  • 5499阅读
  • 6回复
[SandForce]2281开卡失败,不能下载MFB是什么意思? [复制链接]
离线sodohe
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2015-01-24
2281贴了8贴JS29F64G08ACME2,开卡时报错,说什么 不能下载MFB,
请高手给分析一下,是不是flash贴的不问题,谢谢
下面是log:
<?xml version = "1.0"?>
<Genesis_Log>
    <Log_Body>
Overall Summary:
                Start Time: Sun, 01/25/2015 @ 23:04:52
                  End Time: Sun, 01/25/2015 @ 23:06:22
             OverallResult: FAIL
                  ExitCode: (0x10090014:SF_GENESIS_FW_DOWNLOAD_ERROR)
Environment Settings:
          Input Parameters:
                  argv[1]: -PROCESS_SSD
                  argv[2]: 1:0:0:0
                  argv[3]: /root/mpt/FW_SF-2000_MP_5-0-7_Client--12345600/FW_SF-2000_MP_5-0-7_Client.12345600.mfp
                  argv[4]: /root/mpt/22065.12345600.driveconfig
                  argv[5]: 0
                  argv[6]: 0
                  argv[7]: LOG=/root/fw/0_sodohe_DATETIMESTAMP_1.0.0.0_PROCESS_SSD_RESULT.log
                  Log File: /root/fw/0_sodohe_DATETIMESTAMP_1.0.0.0_PROCESS_SSD_RESULT.log
                  Hostname: sodohe
           Host IP Address: 127.0.0.1
               Port Number: 3
                DeviceName: /dev/sg3
        SF_Genesis Version: v1.7.0.01020130612-fc14-32bit
   SF_Core Library Version: v1.7.1.20130612-fc14-32bit
         SF_OS_Information: Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686
Post Processing Device Information:
                   WWN OUI: UNKNOWN
              WWN UniqueID: UNKNOWN
                Serial No.: UNKNOWN
                 Model No.: UNKNOWN
         Firmware Revision: UNKNOWN
              ROM Revision: UNKNOWN
            NAND Page Size: UNKNOWN
     Number Of Chip Enable: UNKNOWN
           Logical Sectors: UNKNOWN
                   NAND ID: UNKNOWN
        Flash Manufacturer: UNKNOWN
              Flash Device: UNKNOWN
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Sun 01/25/2015 23:04:52] - SF_Genesis has been invoked with the following parameters:
                      argv[2]: 1:0:0:0
                      argv[5]: 0
                      argv[6]: 0
[Sun 01/25/2015 23:04:52] - Instructing the operating system to purge any existing cached data for device: '1:0:0:0'
[Sun 01/25/2015 23:04:57] - Issuing a discovery command for device: '1:0:0:0'
[Sun 01/25/2015 23:05:03] - Discovery command completed...
[Sun 01/25/2015 23:05:03] - Waiting 5 seconds for the system to settle...
[Sun 01/25/2015 23:05:08] - Device designation string '1:0:0:0' is mapped to node '/dev/sg3'
[Sun 01/25/2015 23:05:08] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg3
    MFP Package Filename = /root/mpt/FW_SF-2000_MP_5-0-7_Client--12345600/FW_SF-2000_MP_5-0-7_Client.12345600.mfp
      Configuration File = /root/mpt/22065.12345600.driveconfig
              Serial No. = 0
         World Wide Name = 0
[Sun 01/25/2015 23:05:08] - Successfully received the IDENTIFY data from the drive...
[Sun 01/25/2015 23:05:08] - Validating Manufacturing Firmware Package: /root/mpt/FW_SF-2000_MP_5-0-7_Client--12345600/FW_SF-2000_MP_5-0-7_Client.12345600.mfp
[Sun 01/25/2015 23:05:16] - Successfully opened the package: /root/mpt/FW_SF-2000_MP_5-0-7_Client--12345600/FW_SF-2000_MP_5-0-7_Client.12345600.mfp
[Sun 01/25/2015 23:05:16] - file  /root/mpt/22065.12345600.driveconfig Loaded successfully
[Sun 01/25/2015 23:05:16] - Warning:  Unable to query diagnostics information to perform power management settings check
[Sun 01/25/2015 23:05:16] - B01 Power Management configuration request detected
[Sun 01/25/2015 23:05:16] - Successfully extracted *.DriveConfig file: /root/mpt/22065.12345600.driveconfig
[Sun 01/25/2015 23:05:16] - Extracted Config_ID: 1 (22065) in DriveConfig file: /root/mpt/22065.12345600.driveconfig
[Sun 01/25/2015 23:05:16] - Extracted SerialOutputControl: 0
[Sun 01/25/2015 23:05:16] - Searching for flashware image for configuration 22065
[Sun 01/25/2015 23:05:16] - Manifest found for configuration 22065
[Sun 01/25/2015 23:05:16] - Flashware image extracted: 22065_fw_cl_ccmlc_Intel_64Gb_JS29F64G08ACME2_2Q_1C_1D_PP_R00422_s512.vic
[Sun 01/25/2015 23:05:16] - Searching for manufacturing image for configuration 22065
[Sun 01/25/2015 23:05:16] - Manufacturing image extracted: 22065_mf_ccmlc_Intel_64Gb_JS29F64G08ACME2_2Q_1C_1D_PP_R00422_s512.vic
[Sun 01/25/2015 23:05:16] - Proceeding in ROM mode, download feature 3...
[Sun 01/25/2015 23:06:22] - FATAL_ERROR: Could not download MFB to the drive...(0x11000001:SF_SG_DEVICE_CHECK_CONDITION_ERROR)
Extended Error data:
          ATA COMMAND : 0x0092  (146)
          ATA FEATURE : 0x0003  (3)
         Device Status: 0x0001  (1)
         Driver Status: 0x0000  (0)
           Host Status: 0x0008  (8)
Sense Data:
  0 -         No Sense: 114 (0x72)    OK
  1 -  Recovered Error:  11 (0x0B)    FAIL
  2 -        Not Ready:   0 (0x00)    OK
  3 -     Medium Error:   0 (0x00)    OK
  4 -   Hardware Error:   0 (0x00)    OK
  5 -  Illegal Request:   0 (0x00)    OK
  6 -   Unit Attention:   0 (0x00)    OK
  7 -     Data Protect:  14 (0x0E)    OK
  8 -      Blank Check:   9 (0x09)    OK
  9 -  Vendor Specific:  12 (0x0C)    OK
10 -     Copy Aborted:   0 (0x00)    OK
11 -  Aborted Command:   0 (0x00)    OK
12 - Equal Comparison:   0 (0x00)    NA
13 -  Volume Overflow:   1 (0x01)    NA
14 -       Miscompare:   0 (0x00)    OK
15 -         Reserved: 224 (0xE0)    NA
System Trace:
[ 2541.846674] ata2.00: hard resetting link
[ 2542.150156] ata2.01: hard resetting link
[ 2543.154435] ata2.01: failed to resume link (SControl 0)
[ 2543.305134] ata2.00: SATA link up 3.0 Gbps (SStatus 123 SControl 330)
[ 2543.305149] ata2.01: SATA link down (SStatus 0 SControl 0)
[ 2543.305426] ata2.00: ATA-8: SandForce{200026BB}, 20DABBR0, max UDMA/133
[ 2543.305431] ata2.00: 64 sectors, multi 0: LBA48 NCQ (depth 0/32)
[ 2543.308362] ata2.00: configured for UDMA/133
[ 2543.308373] ata2: EH complete
[ 2543.308524] scsi 1:0:0:0: Direct-Access     ATA      SandForce{200026 20DA PQ: 0 ANSI: 5
[ 2543.308752] sd 1:0:0:0: Attached scsi generic sg3 type 0
[ 2543.308932] sd 1:0:0:0: [sdc] 64 512-byte logical blocks: (32.7 kB/32.0 KiB)
[ 2543.308935] sd 1:0:0:0: [sdc] 4096-byte physical blocks
[ 2543.309307] sd 1:0:0:0: [sdc] Write Protect is off
[ 2543.309311] sd 1:0:0:0: [sdc] Mode Sense: 00 3a 00 00
[ 2543.309337] sd 1:0:0:0: [sdc] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 2543.311094]  sdc: unknown partition table
[ 2543.314280] sd 1:0:0:0: [sdc] Attached SCSI disk
[ 2566.835309] ata2: lost interrupt (Status 0x58)
[ 2566.835325] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 frozen
[ 2566.835328] ata2.00: failed command: DOWNLOAD MICROCODE
[ 2566.835332] ata2.00: cmd 92/03:80:00:00:00/00:00:00:00:00/00 tag 0 pio 65536 out
[ 2566.835333]          res 40/00:01:e0:4f:c2/00:00:00:00:00/00 Emask 0x4 (timeout)
[ 2566.835335] ata2.00: status: { DRDY }
[ 2566.835343] ata2.00: hard resetting link
[ 2567.138482] ata2.01: hard resetting link
[ 2568.142749] ata2.01: failed to resume link (SControl 0)
[ 2573.328735] ata2.00: link is slow to respond, please be patient (ready=0)
[ 2576.838237] ata2.00: SRST failed (errno=-16)
[ 2576.838247] ata2.00: hard resetting link
[ 2577.142401] ata2.01: hard resetting link
[ 2578.146672] ata2.01: failed to resume link (SControl 0)
[ 2583.332622] ata2.00: link is slow to respond, please be patient (ready=0)
[ 2586.842128] ata2.00: SRST failed (errno=-16)
[ 2586.842139] ata2.00: hard resetting link
[ 2587.146297] ata2.01: hard resetting link
[ 2588.150581] ata2.01: failed to resume link (SControl 0)
[ 2593.336553] ata2.00: link is slow to respond, please be patient (ready=0)
[ 2621.768548] ata2.00: SRST failed (errno=-16)
[ 2621.768557] ata2.00: limiting SATA link speed to 1.5 Gbps
[ 2621.768562] ata2.01: limiting SATA link speed to 1.5 Gbps
[ 2621.768570] ata2.00: hard resetting link
[ 2622.072721] ata2.01: hard resetting link
[ 2623.077018] ata2.01: failed to resume link (SControl 0)
[ 2626.787944] ata2.00: SRST failed (errno=-16)
[ 2626.787950] ata2.00: reset failed, giving up
[ 2626.787954] ata2.00: disabled
[ 2626.787972] ata2: EH complete
[Sun 01/25/2015 23:06:22] - End of Genesis manufacturing log.
[Sun 01/25/2015 23:06:22] - Exiting...
    </Log_Body>
    <Overall_Summary>
        <Start_Time> Sun, 01/25/2015 @ 23:04:52 </Start_Time>
        <End_Time> Sun, 01/25/2015 @ 23:06:22 </End_Time>
        <Overall_Result> FAIL </Overall_Result>
        <Exit_Code> (0x10090014:SF_GENESIS_FW_DOWNLOAD_ERROR) </Exit_Code>
    </Overall_Summary>
    <Environment_Settings>
        <Input_Parameters>
                  argv[2]: 1:0:0:0
                  argv[5]: 0
                  argv[6]: 0
        </Input_Parameters>
        <Log_File> /root/fw/0_sodohe_DATETIMESTAMP_1.0.0.0_PROCESS_SSD_RESULT.log </Log_File>
        <Hostname> sodohe </Hostname>
        <Host_IP_Address> 127.0.0.1 </Host_IP_Address>
        <Port_Number> 3 </Port_Number>
        <Device_Name> /dev/sg3 </Device_Name>
        <SF_Genesis_Version> v1.7.0.01020130612-fc14-32bit </SF_Genesis_Version>
        <SF_Core_Library_Version> v1.7.1.20130612-fc14-32bit </SF_Core_Library_Version>
        <SF_OS_Information> Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686 </SF_OS_Information>
    </Environment_Settings>
    <Post_Processing_Device_Info>
        <WWN_OUI> UNKNOWN </WWN_OUI>
        <WWN_UniqueID> UNKNOWN </WWN_UniqueID>
        <Serial_Number> UNKNOWN </Serial_Number>
        <Model_Number> UNKNOWN </Model_Number>
        <Firmware_Revision> UNKNOWN </Firmware_Revision>
        <ROM_Revision> UNKNOWN </ROM_Revision>
        <NAND_Page_Size> UNKNOWN </NAND_Page_Size>
        <Number_Of_Chip_Enable> UNKNOWN </Number_Of_Chip_Enable>
        <Logical_Sectors> UNKNOWN </Logical_Sectors>
        <NAND_ID> UNKNOWN </NAND_ID>
        <Flash_Manufacturer> UNKNOWN </Flash_Manufacturer>
        <Flash_Device> UNKNOWN </Flash_Device>
    </Post_Processing_Device_Info>
</Genesis_Log>
[Sun 01/25/2015 23:06:22] - Overall Result for Device: /dev/sg3 ****** FAIL ******
离线john_chuck
只看该作者 1楼 发表于: 2015-01-24
本帖最近打赏记录:共1条打赏M币+3
离线chen7610386
只看该作者 2楼 发表于: 2015-01-24
离线音之韵
只看该作者 3楼 发表于: 2015-01-24
本帖最近打赏记录:共1条打赏M币+3
离线chtianhu
只看该作者 4楼 发表于: 2015-01-24
本帖最近打赏记录:共1条打赏M币+3
离线wzcgx
只看该作者 5楼 发表于: 2015-01-24
本帖最近打赏记录:共1条打赏M币+3
离线9260
只看该作者 6楼 发表于: 2015-01-25
本帖最近打赏记录:共1条打赏M币+3
