  • 1615阅读
  • 0回复
[鑫创]3s6692错误 请求帮助! [复制链接]
离线zxcasdll
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2015-02-26
Starting Time: 15:11:12
Device 1:0xB5
    MP Version:2.178
    INI_File_Name:6692——256P_8KB.INI
    Random delay 0 msec
    --- Download MP ISP ---
    Auto CE: 0x00 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF
    CE-0, Flash ID=98-DE-94-82-76-56-04-20
    Searching SORTING BOARD table ...
    --> Not Found
    Found BACKUP Table (0000023A-0002)
    Defect Table (00000800-0008)
        Original Bad Block - 0:0x04E1
        Original Bad Block - 0:0x0554
        Original Bad Block - 0:0x0607
        Original Bad Block - 0:0x066A
        Original Bad Block - 0:0x0769
        Original Bad Block - 0:0x0996
        Original Bad Block - 0:0x0E5D
        Original Bad Block - 0:0x0F23
    Defect Table shows 4116 Good blocks, 8 Bad blocks
    SafeErase (0,4124)
        Erase failed Block - 0:0:0x04E1
        Erase failed Block - 0:0:0x0554
        Erase failed Block - 0:0:0x0607
        Erase failed Block - 0:0:0x066A
        Erase failed Block - 0:0:0x0769
        Erase failed Block - 0:0:0x0996
        Erase failed Block - 0:0:0x0E5D
        Erase failed Block - 0:0:0x0F23
        ---> Max Bad of Plane (2,3)
        ---> Max BAD/DIE = 3
    Total good blocks after SCAN: 4116 / 4124, Bad block=8
    ==> 2-Plane mode
    MaxWindows=2/1910, MaxLBA=15644912, Size=7639 MB
    Lun0(15644912), Lun1(0), Public=15644912, Secure=0, CDROM=0
    Max BAD of one plane is 3 (50),4124,1,1
    RootSector=0x777F,Sec/Cluster=8, SuperPage=64 ---> Alignment=57
    Boot Block=0x0002,0x0004
    Special FE Config = 54-0B-00
    Defect Table Block=0x0008
    --- Download ISP Code:D:\DESKTOP\3S_USB_MP_UTILITY_VER_2.178\ISP_CODE\6692_B5-IM_20101223_VB7010B-BETA5_7E90.BIN---
    --- ISP Code installed.
    Public,Secure,CDROM = 15644912,0,0
    PHY: E2/E4/E6=72h/36h/04h,  D0/C0/CFG10=DFh/0Bh/87h
    SN=B8763F4A9D76FF21AC242029
    === Preformat Done ===
    Low Level Format DONE
    Store INI/ERROR MSG to Block-0x0002:78.
    ### Error: Device capacity is 0 bytes
Ending Time: 15:11:30
