  • 15723阅读
  • 24回复
[SandForce]SF2281贴了128G,固件使用的是120G,格式化后容量仅111G,为什么? [复制链接]
离线sodohe
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2015-02-17
有一个月多了,SF2281贴了8片29F16B08CCME2,开卡报20错误,今天放假后在家用洗板水泡了整个电路板,再到Fedora14下开卡,竟然pass。
    我用的是22217固件(120G),看重的是有RAISE功能,虽然少了8G,但也值!开卡后到windows下格式化,对齐,最后容量竟然只有111G。
    问高手,8片共128G,固件确认120G,为什么格式化后又少了9G?
    下面是开卡的log:
    粘贴发贴报错,贴部分log吧:
[Tue 02/17/2015 23:41:33] - Successfully received the IDENTIFY data from the drive...
[Tue 02/17/2015 23:41:33] - Validating Manufacturing Firmware Package: /root/mpt/FW_SF-2000_MP_5-0-7_Client--12345600/FW_SF-2000_MP_5-0-7_Client.12345600.mfp
[Tue 02/17/2015 23:41:40] - Successfully opened the package: /root/mpt/FW_SF-2000_MP_5-0-7_Client--12345600/FW_SF-2000_MP_5-0-7_Client.12345600.mfp
[Tue 02/17/2015 23:41:40] - file  /root/mpt/22217.12345600.driveconfig Loaded successfully
[Tue 02/17/2015 23:41:40] - Warning:  Unable to query diagnostics information to perform power management settings check
[Tue 02/17/2015 23:41:40] - B01 Power Management configuration request detected
[Tue 02/17/2015 23:41:40] - Successfully extracted *.DriveConfig file: /root/mpt/22217.12345600.driveconfig
[Tue 02/17/2015 23:41:40] - Extracted Config_ID: 1 (22217) in DriveConfig file: /root/mpt/22217.12345600.driveconfig
[Tue 02/17/2015 23:41:40] - Extracted SerialOutputControl: 0
[Tue 02/17/2015 23:41:40] - Searching for flashware image for configuration 22217
[Tue 02/17/2015 23:41:40] - Manifest found for configuration 22217
[Tue 02/17/2015 23:41:40] - Flashware image extracted: 22217_fw_cl_ccmlc_Intel_64Gb_JS29F16B08CCME2_2Q_2C_1D_PP_R00426_s512.vic
[Tue 02/17/2015 23:41:40] - Searching for manufacturing image for configuration 22217
[Tue 02/17/2015 23:41:40] - Manufacturing image extracted: 22217_mf_ccmlc_Intel_64Gb_JS29F16B08CCME2_2Q_2C_1D_PP_R00426_s512.vic
[Tue 02/17/2015 23:41:40] - Proceeding in ROM mode, download feature 3...
[Tue 02/17/2015 23:41:41] - Successfully downloaded MFB to the drive...
[Tue 02/17/2015 23:41:41] - Waiting (5 sec) for the drive to settle...
[Tue 02/17/2015 23:41:46] - Successfully received the IDENTIFY data from the drive...
[Tue 02/17/2015 23:41:46] - Firmware revision reported to be: '507ABBM0'.  This indicates MFB download was successful.
[Tue 02/17/2015 23:41:46] - Successfully enabled SMART capabilities...
[Tue 02/17/2015 23:41:48] - Successfully issued a diagnostic unlock...
[Tue 02/17/2015 23:41:49] - Performing the flash test of block 0 (0x0000)...
[Tue 02/17/2015 23:41:50] - Flash Test Results:
Flash Test Parameters:
               Block Count: 0
                Page Count: 1
                 Bus Count: 2
        Chip Enabled Count: 2
                 Die Count: 1
                Lane Count: 4
               Plane Count: 2
Results Notes:
   N1 - At least one page tested and passed with no bit errors.
   N2 - No test data available.  Test may have aborted, or failed during the testing.
   N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
   N4 - At least  one erased page tested had bit error rate greater than half the correction power.
   N5 - Walking zeros test failed.
   N6 - Walking ones test failed.
   N7 - Block contained factory bad block markings and testing was skipped.
   N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
   N9 - Block in plane 0 was marked as a factory bad block.
  N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
  N11 - Block in plane 1 was marked as a factory bad block.
| Bus  | CE   | Die  | Lane | Value  | Result Notes                               | Overall |
| 0    | 0    | 0    | 0    | 0x0002 | N3                                         | WARNING |
| 0    | 0    | 0    | 1    | 0x0022 | N3,N5                                      | WARNING |
| 0    | 0    | 0    | 2    | 0x0002 | N3                                         | WARNING |
| 0    | 0    | 0    | 3    | 0x0002 | N3                                         | WARNING |
| 0    | 1    | 0    | 0    | 0x0002 | N3                                         | WARNING |
| 0    | 1    | 0    | 1    | 0x0002 | N3                                         | WARNING |
| 0    | 1    | 0    | 2    | 0x0002 | N3                                         | WARNING |
| 0    | 1    | 0    | 3    | 0x0002 | N3                                         | WARNING |
| 1    | 0    | 0    | 0    | 0x0022 | N3,N5                                      | WARNING |
| 1    | 0    | 0    | 1    | 0x0002 | N3                                         | WARNING |
| 1    | 0    | 0    | 2    | 0x0002 | N3                                         | WARNING |
| 1    | 0    | 0    | 3    | 0x0022 | N3,N5                                      | WARNING |
| 1    | 1    | 0    | 0    | 0x0002 | N3                                         | WARNING |
| 1    | 1    | 0    | 1    | 0x0002 | N3                                         | WARNING |
| 1    | 1    | 0    | 2    | 0x0002 | N3                                         | WARNING |
| 1    | 1    | 0    | 3    | 0x0002 | N3                                         | WARNING |
  Total Number of test results: 16
            Number of failures: 0
         Number of Passed with warnings: 16
      No. Passed without warnings: 0
[Tue 02/17/2015 23:42:25] - FORMAT command completed...
[Tue 02/17/2015 23:42:25] - Waiting (2 sec) for the drive to settle...
[Tue 02/17/2015 23:42:27] - Setting up the stamp information through CDU command...
[Tue 02/17/2015 23:42:30] - Waiting (2 sec) for the drive to settle...
[Tue 02/17/2015 23:42:32] - Downloading the flashware to the drive... feature 3
[Tue 02/17/2015 23:42:34] - Successfully downloaded flashware to the drive...
[Tue 02/17/2015 23:42:34] - Waiting (15 sec) for the drive to settle...
[Tue 02/17/2015 23:42:49] - Successfully received the IDENTIFY data from the drive...
[Tue 02/17/2015 23:42:49] - Firmware revision reported to be: '507ABBF0'
[Tue 02/17/2015 23:42:49] - Enabling SMART support...
[Tue 02/17/2015 23:42:49] - Issuing a diagnostic unlock to the drive...
[Tue 02/17/2015 23:42:51] - Setting up Max LBA settings...
[Tue 02/17/2015 23:42:54] - Change of sector size is not required, sector size is already set to 512
[Tue 02/17/2015 23:42:55] - Setting the serial number of the drive to: 0
[Tue 02/17/2015 23:42:57] - Setting the World Wide Name (WWN) of the drive to: 0
[Tue 02/17/2015 23:43:01] - Processing completed for device: 0
[Tue 02/17/2015 23:43:01] - Begin collecting the device post-process log/information
General Configuration For Device: /dev/sg1
                                           Reserved0: 1
                                           Reserved1: 0
                                 Response Incomplete: NO
                                           Reserved2: 1
                                           Obsolete1: 12
                                           Reserved3: 3
                                         Device Type: ATA
    1 - Obsolete #1:                                  3162  (0x0C5A)
    2 - Specific Configuration:                       16383 (0x3FFF)
    3 - Obsolete #2:                                  51255 (0xC837)
    4 - Reserved #1:                                  16    (0x0010)
    5 - Obsolete #3:                                  0     (0x0000)
    6 - Reserved_CompactFlash1:                       0     (0x0000)
    7 - Reserved_CompactFlash2:                       63    (0x003F)
    8 - Reserved #2:                                  0     (0x0000)
    9 - Serial No.:          0
   19 - Reserved #3:                            170726696 (0x0A2D1528)
   21 - Obsolete #4:                                  0     (0x0000)
   22 - Firmware Revision:                            507ABBF0
   26 - Model No.:           SandForce[565850]
   46 - Read/Write Multiple Command:
                        Max Sectors Per Data Request: 16
                                            Reserved: 128
   47 - Trusted Computing Features:
                                        TC Supported: NO
                                            Reserved: 0
                                            Set Flag: 1
                                          Clear Flag: 0
   48 - Capabilities/Features #1:
                                            Reserved: 0
                                       DMA Supported: YES
                                       LBA Supported: YES
                                    IO Ready Disable: YES
                                  IO Ready Supported: YES
                    Identify Packet Device Reserved1: 0
                    Standby Timers Managed By Device: NO
                    Identify Packet Device Reserved2: 0
   49 - Capabilities/Features #2:
   50 - Obsolete #5:                                  12032 (0x2F00)
   51 - Obsolete #6:                                  16384 (0x4000)
   52 - Validity Flags:
                                            Obsolete: 1
                       Words 64 Through 70 Are Valid: YES
                                 Word At 88 Is Valid: YES
                                            Reserved: 0
                                 Free Fall CTL Sense: 0
   53 - Obsolete #7:                            170731269 (0x0A2D2705)
   55 - Obsolete #8:                                    1 (0x00000001)
   57 - Obsolete #9:                                  63    (0x003F)
   58 - Hardware Reset Results:
                         Current No. Sectors Per DRQ: 16
                    Multiple Sector Setting Is Valid: YES
                                            Reserved: 0
   59 - Total No. User Logical Sectors:           3653620 (0x0037BFF4)
   61 - Obsolete #10:                                 19376 (0x4BB0)
   62 - DMA Information:
                      Multiword DMA Mode 0 Supported: YES
                      Multiword DMA Mode 1 Supported: YES
                      Multiword DMA Mode 2 Supported: YES
                                            Reserved: 0
                       Multiword DMA Mode 0 Selected: NO
                       Multiword DMA Mode 1 Selected: NO
                       Multiword DMA Mode 2 Selected: NO
                                            Reserved: 0
   63 - PIO:
                                 PIO Modes Supported: 3 (0x0003)
                                            Reserved: 0
   64 - Minimum MW DMA:                                 7 (0x00000007)
   65 - Recomended MW DMA Time:                         3 (0x00000003)
   66 - Min PIO Time without Flow CTL:                120 (0x00000078)
   67 - Min PIO Time with IORDY Flow CTL:             120 (0x00000078)
   68 - Reserved #4:                                  120   (0x0078)
   69 - Reserved #5:                                  120   (0x0078)
   70 - Reserved Identify Packet Device #1:           16896 (0x4200)
   71 - Reserved Identify Packet Device #2:           0     (0x0000)
   72 - Reserved Identify Packet Device #3:           0     (0x0000)
   73 - Reserved Identify Packet Device #4:           0     (0x0000)
   74 - Command Queue:
                                     Depth Supported: 31 (0x001F)
                                            Reserved: 0
   75 - Serial ATA Capabilities:
                                               Clear: NO
                      Generation 1 (1.5 Gbs) Support: YES
                      Generation 2 (3.0 Gbs) Support: YES
                                   SATA Gen Reserved: 0
                    Native Command Queuing Supported: YES
                 Host Initiated Power Mgmt Supported: YES
                         Supports Phy Event Counters: YES
                                            Reserved: 1
   76 -  Reserved SATA Capabilities:                  31    (0x001F)
   77 - Serial ATA Supported Features:
                                               Clear: NO
                   Non-Zero Offsets in DMA Setup FIS: NO
                DMA Setup Auto-Activate Optimization: YES
                    Device Initiate Power Management: YES
                              In-order Data Delivery: NO
                                           Reserved1: 1
                      Software Settings Preservation: YES
                                           Reserved2: 1
   78 - Serial ATA Enabled Features:
                                               Clear: NO
                DMA Setup Auto-Activate Optimization: NO
                    Device Initiate Power Management: NO
                                           Reserved1: 0
                                           Reserved2: 0
   79 - Major Version No.:
                                           Reserved1: 0
                                            Obsolete: 6
                                     ATA-4 Supported: YES
                                     ATA-5 Supported: YES
                                     ATA-6 Supported: YES
                                     ATA-7 Supported: YES
                                     ATA-8 Supported: YES
                                           Reserved2: 0
   80 - Minor Version No.:                            64    (0x0040)
   81 - Command/Feature Support #1:
                                   SMART Feature Set: YES
                                       Security Mode: YES
                                           Obsolete1: 0
                          Mandatory Power Management: YES
                                  Packet Feature Set: NO
                                         Write Cache: YES
                                          Look-Ahead: YES
                                   Release Interrupt: NO
                                   Service Interrupt: NO
                                Device Reset Command: NO
                                 Host Protected Area: YES
                                           Obsolete2: 0
                                 Wite Buffer command: YES
                                 Read Buffer command: YES
                                         NOP Command: YES
                                           Obsolete3: 0
   82 - Command/Feature Support #2:
                          Download MicroCode Command: YES
                               Read/Write DMA Queued: NO
                                     CFA Feature Set: NO
                           Advanced Power Management: YES
                                            Obsolete: 0
                                 Power-Up In Standby: YES
               Set Feature To Spin-Up After Power-Up: YES
                                            Reserved: 0
                          Set Max Security Extension: NO
                       Automatic Acoustic Management: NO
                                      48-bit Address: YES
                        Device Configuration Overlay: NO
                                  Manual Flush Cache: YES
                                     Flush Cache Ext: YES
                              Read/Write DMA Queued : YES
                                  Download MicroCode: NO
   83 - Command/Feature Support #3:
                                 SMART Error Logging: YES
                                     SMART Self-Test: YES
                                    Media Serial No.: NO
                      Media Card Passthrough Command: NO
                                           Streaming: NO
                             General Purpose Logging: YES
           Write DMA FUA Ext and Write Multi FUA Ext: YES
                            Write DMA Queued FUA Ext: NO
                              64-Bit World Wide Name: YES
                                            Obsolete: 0
                                            Reserved: 0
                          Idle Immediate With Unload: YES
                                                 Set: YES
                                               Clear: NO
   84 - Command/Feature Support #4:
                                        SMART Enaled: YES
                                Security Mode Enaled: NO
                                           Obsolete1: 0
                   Mandatory Power Management Enaled: YES
                                      Packet Support: NO
                                  Write Cache Enaled: YES
                             Read Look-Ahead Enabled: NO
                           Release Interrupt Enabled: NO
                           Service Interrupt Enabled: NO
                                Device Reset Support: NO
                         Host Protected Area Enabled: YES
                                           Obsolete2: 0
                                Write Buffer Support: YES
                                 Read Buffer Support: YES
                                         NOP Support: YES
                                           Obsolete3: 0
   85 - Command/Feature Support #5:
                                  Download MicroCode: YES
                                          Queued DMA: NO
                                     CFA Feature Set: NO
                            Advance Power Management: YES
                                            Obsolete: 0
                                 Power-Up In Standby: NO
                    SubCommand To Spinup On Power-up: YES
                                           Reserved1: 0
                           Set Max Security Password: NO
               Automatic Acoustic Management Enabled: NO
                           48-Bit Addressing Support: YES
                                     DCO Feature Set: NO
                                         Flush Cache: YES
                                           Reserved2: 0
                             Words 119-120 Are Valid: YES
   86 - Command/Feature Support #6:
                                     SMART Error Log: YES
                                     SMART Self Test: YES
                           Media Serial Number Valid: NO
                                           Obsolete1: 0
                                   DMA Multi FUA Ext: YES
                              64-Bit World wide Name: YES
                                           Obsolete2: 0
                                            Reserved: 0
                                                 Set: YES
                                               Clear: NO
   87 - Ultra DMA Support:
                                     UDMA0 Supported: YES
                                     UDMA1 Supported: YES
                                     UDMA2 Supported: YES
                                     UDMA3 Supported: YES
                                     UDMA4 Supported: YES
                                     UDMA5 Supported: YES
                                     UDMA6 Supported: YES
                                           Reserved1: 0
                                       UDMA0 Enabled: NO
                                       UDMA1 Enabled: NO
                                       UDMA2 Enabled: NO
                                       UDMA3 Enabled: NO
                                       UDMA4 Enabled: NO
                                       UDMA5 Enabled: YES
                                       UDMA6 Enabled: NO
                                           Reserved2: 0
   88 - Time For Normal Security Erase:               24931 (0x6163)
   89 - Time For Enhanced Security Erase:             8319  (0x207F)
   90 - Advanced Power Management Current Value:      1     (0x0001)
   91 - Master Password Identifier:                   0     (0x0000)
   92 - Hardware Reset Result:
                                                Set1: 0
                           Device0 No. Determined By: Reserved
                          Device0 Diagnostics Result: Fail
                                Device0 PDiag Status: 0
                                 Device0 DASP Status: 0
                   Device0 Respond to Device1 Select: 0
                                           Reserved1: 0
                                                Set2: 0
                           Device1 No. Determined By: Reserved
                                Device1 PDiag Status: 0
                                           Reserved2: 0
                               Hardware Reset Result: 0
                                                Set3: 0
                    Device Detected CBLID Above ViHB: 0
   93 - Automtic Acoustic Management:
                             Vendor Recomended Value: 0 (0x0000)
                                       Current Value: 0 (0x0000)
   94 - Stream Min Request Size:                      0     (0x0000)
   95 - Stream Transfer Time DMA:                     0     (0x0000)
   96 - Stream Access Latency PIO:                    0     (0x0000)
   97 - Streaming Performance Granularity:     3220335428 (0xBFF26B44)
   99 - Total User Addressable Logical Sectors:  0x0000 0000 4BB0 0DF9
  103 - Stream Transfer Time PIO:                     0     (0x0000)
  104 - Reserved #6:                                  0     (0x0000)
  105 - Sector Size:
  106 - ISO-7779 Inter-seek Delay (microseconds):     1     (0x0001)
  107 - WWN1:
                         IeeeOUI-UniqueID Bits 23-12: 0     (0x0000)
                                        NAA Bits 0-3: 0     (0x0000)
  108 - WWN2:
                                Unique ID Bits 32-35: 0     (0x0000)
                          IeeeOUI-UniqueID Bits 0-11: 0     (0x0000)
  109 - Unique ID Bits 16-31:                         0     (0x0000)
  110 - Unique ID Bits 0-15:                          0     (0x0000)
  111 - WWN Extension:                           0x0000 0000 0000 0000
  115 - INCITS TR-37-2004:                            0     (0x0000)
  116 - Logical Sector Size Low:                      0     (0x0000)
  117 - Logical Sector Size High:                     0     (0x0000)
  118 - Command/Feature Support #7:
                                           Reserved1: 0
                                   Write-Read-Verify: YES
                             Write Uncorrectable Ext: NO
                          Read and Write Log DMA Ext: YES
                           Download Microcode Mode 3: YES
                                   Free Fall Control: NO
                                           Reserved2: 0
                                                 Set: YES
                                               Clear: NO
  119 - Command/Feature Support #8:
                                           Reserved1: 0
                           Write-Read-Verify Enabled: NO
                     Write Uncorrectable Ext Enabled: NO
                  Read and Write Log DMA Ext Enabled: YES
                   Download Microcode Mode 3 Enabled: YES
                           Free Fall Control Enabled: NO
                                           Reserved2: 0
                                                 Set: YES
                                               Clear: NO
  120 - Reserved Expanded Feature Support #1:         16410 (0x401A)
  121 - Reserved Expanded Feature Support #2:         16408 (0x4018)
  122 - Reserved Expanded Feature Support #3:         0     (0x0000)
  123 - Reserved Expanded Feature Support #4:         0     (0x0000)
  124 - Reserved Expanded Feature Support #5:         0     (0x0000)
  125 - Reserved Expanded Feature Support #6:         0     (0x0000)
  126 - Obsolete #11:                                 0     (0x0000)
  127 - Security:
                                           Supported: YES
                                             Enabled: NO
                                              Locked: NO
                                              Frozen: NO
                                       Count Expired: NO
                   Enhanced Security Erase Supported: NO
                                           Reserved1: 0
                                               Level: NO
                                           Reserved2: 0
  128 - Vendor Specific:
            0x0000        0x0000        0x0000        0x0000
  159 - CFA Power Mode:
                                   Max Current in mA: 0 (0x0000)
                                Power Mode1 Disabled: NO
                                Power Mode1 Required: NO
                                            Reserved: 0
                       Power Mode Word 160 Supported: NO
  160 - CFA Reserved:
  175 - Currnt Media Serial Number:
           0x00  0x00  0x00  0x00  0x00  0x00  0x00  0x00
           0x00  0x00  0x00  0x00
  205 - SMART Command Transport:
                                           Supported: YES
                                  Long Sector Access: NO
                                          Write Same: NO
                              Error Recovery Control: NO
                                    Features Control: NO
                                         Data Tables: YES
                                            Reserved: 0
                                     Vendor Specific: 0
  206 - CE-ATA Reserved #1:                           0     (0x0000)
  207 - CE-ATA Reserved #2:                           0     (0x0000)
  208 - Alignment:
      Logical Sector Offset in First Physical Sector: 0
                                                 Set: YES
                                               Clear: NO
  209 - Write Verify Sector Count Mode 3:               0 (0x00000000)
  211 - Write Verify Sector Count Mode 2:             256 (0x00000100)
  213 - NV Cache Capabilities:
                                  Power Mode Support: NO
                                  Power Mode Enabled: NO
                                           Reserved1: 0
                                 Feature Set Enabled: NO
                                           Reserved2: 0
                                  Power Mode Version: 0
                                 Feature Set Version: 0
  214 - NV Cache Size Low:                            0     (0x0000)
  215 - NV Cache Size High:                           0     (0x0000)
  216 - Nominal Media Rotation Rate:                  0     (0x0000)
  217 - Reserved #7:                                  0     (0x0000)
  218 - NV Cache Options:
                                 Spinup Time Seconds: 0
                                            Reserved: 0
  219 - Write-Read-Verify:
                                        Current Mode: 0
                                            Reserved: 0
  220 - Reserved #8:                                  0     (0x0000)
  221 - Transport Major Version No:                   0     (0x0000)
  222 - Transport Minor Version No:                   0     (0x0000)
  223 - CE-ATA Reserved:
            0x0000        0x0000
  233 - Min 512 Block Per Microcode Download:         0     (0x0000)
  234 - Max 512 Block Per Microcode Download:         0     (0x0000)
  235 - Reserved #9:
  254 - Integrity Word:
                                           Signature: 0
                                            Checksum: 0
本帖最近打赏记录:共2条打赏M币+8
离线sodohe
只看该作者 1楼 发表于: 2015-02-17
本帖最近打赏记录:共2条打赏M币+6
离线wangyonjie
只看该作者 2楼 发表于: 2015-02-17
本帖最近打赏记录:共4条打赏M币+10
离线sodohe
只看该作者 3楼 发表于: 2015-02-17
回 wangyonjie 的帖子
离线sodohe
只看该作者 4楼 发表于: 2015-02-17
离线fghlw
只看该作者 5楼 发表于: 2015-02-17
本帖最近打赏记录:共2条打赏M币+4
离线john_chuck
只看该作者 6楼 发表于: 2015-02-17
本帖最近打赏记录:共3条打赏M币+7
离线galgame
只看该作者 7楼 发表于: 2015-02-17
本帖最近打赏记录:共3条打赏M币+7
离线xffsfy
只看该作者 8楼 发表于: 2015-02-17
回 qq489320666 的帖子
本帖最近打赏记录:共3条打赏M币+7
离线sodohe
只看该作者 9楼 发表于: 2015-02-17
本帖最近打赏记录:共2条打赏M币+4
