  • 4058阅读
  • 6回复
[SandForce]2281开卡见红,请麻烦帮忙看看哪儿的问题 [复制链接]
离线lover520yd
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2015-02-14
2281开卡见红,请麻烦帮忙看看哪儿的问题,板子检查好几遍了,确实不知道是哪儿出错了
日志文件主体如下:
- Proceeding in ROM mode, download feature 3...
- FATAL_ERROR: Could not download MFB to the drive...(0x11000001:SF_SG_DEVICE_CHECK_CONDITION_ERROR)
Extended Error data:
          ATA COMMAND : 0x0092  (146)
          ATA FEATURE : 0x0003  (3)
         Device Status: 0x0001  (1)
         Driver Status: 0x0000  (0)
           Host Status: 0x0008  (8)
Sense Data:
  0 -         No Sense: 114 (0x72)    OK
  1 -  Recovered Error:  11 (0x0B)    FAIL
  2 -        Not Ready:   0 (0x00)    OK
  3 -     Medium Error:   0 (0x00)    OK
  4 -   Hardware Error:   0 (0x00)    OK
  5 -  Illegal Request:   0 (0x00)    OK
  6 -   Unit Attention:   0 (0x00)    OK
  7 -     Data Protect:  14 (0x0E)    OK
  8 -      Blank Check:   9 (0x09)    OK
  9 -  Vendor Specific:  12 (0x0C)    OK
10 -     Copy Aborted:   0 (0x00)    OK
11 -  Aborted Command:   0 (0x00)    OK
12 - Equal Comparison:   0 (0x00)    NA
13 -  Volume Overflow:   0 (0x00)    NA
14 -       Miscompare:   0 (0x00)    OK
15 -         Reserved: 128 (0x80)    NA
System Trace:
[  688.678944] ata1.00: status: { DRDY ERR }
[  688.678948] ata1.00: error: { ABRT }
[  688.678961] ata1.00: device reported invalid CHS sector 0
[  688.678984] sd 0:0:0:0: [sda] START_STOP FAILED
[  688.678987] sd 0:0:0:0: [sda] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[  688.678993] sd 0:0:0:0: [sda] Sense Key : Aborted Command [current] [descriptor]
[  688.679001] sd 0:0:0:0: [sda] Add. Sense: No additional sense information
[  688.679135] ata1.00: disabled
[  693.683894] ata1: hard resetting link
[  694.143046] ata1: softreset failed (device not ready)
[  694.143054] ata1: applying SB600 PMP SRST workaround and retrying
[  694.298069] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[  694.299077] ata1.00: ATA-8: SandForce{200026BB}, 20DABBR0, max UDMA/133
[  694.299085] ata1.00: 64 sectors, multi 0: LBA48 NCQ (depth 31/32), AA
[  694.304758] ata1.00: configured for UDMA/133
[  694.304772] ata1: EH complete
[  694.304955] scsi 0:0:0:0: Direct-Access     ATA      SandForce{200026 20DA PQ: 0 ANSI: 5
[  694.308391] sd 0:0:0:0: [sda] 64 512-byte logical blocks: (32.7 kB/32.0 KiB)
[  694.308398] sd 0:0:0:0: [sda] 4096-byte physical blocks
[  694.308477] sd 0:0:0:0: [sda] Write Protect is off
[  694.308483] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[  694.308517] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[  694.308993] sd 0:0:0:0: Attached scsi generic sg0 type 0
[  694.310006]  sda: unknown partition table
[  694.319354] sd 0:0:0:0: [sda] Attached SCSI disk
[  710.774417] ata1.00: exception Emask 0x50 SAct 0x0 SErr 0x90a02 action 0xe frozen
[  710.774426] ata1.00: irq_stat 0x00400000, PHY RDY changed
[  710.774433] ata1: SError: { RecovComm Persist HostInt PHYRdyChg 10B8B }
[  710.774440] ata1.00: failed command: DOWNLOAD MICROCODE
[  710.774452] ata1.00: cmd 92/03:6a:00:80:01/00:00:00:00:00/00 tag 0 pio 54272 out
[  710.774455]          res 50/00:00:80:00:00/00:00:00:00:00/e0 Emask 0x50 (ATA bus error)
[  710.774460] ata1.00: status: { DRDY }
[  710.774470] ata1: hard resetting link
[  711.497055] ata1: SATA link down (SStatus 0 SControl 300)
[  716.497051] ata1: hard resetting link
[  716.802049] ata1: SATA link down (SStatus 0 SControl 300)
[  716.802064] ata1: limiting SATA link speed to 1.5 Gbps
[  721.802028] ata1: hard resetting link
[  722.107056] ata1: SATA link down (SStatus 0 SControl 310)
[  722.107070] ata1.00: disabled
[  722.107107] ata1: EH complete
[  722.107119] ata1.00: detaching (SCSI 0:0:0:0)
[  722.110462] sd 0:0:0:0: [sda] Stopping disk
[  722.110503] sd 0:0:0:0: [sda] START_STOP FAILED
[  722.110508] sd 0:0:0:0: [sda] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
离线lover520yd
只看该作者 1楼 发表于: 2015-02-14
本帖最近打赏记录:共1条打赏M币+3
离线sodohe
只看该作者 2楼 发表于: 2015-02-14
离线afu7310
只看该作者 3楼 发表于: 2015-02-14
离线lover520yd
只看该作者 4楼 发表于: 2015-02-14
回 afu7310 的帖子
离线guoke1930
只看该作者 5楼 发表于: 2015-02-15
离线wzcgx
只看该作者 6楼 发表于: 2015-02-16
