  • 5005阅读
  • 10回复
[SandForce]SF2141想重新卡开下,开到71%报错 [复制链接]
离线xitianming
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2015-01-20
想重新开下5.2.2固件,选择20016配置文件,刷新时候出现如下错误。我卡开的时候没用强制跳线开机自动识别的,是否需要强制跳线才行
另外强制跳线是不是左上角2个点?
最新消息,接短跳线后可以开卡,但是到71%的时候报错。。。。
贴LOG文件
Starting command:[/root/soft/SF_Genesis-v1.7.0.01020130612-fc14-32bit/SF_Genesis -PROCESS_SSD 2:0:1:0 "/root/mpt/FW_PPRO_5_2_2_Release.672199.release--123456/FW_PPRO_5_2_2_Release.672199.release.123456.mfp" "/root/mpt/FW_PPRO_5_2_2_Release.672199.release--123456/20016.123456.driveconfig" 150303192AF6 0  LOG="/root/mpt/FW_PPRO_5_2_2_Release.672199.release--123456/150303192AF6_localhost.localdomain_DATETIMESTAMP_2.0.1.0_PROCESS_SSD_RESULT.log"   ]...~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Wed 01/21/2015 00:26:05] - SF_Genesis has been invoked with the following parameters:
                      argv[1]: -PROCESS_SSD
                      argv[2]: 2:0:1:0
                      argv[3]: /root/mpt/FW_PPRO_5_2_2_Release.672199.release--123456/FW_PPRO_5_2_2_Release.672199.release.123456.mfp
                      argv[4]: /root/mpt/FW_PPRO_5_2_2_Release.672199.release--123456/20016.123456.driveconfig
                      argv[5]: 150303192AF6
                      argv[6]: 0
                      argv[7]: LOG=/root/mpt/FW_PPRO_5_2_2_Release.672199.release--123456/150303192AF6_localhost.localdomain_DATETIMESTAMP_2.0.1.0_PROCESS_SSD_RESULT.log
[Wed 01/21/2015 00:26:05] - Instructing the operating system to purge any existing cached data for device: '2:0:1:0'
[Wed 01/21/2015 00:26:10] - Issuing a discovery command for device: '2:0:1:0'
[Wed 01/21/2015 00:26:15] - Discovery command completed...
[Wed 01/21/2015 00:26:15] - Waiting 5 seconds for the system to settle...
[Wed 01/21/2015 00:26:20] - Device designation string '2:0:1:0' is mapped to node '/dev/sg1'
[Wed 01/21/2015 00:26:20] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg1
    MFP Package Filename = /root/mpt/FW_PPRO_5_2_2_Release.672199.release--123456/FW_PPRO_5_2_2_Release.672199.release.123456.mfp
      Configuration File = /root/mpt/FW_PPRO_5_2_2_Release.672199.release--123456/20016.123456.driveconfig
              Serial No. = 150303192AF6
         World Wide Name = 0
[Wed 01/21/2015 00:26:20] - Successfully received the IDENTIFY data from the drive...
[Wed 01/21/2015 00:26:20] - Validating Manufacturing Firmware Package: /root/mpt/FW_PPRO_5_2_2_Release.672199.release--123456/FW_PPRO_5_2_2_Release.672199.release.123456.mfp
[Wed 01/21/2015 00:26:24] - Successfully opened the package: /root/mpt/FW_PPRO_5_2_2_Release.672199.release--123456/FW_PPRO_5_2_2_Release.672199.release.123456.mfp
[Wed 01/21/2015 00:26:24] - file  /root/mpt/FW_PPRO_5_2_2_Release.672199.release--123456/20016.123456.driveconfig Loaded successfully
[Wed 01/21/2015 00:26:24] - Warning:  Unable to query diagnostics information to perform power management settings check
[Wed 01/21/2015 00:26:24] - B01 Power Management configuration request detected
[Wed 01/21/2015 00:26:24] - Successfully extracted *.DriveConfig file: /root/mpt/FW_PPRO_5_2_2_Release.672199.release--123456/20016.123456.driveconfig
[Wed 01/21/2015 00:26:24] - Extracted Config_ID: 1 (20016) in DriveConfig file: /root/mpt/FW_PPRO_5_2_2_Release.672199.release--123456/20016.123456.driveconfig
[Wed 01/21/2015 00:26:24] - Extracted SerialOutputControl: 0
[Wed 01/21/2015 00:26:24] - Searching for flashware image for configuration 20016
[Wed 01/21/2015 00:26:24] - Manifest found for configuration 20016
[Wed 01/21/2015 00:26:24] - Flashware image extracted: 20016_fw_cl_mlc_Micron_64Gb_MT29F64G08CBCABH1_1Q_2C_1D_PP_R00435_s512.vic
[Wed 01/21/2015 00:26:24] - Searching for manufacturing image for configuration 20016
[Wed 01/21/2015 00:26:24] - Manufacturing image extracted: 20016_mf_mlc_Micron_64Gb_MT29F64G08CBCABH1_1Q_2C_1D_PP_R00435_s512.vic
[Wed 01/21/2015 00:26:24] - Proceeding in ROM mode, download feature 3...
[Wed 01/21/2015 00:26:25] - Successfully downloaded MFB to the drive...
[Wed 01/21/2015 00:26:25] - Waiting (5 sec) for the drive to settle...
[Wed 01/21/2015 00:26:30] - Successfully received the IDENTIFY data from the drive...
[Wed 01/21/2015 00:26:30] - Firmware revision reported to be: '522ABBM0'.  This indicates MFB download was successful.
[Wed 01/21/2015 00:26:30] - Successfully enabled SMART capabilities...
[Wed 01/21/2015 00:26:32] - Successfully issued a diagnostic unlock...
[Wed 01/21/2015 00:26:33] - Performing the flash test of block 0 (0x0000)...
[Wed 01/21/2015 00:26:34] - Flash Test Results:
Flash Test Parameters:
               Block Count: 0
                Page Count: 1
                 Bus Count: 1
        Chip Enabled Count: 2
                 Die Count: 1
                Lane Count: 4
               Plane Count: 2
Results Notes:
   N1 - At least one page tested and passed with no bit errors.
   N2 - No test data available.  Test may have aborted, or failed during the testing.
   N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
   N4 - At least  one erased page tested had bit error rate greater than half the correction power.
   N5 - Walking zeros test failed.
   N6 - Walking ones test failed.
   N7 - Block contained factory bad block markings and testing was skipped.
   N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
   N9 - Block in plane 0 was marked as a factory bad block.
  N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
  N11 - Block in plane 1 was marked as a factory bad block.
| Bus  | CE   | Die  | Lane | Value  | Result Notes                               | Overall |
| 0    | 0    | 0    | 0    | 0x0002 | N3                                         | WARNING |
| 0    | 0    | 0    | 1    | 0x0042 | N3,N6                                      | WARNING |
| 0    | 0    | 0    | 2    | 0x0002 | N3                                         | WARNING |
| 0    | 0    | 0    | 3    | 0x0002 | N3                                         | WARNING |
| 0    | 1    | 0    | 0    | 0x0002 | N3                                         | WARNING |
| 0    | 1    | 0    | 1    | 0x0002 | N3                                         | WARNING |
| 0    | 1    | 0    | 2    | 0x0002 | N3                                         | WARNING |
| 0    | 1    | 0    | 3    | 0x0002 | N3                                         | WARNING |
  Total Number of test results: 8
            Number of failures: 0
         Number of Passed with warnings: 8
      No. Passed without warnings: 0
[Wed 01/21/2015 00:26:34] - Performing the FORMAT Command with the following parameters:
         MemoryWearCycleCapability = 0
              CurrentPE_CycleCount = 0
                     LifeInSeconds = 0
                   LogicalCapacity = 125045424
                        SectorSize = 512
             SectorAlignmentOffset = 0
                  ExpectedMemoryID = 34860 (0x882C)
                   ExpectedNumDies = 0
               SerialOutputControl = 0
                           Time[8] = 0x0000000000000000
            MiscFlag_Erase_R_Block = 0
     MiscFlag_PanicHandlingEnabled = 0
        MiscFlag_PanicOnSATA_Error = 0
  MiscFlag_WriteThrottlingTestMode = 0
      MiscFlag_DisableUserBandECCX = 1
                        L_PageSize = 0
                        E_PageSize = 0
              ErrorCorrectionPower = 0
      ConfigDeviceReadDisturbCount = 0
   ConfigDeviceReadDisturbCountLow = 0
                  ExtraOptions_0_1 = 0
[Wed 01/21/2015 00:26:52] - FATAL_ERROR: Could not perform the FORMAT() operation on the drive... (0x0000C048:SF_SCT (C048h): Root Creation Failed (MFB format))
[Wed 01/21/2015 00:26:52] - End of Genesis manufacturing log.
[Wed 01/21/2015 00:26:52] - Exiting...
[Wed 01/21/2015 00:26:52] - Overall Result for Device: /dev/sg1 ****** FAIL ******
Process exited with code 8
[ 此帖被xitianming在2015-01-21 00:35重新编辑 ]
本帖最近打赏记录:共2条打赏M币+6
离线如影如梦
只看该作者 1楼 发表于: 2015-01-20
本帖最近打赏记录:共3条打赏M币+9
离线spyke
只看该作者 2楼 发表于: 2015-01-20
本帖最近打赏记录:共2条打赏M币+6
离线guoke1930
只看该作者 3楼 发表于: 2015-01-20
离线xitianming
只看该作者 4楼 发表于: 2015-01-20
回 如影如梦 的帖子
离线xitianming
只看该作者 5楼 发表于: 2015-01-21
离线huakun888
只看该作者 6楼 发表于: 2015-01-21
回 xitianming 的帖子
本帖最近打赏记录:共3条打赏M币+9
离线xitianming
只看该作者 7楼 发表于: 2015-01-21
回 huakun888 的帖子
离线hepcboy
只看该作者 8楼 发表于: 2015-01-21
本帖最近打赏记录:共2条打赏M币+8
离线xitianming
只看该作者 9楼 发表于: 2015-01-21
回 hepcboy 的帖子
