中文使用手册是繁体中文,操作步骤对应的是V1.65.19.00。下载压缩包里面包含有V1.65.19.00和V1.65.20.00
使用注意事项:
1、务必在Windows XP下使用,尽量用全新的系统;
2、安装完成后,请先运行开始-》所有应用程序-》程序组MFPT中的InfUpdate,然后输入VID=1307 PID=0165
3、最后在运行桌面快捷方式MFPT
UT165 MP Tool V1.65.20.00更新:
Ver 1.65.1.0
1. First formal release
2. Support Samsung 50nm flash only
Ver 1.65.2.0
1. Fix power cycling 0 issue
2. Update F/W
Ver 1.65.5.0
1. Modify format size of K9LAG08U0A Dual channel.
2. Fix some 2k flash 0x88 issue.
3. Solved Power cycling issue.
4. Solved K9HCG08U1M 16CE MP error.
5. Add no read status function for UT165.
6. Improve Readdy Boost performance for Intel flash 29F16G08AAMC1.
7. Disable cache program function for MLC flash.
8. Close "F10 quicktest" function.
Ver 1.65.6.0
1. Delete "F1"select device UT163 function
Ver 1.65.8.0
1. Fix issue: LED idle mode abnormal after loading ERP file.
2. Add MBR support(Default is no-MBR).
Ver 1.65.10.0
1. Improve Micron Readyboost read Performance.
2. Show smooth progress when reverting flash.
3. Public is allowed to set as 0MB if hidden area exist.
4. Add force single channel, force single plane and force single channel + force single plane.
5. Adjust tolerance for Micron MLC flash.
6. Improve small files copy speed.
7. Improve random write performance.
8. Add No_Read_Status function.
9. Add LED Mode blink function.
10. Fix capacity display error of disk check option .
11. Fix status disaply error when erase blk for >=16GB flash.
12. Solved Toshiba 4D4C Burn-In fail (f/w issue).
13. Toshiba 3D4C force single plane 0X48.
14. Fix ReBuild TBL Option.
Ver 1.65.11.0
1. Fixed: Hynix 27UW08CGFM flash dual channel at UT165 BurnInTest fail.
2. Fixed: Micron 29F64G08TAA Dual MP 0X88.
3. Add: MP tool version in the top of MP tool.
4. Fixed Multi ports MP 0x28 Error.
5. Remove AGAND block from MP tool.
6. Hynix 60nm flash R/W cycle timing 83ns and 66ns firmware bug.
7. Add a new option of disk format ¨Format as Windows Size〃
8. Add active write image function.
9. 4CE and 2CE dual channel change R/W cycle to 50ns.
10. Fixed NTFS format issue.
11. Fixed force single plane + single channel MP fail Issue.
12. Impreved Power cycling.
13. Improved small files copy speed.
14. Improved flash quick format speed at WinXP.
15. Fixed: security issue for one disk autorun.
Ver 1.65.12.0
F/W
1. Fixed Hynix 83ns copy/compare error.
2. 0X28 error.
3. Fixed small files copy/compare fail under win2k.
4. Improved WinSAT performance.
5. Read only disk login security can not ready issue.
6. Fixed media change error when write-protect was enable.
MP
1. Korean O.S Display issue.
2. Chinese version not completely.
3. Modify bad block tolerance and BinSelect text.
4. Remove ¨F10〃Function.
5. Capacity check add 64GB.
6. Modify R/W Cycle Option . 4CE set to "default timming", 8CE set to 50ns and 16CE set to 66ns.
7. Modify Intel / Micron MLC R/W Cycle time to 30ns.
8. Modify MP tool halt when one of device fail.
9. Add running&erase time in log file for Aristech
10.Fix QFN dialog issue
11. Add HubScan to fix D-link Hub location.
12. Remove usb mode setting function.
13. Remove QFN function.
Ver 1.65.13.0
F/W
1. Support Toshiba 43nm flash.
MP
1. Fixed English/Korea/China OS Display issue.
2. Hynix 48nm will not do erase good blk at normal MP.
3. Modify Intel/Micron 50nm MLC R/W Cycle time to 30ns.
4. Add [Fixed serial number generation] option.
Ver 1.65.14.0
F/W
1. Fixed : Hidden area write speed too slow at WinXP.
2. Fixed : Hynix 60nm flash force single plane security area copy fail . (HY27UV08BG5A Dual / copy small file too slow)
3. Fixed : Hynix 60nm flash force single plane + 100% stress had 0X28 .
4. Fixed : default开完卡,不做erase good 再用force single plane重开会发生转mode ,UFD会出现0X28等问题.
5. Add: Support Toshiba TH58NVG6D2ETA20 (F/W=us9.bin)
MP
1. Fixed: MPtool had 0x94 bug.
2. Fixed: Rebuild function fail if import eep file.
3. Fixed: PFC flash MP 0x28 issue.
4. Fixed: Build ISO Image Volume Label 无法出现错误.
5. Fixed: maximum devices 为 20/24/28/32时插入UFD装置会重复出现的错误.
6. Fixed: 载入位於非安装目录的 erp 时 Rebuild BAD Block 会导致 hang住错误.
7. Fixed: Write Image 时 单一档案大小超过4096MB ( 4GB ) 会导致写入错误.
8. Fixed: 简体中文 "序号 固定" 及 "强行双通道" 无法显示
9. Fixed: 载入 .erp 时 Security Area Hint, Password 无法 Refresh.
10. Add: Display flash ID on the MPtool.
11. Add: Flash Id 8k page 的显示".
Ver 1.65.15.0
1. Add: MP tool support native driver (Win2K still need install driver).
2. Add: MP tool can take partial device out without conflict other device.
3. Add: Display "SearchBlk" message in status bar.
4. Add: MP tool add (MP + erase good) option.
5. Add: Support single device MP.
6. Add: Support interleave function, please reference flash support list version 22.
MPTool v1.65.15.77
1. Support OTP function.
Ver 1.65.16.0
[F/W Update]
1. Improved interleave small file performance
[MP Tool Update]
1. Add NTFS format function
Ver 1.65.16.80
[MP Tool Update]
1. 增加安装时可选择 ITE FABULK driver option.
Ver 1.65.17.0
[F/W Update]
1.Fixed: R/W performance unstable issue.
2.Fixed: MPTool display error when ISP find checksum error.
3.Fixed: Samsung K9L8G MP error.
[MP Tool Update]
1.修改新版 Revert 程式码
2.程式结束後清除装置 Registry
3.新增 QFN Monitor
4.新增读取存放於 CDROM 内之 .erp
5.Flash Parameter 新增interleave disable 选项
6.Improve sorting timing.
7.Fixed: Process is running issue.
8.Logfile 新增 Start Date
Ver 1.65.18.0
[F/W Update]
1.Fixed sorting error 0x58 issue.
2.Support L63A/B, L62A and Hynix EF-NAND.
3.Add the "Config Flash" function for special ID.
4.Enable UT165 A1B.
[MP Tool Update]
4.整合手测 MP tool .
5.Enable UT165 A1B.
6.Add 8K page flash sorting(Toshiba flash).
7.Fixed preload file error.
8.Modify QFN monitor function.
9.Add L62A sorting tool.
10.Format size error when enable bin select.
11.Modify format size.
12.Update re-build function.
13.Add Rebuild+MP+Erase system block,Erase good+MP+Erase system block and RestoreBADBlk+MP in prescan option.
14.Support Toshiba VCI_X2 SLC 8K Page Flash (Flash Parameter select "VCI_X2").
Ver 1.65.19.0
[F/W Update]
1.Support Hynix 41nm H27UAG8T2A, H27UBG8T2M series
2.Support Hynix 48nm H2EUBG8M1MYR series
[MP Tool Update]
1.Add CDROM TOC minutes/seconds/fractions 支持以修正 autorun 在 Mac OS 容量读取错误
2.Fixed FAT32 Master Boot Record 0x1C2 System ID 为 0x06 / 0x0C, 改善某些平台无法开机
3.Fixed Product Name error.
4.Support sorting 0~ 128block bad (0x72) issue.
1.65.20.0
[F/W Update]
1.Improve performance.
[MP Tool Update]
1.修正输入含空白字串 造成字串遗失错误
2.Add UBRevert Version in Log File .
3.执行完若有错误显示红色字体
4.The String of product name change to "USB Flash Disk".
5.Modify format size.
6.Remove Native Driver.
7.Add "Fixed serial number with custom define" and "Auto date with SN" options.
[ 此帖被bjcat在2009-09-01 23:55重新编辑 ]
