型号hg100n 原密码nE7jA%5m清除信息后密码无法登陆,信息如下:
Build Date: Wed Aug 31 13:40:45 CST 2011 (
tyrone@sw3-code-build-srv-02)
Copyright (C) 2000-2009 Broadcom Corporation.
HS Serial flash device: name MX25L32, id 0xc216 size 4096KB
Total Flash size: 4096K with 79 sectors
Flash not used for Auxillary File System
Chip ID: BCM6328B0, MIPS: 320MHz, DDR: 320MHz, Bus: 160MHz
Main Thread: TP0
Memory Test Passed
Total Memory: 67108864 bytes (64MB)
Boot Address: 0xb8000000
** Flash image not found. **
Board IP address : 192.168.1.1:ffffff00
Host IP address : 192.168.1.100
Gateway IP address :
Run from flash/host (f/h) : f
Default host run file name : vmlinux
Default host flash file name : bcm963xx_fs_kernel
Boot delay (0-9 seconds) : 1
Board Id (0-7) : DSL100N-B1 v2
Number of MAC Addresses (1-32) : 10
Base MAC Address : 00:10:18:00:00:00
PSI Size (1-64) KBytes : 24
Enable Backup PSI [0|1] : 0
System Log Size (0-256) KBytes : 0
Flash Block Size (1-128) in KBytes: 64
Auxillary File System Size Percent: 0
Main Thread Number [0|1] : 0
Serial Number : 47900001FA3B98504
Password for Useradmin : 0019cb000001
SSID for first wireless (10-31) : Huatian
Password for first wireless (8-31): 0019cb000001
PA(e=External PA,i=Internal PA) : i
Minimal Core Max Size (0-2097152) in Bytes: 0
The Max Size of Minimal Core is 0, can't boot Minimal Core Successfully
login:telecomadmin
Password:
