  • 3437阅读
  • 19回复
[钟表]自己用单片机制作电子万年历 [复制链接]
离线sworderchina
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2015-03-12
万年历制作原理图和代码分享给大家,本人是一个机械出生,自己喜欢搞电子分享给大家,希望大家做自己的个性时钟吧。
怕大家误会时间不准,本只做用了ds1302,三个电容断电记忆5个小时保持没问题,
日期和礼拜不需要再编程的
#include<stc.h>
#define uchar unsigned char
#define uint unsigned int
#define write_second 0x80
#define write_minute 0x82
#define write_hour 0x84
#define write_tian 0x86
#define write_yue 0x88
#define write_nian 0x8c
#define write_zhou 0x8a
#define read_miao 0x81
#define read_fen 0x83
#define read_xiaoshi 0x85
#define read_tian  0x87
#define read_yue   0x89
#define read_nian  0x8d
#define read_zhou  0x8b
#define write_protect 0x8e
sbit rst=P2^2;
sbit sclk=P2^1;
sbit io=P2^0;
sbit change=P2^6;
sbit set=P2^7;
sbit shi=P2^5;
sbit fen=P2^4;
sbit miao=P2^3;
sbit sh=P3^2;
sbit ds=P3^3;
sbit st=P3^4;
sbit sh1=P3^5;
sbit ds1=P3^6;
sbit st1=P3^7;
uchar temp=0;
uchar count,bian;
uchar hou,miu,sec,nian,yue,ri,xinqi,zhou;
uchar g,s,b,q,w,sw;
uchar g1,s1,b1,q1,w1,sw1;
unsigned char code numtab[16]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90,0x88,0x83,0xC6,0xA1,0x86,0xbf};
uchar code wx[8]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
//74hc595驱动函数
dr_595(unsigned char dat)
unsigned char temp1;
st=0;
for(temp1=0;temp1<8;temp1++)
    sh=0;
    dat=dat<<1;
    ds=CY;
    sh=1;
    sh=0;
st=1;
st=0;
dr_595_1(unsigned char dat)
st1=0;
    sh1=0;
    dat=dat<<1;
    ds1=CY;
    sh1=1;
    sh1=0;
st1=1;
st1=0;
//写8位字符串数据
void DS1302_Write(uchar D)
uchar i;
for(i=0;i<8;i++)
io=D&0x01;
sclk=1;
sclk=0;
D=D>>1;
//写地址和数据
void WDS1302(uchar ucAddr, uchar ucDat)
rst = 0;
sclk = 0;
rst = 1;
DS1302_Write(ucAddr);
DS1302_Write(ucDat);
sclk = 1;
rst = 0;
//读一串数据
uchar DS1302_Read()
uchar TempDat=0,i;
    for(i=0;i<8;i++)
    TempDat>>=1;
    if(io) TempDat=TempDat|0x80;
    sclk=1;
    sclk=0;
return TempDat;
//写地址然后读数据
uchar read1302(uchar ucAddr)
uchar ucDat;
rst = 0;
sclk = 0;
rst = 1;
ucDat=DS1302_Read();
sclk = 1;
rst = 0;
return ucDat;
void init()
WDS1302(0x8e,0x00);//关闭保护寄存器
WDS1302(0x80,0x58);//秒
WDS1302(0x82,0x30);//分
WDS1302(0x84,0x12);//时
WDS1302(0x8A,0x07);//星期
WDS1302(0x86,0x16);//日
WDS1302(0x88,0x07);//月
WDS1302(0x8C,0x14);//年
WDS1302(0x90,0xa5);//充电
WDS1302(0x8e,0x80);//开保护
void InitTimer0(void)
    TMOD = 0x01;
    TL0 = 0x91;        //设置定时初值
    TH0 = 0xFF;        //设置定时初值
    EA = 1;
    ET0 = 1;
    TR0 = 1;
chuli_t()
    sec=read1302(read_miao);
    miu=read1302(read_fen);
    hou=read1302(read_xiaoshi);
    nian=read1302(read_nian);
    yue=read1302(read_yue);
    ri=read1302(read_tian);
    zhou=read1302(read_zhou);
       g=sec%16;
       g1=zhou%16;
       s=sec/16;
       //s1=ri/16;
       b=miu%16;
       b1=ri%16;
       q=miu/16;
       q1=ri/16;
       w=hou%16;
       w1=yue%16;
       sw=hou/16;
       sw1=yue/16;
chuli_n()
       g=sec%16;
       g1=ri%16;
       s=sec/16;
       s1=ri/16;
       b=miu%16;
       b1=yue%16;
       q=miu/16;
       q1=yue/16;
       w=hou%16;
       w1=nian%16;
       sw=hou/16;
       sw1=nian/16;
void Delay100us()        //@16MHz
    unsigned char i, j;
    i = 10;
    j = 83;
    do
        while (--j);
    } while (--i);
void main(void)
     InitTimer0();
    xinqi=0;
    while(change==0)init();
    while(1)
    xinqi=0;
    chuli_t();
      while(change==0)
            chuli_t();
                    WDS1302(0x8e,0x00);
                    if(miao==0)
                       count=read1302(read_miao)%16+read1302(read_miao)/16*10;
                       while(miao==0);
                        Delay100us();
                       count++;
                       if(count==60)
                        count=0;
                        bian=count%10+count/10*16;
                        WDS1302(write_second,bian);
                        else if(fen==0)
                        count=read1302(read_fen)%16+read1302(read_fen)/16*10;
                            while(fen==0); Delay100us();
                            count++;
                            if(count==60)
                            count=0;
                            WDS1302(write_minute,bian);
                        else if(shi==0)
                            count=read1302(read_xiaoshi)%16+read1302(read_xiaoshi)/16*10;
                            while(shi==0); Delay100us();
                            count++;
                            if(count==24)
                            count=0;
                            WDS1302(write_hour,bian);
              chuli_t();
              WDS1302(0x8e,0x80);
while(shi==0)
chuli_t();
    WDS1302(0x8e,0x00);
    if(miao==0)
        count=read1302(read_zhou)%16+read1302(read_zhou)/16*10;
        while(miao==0);
        Delay100us();
        count++;
        if(count==8)
             count=1;
        WDS1302(write_zhou,bian);
    WDS1302(0x8e,0x80);
while(set==0)
{       xinqi=1;
        chuli_n();
        WDS1302(0x8e,0x00);
        if(miao==0)
            count=read1302(read_tian)%16+read1302(read_tian)/16*10;
            while(miao==0); Delay100us();
            count++;
            if(count==32)
            count=1;
            WDS1302(write_tian,bian);
        else if(fen==0)
                count=read1302(read_yue)%16+read1302(read_yue)/16*10;
                if(fen==0)
                    count++;
                    if(count==13)
                    count=1;
                    WDS1302(write_yue,bian);
                        miu=read1302(read_yue);
        else if(shi==0)
        count=read1302(read_nian)%16+read1302(read_nian)/16*10;
            if(shi==0)
             count++;
            if(count==21)
            count=14;
            WDS1302(write_nian,bian);
    WDS1302(0x8e,0x80);
void Timer0Interrupt(void) interrupt 1
           temp++;
     if(temp==8)temp=0;
     switch(temp)
           case 0:P0=0xff;
                  dr_595(numtab[g]);
                  if(xinqi==1)
                  dr_595_1(numtab[g1]);
                  else dr_595_1(numtab[g1]);
                  P0=wx[7];
                  break;
           case 1:P0=0xff;
                  dr_595(numtab[s]);
                  if(xinqi==1)
                  dr_595_1(numtab[s1]);
                  else dr_595_1(0xff);
                  P0=wx[6];
                  break;
           case 2:P0=0xff;
                  dr_595(0xbf);
                  if(xinqi==1)
                  dr_595_1(0xbf);
                  P0=wx[5];
                  break;              //第6位显示横码
           case 3:P0=0xff;
                  dr_595(numtab);
                  dr_595_1(numtab[b1]);
                  P0=wx[4];
                  break;
           case 4:P0=0xff;
                  dr_595(numtab[q]);
                  dr_595_1(numtab[q1]);
                  P0=wx[3];
                  break;
           case 5:P0=0xff;
                  dr_595(0xbf);
                  dr_595_1(0xbf);
                  P0=wx[2];
                  break;                 //第三位显示横码
           case 6:P0=0xff;
                  dr_595(numtab[w]);
                  dr_595_1(numtab[w1]);
                  P0=wx[1];
                  break;
           case 7:P0=0xff;
                  dr_595(numtab[sw]);
                  dr_595_1(numtab[sw1]);
                  P0=wx[0];
                  break;
[ 此帖被sworderchina在2015-03-12 20:50重新编辑 ]
本帖最近打赏记录:共15条打赏 ,M币+38
12
离线jshya2011
只看该作者 1楼 发表于: 2015-03-12
离线锰子
只看该作者 2楼 发表于: 2015-03-12
离线jpdd521
只看该作者 3楼 发表于: 2015-03-12
离线abigbell
只看该作者 4楼 发表于: 2015-03-12
本帖最近打赏记录:共3条打赏 ,M币+7
离线xtmk
只看该作者 5楼 发表于: 2015-03-12
离线lajizhuce
只看该作者 6楼 发表于: 2015-03-12
离线xingji000001
只看该作者 7楼 发表于: 2015-03-12
离线huzhizhang
只看该作者 8楼 发表于: 2015-03-12
离线smw
只看该作者 9楼 发表于: 2015-03-12
