本人的优盘是金士顿的2.0 16G 但是检测不出来是G2还是G3 黑色的外壳上也没有标明
外壳造型就是带金属旋转保护壳的
谢谢大大们了
错误代码是1106。。原来的主人把这优盘量产了一个隐藏分区
现在想恢复过来,可是量产工具恢复不能。。
金士顿低格工具也不行 ,错误代码-2
现在插机器上显示盘符。。但是没有容量
双击提示 请插入磁盘
[ 2015-03-30 15:48:30 ]
OS Version: Win 7
MP Version: 2.090 (2014.08.15)
PC Name : []
DUT Slot: 0
Driver : F
IC Type : 1D-1
ISP Type: 1
F-Slot : 1
0:00.0 -------------------------------------
0:00.0 New Flow Initial ... 2090
0:00.0 + INQ:........ 2267 SORTER V1.01.00PMAP1234
0:01.1 + ISP Version : OS61 Ver 1.06k (2014.08.07-1)
0:01.1 + Flash Unit Index = 24 / (71) / 628
0:01.1 - ID: 98-DE-98-92-72-57 x 2
0:01.1 - Mask: FF-FF-4F-FF-FF-8F
0:01.1 - Flash Parameters : 19nm,x8,4168,86,16, HW.ECC=60,844
0:01.1 Flash Notes: Toshiba 19nm eD3 (Check)
0:01.1 + New CE Mode_3=02, CEMask=11
0:01.3 + ECC setting : 60, 60, 50
0:01.3 * Model=1D-1-1
0:01.3 - UP23, TH58NVG7T2JTA(2CE)(eD3.8K)
0:01.3 + Total effective blocks = 2 x 1 x 4168 = 8336
0:01.3 + Bad Column Init ...
0:01.3 -------------------------------------
0:01.3 Test & Scan Stage ... 1 FSlot mode
0:01.3 [ Low Level Format + TestMode=7 ]
0:01.3 >> SmartEcc=1, Ecc=0
0:01.3 >> Mode=3, Optimize=0, SizeMode=0
0:01.3 >> Max ECC = D1(45), D3(20,50,D1+D3=50)
0:01.3 + Smart Test ... 0000-0000
0:01.3 + INQ:........ 2267 SORTER V1.01.00PMAP1234
0:01.3 + ISP Version : OS61 Ver 1.06k (2014.08.07-1)
0:01.3 + GPIO = FF,06,FF,FF
0:01.3 + New CE Mode_3=02, CEMask=11
0:01.6 + ECC setting : 60, 60, 50
0:01.6 + Set Retry Table (19 eD3 D1).
0:01.6 + CE=2, Page Layout Mode = 0, MaxWL=86
0:01.6 + Total effective blocks = 2 x 1 x 4168 = 8336
0:01.6 +-----------------------------------------------------+
0:28.5 * Erase takes 00:00:26, (Found 0 NoResponse Blocks) 0, Continue Error=0
0:33.1 + Smart Flash Pin Check takes 00:00:04, 86 Pages are OK, 0 Pages Error
0:33.1 Influence Test:C0,D0,P0,G0,Block:0000
0:33.4 Influence Test:C0,D0,P1,G0,Block:0001
0:33.7 Influence Test:C1,D0,P0,G0,Block:0000
0:34.0 Influence Test:C1,D0,P1,G0,Block:0001
0:34.3 + Page Influence Test takes 00:00:01
0:41.8 + Smart Test-W Sec(35776,0,0,0,0/0,0,0,0,0)
0:41.8 + Smart Test-W Pg(4472,0,0,0,0/0,0,0,0,0)
0:41.8 + Multi write P:0 Page A Bad Sec(0,0,0,0,0/0,0,0,0,0)
0:41.8 + Multi write P:0 Page A Error bit(90,0,0,0,0/0,0,0,0,0)
0:41.8 + Multi write P:1 Page A Bad Sec(0,0,0,0,0/0,0,0,0,0)
0:41.8 + Multi write P:1 Page A Error bit(57,0,0,0,0/0,0,0,0,0)
0:41.8 - F0: Sector Best Multi-Write is 1
0:41.8 - F0: Page Best Multi-Write is 1
0:41.8 - Final Select 1 Multi-Write.
0:59.3 + Smart Test-0-Loop:0 (552,432,528,528,480,584), Select=0
0:59.3 + Conversion on get worse ,Final Select=0
0:59.3 >>> IC Type:0x1d ,Use Max Group Bad Column 64 Set <<<
1:13.5 + SecGood[]=0/860,1/860,2/860,3/860,4/860,5/860,6/860,7/860,
1:16.9 - SecMask=FF, Paramters=6880,286,6880,3.00
1:16.9 + Free PC RAM: 4095/4095 MB
1:20.8 + Parameter Test-1 takes 00:00:03, Select 4 (3072,3072,3072,3072,3072)
1:23.3 + Parameter Test-2 takes 00:00:02, Select 1 (3072,3072,3072,3072) 24
1:32.3 + Block-11224488 takes 00:00:08
1:36.1 + Parameter Test-3 takes 00:00:03, Select 2 (-,3072+3072,3072+3072,3072,3072)
1:40.9 + Parameter Test-4 takes 00:00:04, Find 0 better, Find 0 worse, And Full=0(0.00,0.00,0.00,0.00,0.00)
4:19.3 --- Full Page Mode (86) --
4:19.3 +-----------------------------------------------------+
25:38.8 * Write/Read takes 00:21:19, Found 0/8336 Big Difference Block
25:39.0 + Error Calculation-1 ... Select Max Error = 20
25:39.6 + Finding Best Mode ... M=1,E=20,P=86,S=00FF,Opt=10 --> 8322(5725536)
25:40.2 + Finding Best Mode2 ... M=1,E=20,P=86,S=00FF,Opt=10 --> 8322(5725536)
25:40.2 + [Find Best Mode] Pickup-1, 5725536>=5725536, Mode=1, 1:[5725536,86,00FF,0.546], 2:[5725536,86,00FF,0.561]
25:40.2 + Calculate_GoodBlocks: (Mode=1, Mask=FF,20), Flag=0002
25:40.3 - Good Blocks=8322, Bad Blocks=14
25:40.3 + Calculate Disk Size: (Mode=1, Mask=FF, Ecc=20)
25:40.3 - FW Spare = 32,41
25:40.4 - CE=0,DIE=0, Plane=0: Good Block(E=2081,O=2081,F=4162)=Size(1370,1370,2741)
25:40.4 - CE=1,DIE=0, Plane=0: Good Block(E=2080,O=2080,F=4160)=Size(1369,1369,2739)
25:40.4 - Mode=1: (E=2740,O=2740,F=5481), Size=5481 MB, HP=00
25:40.4 + Set Retry Table (19 eD3).
25:40.4 +-----------------------------------------------------+
25:50.9 + Smart Test D1/D3 PreTest ... F=0/20
25:50.9 +-----------------------------------------------------+
25:50.9 - FW Spare = 32,105
74:15.0 * D3 Write/Read Test-4 takes 00:48:24, Found 25498/86,7896
91:51.2 * Read Test takes 00:17:36, (Found 109840+96 Bad Sectors), 0 WeakGroup
91:51.6 + Error Calculation-2 ... Select Max Error = 30
91:51.9 + Start Week Flash Dectect......
91:51.9 + Week Flash Dectect Mode ,Select Max Error(30) < 40 bit,Change Select Max Error to 40 bit
91:52.2 + C:0,D:0,P0 D1 MaxE= 2, MinE= 0, Diff ECC = 2
91:52.2 + C:1,D:0,P0 D1 MaxE= 2, MinE= 0, Diff ECC = 2
91:52.2 + D1 MaxDifEcc=2, D3 ECC = 50 --> 48
91:52.2 + Update D3 Ecc Error Calculation ... Select Max Error = 48
91:52.8 + Error Calculation-2 ... Select Max Error = 48
91:54.7 + Finding Best Mode ... M=2,E=48,P=86,S=00FF,Opt=10 --> 7792(16082688)
91:56.3 + Finding Best Mode2 ... M=2,E=48,P=86,S=00FF,Opt=10 --> 7792(16082688)
91:56.3 + [Find Best Mode] Pickup-1, 16082688>=16082688, Mode=2, 1:[16082688,86,00FF,1.576], 2:[16082688,86,00FF,1.575]
91:57.8 + Finding Best Mode ... M=2,E=48,P=86,S=00FF,Opt=10 --> 7796(10727296)
91:59.3 + Finding Best Mode2 ... M=2,E=48,P=86,S=00FF,Opt=10 --> 7796(10727296)
91:59.3 + [Find Best Mode] Pickup-1, 10727296>=10727296, Mode=2, 1:[10727296,86,00FF,1.513], 2:[10727296,86,00FF,1.498]
92:00.8 + Finding Best Mode ... M=2,E=48,P=86,S=00FF,Opt=10 --> 7792(10721792)
92:02.3 + Finding Best Mode2 ... M=2,E=48,P=86,S=00FF,Opt=10 --> 7792(10721792)
92:02.3 + [Find Best Mode] Pickup-1, 10721792>=10721792, Mode=2, 1:[10721792,86,00FF,1.513], 2:[10721792,86,00FF,1.498]
92:03.8 + Finding Best Mode ... M=2,E=48,P=86,S=00FF,Opt=10 --> 7792(10721792)
92:05.3 + Finding Best Mode2 ... M=2,E=48,P=86,S=00FF,Opt=10 --> 7792(10721792)
92:05.3 + [Find Best Mode] Pickup-1, 10721792>=10721792, Mode=2, 1:[10721792,86,00FF,1.513], 2:[10721792,86,00FF,1.498]
92:05.3 + Calculate Disk Size (D3 Only): Mask=FF, Ecc=48, SubD1=1,PgMask=00
92:05.9 - Calculate D3 Size (E=3896,O=3896,F=7792), Size=15697 MB, HP=00, PgMask=00
92:05.9 + Calculate Disk Size (D3 Only): Mask=FF, Ecc=48, SubD1=1,PgMask=00
92:06.6 - Calculate D3 Size (E=3896,O=3896,F=7792), Size=15697 MB, HP=00, PgMask=00
92:06.6 + Calculate Disk Size (D3 Only): Mask=FF, Ecc=48, SubD1=1,PgMask=00
92:07.2 - Calculate D3 Size (E=3896,O=3896,F=7792), Size=15697 MB, HP=00, PgMask=00
92:07.2 - F0: Select D3 Mode, 5481 < 15697 (FF)
92:07.2 +-----------------------------------------------------+
92:07.2 + Reverse Test ... ... (00FF), DWL=0, Tm=33, TestPage=0-th
92:10.2 + 440 Block been tested, 0 New Error Block
92:10.2 + Double Check Block Scan ... 0-0(00FF), Marker=C2
92:10.7 + 0-0-0000: ..................................XX..........................XX
92:11.2 + 0-0-0040: ................................................................
92:11.8 + 0-0-0080: ................................................................
92:12.0 + 0-0-00C0: ................................XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.1 + 0-0-0100: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.1 + 0-0-0140: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.1 + 0-0-0180: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.1 + 0-0-01C0: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.1 + 0-0-0200: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.1 + 0-0-0240: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.1 + 0-0-0280: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.1 + 0-0-02C0: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.1 + 0-0-0300: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.1 + 0-0-0340: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.1 + 0-0-0380: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.2 + 0-0-03C0: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.2 + 0-0-0400: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.2 + 0-0-0440: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.2 + 0-0-0480: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.2 + 0-0-04C0: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.2 + 0-0-0500: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.2 + 0-0-0540: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.2 + 0-0-0580: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.2 + 0-0-05C0: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.2 + 0-0-0600: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.3 + 0-0-0640: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.3 + 0-0-0680: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.3 + 0-0-06C0: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.3 + 0-0-0700: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.3 + 0-0-0740: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.3 + 0-0-0780: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.3 + 0-0-07C0: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.3 + 0-0-0800: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.3 + 0-0-0840: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.3 + 0-0-0880: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.3 + 0-0-08C0: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.4 + 0-0-0900: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.4 + 0-0-0940: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.4 + 0-0-0980: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.4 + 0-0-09C0: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.4 + 0-0-0A00: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.4 + 0-0-0A40: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.4 + 0-0-0A80: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.4 + 0-0-0AC0: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.4 + 0-0-0B00: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.4 + 0-0-0B40: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.4 + 0-0-0B80: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.5 + 0-0-0BC0: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.5 + 0-0-0C00: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.5 + 0-0-0C40: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.5 + 0-0-0C80: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.5 + 0-0-0CC0: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.5 + 0-0-0D00: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.5 + 0-0-0D40: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.5 + 0-0-0D80: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.5 + 0-0-0DC0: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.5 + 0-0-0E00: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.5 + 0-0-0E40: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.5 + 0-0-0E80: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.6 + 0-0-0EC0: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.6 + 0-0-0F00: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.6 + 0-0-0F40: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.6 + 0-0-0F80: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.6 + 0-0-0FC0: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.6 + 0-0-1000: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:12.6 + 0-0-1040: XXXXXXXX
92:13.2 + 1-0-0000: ................................................................
92:13.7 + 1-0-0040: ................................................................
92:14.3 + 1-0-0080: ................................................................
92:14.5 + 1-0-00C0: ............................XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.5 + 1-0-0100: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.5 + 1-0-0140: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.5 + 1-0-0180: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.5 + 1-0-01C0: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.6 + 1-0-0200: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.6 + 1-0-0240: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.6 + 1-0-0280: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.6 + 1-0-02C0: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.6 + 1-0-0300: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.6 + 1-0-0340: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.6 + 1-0-0380: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.6 + 1-0-03C0: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.6 + 1-0-0400: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.6 + 1-0-0440: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.6 + 1-0-0480: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.6 + 1-0-04C0: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.6 + 1-0-0500: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.6 + 1-0-0540: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.6 + 1-0-0580: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.6 + 1-0-05C0: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.6 + 1-0-0600: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.6 + 1-0-0640: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.6 + 1-0-0680: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.6 + 1-0-06C0: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.6 + 1-0-0700: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.6 + 1-0-0740: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.6 + 1-0-0780: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.6 + 1-0-07C0: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.6 + 1-0-0800: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.6 + 1-0-0840: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.6 + 1-0-0880: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.6 + 1-0-08C0: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.6 + 1-0-0900: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.7 + 1-0-0940: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.7 + 1-0-0980: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.7 + 1-0-09C0: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.7 + 1-0-0A00: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.7 + 1-0-0A40: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.7 + 1-0-0A80: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.7 + 1-0-0AC0: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.7 + 1-0-0B00: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.7 + 1-0-0B40: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.7 + 1-0-0B80: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.7 + 1-0-0BC0: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.7 + 1-0-0C00: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.7 + 1-0-0C40: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.7 + 1-0-0C80: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.7 + 1-0-0CC0: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.7 + 1-0-0D00: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.7 + 1-0-0D40: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.7 + 1-0-0D80: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.7 + 1-0-0DC0: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.7 + 1-0-0E00: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.7 + 1-0-0E40: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.7 + 1-0-0E80: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.7 + 1-0-0EC0: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.7 + 1-0-0F00: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.7 + 1-0-0F40: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.7 + 1-0-0F80: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.7 + 1-0-0FC0: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.7 + 1-0-1000: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
92:14.7 + 1-0-1040: XXXXXXXX
92:14.7 - 440 Block been scanned, 0 New Error Block
92:41.7 * Erase takes 00:00:26, (Found 0 NoResponse Blocks) 0, Continue Error=0
92:41.7 + New ISP to Save IB Table.
92:41.7 + Free PC RAM: 4095/4095 MB
92:41.7 [D1 Good Block] .. C2
92:41.7 + CE-0:0000,0001,0002,0003,0004,0005,0006,0007,0008,0009,000A,000B,000C,000D,000E,000F,
92:41.7 0010,0011,0012,0013,0014,0015,0016,0017,0018,0019,001A,001B,001C,001D,001E,001F,
92:41.7 0020,0021,0024,0025,0026,0027,0028,0029,002A,002B,002C,002D,002E,002F,0030,0031,
92:41.7 0032,0033,0034,0035,0036,0037,0038,0039,003A,003B,003C,003D,0040,0041,0042,0043,
92:41.7 0044,0045,0046,0047,0048,0049,004A,004B,004C,004D,004E,004F,0050,0051,0052,0053,
92:41.7 0054,0055,0056,0057,0058,0059,005A,005B,005C,005D,005E,005F,0060,0061,0062,0063,
92:41.7 0064,0065,0066,0067,0068,0069,006A,006B,006C,006D,006E,006F,0070,0071,0072,0073,
92:41.7 0074,0075,0076,0077,0078,0079,007A,007B,007C,007D,007E,007F,0080,0081,0082,0083,
92:41.7 0084,0085,0086,0087,0088,0089,008A,008B,008C,008D,008E,008F,0090,0091,0092,0093,
92:41.7 0094,0095,0096,0097,0098,0099,009A,009B,009C,009D,009E,009F,00A0,00A1,00A2,00A3,
92:41.7 00A4,00A5,00A6,00A7,00A8,00A9,00AA,00AB,00AC,00AD,00AE,00AF,00B0,00B1,00B2,00B3,
92:41.7 00B4,00B5,00B6,00B7,00B8,00B9,00BA,00BB,00BC,00BD,00BE,00BF,00C0,00C1,00C2,00C3,
92:41.7 00C4,00C5,00C6,00C7,00C8,00C9,00CA,00CB,00CC,00CD,00CE,00CF,00D0,00D1,00D2,00D3,
92:41.7 00D4,00D5,00D6,00D7,00D8,00D9,00DA,00DB,00DC,00DD,00DE,00DF,
92:41.7 + CE-1:0000,0001,0002,0003,0004,0005,0006,0007,0008,0009,000A,000B,000C,000D,000E,000F,
92:41.7 0020,0021,0022,0023,0024,0025,0026,0027,0028,0029,002A,002B,002C,002D,002E,002F,
92:41.7 0030,0031,0032,0033,0034,0035,0036,0037,0038,0039,003A,003B,003C,003D,003E,003F,
92:41.7 0040,0041,0042,0043,0044,0045,0046,0047,0048,0049,004A,004B,004C,004D,004E,004F,
92:41.7 0050,0051,0052,0053,0054,0055,0056,0057,0058,0059,005A,005B,005C,005D,005E,005F,
92:41.7 0060,0061,0062,0063,0064,0065,0066,0067,0068,0069,006A,006B,006C,006D,006E,006F,
92:41.7 0070,0071,0072,0073,0074,0075,0076,0077,0078,0079,007A,007B,007C,007D,007E,007F,
92:41.7 0080,0081,0082,0083,0084,0085,0086,0087,0088,0089,008A,008B,008C,008D,008E,008F,
92:41.7 0090,0091,0092,0093,0094,0095,0096,0097,0098,0099,009A,009B,009C,009D,009E,009F,
92:41.7 00A0,00A1,00A2,00A3,00A4,00A5,00A6,00A7,00A8,00A9,00AA,00AB,00AC,00AD,00AE,00AF,
92:41.7 00B0,00B1,00B2,00B3,00B4,00B5,00B6,00B7,00B8,00B9,00BA,00BB,00BC,00BD,00BE,00BF,
92:41.7 00C0,00C1,00C2,00C3,00C4,00C5,00C6,00C7,00C8,00C9,00CA,00CB,00CC,00CD,00CE,00CF,
92:41.7 00D0,00D1,00D2,00D3,00D4,00D5,00D6,00D7,00D8,00D9,00DA,00DB,
92:41.7 - Total 440 Good D1 Blocks
92:41.7 [D3 DefectBlock] .. C4
92:41.7 0030,0031,0032,0033,0034,0035,0036,0037,0038,0039,003A,003B,003C,003D,0040,0041,
92:41.7 0042,0043,0044,0045,0046,0047,0048,0049,004A,004B,004C,004D,004E,004F,0050,0051,
92:41.7 0052,0053,0054,0055,0056,0057,0058,0059,005A,005B,005C,005D,005E,005F,0060,0061,
92:41.7 0062,0063,0064,0065,0066,0067,0068,0069,006A,006B,006C,006D,006E,006F,0070,0071,
92:41.7 0072,0073,0074,0075,0076,0077,0078,0079,007A,007B,007C,007D,007E,007F,0080,0081,
92:41.7 0082,0083,0084,0085,0086,0087,0088,0089,008A,008B,008C,008D,008E,008F,0090,0091,
92:41.7 0092,0093,0094,0095,0096,0097,0098,0099,009A,009B,009C,009D,009E,009F,00A0,00A1,
92:41.7 00A2,00A3,00A4,00A5,00A6,00A7,00A8,00A9,00AA,00AB,00AC,00AD,00AE,00AF,00B0,00B1,
92:41.7 00B2,00B3,00B4,00B5,00B6,00B7,00B8,00B9,00BA,00BB,00BC,00BD,00BE,00BF,00C0,00C1,
92:41.7 00C2,00C3,00C4,00C5,00C6,00C7,00C8,00C9,00CA,00CB,00CC,00CD,00CE,00CF,00D0,00D1,
92:41.7 00D2,00D3,00D4,00D5,00D6,00D7,00D8,00D9,00DA,00DB,00DC,00DD,00DE,00DF,016E,016F,
92:41.7 02F0,02F1,031E,031F,0320,0321,0FE8,0FE9,0FEA,0FEB,0FEC,0FED,0FEE,0FEF,0FF0,0FF1,
92:41.7 0FF2,0FF3,0FF4,0FF5,0FF6,0FF7,0FF8,0FF9,0FFA,0FFB,0FFC,0FFD,0FFE,0FFF,1000,1001,
92:41.7 1002,1003,1004,1005,1006,1007,1008,1009,100A,100B,100C,100D,100E,100F,1010,1011,
92:41.7 1012,1013,1014,1015,1016,1017,1018,1019,101A,101B,101C,101D,101E,101F,1020,1021,
92:41.7 1022,1023,1024,1025,1026,1027,1028,1029,102A,102B,102C,102D,102E,102F,1030,1031,
92:41.7 1032,1033,1034,1035,103C,103D,103E,103F,1040,1041,
92:41.7 00D0,00D1,00D2,00D3,00D4,00D5,00D6,00D7,00D8,00D9,00DA,00DB,0AE4,0AE5,0B80,0B81,
92:41.7 0D1C,0D1D,0D50,0D51,1008,1009,
92:41.7 - Total 544 Bad D3 Blocks
92:41.7 O.PA[]=OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
92:41.7 O.SA[]=OOOOOOOO
92:41.7 + Calculate User BIN ... CE(0-1)
92:41.7 - Bad Wl = 0,0
92:41.7 - FW Spare = 32,105
92:41.7 - Calculate capacity D3 : WL(Good/Bad) = 86 / 0
92:41.7 + Calculate Disk Size (D3 Only):
92:41.7 - Calculate D3 Good Block (E=3896,O=3896,F=7792)
92:41.7 - Size= 15697 =(7792-4) x (86) x (8-0) x 3 / 1024
92:41.7 <MaxSize> Physical Size=15697 (MB), Selected Size=15697 (MB)
92:41.7 + Setup Parameters for IB-Table ... Slot-0
92:41.7 PA[]=OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
92:41.7 SA[]=OOOOOOOO
92:41.7 - F0: Total Sector=8, Pages for IB=1
92:41.7 - EvenZonePage[]=0,1,2,3, OddZonePage[]=0,1,2,3
92:41.7 + 40(00) / OBC:40(00)
92:41.7 + Not found OLD IB, Save a newer
92:41.7 -------------------------------------------
92:41.7 + Install IB-Table ... Page=8 K, Skip=0000, TM=33, MBC=0, EM=C3
92:41.7 - SecMapping :0(0),1(1),2(2),3(3),4(4),5(5),6(6),7(7),
92:41.7 - Toshiba 19/24nm block pair (0000-0001)
92:41.7 - Good/Plane=1927,1927,
92:41.9 --> IB-block verified Pass (0-0000).
92:41.9 - Toshiba 19/24nm block pair (0000-0001)
92:41.9 - Good/Plane=1969,1969,
92:42.1 --> IB-block verified Pass (1-0000).
92:42.2 - F0: Shrink Check DiskSize (15697 > 15370), ** Shrink it **
92:42.2 --------------------------------------------------------------------------------
92:42.2 DoPreFormat ... ... BurnerMode=1
92:42.2 - TestMode=1, D3Mode=1, Dummy=0, Full=0, Skip=0000, IBTMode=40
92:42.2 - FW(13)=<>
92:42.2 + Burner Process 2 Start ... MW=1
92:42.2 + INQ:........ 2267 SORTER V1.01.00PMAP1234
92:42.2 + Smart Test ISP Version : OS61 Ver 1.06k (2014.08.07-1)
92:42.2 + New CE Mode_3=02, CEMask=11
92:42.4 + Set Flash Timing = 33 ns (4)
92:42.4 + ECC setting : 60, 60, 50
92:42.4 R.PA[]=POOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOPOPPPOOOOOOOOOOOOOOOPOOOOOOOOOOOOOOOOOOOOO
92:42.4 - 8 / 8 Sector Available for CZ block, CZ Page= 1.
92:42.4 ### Err: ISP file not found
92:42.4 ### F0, Err:1106 ###
92:42.4 + NewBurnerPage[]=PZOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOPOPPPOOOOOOOOOOOOOOOPOOOOOOOOOOOOOOOOOOOOO
92:42.4 ### Err: Burner Process2 fail
92:42.4 ### Err(0002): DoPreFormat Error
92:42.4 [RESULT] ErrorCode : 1106
92:42.4 + Static Summary: B=0 ,P=0 ,S=0 ,Others=0 ,D1B=0 ,D1P=0 ,D1S=0 ,D1Others=0 ,
[ 2015-03-30 17:21:13 ]
[ UPTool takes 01:32:43 ]
