- U-Boot 1.1.3 (Dec 19 2014 - 16:57:10)
- Board: Ralink APSoC DRAM: 128 MB
- relocate_code Pointer at: 87fb8000
- enable ephy clock...done. rf reg 29 = 5
- SSC disabled.
- spi_wait_nsec: 29
- spi device id: ef 40 19 0 0 (40190000)
- find flash: W25Q256FV
- raspi_read: from:30000 len:1000
- *** Warning - bad CRC, using default environment
- Ralink UBoot Version: 4.2.1.0
- ASIC 7620_MP (Port5<->None)
- DRAM component: 1024 Mbits DDR, width 16
- DRAM bus: 16 bit
- Total memory: 128 MBytes
- Flash component: SPI Flash
- Date:Dec 19 2014 Time:16:57:10
- icache: sets:512, ways:4, linesz:32 ,total:65536
- dcache: sets:256, ways:4, linesz:32 ,total:32768
- ##### The CPU freq = 580 MHZ ####
- estimate memory size =128 Mbytes
- Please input the operation:
- 0
- 3: System Boot system code via Flash.
- ## Booting image at bc050000 ...
- raspi_read: from:50000 len:40
- Image Name: MIPS OpenWrt Linux-2.6.36
- Image Type: MIPS Linux Kernel Image (lzma compressed)
- Data Size: 1593752 Bytes = 1.5 MB
- Load Address: 80000000
- Entry Point: 80000000
- raspi_read: from:50040 len:185198
- Verifying Checksum ... OK
- Uncompressing Kernel Image ... OK
- No initrd
- ## Transferring control to Linux (at address 80000000) ...
- ## Giving linux memsize in MB, 128
- Starting kernel ...
- LINUX started...
- THIS IS ASIC
- [ 0.000000] Linux version 2.6.36 (yjy@10.10.72.192) (gcc version 4.6.4 (OpenWrt/Linaro GCC 4.6-2013.05 1.1) ) #1 Mon Dec 29 23:39:27 CST 2014
- [ 0.000000]
- [ 0.000000] The CPU feqenuce set to 580 MHz
- [ 0.000000] PCIE: bypass PCIe DLL.
- [ 0.000000] PCIE: Elastic buffer control: Addr:0x68 -> 0xB4
- [ 0.000000] disable all power about PCIe
- [ 0.000000] CPU revision is: 00019650 (MIPS 24Kc)
- [ 0.000000] Software DMA cache coherency
- [ 0.000000] Determined physical RAM map:
- [ 0.000000] memory: 08000000 @ 00000000 (usable)
- [ 0.000000] Initrd not found or empty - disabling initrd
- [ 0.000000] Zone PFN ranges:
- [ 0.000000] Normal 0x00000000 -> 0x00008000
- [ 0.000000] Movable zone start PFN for each node
- [ 0.000000] early_node_map[1] active PFN ranges
- [ 0.000000] 0: 0x00000000 -> 0x00008000
- [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
- [ 0.000000] Kernel command line: console=ttyS1,57600n8 root=/dev/mtdblock5 console=ttyS0 init_debug=99
- [ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
- [ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
- [ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
- [ 0.000000] Primary instruction cache 64kB, VIPT, , 4-waylinesize 32 bytes.
- [ 0.000000] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
- [ 0.000000] Writing ErrCtl register=0001439f
- [ 0.000000] Readback ErrCtl register=0001439f
- [ 0.000000] Memory: 125048k/131072k available (3415k kernel code, 6024k reserved, 981k data, 176k init, 0k highmem)
- [ 0.000000] NR_IRQS:128
- [ 0.000000] console [ttyS1] enabled
- [ 0.008000] Calibrating delay loop... 386.04 BogoMIPS (lpj=772096)
- [ 0.096000] pid_max: default: 32768 minimum: 301
- [ 0.100000] Mount-cache hash table entries: 512
- [ 0.104000] NET: Registered protocol family 16
- [ 0.108000] RALINK_GPIOMODE = 1a311c
- [ 0.112000] RALINK_GPIOMODE = 18311c
- [ 0.116000] PPLL_CFG1=0xea4000
- [ 0.120000] MT7620 PPLL lock
- [ 0.124000] PPLL_DRV =0x80080504
- [ 0.128000] start PCIe register access
- [ 0.628000] RALINK_RSTCTRL = 2400000
- [ 0.632000] RALINK_CLKCFG1 = 75afffc0
- [ 0.636000]
- [ 0.636000] *************** MT7620 PCIe RC mode *************
- [ 1.136000] PCIE0 no card, disable it(RST&CLK)
- [ 1.140000] PCIE0 enabled
- [ 1.144000] init_rt2880pci done
- [ 1.148000] bio: create slab <bio-0> at 0
- [ 1.152000] vgaarb: loaded
- [ 1.156000] SCSI subsystem initialized
- [ 1.160000] usbcore: registered new interface driver usbfs
- [ 1.164000] usbcore: registered new interface driver hub
- [ 1.168000] usbcore: registered new device driver usb
- [ 1.172000] Switching to clocksource MIPS
- [ 1.176000] NET: Registered protocol family 2
- [ 1.184000] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
- [ 1.196000] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
- [ 1.212000] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
- [ 1.224000] TCP: Hash tables configured (established 4096 bind 4096)
- [ 1.236000] TCP reno registered
- [ 1.244000] UDP hash table entries: 256 (order: 0, 4096 bytes)
- [ 1.256000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
- [ 1.268000] NET: Registered protocol family 1
- [ 1.276000] RT3xxx EHCI/OHCI init.
- [ 1.284000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
- [ 1.296000] JFFS2 version 2.2 (NAND) (SUMMARY) (ZLIB) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
- [ 1.316000] fuse init (API version 7.15)
- [ 1.324000] msgmni has been set to 244
- [ 1.332000] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254)
- [ 1.348000] io scheduler noop registered (default)
- [ 1.584000] Ralink gpio driver initialized
- [ 1.592000] Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
- [ 1.604000] serial8250: ttyS0 at MMIO 0x10000500 (irq = 37) is a 16550A
- [ 1.620000] serial8250: ttyS1 at MMIO 0x10000c00 (irq = 12) is a 16550A
- [ 1.636000] brd: module loaded
- [ 1.644000] deice id : ef 40 19 0 0 (40190000)
- [ 1.652000] W25Q256FV(ef 40190000) (32768 Kbytes)
- [ 1.664000] mtd .name = raspi, .size = 0x02000000 (0M) .erasesize = 0x00000020 (0K) .numeraseregions = 65536
- [ 1.680000] Creating 5 MTD partitions on "raspi":
- [ 1.692000] 0x000000000000-0x000002000000 : "ALL"
- [ 1.700000] 0x000000000000-0x000000030000 : "Bootloader"
- [ 1.712000] 0x000000030000-0x000000040000 : "Config"
- [ 1.724000] 0x000000040000-0x000000050000 : "Factory"
- [ 1.736000] 0x000000050000-0x000002000000 : "firmware"
- [ 1.748000] mtd: try split firmware partition
- [ 1.756000] mtd: split_firmware
- [ 1.764000] mtd: firmware_partition->size 0x1fb0000
- [ 1.772000] mtd: firmware_partition->offset 0x50000
- [ 1.784000] mtd: uimage_len 1593816
- [ 1.788000] mtd: rootfs_partition->size 0x1e2ae28
- [ 1.800000] mtd: rootfs_partition->offset 0x1d51d8
- [ 1.808000] mtd: partition "rootfs" created automatically, ofs=1D51D8, len=1E2AE28
- [ 1.824000] 0x0000001d51d8-0x000002000000 : "rootfs"
- [ 1.832000] mtd: partition "rootfs" doesn't start on an erase block boundary -- force read-only
- [ 1.852000] mtd: rootfs_len 7188008
- [ 1.860000] mtd: unused_partition->size 0x1750000
- [ 1.868000] mtd: unused_partition->offset 0x8b0000
- [ 1.880000] mtd: partition "rootfs_data" created automatically, ofs=8B0000, len=1750000
- [ 1.896000] 0x0000008b0000-0x000002000000 : "rootfs_data"
- [ 1.908000] rdm_major = 253
- [ 1.912000] SMACCR1 -- : 0x00005436
- [ 1.920000] SMACCR0 -- : 0x9b000a1e
- [ 1.928000] Ralink APSoC Ethernet Driver Initilization. v3.1 512 rx/tx descriptors allocated, mtu = 1500!
- [ 1.944000] SMACCR1 -- : 0x00005436
- [ 1.952000] SMACCR0 -- : 0x9b000a1e
- [ 1.960000] PROC INIT OK!
- [ 1.964000] $$$$$$ enter:mt7530_probe, dev:0x0.
- [ 1.976000] loaded mt7530 driver!!
- [ 1.980000] PPP generic driver version 2.4.2
- [ 1.992000] PPP MPPE Compression module registered
- [ 2.000000] NET: Registered protocol family 24
- [ 2.008000] PPTP driver version 0.8.5
- [ 2.016000] IMQ driver loaded successfully.
- [ 2.028000] Hooking IMQ after NAT on PREROUTING.
- [ 2.036000] Hooking IMQ before NAT on POSTROUTING.
- [ 2.044000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
- [ 2.080000] rt3xxx-ehci rt3xxx-ehci: Ralink EHCI Host Controller
- [ 2.092000] rt3xxx-ehci rt3xxx-ehci: new USB bus registered, assigned bus number 1
- [ 2.128000] rt3xxx-ehci rt3xxx-ehci: irq 18, io mem 0x101c0000
- [ 2.148000] rt3xxx-ehci rt3xxx-ehci: USB 0.0 started, EHCI 1.00
- [ 2.160000] hub 1-0:1.0: USB hub found
- [ 2.168000] hub 1-0:1.0: 1 port detected
- [ 2.176000] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
- [ 2.208000] rt3xxx-ohci rt3xxx-ohci: RT3xxx OHCI Controller
- [ 2.216000] rt3xxx-ohci rt3xxx-ohci: new USB bus registered, assigned bus number 2
- [ 2.232000] rt3xxx-ohci rt3xxx-ohci: irq 18, io mem 0x101c1000
- [ 2.304000] hub 2-0:1.0: USB hub found
- [ 2.312000] hub 2-0:1.0: 1 port detected
- [ 2.320000] Initializing USB Mass Storage driver...
- [ 2.328000] usbcore: registered new interface driver usb-storage
- [ 2.340000] USB Mass Storage support registered.
- [ 2.348000] MTK MSDC device init.
- [ 2.356000] mtk-sd: MediaTek MT6575 MSDC Driver
- [ 2.364000] nf_conntrack version 0.5.0 (1953 buckets, 7812 max)
- [ 2.376000] IPVS: Registered protocols ()
- [ 2.388000] IPVS: Connection hash table configured (size=4096, memory=32Kbytes)
- [ 2.400000] IPVS: ipvs loaded.
- [ 2.408000] GRE over IPv4 demultiplexor driver
- [ 2.416000] gre: can't add protocol
- [ 2.424000] ip_tables: (C) 2000-2006 Netfilter Core Team, Type=Restricted Cone
- [ 2.436000] TCP cubic registered
- [ 2.444000] NET: Registered protocol family 10
- [ 2.452000] lo: Disabled Privacy Extensions
- [ 2.464000] NET: Registered protocol family 17
- [ 2.472000] L2TP core driver, V2.0
- [ 2.480000] PPPoL2TP kernel driver, V2.0
- [ 2.488000] 802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
- [ 2.500000] All bugs added by David S. Miller <davem@redhat.com>
- [ 2.532000] msdc0 -> ops_get_cd return<1> <- msdc_ops_get_cd() : L<2319> PID<kworker/u:1><0x18>
- [ 2.556000] VFS: Mounted root (squashfs filesystem) readonly on device 31:5.
- [ 2.568000] Freeing unused kernel memory: 176k freed
- [ 2.580000] msdc0 -> ================ <- msdc_set_mclk() : L<688> PID<kworker/u:1><0x18>
- [ 2.596000] msdc0 -> !!! Set<400KHz> Source<48000KHz> -> sclk<400KHz> <- msdc_set_mclk() : L<689> PID<kworker/u:1><0x18>
- [ 2.616000] msdc0 -> ================ <- msdc_set_mclk() : L<690> PID<kworker/u:1><0x18>
- [ 2.740000] msdc0 -> XXX CMD<52> MSDC_INT_CMDTMO <- msdc_irq() : L<2460>
- [ 2.752000] msdc0 -> XXX CMD<52> MSDC_INT_CMDTMO <- msdc_irq() : L<2460>
- [ 2.872000] msdc0 -> XXX CMD<5> MSDC_INT_CMDTMO <- msdc_irq() : L<2460>
- [ 2.888000] msdc0 -> XXX CMD<5> MSDC_INT_CMDTMO <- msdc_irq() : L<2460>
- [ 2.900000] msdc0 -> XXX CMD<5> MSDC_INT_CMDTMO <- msdc_irq() : L<2460>
- [ 2.940000] msdc0 -> XXX CMD<5> MSDC_INT_CMDTMO <- msdc_irq() : L<2460>
- [ 3.324000] msdc0 -> SD data latch edge<1> <- msdc_ops_set_ios() : L<2252> PID<kworker/u:1><0x18>
- [ 3.340000] msdc0 -> ================ <- msdc_set_mclk() : L<688> PID<kworker/u:1><0x18>
- [ 3.356000] msdc0 -> !!! Set<48000KHz> Source<48000KHz> -> sclk<48000KHz> <- msdc_set_mclk() : L<689> PID<kworker/u:1><0x18>
- [ 3.380000] msdc0 -> ================ <- msdc_set_mclk() : L<690> PID<kworker/u:1><0x18>
- [ 3.400000] mmc0: new high speed SDHC card at address aaaa
- [ 3.416000] mmcblk0: mmc0:aaaa SS08G 7.40 GiB
- [ 3.432000] mmcblk0: p1
- Console is alive
- procd: Console is alive
- - skip procd watchdog -
- procd: - skip procd watchdog -
- kmod: ran 1 iterations
- - preinit -
- procd: - preinit -
- procd: procd_preinit(67): Launched preinit instance, pid=35
- [ 5.572000] JFFS2 notice: (51) jffs2_build_xattr_subsystem: complete building xattr subsystem, 24 of xdatum (1 unchecked, 23 orphan) and 45 of xref (0 dead, 34 orphan) found.
- mount_root: jffs2 is ready
- [ 5.780000] JFFS2 notice: (48) jffs2_build_xattr_subsystem: complete building xattr subsystem, 24 of xdatum (1 unchecked, 23 orphan) and 45 of xref (0 dead, 34 orphan) found.
- procd: spawn_procd(40): Exec to real procd now
- - early -
- procd: - early -
- - init -
- procd: - init -
- Please press Enter to activate this console.
- [ 8.288000] NTFS driver 2.1.29 [Flags: R/O MODULE].
- [ 8.392000] ip6_tables: (C) 2000-2006 Netfilter Core Team
- [ 8.520000] Ralink APSoC Hardware Watchdog Timer
- [ 9.684000] mt7620: module license 'unspecified' taints kernel.
- [ 9.696000] Disabling lock debugging due to kernel taint
- [ 10.548000]
- [ 10.548000]
- [ 10.548000] === pAd = c0644000, size = 957232 ===
- [ 10.548000]
- [ 10.564000] <-- RTMPAllocTxRxRingMemory, Status=0
- [ 10.576000] <-- RTMPAllocAdapterBlock, Status=0
- [ 10.584000] AP Driver version-2.7.1.6
- [ 13.552000] xt_time: kernel timezone is -0000
- [ 18.000000] Raeth v3.1 (Tasklet,SkbRecycle)
- [ 18.012000]
- [ 18.012000] phy_tx_ring = 0x06a98000, tx_ring = 0xa6a98000
- [ 18.024000]
- [ 18.024000] phy_rx_ring0 = 0x06a9a000, rx_ring0 = 0xa6a9a000
- [ 18.040000] SMACCR1 -- : 0x00005436
- [ 18.048000] SMACCR0 -- : 0x9b000a1e
- [ 18.056000] CDMA_CSG_CFG = 81000000
- [ 18.060000] GDMA1_FWD_CFG = 20710000
- [ 18.136000] device eth0.1 entered promiscuous mode
- [ 18.148000] device eth0 entered promiscuous mode
- [ 18.172000] br-lan: port 1(eth0.1) entering learning state
- [ 18.184000] br-lan: port 1(eth0.1) entering learning state
- [ 18.228000] device eth0.3 entered promiscuous mode
- [ 18.248000] br-public: port 1(eth0.3) entering learning state
- [ 18.256000] br-public: port 1(eth0.3) entering learning state
- [ 19.136000] ADDRCONF(NETDEV_CHANGE): eth0.3: link becomes ready
- [ 20.188000] br-lan: port 1(eth0.1) entering forwarding state
- [ 20.260000] br-public: port 1(eth0.3) entering forwarding state
- [ 24.516000] RtmpOSNetDevDetach(): RtmpOSNetDeviceDetach(), dev->name=ra0!
- [ 25.456000]
- [ 25.456000]
- [ 25.456000] === pAd = c144e000, size = 957232 ===
- [ 25.456000]
- [ 25.472000] <-- RTMPAllocTxRxRingMemory, Status=0
- [ 25.484000] <-- RTMPAllocAdapterBlock, Status=0
- [ 25.492000] AP Driver version-2.7.1.6
- [ 25.544000] RX DESC a7782000 size = 2048
- [ 25.552000] RTMP_TimerListAdd: add timer obj c14f5a50!
- [ 25.564000] RTMP_TimerListAdd: add timer obj c14b7460!
- [ 25.576000] RTMP_TimerListAdd: add timer obj c14b9cac!
- [ 25.584000] RTMP_TimerListAdd: add timer obj c14b9d6c!
- [ 25.596000] RTMP_TimerListAdd: add timer obj c14b9e2c!
- [ 25.604000] RTMP_TimerListAdd: add timer obj c14b9eec!
- [ 25.616000] RTMP_TimerListAdd: add timer obj c14b9fac!
- [ 25.624000] RTMP_TimerListAdd: add timer obj c14ba06c!
- [ 25.636000] RTMP_TimerListAdd: add timer obj c14ba12c!
- [ 25.648000] RTMP_TimerListAdd: add timer obj c14ba1ec!
- [ 25.656000] RTMP_TimerListAdd: add timer obj c14ba2ac!
- [ 25.668000] RTMP_TimerListAdd: add timer obj c14ba36c!
- [ 25.676000] RTMP_TimerListAdd: add timer obj c14ba42c!
- [ 25.688000] RTMP_TimerListAdd: add timer obj c14ba4ec!
- [ 25.696000] RTMP_TimerListAdd: add timer obj c14ba5ac!
- [ 25.708000] RTMP_TimerListAdd: add timer obj c14ba66c!
- [ 25.716000] RTMP_TimerListAdd: add timer obj c14ba72c!
- [ 25.728000] RTMP_TimerListAdd: add timer obj c14ba7ec!
- [ 25.740000] RTMP_TimerListAdd: add timer obj c14b7434!
- [ 25.748000] RTMP_TimerListAdd: add timer obj c14b9c80!
- [ 25.760000] RTMP_TimerListAdd: add timer obj c14b9d40!
- [ 25.768000] RTMP_TimerListAdd: add timer obj c14b9e00!
- [ 25.780000] RTMP_TimerListAdd: add timer obj c14b9ec0!
- [ 25.788000] RTMP_TimerListAdd: add timer obj c14b9f80!
- [ 25.800000] RTMP_TimerListAdd: add timer obj c14ba040!
- [ 25.808000] RTMP_TimerListAdd: add timer obj c14ba100!
- [ 25.820000] RTMP_TimerListAdd: add timer obj c14ba1c0!
- [ 25.832000] RTMP_TimerListAdd: add timer obj c14ba280!
- [ 25.840000] RTMP_TimerListAdd: add timer obj c14ba340!
- [ 25.852000] RTMP_TimerListAdd: add timer obj c14ba400!
- [ 25.860000] RTMP_TimerListAdd: add timer obj c14ba4c0!
- [ 25.872000] RTMP_TimerListAdd: add timer obj c14ba580!
- [ 25.880000] RTMP_TimerListAdd: add timer obj c14ba640!
- [ 25.892000] RTMP_TimerListAdd: add timer obj c14ba700!
- [ 25.904000] RTMP_TimerListAdd: add timer obj c14ba7c0!
- [ 25.912000] RTMP_TimerListAdd: add timer obj c14b7408!
- [ 25.924000] RTMP_TimerListAdd: add timer obj c14b9cd8!
- [ 25.932000] RTMP_TimerListAdd: add timer obj c14b9d98!
- [ 25.944000] RTMP_TimerListAdd: add timer obj c14b9e58!
- [ 25.952000] RTMP_TimerListAdd: add timer obj c14b9f18!
- [ 25.964000] RTMP_TimerListAdd: add timer obj c14b9fd8!
- [ 25.972000] RTMP_TimerListAdd: add timer obj c14ba098!
- [ 25.984000] RTMP_TimerListAdd: add timer obj c14ba158!
- [ 25.996000] RTMP_TimerListAdd: add timer obj c14ba218!
- [ 26.004000] RTMP_TimerListAdd: add timer obj c14ba2d8!
- [ 26.016000] RTMP_TimerListAdd: add timer obj c14ba398!
- [ 26.024000] RTMP_TimerListAdd: add timer obj c14ba458!
- [ 26.036000] RTMP_TimerListAdd: add timer obj c14ba518!
- [ 26.044000] RTMP_TimerListAdd: add timer obj c14ba5d8!
- [ 26.056000] RTMP_TimerListAdd: add timer obj c14ba698!
- [ 26.068000] RTMP_TimerListAdd: add timer obj c14ba758!
- [ 26.076000] RTMP_TimerListAdd: add timer obj c14ba818!
- [ 26.088000] RTMP_TimerListAdd: add timer obj c14560d4!
- [ 26.096000] RTMP_TimerListAdd: add timer obj c1455cc8!
- [ 26.108000] RTMP_TimerListAdd: add timer obj c14560a4!
- [ 26.116000] RTMP_TimerListAdd: add timer obj c145644c!
- [ 26.128000] RTMP_TimerListAdd: add timer obj c145619c!
- [ 26.136000] RTMP_TimerListAdd: add timer obj c14561cc!
- [ 26.148000] RTMP_TimerListAdd: add timer obj c145638c!
- [ 26.160000] RTMP_TimerListAdd: add timer obj c14563bc!
- [ 26.168000] RTMP_TimerListAdd: add timer obj c1459350!
- [ 26.180000] RTMP_TimerListAdd: add timer obj c1458f44!
- [ 26.188000] RTMP_TimerListAdd: add timer obj c1459320!
- [ 26.200000] RTMP_TimerListAdd: add timer obj c14596c8!
- [ 26.208000] RTMP_TimerListAdd: add timer obj c1459418!
- [ 26.220000] RTMP_TimerListAdd: add timer obj c1459448!
- [ 26.232000] RTMP_TimerListAdd: add timer obj c1459608!
- [ 26.240000] RTMP_TimerListAdd: add timer obj c1459638!
- [ 26.252000] RTMP_TimerListAdd: add timer obj c145c5cc!
- [ 26.260000] RTMP_TimerListAdd: add timer obj c145c1c0!
- [ 26.272000] RTMP_TimerListAdd: add timer obj c145c59c!
- [ 26.280000] RTMP_TimerListAdd: add timer obj c145c944!
- [ 26.292000] RTMP_TimerListAdd: add timer obj c145c694!
- [ 26.300000] RTMP_TimerListAdd: add timer obj c145c6c4!
- [ 26.312000] RTMP_TimerListAdd: add timer obj c145c884!
- [ 26.324000] RTMP_TimerListAdd: add timer obj c145c8b4!
- [ 26.332000] RTMP_TimerListAdd: add timer obj c145f848!
- [ 26.344000] RTMP_TimerListAdd: add timer obj c145f43c!
- [ 26.352000] RTMP_TimerListAdd: add timer obj c145f818!
- [ 26.364000] RTMP_TimerListAdd: add timer obj c145fbc0!
- [ 26.372000] RTMP_TimerListAdd: add timer obj c145f910!
- [ 26.384000] RTMP_TimerListAdd: add timer obj c145f940!
- [ 26.396000] RTMP_TimerListAdd: add timer obj c145fb00!
- [ 26.404000] RTMP_TimerListAdd: add timer obj c145fb30!
- [ 26.416000] RTMP_TimerListAdd: add timer obj c1462ac4!
- [ 26.424000] RTMP_TimerListAdd: add timer obj c14626b8!
- [ 26.436000] RTMP_TimerListAdd: add timer obj c1462a94!
- [ 26.444000] RTMP_TimerListAdd: add timer obj c1462e3c!
- [ 26.456000] RTMP_TimerListAdd: add timer obj c1462b8c!
- [ 26.464000] RTMP_TimerListAdd: add timer obj c1462bbc!
- [ 26.476000] RTMP_TimerListAdd: add timer obj c1462d7c!
- [ 26.488000] RTMP_TimerListAdd: add timer obj c1462dac!
- [ 26.496000] RTMP_TimerListAdd: add timer obj c1465d40!
- [ 26.508000] RTMP_TimerListAdd: add timer obj c1465934!
- [ 26.516000] RTMP_TimerListAdd: add timer obj c1465d10!
- [ 26.528000] RTMP_TimerListAdd: add timer obj c14660b8!
- [ 26.536000] RTMP_TimerListAdd: add timer obj c1465e08!
- [ 26.548000] RTMP_TimerListAdd: add timer obj c1465e38!
- [ 26.556000] RTMP_TimerListAdd: add timer obj c1465ff8!
- [ 26.568000] RTMP_TimerListAdd: add timer obj c1466028!
- [ 26.580000] RTMP_TimerListAdd: add timer obj c1468fbc!
- [ 26.588000] RTMP_TimerListAdd: add timer obj c1468bb0!
- [ 26.600000] RTMP_TimerListAdd: add timer obj c1468f8c!
- [ 26.608000] RTMP_TimerListAdd: add timer obj c1469334!
- [ 26.620000] RTMP_TimerListAdd: add timer obj c1469084!
- [ 26.628000] RTMP_TimerListAdd: add timer obj c14690b4!
- [ 26.640000] RTMP_TimerListAdd: add timer obj c1469274!
- [ 26.652000] RTMP_TimerListAdd: add timer obj c14692a4!
- [ 26.660000] RTMP_TimerListAdd: add timer obj c146c238!
- [ 26.672000] RTMP_TimerListAdd: add timer obj c146be2c!
- [ 26.680000] RTMP_TimerListAdd: add timer obj c146c208!
- [ 26.692000] RTMP_TimerListAdd: add timer obj c146c5b0!
- [ 26.700000] RTMP_TimerListAdd: add timer obj c146c300!
- [ 26.712000] RTMP_TimerListAdd: add timer obj c146c330!
- [ 26.720000] RTMP_TimerListAdd: add timer obj c146c4f0!
- [ 26.732000] RTMP_TimerListAdd: add timer obj c146c520!
- [ 26.744000] RTMP_TimerListAdd: add timer obj c14b9864!
- [ 26.752000] RTMP_TimerListAdd: add timer obj c14b9458!
- [ 26.764000] RTMP_TimerListAdd: add timer obj c14b9834!
- [ 26.772000] RTMP_TimerListAdd: add timer obj c14b9bdc!
- [ 26.784000] RTMP_TimerListAdd: add timer obj c14b992c!
- [ 26.792000] RTMP_TimerListAdd: add timer obj c14b995c!
- [ 26.804000] RTMP_TimerListAdd: add timer obj c14b9894!
- [ 26.816000] RTMP_TimerListAdd: add timer obj c14b98c4!
- [ 26.824000] RTMP_TimerListAdd: add timer obj c14b98f4!
- [ 26.836000] RTMP_TimerListAdd: add timer obj c14c43bc!
- [ 26.844000] RTMP_TimerListAdd: add timer obj c14c44d8!
- [ 26.856000] RTMP_TimerListAdd: add timer obj c14c43e8!
- [ 26.864000] RTMP_TimerListAdd: add timer obj c14bb9ac!
- [ 26.876000] RTMP_TimerListAdd: add timer obj c1453594!
- [ 26.888000] RTMP_TimerListAdd: add timer obj c1456810!
- [ 26.896000] RTMP_TimerListAdd: add timer obj c1459a8c!
- [ 26.908000] RTMP_TimerListAdd: add timer obj c145cd08!
- [ 26.920000] RTMP_TimerListAdd: add timer obj c145ff84!
- [ 26.928000] RTMP_TimerListAdd: add timer obj c1463200!
- [ 26.940000] RTMP_TimerListAdd: add timer obj c146647c!
- [ 26.948000] RTMP_TimerListAdd: add timer obj c14696f8!
- [ 26.960000] RTMP_TimerListAdd: add timer obj c14bb6b0!
- [ 27.112000] APSDCapable[0]=1
- [ 27.120000] APSDCapable[1]=1
- [ 27.124000] APSDCapable[2]=1
- [ 27.132000] APSDCapable[3]=1
- [ 27.136000] APSDCapable[4]=1
- [ 27.144000] APSDCapable[5]=1
- [ 27.148000] APSDCapable[6]=1
- [ 27.156000] APSDCapable[7]=1
- [ 27.160000] APSDCapable[8]=1
- [ 27.164000] APSDCapable[9]=1
- [ 27.172000] APSDCapable[10]=1
- [ 27.176000] APSDCapable[11]=1
- [ 27.184000] APSDCapable[12]=1
- [ 27.188000] APSDCapable[13]=1
- [ 27.196000] APSDCapable[14]=1
- [ 27.200000] APSDCapable[15]=1
- [ 27.208000] default ApCliAPSDCapable[0]=1
- [ 27.404000] Key1Str is Invalid key length(0) or Type(0)
- [ 27.416000] Key2Str is Invalid key length(0) or Type(0)
- [ 27.428000] Key3Str is Invalid key length(0) or Type(0)
- [ 27.440000] Key4Str is Invalid key length(0) or Type(0)
- [ 27.476000] 1. Phy Mode = 9
- [ 27.484000] 2. Phy Mode = 9
- [ 27.488000] E2PROM: D0 target power=0xff20
- [ 27.496000] E2PROM: 40 MW Power Delta= 0
- [ 27.504000] 3. Phy Mode = 9
- [ 27.512000] RTMP_TimerListAdd: add timer obj c1453148!
- [ 27.520000] AntCfgInit: primary/secondary ant 0/1
- [ 27.520000] Initialize RF Central Registers for E2 !!!
- [ 27.540000] Initialize RF Central Registers for E3 !!!
- [ 27.552000] Initialize RF Channel Registers for E2 !!!
- [ 27.560000] Initialize RF Channel Registers for E3 !!!
- [ 27.572000] Initialize RF DCCal Registers for E2 !!!
- [ 27.584000] Initialize RF DCCal Registers for E3 !!!
- [ 27.592000] D1 = -1, D2 = 11, CalCode = 28 !!!
- [ 27.604000] RT6352_Temperature_Init : BBPR49 = 0xffffffff
- [ 27.616000] RT6352_Temperature_Init : TemperatureRef25C = 0xfffffff5
- [ 27.628000] Current Temperature from BBP_R49=0xffffffea
- [ 27.640000] TX BW Filter Calibration !!!
- [ 27.760000] RX BW Filter Calibration !!!
- [ 27.992000] LOFT Calibration Done!
- [ 28.000000] IQCalibration Start!
- [ 28.020000] IQCalibration Done! CH = 0, (gain= 0, phase= 1)
- [ 28.032000] IQCalibration Start!
- [ 28.048000] IQCalibration Done! CH = 1, (gain= 0, phase=3f)
- [ 28.060000] TX IQ Calibration Done!
- [ 28.100000] RXIQ Sigma_i=965, Sigma_q=976, R_iq=-2240
- [ 28.108000] RXIQ calibration FAIL
- [ 28.116000] Change as Normal Mode(0x4171d)
- [ 28.128000] After Change, now GPIO_MODE value is 0x4171d
- [ 28.136000] internal ALC is not enabled in NVM !
- [ 28.144000] RTMPSetPhyMode: channel is out of range, use first channel=0
- [ 28.160000] MCS Set = ff ff 00 00 01
- [ 28.200000] SYNC - BBP R4 to 20MHz.l
- [ 30.808000] RTMP_TimerListAdd: add timer obj c14bbc94!
- [ 31.044000] The 2-BSSID mode is enabled, the BSSID byte5 MUST be the multiple of 2
- [ 31.060000] Main bssid = 54:36:9b:00:0a:1f
- [ 31.068000] <==== rt28xx_init, Status=0
- [ 31.076000] 0x1300 = 00064320
- [ 31.612000] The 2-BSSID mode is enabled, the BSSID byte5 MUST be the multiple of 2
- [ 32.232000] device ra0 entered promiscuous mode
- [ 32.244000] br-lan: port 2(ra0) entering learning state
- [ 32.252000] br-lan: port 2(ra0) entering learning state
- [ 32.444000] phy 1, reg 0, val 0x3300
- [ 32.456000] phy 0, reg 0, val 0x3300
- [ 32.480000] Ralink HW NAT Module Start!
- [ 32.492000] Ralink HW NAT Module Enabled!
- [ 34.256000] br-lan: port 2(ra0) entering forwarding state
- [ 60.952000] FAT: utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
- procd: - init complete -
- [ 64.476000] switch register base addr to system register 0xb0000000
- [ 64.568000] write offset 0x60, value 0x4171d
- [ 64.684000] switch register base addr to system register 0xb0000000
- [ 64.704000] write offset 0x60, value 0x4171d
- [ 64.960000] switch register base addr to system register 0xb0000000
- [ 64.988000] write offset 0x60, value 0x4171d
- [ 65.264000] led=35, on=1, off=4000, blinks,=1, reset=1, time=4000
- [ 70.468000] Started WatchDog Timer.
- [ 70.472000] before SetWdgResetPeriod(0xb0000038,1024), reg = 0xc0030000
- [ 70.488000] after SetWdgResetPeriod(0xb0000038,1024), reg = 0xc4000000
数码相机数据线找不到了,尼玛先贴个TTL启动信息吧!
