  • 2480阅读
  • 6回复
[鑫创]一个老U盘 SSS6692-B5 [复制链接]
离线wjw0080
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2015-01-21
Device 1:0xB5
MP Version:2.182
INI_File_Name:6692_Toshiba 32nm D2 Flash.INI
Random delay 0 msec
--- Download MP ISP ---
### No support [SCAN_RDY_BSY-0xFF 0x30] !
CE-0, Flash ID=98-D7-94-32-76-55-0D-00
Found BACKUP Table (000000BB-0001)
Defect Table (00000200-0004)
  Original Bad Block - 0:0x0000
  Original Bad Block - 0:0x0268
  Original Bad Block - 0:0x0427
  Original Bad Block - 0:0x058D
  Original Bad Block - 0:0x0591
  Original Bad Block - 0:0x0597
  Original Bad Block - 0:0x0620
  Original Bad Block - 0:0x0680
  Original Bad Block - 0:0x0684
  Original Bad Block - 0:0x0798
  Original Bad Block - 0:0x079A
  Original Bad Block - 0:0x08D5
  Original Bad Block - 0:0x0AB4
  Original Bad Block - 0:0x0AB6
  Original Bad Block - 0:0x0AD5
  Original Bad Block - 0:0x0AD7
  Original Bad Block - 0:0x0E72
  Original Bad Block - 0:0x0EED
  Original Bad Block - 0:0x0FAD
Defect Table shows 4081 Good blocks, 19 Bad blocks
SafeErase (0,4100)
  Erase failed Block - 0:0:0x0000
  Erase failed Block - 0:0:0x0268
  Erase failed Block - 0:0:0x0427
  Erase failed Block - 0:0:0x058D
  Erase failed Block - 0:0:0x0591
  Erase failed Block - 0:0:0x0597
  Erase failed Block - 0:0:0x0620
  Erase failed Block - 0:0:0x0680
  Erase failed Block - 0:0:0x0684
  Erase failed Block - 0:0:0x0798
  Erase failed Block - 0:0:0x079A
  Erase failed Block - 0:0:0x08D5
  Erase failed Block - 0:0:0x0AB4
  Erase failed Block - 0:0:0x0AB6
  Erase failed Block - 0:0:0x0AD5
  Erase failed Block - 0:0:0x0AD7
  Erase failed Block - 0:0:0x0E72
  Erase failed Block - 0:0:0x0EED
  Erase failed Block - 0:0:0x0FAD
  ---> Max Bad of Plane (5,5)
  ---> Max BAD/DIE = 5
Total good blocks after SCAN: 4081 / 4100, Bad block=19
==> 2-Plane mode
Max. Bad Block Allowed = 183(19)
Adjust Max LBA = 7823360, 7823296
MaxWindows=2/1910, MaxLBA=7823296, Size=3819 MB
Max BAD of one plane is 5 (45),4100,1,1
RootSector=0xBF5,Sec/Cluster=32, SuperPage=32 ---> Alignment=11
Boot Block=0x0001,0x0002
Lun0(6074788), Lun1(1748508), Public=6074788, Secure=0, CDROM=1748508
Special FE Config = 56-0B-00
Defect Table Block=0x0004
--- Download ISP Code:D:\1\ISP_CODE\6692_B5-A_20100916_VB10000_63E2.BIN---
--- ISP Code installed.
Public,Secure,CDROM = 6074788,0,1748508
PHY: E2/E4/E6=72h/36h/04h,  D0/C0/CFG10=DFh/0Bh/87h
SN=406186CF6BD3FF115302202F
=== Preformat Done ===
Low Level Format DONE
Store INI/ERROR MSG to Block-0x0001:79.
CDROM image:D:\1\1.iso
Total=7823296,CDROM=1748508, PublicArea=6074660, SecureArea=0
Create SECURE(CDROM=1,Public=2966 MB,Secure=0 MB)
DOS check fail- LBA(0x00000059): 014A=00,F6
### Err: SECURE failed(40).
这个是提示 ERROR 28
欢迎大家探讨一下~用的是V2.182的专用版本~
本帖最近打赏记录:共1条打赏M币+1
离线wjw0080
只看该作者 1楼 发表于: 2015-01-21
本帖最近打赏记录:共1条打赏M币+2
离线wjw0080
只看该作者 2楼 发表于: 2015-01-21
只看该作者 3楼 发表于: 2015-01-21
本帖最近打赏记录:共1条打赏M币+3
离线yxd029
只看该作者 4楼 发表于: 2015-01-21
离线zangzj
只看该作者 5楼 发表于: 2015-01-21
只看该作者 6楼 发表于: 2015-01-21
