  • 2930阅读
  • 8回复
[SandForce]2281 6贴 开卡每次都20%失败 [复制链接]
离线sclwindows
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2015-05-02
好久不玩ssd了,今天买了个清空器,
6贴 128G08CFAAB 开卡每次都20%失败
22437 开6贴失败 8贴22187当然也失败 4贴22452 pass
所有F都清空过 坏块4个
请教啊
2281 6贴 开卡每次都20%失败
Starting command:[/home/scl/ssd/soft/SF_Genesis -PROCESS_SSD 1:0:0:0 "/home/scl/ssd/mpt/FW_SF-2000_MP_5-0-7_Client--123456/FW_SF-2000_MP_5-0-7_Client.123456.mfp" "/home/scl/ssd/mpt/FW_SF-2000_MP_5-0-7_Client--123456/22437.123456.90G.driveconfig" 12345 12345  LOG="/home/scl/ssd/mpt/FW_SF-2000_MP_5-0-7_Client--123456/Configuration_Files/12345_scl_DATETIMESTAMP_1.0.0.0_PROCESS_SSD_RESULT.log"   ]...
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Sun 05/03/2015 01:35:12] - SF_Genesis has been invoked with the following parameters:
                      argv[1]: -PROCESS_SSD
                      argv[2]: 1:0:0:0
                      argv[3]: /home/scl/ssd/mpt/FW_SF-2000_MP_5-0-7_Client--123456/FW_SF-2000_MP_5-0-7_Client.123456.mfp
                      argv[4]: /home/scl/ssd/mpt/FW_SF-2000_MP_5-0-7_Client--123456/22437.123456.90G.driveconfig
                      argv[5]: 12345
                      argv[6]: 12345
                      argv[7]: LOG=/home/scl/ssd/mpt/FW_SF-2000_MP_5-0-7_Client--123456/Configuration_Files/12345_scl_DATETIMESTAMP_1.0.0.0_PROCESS_SSD_RESULT.log
[Sun 05/03/2015 01:35:12] - Instructing the operating system to purge any existing cached data for device: '1:0:0:0'
[Sun 05/03/2015 01:35:17] - Issuing a discovery command for device: '1:0:0:0'
[Sun 05/03/2015 01:35:23] - Discovery command completed...
[Sun 05/03/2015 01:35:23] - Waiting 5 seconds for the system to settle...
[Sun 05/03/2015 01:35:28] - Device designation string '1:0:0:0' is mapped to node '/dev/sg1'
[Sun 05/03/2015 01:35:28] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg1
    MFP Package Filename = /home/scl/ssd/mpt/FW_SF-2000_MP_5-0-7_Client--123456/FW_SF-2000_MP_5-0-7_Client.123456.mfp
      Configuration File = /home/scl/ssd/mpt/FW_SF-2000_MP_5-0-7_Client--123456/22437.123456.90G.driveconfig
              Serial No. = 12345
         World Wide Name = 12345
[Sun 05/03/2015 01:35:28] - Successfully received the IDENTIFY data from the drive...
[Sun 05/03/2015 01:35:28] - Validating Manufacturing Firmware Package: /home/scl/ssd/mpt/FW_SF-2000_MP_5-0-7_Client--123456/FW_SF-2000_MP_5-0-7_Client.123456.mfp
[Sun 05/03/2015 01:35:32] - Successfully opened the package: /home/scl/ssd/mpt/FW_SF-2000_MP_5-0-7_Client--123456/FW_SF-2000_MP_5-0-7_Client.123456.mfp
[Sun 05/03/2015 01:35:32] - file  /home/scl/ssd/mpt/FW_SF-2000_MP_5-0-7_Client--123456/22437.123456.90G.driveconfig Loaded successfully
[Sun 05/03/2015 01:35:33] - B01 Power Management configuration request detected
[Sun 05/03/2015 01:35:33] - B01 Power Management conforms to hardware version 0x200026BB
[Sun 05/03/2015 01:35:33] - Successfully extracted *.DriveConfig file: /home/scl/ssd/mpt/FW_SF-2000_MP_5-0-7_Client--123456/22437.123456.90G.driveconfig
[Sun 05/03/2015 01:35:33] - Extracted Config_ID: 1 (22437) in DriveConfig file: /home/scl/ssd/mpt/FW_SF-2000_MP_5-0-7_Client--123456/22437.123456.90G.driveconfig
[Sun 05/03/2015 01:35:33] - Extracted SerialOutputControl: 0
[Sun 05/03/2015 01:35:33] - Searching for flashware image for configuration 22437
[Sun 05/03/2015 01:35:33] - Manifest found for configuration 22437
[Sun 05/03/2015 01:35:33] - Flashware image extracted: 22437_fw_cl_mlc_Micron_64Gb_MT29F128G08CFAAAWP_2Q_2C_1D_PP_R01374_s512.vic
[Sun 05/03/2015 01:35:33] - Searching for manufacturing image for configuration 22437
[Sun 05/03/2015 01:35:33] - Manufacturing image extracted: 22437_mf_mlc_Micron_64Gb_MT29F128G08CFAAAWP_2Q_2C_1D_PP_R01374_s512.vic
[Sun 05/03/2015 01:35:33] - Proceeding in non-ROM mode, Download feature 3...
[Sun 05/03/2015 01:35:33] - FATAL_ERROR: Could not download MFB to the drive...(0x11000001:SF_SG_DEVICE_CHECK_CONDITION_ERROR)
Extended Error data:
          ATA COMMAND : 0x0092  (146)
          ATA FEATURE : 0x0003  (3)
         Device Status: 0x0001  (1)
         Driver Status: 0x0000  (0)
           Host Status: 0x0008  (8)
Sense Data:
  0 -         No Sense: 114 (0x72)    OK
  1 -  Recovered Error:  11 (0x0B)    FAIL
  2 -        Not Ready:   0 (0x00)    OK
  3 -     Medium Error:   0 (0x00)    OK
  4 -   Hardware Error:   0 (0x00)    OK
  5 -  Illegal Request:   0 (0x00)    OK
  6 -   Unit Attention:   0 (0x00)    OK
  7 -     Data Protect:  14 (0x0E)    OK
  8 -      Blank Check:   9 (0x09)    OK
  9 -  Vendor Specific:  12 (0x0C)    OK
10 -     Copy Aborted:   0 (0x00)    OK
11 -  Aborted Command:   4 (0x04)    FAIL
12 - Equal Comparison:   0 (0x00)    NA
13 -  Volume Overflow:   0 (0x00)    NA
14 -       Miscompare:   0 (0x00)    OK
15 -         Reserved: 128 (0x80)    NA
System Trace:
[ 1607.420560] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 1607.420606] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1607.421030]  sdb: unknown partition table
[ 1607.421752] sd 1:0:0:0: [sdb] Attached SCSI disk
[ 1643.313790] sd 1:0:0:0: [sdb] Synchronizing SCSI cache
[ 1643.316915] sd 1:0:0:0: [sdb] Stopping disk
[ 1643.343597] ata2.00: disabled
[ 1648.349588] ata2: hard resetting link
[ 1648.809090] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1648.823038] ata2.00: ATA-8: SandForce[565850], 507, max UDMA/133
[ 1648.823050] ata2.00: 125045424 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[ 1648.832807] ata2.00: configured for UDMA/133
[ 1648.832832] ata2: EH complete
[ 1648.833295] scsi 1:0:0:0: Direct-Access     ATA      SandForce[565850 507  PQ: 0 ANSI: 5
[ 1648.833762] sd 1:0:0:0: Attached scsi generic sg1 type 0
[ 1648.833866] sd 1:0:0:0: [sdb] 125045424 512-byte logical blocks: (64.0 GB/59.6 GiB)
[ 1648.833982] sd 1:0:0:0: [sdb] Write Protect is off
[ 1648.833990] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 1648.834039] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1648.834716]  sdb: unknown partition table
[ 1648.839477] sd 1:0:0:0: [sdb] Attached SCSI disk
[ 1822.858116] ata2: exception Emask 0x10 SAct 0x0 SErr 0x90202 action 0xe frozen
[ 1822.858126] ata2: irq_stat 0x00400000, PHY RDY changed
[ 1822.858136] ata2: SError: { RecovComm Persist PHYRdyChg 10B8B }
[ 1822.858150] ata2: hard resetting link
[ 1824.230141] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1824.250067] ata2.00: configured for UDMA/133
[ 1824.250080] ata2: EH complete
[ 1944.604078] sd 1:0:0:0: [sdb] Synchronizing SCSI cache
[ 1944.607427] sd 1:0:0:0: [sdb] Stopping disk
[ 1944.632579] ata2.00: disabled
[ 1949.638240] ata2: hard resetting link
[ 1950.098079] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1950.111495] ata2.00: ATA-8: SandForce[565850], 507, max UDMA/133
[ 1950.111506] ata2.00: 125045424 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[ 1950.121306] ata2.00: configured for UDMA/133
[ 1950.121330] ata2: EH complete
[ 1950.121695] scsi 1:0:0:0: Direct-Access     ATA      SandForce[565850 507  PQ: 0 ANSI: 5
[ 1950.122223] sd 1:0:0:0: Attached scsi generic sg1 type 0
[ 1950.122700] sd 1:0:0:0: [sdb] 125045424 512-byte logical blocks: (64.0 GB/59.6 GiB)
[ 1950.122812] sd 1:0:0:0: [sdb] Write Protect is off
[ 1950.122820] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 1950.122869] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1950.123246]  sdb: unknown partition table
[ 1950.123940] sd 1:0:0:0: [sdb] Attached SCSI disk
[Sun 05/03/2015 01:35:33] - End of Genesis manufacturing log.
[Sun 05/03/2015 01:35:33] - Exiting...
[Sun 05/03/2015 01:35:33] - Overall Result for Device: /dev/sg1 ****** FAIL ******
Process exited with code 20
[ 此帖被sclwindows在2015-05-02 17:58重新编辑 ]
离线pigeonming
只看该作者 1楼 发表于: 2015-05-02
本帖最近打赏记录:共2条打赏M币+6
离线chen7610386
只看该作者 2楼 发表于: 2015-05-02
离线gs800911
只看该作者 3楼 发表于: 2015-05-02
离线zy1313113a
只看该作者 4楼 发表于: 2015-05-02
离线ph3203485
只看该作者 5楼 发表于: 2015-05-02
离线guoke1930
只看该作者 6楼 发表于: 2015-05-02
本帖最近打赏记录:共1条打赏M币+3
离线y781638432
只看该作者 7楼 发表于: 2015-05-03
本帖最近打赏记录:共1条打赏M币+1
离线ph3203485
只看该作者 8楼 发表于: 2015-05-03
本帖最近打赏记录:共1条打赏M币+3
