  • 3306阅读
  • 11回复
[鑫创]SSS6692  量产报错 Eerror25 [复制链接]
离线98078
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2015-01-07
昨天新买的16G 我拆了主控芯片背面的那片FLASH另作他用,但剩下的这片量产就出错!(不是量产作为启动盘)
试了几个工具都不行
求大神指点!有M币奖励!
先报Error8  我加了ID17=1  又报 错误25
card info 检测结果
---------------- Device 1------------------
CE-1, Flash ID=2C-88-04-4B-A9-00-00
### Error: No found boot block (non-MPed disk)
二  没加ID=17   Report 内容
Device 1:0xB5    MP Version:2.182
    INI_File_Name:6692_IM25_256P_8KB.INI     Random delay 0 msec
    --- Download MP ISP ---    Auto CE: 0xFF 0x01 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF
    CE-1, Flash ID=2C-88-04-4B-A9-00-00-00    Page/Block=256
    Searching SORTING BOARD table ...    --> Not Found
        ---> Max BAD/DIE = 0    Total good blocks after SCAN: 4096 / 4096, Bad block=0
    ==> 2-Plane mode    Max. Bad Block Allowed = 174(0)
    Adjust Max LBA = 15646720, 15646656    MaxWindows=2/1910, MaxLBA=15646656, Size=7639 MB
    Max BAD of one plane is 0 (43),4096,1,1    RootSector=0xF4B,Sec/Cluster=64, SuperPage=64 ---> Alignment=53
    Boot Block=0x0002,0x0004    Lun0(15646656), Lun1(0), Public=15646656, Secure=0, CDROM=0
    Special FE Config = 54-0B-00    Defect Table Block=0x0008
    --- Download ISP Code:C:\USERS\L\DESKTOP\新建文件夹 (2)\6692_IM25_MP_V2182\ISP_CODE\6692_B5-IM_20110214_VB70200_8277.BIN---    --- ISP Code installed.
    Lun0(15646656), Lun1(0), Public=15646656, Secure=0, CDROM=0    Public,Secure,CDROM = 15646656,0,0
    PHY: E2/E4/E6=72h/36h/04h,  D0/C0/CFG10=DFh/0Bh/87h    SN=0015AF000A60FF1072DD202E
    === Preformat Done ===    Low Level Format DONE
    Store INI/ERROR MSG to Block-0x0002:78.    ### Error: Device capacity is 0 bytes
三  加ID=17后
Device 1:0xB5
    MP Version:2.182
    Random delay 0 msec
    Page/Block=256
    --> Not Found
    ==> 2-Plane mode
    MaxWindows=2/-60, MaxLBA=16359424, Size=7988 MB
    Max BAD of one plane is 0 (1028),4096,1,1
    RootSector=0xFF9,Sec/Cluster=64, SuperPage=64 ---> Alignment=7
    Lun0(16359424), Lun1(0), Public=16359424, Secure=0, CDROM=0
    ### Err: Preformat Abort ###
    not enought block for d-block + min_algorithm_need
    ### Error: Low level format failed ###
四    INI内容
[OEM]
PN=6692 + Intel & Micron 25nm Normal Flash (256P,8KB)
Note=6692_B5-IM_20110214_VB70200_8277.BIN
VID=0
PID=0
VENDOR_NAME="3SYSTEM"
PRODUCT_NAME="USB Flash Disk"
STRING_DESC_ENABLE=1
SN_CustomerCode=0x0F
[FEATURE_SETTING]
FLASH_OP="ALL123"
ID35=1
ID17=1
[CDROM]
CDROM_ISO=D:\WinPE.iso
[ISP]
Code=6692_B5-IM_20110214_VB70200_8277.BIN
[LED]
LED_Period=1
LED_DutyCycle=10
[ 此帖被98078在2015-01-07 20:45重新编辑 ]
离线shuishou
只看该作者 1楼 发表于: 2015-01-07
本帖最近打赏记录:共2条打赏M币+6
离线98078
只看该作者 2楼 发表于: 2015-01-07
离线lozy3
只看该作者 3楼 发表于: 2015-01-07
本帖最近打赏记录:共2条打赏M币+5
只看该作者 4楼 发表于: 2015-01-07
Re:SSS6692  量产报错 Eerror25
本帖最近打赏记录:共5条打赏M币+19
离线malonger
只看该作者 5楼 发表于: 2015-01-07
本帖最近打赏记录:共1条打赏M币+2
离线malonger
只看该作者 6楼 发表于: 2015-01-07
本帖最近打赏记录:共1条打赏M币+2
离线98078
只看该作者 7楼 发表于: 2015-01-07
回 malonger 的帖子
离线malonger
只看该作者 8楼 发表于: 2015-01-07
回 98078 的帖子
本帖最近打赏记录:共2条打赏M币+5
离线malonger
只看该作者 9楼 发表于: 2015-01-07
本帖最近打赏记录:共1条打赏M币+3
