  • 2075阅读
  • 3回复
[鑫创]坑屎蹲量产求助 [复制链接]
离线panboo86
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2015-05-12
        手上有个N年前捡到的坑屎蹲G2盘,就是那种推拉盘。虽然是N年前的,但是写入各方面分分钟秒杀现在N多2.0的盘。CG显示是SSS6691+坨屎吧的43NM NAND 想量产成CDROM+U盘。但是试了好几个版本。从59到61到82。全部都是Error28 DOS format Fail。格式化错误。已经改好了ISO文件的路径了,但就是死活不过dos format。求大神帮忙看看。。
Starting Time: 16:07:06
Device 1:0xB3
    MP Version:2.162
    INI_File_Name:
    Random delay 0 msec
    --- Download MP ISP ---
    CE-0, Flash ID=98-D5-94-32-76-54-0B-00
    CE-1, Flash ID=98-D5-94-32-76-54-0B-00
    Found BACKUP Table (000000BB-0001)
    Defect Table (00000200-0004)
        Original Bad Block - 0:0x0253
        Original Bad Block - 0:0x0445
        Original Bad Block - 0:0x04EB
        Original Bad Block - 0:0x0512
        Original Bad Block - 0:0x0694
        Original Bad Block - 0:0x06F3
        Original Bad Block - 0:0x073B
        Original Bad Block - 0:0x0804
        Original Bad Block - 0:0x0806
        Original Bad Block - 1:0x0095
        Original Bad Block - 1:0x023E
        Original Bad Block - 1:0x0256
        Original Bad Block - 1:0x035F
        Original Bad Block - 1:0x0430
        Original Bad Block - 1:0x04D7
        Original Bad Block - 1:0x058B
        Original Bad Block - 1:0x05DC
        Original Bad Block - 1:0x066F
        Original Bad Block - 1:0x06F9
    Defect Table shows 4149 Good blocks, 19 Bad blocks
    SafeErase (0,2084)
        Erase failed Block - 0:0:0x0253
        Erase failed Block - 0:0:0x0445
        Erase failed Block - 0:0:0x04EB
        Erase failed Block - 0:0:0x0512
        Erase failed Block - 0:0:0x0694
        Erase failed Block - 0:0:0x06F3
        Erase failed Block - 0:0:0x073B
        Erase failed Block - 0:0:0x0804
        Erase failed Block - 0:0:0x0806
        ---> Max Bad of Plane (4,5)
    SafeErase (1,2084)
        Erase failed Block - 1:0:0x0095
        Erase failed Block - 1:0:0x023E
        Erase failed Block - 1:0:0x0256
        Erase failed Block - 1:0:0x035F
        Erase failed Block - 1:0:0x0430
        Erase failed Block - 1:0:0x04D7
        Erase failed Block - 1:0:0x058B
        Erase failed Block - 1:0:0x05DC
        Erase failed Block - 1:0:0x066F
        Erase failed Block - 1:0:0x06F9
        ---> Max Bad of Plane (4,6)
        ---> Max BAD/DIE = 6
    Total good blocks after SCAN: 4149 / 4168, Bad block=19
    ==> 2-Plane mode
    Max. Bad Block Allowed = 251(19)
    Adjust Max LBA = 7823360, 7823296
    MaxWindows=2/1910, MaxLBA=7823296, Size=3819 MB
    Max BAD of one plane is 6 (62),4168,1,2
    RootSector=0xC99,Sec/Cluster=32, SuperPage=32 ---> Alignment=7
    Boot Block=0x0001,0x0002
    Lun0(6410076), Lun1(1413220), Public=6410076, Secure=0, CDROM=1413220
    Special FE Config = 56-0B-00
    Defect Table Block=0x0004
    --- Download ISP Code:E:\新建文件夹\MP_VER2162_ALL\ISP_CODE\6691_B3-A_20100331_VA10F00_9083.BIN---
    --- ISP Code installed.
    Public,Secure,CDROM = 6410076,0,1413220
    SN=00FF833400D8F550C57414DC
    === Preformat Done ===
    Low Level Format DONE
    Store INI/ERROR MSG to Block-0x0001:79.
    CDROM image:D:\2014.iso
    Total=7823296,CDROM=1413220, PublicArea=6409948, SecureArea=0
    Create SECURE(CDROM=1,Public=3129 MB,Secure=0 MB)
      Write LBA(0x00000000,128) Fail !
    ### Err: SECURE failed(41).
Ending Time: 16:07:18
本帖最近打赏记录:共1条打赏M币+1
离线wwggdd
只看该作者 1楼 发表于: 2015-05-12
离线shuishou
只看该作者 2楼 发表于: 2015-05-12
离线panboo86
只看该作者 3楼 发表于: 2015-05-13
回 shuishou 的帖子
