMERA, NES games enabled).
and be prepared to do it.
let´s start!
Notice: first your player must be "turn OFF".
OK.
1. Enter the "BIOS"
Firsts Hold MENU and connect the USB cable to the computer and the player.
then release MENU and press "PLAY" quickly.
If you do it well you should see this.
ok then press "REWIND"(left <<|) and "MENU" and "|>>"(right).
you should see this
(NOTE: some versions should see "Pres MENU to format, pres other key to use USB disk, or , not format"
in any case you should format!
Be prepare to lose everything in the player.
OK, if you failed,repeat all procedures, we need this (see image), calm down and everything will be OK, this MP4 player is very related to a computer itself, for that reason its very secure upgrade firmware.
OK Windows will detect it, but one unit will have 16 Mb of storage space, well, copy the following files of the firmware:
AKresData.bin (controllers)
Magic.bin (O.S. itself)
other files are optional.
then Release the player in secure form, restart it, and if you´re lucky, your player will be alive again!
ENJOY!
New Model nGage like
CONFIRMED WORKS!
first you will need
* Fimwares for try compatibles whit this model
One
Two
Three (hight experimental)
* Battery charged its not needed for this model connect the USB cable and press UP, then jump to the step 5.
* USB cable
* Be very prepared for all.
Please use the reference images.
figure 1
figure 2
Ok try this
(Use the Images to reference)
1 Press UP and POWER ... wait a little.
2 Release UP, and POWER
3 Press DOWN (The screen maybe blink, be careful but don´t worry if the player restart, repeat the step 1)
4 Connect the USB Cable
5 press UP and the player will be Formatted automatically in FAT32.
6 Copy the new firmware. (try with all the firmwares.)
7 press RESET
8 Turn on and Hold the POWER button for 3 Seconds
if works please let me know.
thanks for reading
本帖最近打赏记录:共1条打赏
离线saleem
只看该作者 1楼 发表于: 2009-06-22
离线hongson2105
只看该作者 2楼 发表于: 2009-06-22
离线mahmoud
只看该作者 3楼 发表于: 2009-06-23
