  • 5540阅读
  • 22回复
[SandForce]sf2281 29f64g08cbaba 25% error [复制链接]
离线rufat66
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2015-05-21
所有的問候對不起我的中國我來自俄羅斯是我需要你的幫助或提示。不能你需要做的是完成我25%閃存SSD Kingston svp200s37a錯誤?如何使用教材,並在哪裡?請幫助
<?xml version = "1.0"?>
<Genesis_Log>
    <Log_Body>
Overall Summary:
                Start Time: Wed, 05/20/2015 @ 21:15:41
                  End Time: Wed, 05/20/2015 @ 21:17:16
             OverallResult: FAIL
                  ExitCode: (0x10090014:SF_GENESIS_FW_DOWNLOAD_ERROR)
Environment Settings:
          Input Parameters:
                  argv[1]: -PROCESS_SSD
                  argv[2]: 0:0:0:0
                  argv[3]: /home/admin/fw/FW_SF-2000_5_0_4_Client_Mass_Production--123456/FW_SF-2000_5_0_4_Client_Mass_Production.123456.mfp
                  argv[4]: /home/admin/fw/FW_SF-2000_5_0_4_Client_Mass_Production--123456/Configuration_Files/22332.123456.driveconfig
                  argv[5]: 123
                  argv[6]: 111
                  argv[7]: LOG=/home/admin/SF_Genesis-v1.5/log/123_localhost.localdomain_DATETIMESTAMP_0.0.0.0_PROCESS_SSD_RESULT.log
                  Log File: /home/admin/SF_Genesis-v1.5/log/123_localhost.localdomain_DATETIMESTAMP_0.0.0.0_PROCESS_SSD_RESULT.log
                  Hostname: localhost.localdomain
           Host IP Address: 127.0.0.1
               Port Number: 0
                DeviceName: /dev/sg0
        SF_Genesis Version: v1.7.0.01020130612-fc14-32bit
   SF_Core Library Version: v1.7.1.20130612-fc14-32bit
         SF_OS_Information: Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686
Post Processing Device Information:
                   WWN OUI: UNKNOWN
              WWN UniqueID: UNKNOWN
                Serial No.: UNKNOWN
                 Model No.: UNKNOWN
         Firmware Revision: UNKNOWN
              ROM Revision: UNKNOWN
            NAND Page Size: UNKNOWN
     Number Of Chip Enable: UNKNOWN
           Logical Sectors: UNKNOWN
                   NAND ID: UNKNOWN
        Flash Manufacturer: UNKNOWN
              Flash Device: UNKNOWN
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Wed 05/20/2015 21:15:41] - SF_Genesis has been invoked with the following parameters:
                      argv[2]: 0:0:0:0
                      argv[5]: 123
                      argv[6]: 111
[Wed 05/20/2015 21:15:41] - Instructing the operating system to purge any existing cached data for device: '0:0:0:0'
[Wed 05/20/2015 21:15:46] - Issuing a discovery command for device: '0:0:0:0'
[Wed 05/20/2015 21:15:52] - Discovery command completed...
[Wed 05/20/2015 21:15:52] - Waiting 5 seconds for the system to settle...
[Wed 05/20/2015 21:15:57] - Device designation string '0:0:0:0' is mapped to node '/dev/sg0'
[Wed 05/20/2015 21:15:57] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg0
    MFP Package Filename = /home/admin/fw/FW_SF-2000_5_0_4_Client_Mass_Production--123456/FW_SF-2000_5_0_4_Client_Mass_Production.123456.mfp
      Configuration File = /home/admin/fw/FW_SF-2000_5_0_4_Client_Mass_Production--123456/Configuration_Files/22332.123456.driveconfig
              Serial No. = 123
         World Wide Name = 111
[Wed 05/20/2015 21:15:57] - Successfully received the IDENTIFY data from the drive...
[Wed 05/20/2015 21:15:57] - Validating Manufacturing Firmware Package: /home/admin/fw/FW_SF-2000_5_0_4_Client_Mass_Production--123456/FW_SF-2000_5_0_4_Client_Mass_Production.123456.mfp
[Wed 05/20/2015 21:16:11] - Successfully opened the package: /home/admin/fw/FW_SF-2000_5_0_4_Client_Mass_Production--123456/FW_SF-2000_5_0_4_Client_Mass_Production.123456.mfp
[Wed 05/20/2015 21:16:11] - file  /home/admin/fw/FW_SF-2000_5_0_4_Client_Mass_Production--123456/Configuration_Files/22332.123456.driveconfig Loaded successfully
[Wed 05/20/2015 21:16:11] - Warning:  Unable to query diagnostics information to perform power management settings check
[Wed 05/20/2015 21:16:11] - B01 Power Management configuration request detected
[Wed 05/20/2015 21:16:11] - Successfully extracted *.DriveConfig file: /home/admin/fw/FW_SF-2000_5_0_4_Client_Mass_Production--123456/Configuration_Files/22332.123456.driveconfig
[Wed 05/20/2015 21:16:11] - Extracted Config_ID: 1 (22332) in DriveConfig file: /home/admin/fw/FW_SF-2000_5_0_4_Client_Mass_Production--123456/Configuration_Files/22332.123456.driveconfig
[Wed 05/20/2015 21:16:11] - Extracted SerialOutputControl: 0
[Wed 05/20/2015 21:16:11] - Searching for flashware image for configuration 22332
[Wed 05/20/2015 21:16:11] - Manifest found for configuration 22332
[Wed 05/20/2015 21:16:11] - Flashware image extracted: 22332_fw_cl_mlc_MIC_64Gb_MT29F64G08CBABAWPES_2Q_2C_1D_S_PP_R01108_s512.vic
[Wed 05/20/2015 21:16:11] - Searching for manufacturing image for configuration 22332
[Wed 05/20/2015 21:16:11] - Manufacturing image extracted: 22332_mf_mlc_MIC_64Gb_MT29F64G08CBABAWPES_2Q_2C_1D_S_PP_R01108_s512.vic
[Wed 05/20/2015 21:16:11] - Proceeding in ROM mode, download feature 3...
[Wed 05/20/2015 21:17:16] - FATAL_ERROR: Could not download MFB to the drive...(0x11000001:SF_SG_DEVICE_CHECK_CONDITION_ERROR)
Extended Error data:
          ATA COMMAND : 0x0092  (146)
          ATA FEATURE : 0x0003  (3)
         Device Status: 0x0001  (1)
         Driver Status: 0x0000  (0)
           Host Status: 0x0008  (8)
Sense Data:
  0 -         No Sense: 114 (0x72)    OK
  1 -  Recovered Error:  11 (0x0B)    FAIL
  2 -        Not Ready:   0 (0x00)    OK
  3 -     Medium Error:   0 (0x00)    OK
  4 -   Hardware Error:   0 (0x00)    OK
  5 -  Illegal Request:   0 (0x00)    OK
  6 -   Unit Attention:   0 (0x00)    OK
  7 -     Data Protect:  14 (0x0E)    OK
  8 -      Blank Check:   9 (0x09)    OK
  9 -  Vendor Specific:  12 (0x0C)    OK
10 -     Copy Aborted:   0 (0x00)    OK
11 -  Aborted Command:   0 (0x00)    OK
12 - Equal Comparison:   0 (0x00)    NA
13 -  Volume Overflow:   0 (0x00)    NA
14 -       Miscompare:   0 (0x00)    OK
15 -         Reserved: 128 (0x80)    NA
System Trace:
[  105.168653]          res 51/04:00:00:00:00/00:00:00:00:00/a0 Emask 0x1 (device error)
[  105.168655] ata1.00: status: { DRDY ERR }
[  105.168657] ata1.00: error: { ABRT }
[  105.168665] ata1.00: device reported invalid CHS sector 0
[  105.168675] sd 0:0:0:0: [sda] START_STOP FAILED
[  105.168677] sd 0:0:0:0: [sda] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[  105.168680] sd 0:0:0:0: [sda] Sense Key : Aborted Command [current] [descriptor]
[  105.168684] sd 0:0:0:0: [sda] Add. Sense: No additional sense information
[  105.170448] ata1.00: disabled
[  110.168434] ata1: hard resetting link
[  110.473503] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[  110.474912] ata1.00: ACPI cmd ef/10:06:00:00:00:a0 (SET FEATURES) succeeded
[  110.478080] ata1.00: ATA-8: SandForce{200026BB}, 20DABBR0, max UDMA/133
[  110.478089] ata1.00: 64 sectors, multi 0: LBA48 NCQ (depth 31/32), AA
[  110.484157] ata1.00: ACPI cmd ef/10:06:00:00:00:a0 (SET FEATURES) succeeded
[  110.487679] ata1.00: configured for UDMA/133
[  110.487697] ata1: EH complete
[  110.488020] scsi 0:0:0:0: Direct-Access     ATA      SandForce{200026 20DA PQ: 0 ANSI: 5
[  110.493600] sd 0:0:0:0: Attached scsi generic sg0 type 0
[  110.493913] sd 0:0:0:0: [sda] 64 512-byte logical blocks: (32.7 kB/32.0 KiB)
[  110.493925] sd 0:0:0:0: [sda] 4096-byte physical blocks
[  110.494134] sd 0:0:0:0: [sda] Write Protect is off
[  110.494144] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[  110.494228] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[  110.495704]  sda: unknown partition table
[  110.505047] sd 0:0:0:0: [sda] Attached SCSI disk
[  139.754136] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 frozen
[  139.754153] ata1.00: failed command: DOWNLOAD MICROCODE
[  139.754173] ata1.00: cmd 92/03:65:00:80:01/00:00:00:00:00/00 tag 0 pio 51712 out
[  139.754178]          res 40/00:00:80:00:00/00:00:00:00:00/e0 Emask 0x4 (timeout)
[  139.754188] ata1.00: status: { DRDY }
[  139.754209] ata1: hard resetting link
[  145.102203] ata1: link is slow to respond, please be patient (ready=0)
[  149.789022] ata1: COMRESET failed (errno=-16)
[  149.789052] ata1: hard resetting link
[  155.137113] ata1: link is slow to respond, please be patient (ready=0)
[  159.823935] ata1: COMRESET failed (errno=-16)
[  159.823964] ata1: hard resetting link
[  165.172025] ata1: link is slow to respond, please be patient (ready=0)
[  194.825256] ata1: COMRESET failed (errno=-16)
[  194.825288] ata1: limiting SATA link speed to 1.5 Gbps
[  194.825297] ata1: hard resetting link
[  199.867692] ata1: COMRESET failed (errno=-16)
[  199.867705] ata1: reset failed, giving up
[  199.867711] ata1.00: disabled
[  199.867751] ata1: EH complete
[Wed 05/20/2015 21:17:16] - End of Genesis manufacturing log.
[Wed 05/20/2015 21:17:16] - Exiting...
    </Log_Body>
    <Overall_Summary>
        <Start_Time> Wed, 05/20/2015 @ 21:15:41 </Start_Time>
        <End_Time> Wed, 05/20/2015 @ 21:17:16 </End_Time>
        <Overall_Result> FAIL </Overall_Result>
        <Exit_Code> (0x10090014:SF_GENESIS_FW_DOWNLOAD_ERROR) </Exit_Code>
    </Overall_Summary>
    <Environment_Settings>
        <Input_Parameters>
                  argv[2]: 0:0:0:0
                  argv[5]: 123
                  argv[6]: 111
        </Input_Parameters>
        <Log_File> /home/admin/SF_Genesis-v1.5/log/123_localhost.localdomain_DATETIMESTAMP_0.0.0.0_PROCESS_SSD_RESULT.log </Log_File>
        <Hostname> localhost.localdomain </Hostname>
        <Host_IP_Address> 127.0.0.1 </Host_IP_Address>
        <Port_Number> 0 </Port_Number>
        <Device_Name> /dev/sg0 </Device_Name>
        <SF_Genesis_Version> v1.7.0.01020130612-fc14-32bit </SF_Genesis_Version>
        <SF_Core_Library_Version> v1.7.1.20130612-fc14-32bit </SF_Core_Library_Version>
        <SF_OS_Information> Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686 </SF_OS_Information>
    </Environment_Settings>
    <Post_Processing_Device_Info>
        <WWN_OUI> UNKNOWN </WWN_OUI>
        <WWN_UniqueID> UNKNOWN </WWN_UniqueID>
        <Serial_Number> UNKNOWN </Serial_Number>
        <Model_Number> UNKNOWN </Model_Number>
        <Firmware_Revision> UNKNOWN </Firmware_Revision>
        <ROM_Revision> UNKNOWN </ROM_Revision>
        <NAND_Page_Size> UNKNOWN </NAND_Page_Size>
        <Number_Of_Chip_Enable> UNKNOWN </Number_Of_Chip_Enable>
        <Logical_Sectors> UNKNOWN </Logical_Sectors>
        <NAND_ID> UNKNOWN </NAND_ID>
        <Flash_Manufacturer> UNKNOWN </Flash_Manufacturer>
        <Flash_Device> UNKNOWN </Flash_Device>
    </Post_Processing_Device_Info>
</Genesis_Log>
[Wed 05/20/2015 21:17:16] - Overall Result for Device: /dev/sg0 ****** FAIL ******
本帖最近打赏记录:共1条打赏M币+5
离线jacythomas
只看该作者 1楼 发表于: 2015-05-21
本帖最近打赏记录:共2条打赏M币+6
离线haseehao
只看该作者 2楼 发表于: 2015-05-21
离线huakun888
只看该作者 3楼 发表于: 2015-05-21
本帖最近打赏记录:共4条打赏M币+14
离线m820426883
只看该作者 4楼 发表于: 2015-05-21
本帖最近打赏记录:共6条打赏M币+18
离线m820426883
只看该作者 5楼 发表于: 2015-05-21
回 huakun888 的帖子
本帖最近打赏记录:共4条打赏M币+12
离线shuma520
只看该作者 6楼 发表于: 2015-05-21
本帖最近打赏记录:共1条打赏M币+3
离线guoke1930
只看该作者 7楼 发表于: 2015-05-21
本帖最近打赏记录:共1条打赏M币+3
离线m820426883
只看该作者 8楼 发表于: 2015-05-21
离线527945545
只看该作者 9楼 发表于: 2015-05-21
本帖最近打赏记录:共1条打赏M币+3
