钢口号
C4300-316 A00LF 5V
CH4938872
[OEM]
PN=6691 + Toshiba 43nm D2 Normal Flash
Note=ISP:6691_B3-A_20100331_VA10F00_9083.BIN
VID=0x0951
PID=0x1625
VENDOR_NAME="Kingston"
PRODUCT_NAME="DT101C"
STRING_DESC_ENABLE=1
SN_CustomerCode=0x0F
[FEATURE_SETTING]
FLASH_OP="ALL123"
ID35=1
[ISP]
Code=6691_B3-A_20100331_VA10F00_9083.BIN
Device 1:0xB3
MP Version:2.162
INI_File_Name:
Random delay 0 msec
--- Download MP ISP ---
CE-0, Flash ID=98-D7-94-32-76-54-0C-00
--> ROOT is not found
Scan (0,4148)
Original Defect Block - 0:0:0x0000
Original Defect Block - 0:0:0x0008
Original Defect Block - 0:0:0x0009
Original Defect Block - 0:0:0x0016
Original Defect Block - 0:0:0x001A
Original Defect Block - 0:0:0x004D
Original Defect Block - 0:0:0x0070
Original Defect Block - 0:0:0x008C
Original Defect Block - 0:0:0x00BE
Original Defect Block - 0:0:0x00FA
Original Defect Block - 0:0:0x00FB
Original Defect Block - 0:0:0x010C
Original Defect Block - 0:0:0x011A
Original Defect Block - 0:0:0x0124
Original Defect Block - 0:0:0x0162
Original Defect Block - 0:0:0x0174
Original Defect Block - 0:0:0x0176
Original Defect Block - 0:0:0x017F
Original Defect Block - 0:0:0x0182
Original Defect Block - 0:0:0x0192
Original Defect Block - 0:0:0x01D5
Original Defect Block - 0:0:0x01DA
Original Defect Block - 0:0:0x01FA
Original Defect Block - 0:0:0x0214
Original Defect Block - 0:0:0x0228
Original Defect Block - 0:0:0x0244
Original Defect Block - 0:0:0x024C
Original Defect Block - 0:0:0x024E
Original Defect Block - 0:0:0x025A
Original Defect Block - 0:0:0x0308
Original Defect Block - 0:0:0x030E
Original Defect Block - 0:0:0x0320
Original Defect Block - 0:0:0x0333
Original Defect Block - 0:0:0x03A4
Original Defect Block - 0:0:0x03C7
Original Defect Block - 0:0:0x03D4
Original Defect Block - 0:0:0x03EC
Original Defect Block - 0:0:0x03F0
Original Defect Block - 0:0:0x041A
Original Defect Block - 0:0:0x044C
Original Defect Block - 0:0:0x0472
Original Defect Block - 0:0:0x0474
Original Defect Block - 0:0:0x047A
Original Defect Block - 0:0:0x04A8
Original Defect Block - 0:0:0x04BC
Original Defect Block - 0:0:0x04C2
Original Defect Block - 0:0:0x04EC
Original Defect Block - 0:0:0x0519
Original Defect Block - 0:0:0x053E
Original Defect Block - 0:0:0x05AC
Original Defect Block - 0:0:0x05EE
Original Defect Block - 0:0:0x0612
Original Defect Block - 0:0:0x069E
Original Defect Block - 0:0:0x06E8
Original Defect Block - 0:0:0x0708
Original Defect Block - 0:0:0x072E
Original Defect Block - 0:0:0x07DE
Original Defect Block - 0:0:0x08A3
Original Defect Block - 0:0:0x08BB
Original Defect Block - 0:0:0x0908
Original Defect Block - 0:0:0x093E
Original Defect Block - 0:0:0x0942
Original Defect Block - 0:0:0x097A
Original Defect Block - 0:0:0x09D7
Original Defect Block - 0:0:0x09D8
Original Defect Block - 0:0:0x09EC
Original Defect Block - 0:0:0x09EE
Original Defect Block - 0:0:0x09F4
Original Defect Block - 0:0:0x0A16
Original Defect Block - 0:0:0x0A5A
Original Defect Block - 0:0:0x0A78
Original Defect Block - 0:0:0x0A84
Original Defect Block - 0:0:0x0A96
Original Defect Block - 0:0:0x0A97
Original Defect Block - 0:0:0x0AB0
Original Defect Block - 0:0:0x0B44
Original Defect Block - 0:0:0x0B6C
Original Defect Block - 0:0:0x0BB4
Original Defect Block - 0:0:0x0BBB
Original Defect Block - 0:0:0x0C14
Original Defect Block - 0:0:0x0C1A
Original Defect Block - 0:0:0x0C34
Original Defect Block - 0:0:0x0C52
Original Defect Block - 0:0:0x0C54
Original Defect Block - 0:0:0x0C90
Original Defect Block - 0:0:0x0CC2
Original Defect Block - 0:0:0x0CC3
Original Defect Block - 0:0:0x0CC5
Original Defect Block - 0:0:0x0CF6
Original Defect Block - 0:0:0x0CF8
Original Defect Block - 0:0:0x0D04
Original Defect Block - 0:0:0x0D08
Original Defect Block - 0:0:0x0D10
Original Defect Block - 0:0:0x0D36
Original Defect Block - 0:0:0x0D4A
Original Defect Block - 0:0:0x0D4E
Original Defect Block - 0:0:0x0D5E
Original Defect Block - 0:0:0x0D80
Original Defect Block - 0:0:0x0D81
Original Defect Block - 0:0:0x0D86
Original Defect Block - 0:0:0x0D8C
Original Defect Block - 0:0:0x0D94
Original Defect Block - 0:0:0x0D96
Original Defect Block - 0:0:0x0DAC
Original Defect Block - 0:0:0x0DB6
Original Defect Block - 0:0:0x0DB8
Original Defect Block - 0:0:0x0DB9
Original Defect Block - 0:0:0x0DBA
Original Defect Block - 0:0:0x0DBE
Original Defect Block - 0:0:0x0DBF
Original Defect Block - 0:0:0x0DCC
Original Defect Block - 0:0:0x0DD2
Original Defect Block - 0:0:0x0DF0
Original Defect Block - 0:0:0x0E13
Original Defect Block - 0:0:0x0E1C
Original Defect Block - 0:0:0x0E30
Original Defect Block - 0:0:0x0E34
Original Defect Block - 0:0:0x0E39
Original Defect Block - 0:0:0x0E3A
Original Defect Block - 0:0:0x0E4A
Original Defect Block - 0:0:0x0E72
Original Defect Block - 0:0:0x0E76
Original Defect Block - 0:0:0x0EC7
Original Defect Block - 0:0:0x0ECA
Original Defect Block - 0:0:0x0F0E
Original Defect Block - 0:0:0x0F22
Original Defect Block - 0:0:0x0F2C
Original Defect Block - 0:0:0x0F3C
Original Defect Block - 0:0:0x0F3E
Original Defect Block - 0:0:0x0F44
Original Defect Block - 0:0:0x0F7C
Original Defect Block - 0:0:0x0F7D
Original Defect Block - 0:0:0x0F92
Original Defect Block - 0:0:0x0FAC
Original Defect Block - 0:0:0x0FCE
Original Defect Block - 0:0:0x0FD4
Original Defect Block - 0:0:0x0FDE
Original Defect Block - 0:0:0x0FE0
Original Defect Block - 0:0:0x1009
Original Defect Block - 0:0:0x1030
Original Defect Block - 0:0:0x1031
Original Defect Block - 0:0:0x1032
Original Defect Block - 0:0:0x1033
---> Max Bad of Plane (59,13)
---> Max BAD/DIE = 59
Total good blocks after SCAN: 4005 / 4148, Bad block=143
==> 2-Plane mode
Max. Bad Block Allowed = 231(143)
Adjust Max LBA = 7823360, 7823296
MaxWindows=2/1910, MaxLBA=7823296, Size=3819 MB
Max BAD of one plane is 59 (57),4148,1,1
### Error: Low level format failed ###
SafeErase (0,4148)
Erase failed Block - 0:0:0x0000
Erase failed Block - 0:0:0x0008
Erase failed Block - 0:0:0x0009
Erase failed Block - 0:0:0x0016
Erase failed Block - 0:0:0x001A
Erase failed Block - 0:0:0x004D
Erase failed Block - 0:0:0x0070
Erase failed Block - 0:0:0x008C
Erase failed Block - 0:0:0x00BE
Erase failed Block - 0:0:0x00FA
Erase failed Block - 0:0:0x00FB
Erase failed Block - 0:0:0x010C
Erase failed Block - 0:0:0x011A
Erase failed Block - 0:0:0x0124
Erase failed Block - 0:0:0x0162
Erase failed Block - 0:0:0x0174
Erase failed Block - 0:0:0x0176
Erase failed Block - 0:0:0x017F
Erase failed Block - 0:0:0x0182
Erase failed Block - 0:0:0x0192
Erase failed Block - 0:0:0x01D5
Erase failed Block - 0:0:0x01DA
Erase failed Block - 0:0:0x01FA
Erase failed Block - 0:0:0x0214
Erase failed Block - 0:0:0x0228
Erase failed Block - 0:0:0x0244
Erase failed Block - 0:0:0x024C
Erase failed Block - 0:0:0x024E
Erase failed Block - 0:0:0x025A
Erase failed Block - 0:0:0x0308
Erase failed Block - 0:0:0x030E
Erase failed Block - 0:0:0x0320
Erase failed Block - 0:0:0x0333
Erase failed Block - 0:0:0x03A4
Erase failed Block - 0:0:0x03C7
Erase failed Block - 0:0:0x03D4
Erase failed Block - 0:0:0x03EC
Erase failed Block - 0:0:0x03F0
Erase failed Block - 0:0:0x041A
Erase failed Block - 0:0:0x044C
Erase failed Block - 0:0:0x0472
Erase failed Block - 0:0:0x0474
Erase failed Block - 0:0:0x047A
Erase failed Block - 0:0:0x04A8
Erase failed Block - 0:0:0x04BC
Erase failed Block - 0:0:0x04C2
Erase failed Block - 0:0:0x04EC
Erase failed Block - 0:0:0x0519
Erase failed Block - 0:0:0x053E
Erase failed Block - 0:0:0x05AC
Erase failed Block - 0:0:0x05EE
Erase failed Block - 0:0:0x0612
Erase failed Block - 0:0:0x069E
Erase failed Block - 0:0:0x06E8
Erase failed Block - 0:0:0x0708
Erase failed Block - 0:0:0x072E
Erase failed Block - 0:0:0x07DE
Erase failed Block - 0:0:0x08A3
Erase failed Block - 0:0:0x08BB
Erase failed Block - 0:0:0x0908
Erase failed Block - 0:0:0x093E
Erase failed Block - 0:0:0x0942
Erase failed Block - 0:0:0x097A
Erase failed Block - 0:0:0x09D7
Erase failed Block - 0:0:0x09D8
Erase failed Block - 0:0:0x09EC
Erase failed Block - 0:0:0x09EE
Erase failed Block - 0:0:0x09F4
Erase failed Block - 0:0:0x0A16
Erase failed Block - 0:0:0x0A5A
Erase failed Block - 0:0:0x0A78
Erase failed Block - 0:0:0x0A84
Erase failed Block - 0:0:0x0A96
Erase failed Block - 0:0:0x0A97
Erase failed Block - 0:0:0x0AB0
Erase failed Block - 0:0:0x0B44
Erase failed Block - 0:0:0x0B6C
Erase failed Block - 0:0:0x0BB4
Erase failed Block - 0:0:0x0BBB
Erase failed Block - 0:0:0x0C14
Erase failed Block - 0:0:0x0C1A
Erase failed Block - 0:0:0x0C34
Erase failed Block - 0:0:0x0C52
Erase failed Block - 0:0:0x0C54
Erase failed Block - 0:0:0x0C90
Erase failed Block - 0:0:0x0CC2
Erase failed Block - 0:0:0x0CC3
Erase failed Block - 0:0:0x0CC5
Erase failed Block - 0:0:0x0CF6
Erase failed Block - 0:0:0x0CF8
Erase failed Block - 0:0:0x0D04
Erase failed Block - 0:0:0x0D08
Erase failed Block - 0:0:0x0D10
Erase failed Block - 0:0:0x0D36
Erase failed Block - 0:0:0x0D4A
Erase failed Block - 0:0:0x0D4E
Erase failed Block - 0:0:0x0D5E
Erase failed Block - 0:0:0x0D80
Erase failed Block - 0:0:0x0D81
Erase failed Block - 0:0:0x0D86
Erase failed Block - 0:0:0x0D8C
Erase failed Block - 0:0:0x0D94
Erase failed Block - 0:0:0x0D96
Erase failed Block - 0:0:0x0DAC
Erase failed Block - 0:0:0x0DB6
Erase failed Block - 0:0:0x0DB8
Erase failed Block - 0:0:0x0DB9
Erase failed Block - 0:0:0x0DBA
Erase failed Block - 0:0:0x0DBE
Erase failed Block - 0:0:0x0DBF
Erase failed Block - 0:0:0x0DCC
Erase failed Block - 0:0:0x0DD2
Erase failed Block - 0:0:0x0DF0
Erase failed Block - 0:0:0x0E13
Erase failed Block - 0:0:0x0E1C
Erase failed Block - 0:0:0x0E30
Erase failed Block - 0:0:0x0E34
Erase failed Block - 0:0:0x0E39
Erase failed Block - 0:0:0x0E3A
Erase failed Block - 0:0:0x0E4A
Erase failed Block - 0:0:0x0E72
Erase failed Block - 0:0:0x0E76
Erase failed Block - 0:0:0x0EC7
Erase failed Block - 0:0:0x0ECA
Erase failed Block - 0:0:0x0F0E
Erase failed Block - 0:0:0x0F22
Erase failed Block - 0:0:0x0F2C
Erase failed Block - 0:0:0x0F3C
Erase failed Block - 0:0:0x0F3E
Erase failed Block - 0:0:0x0F44
Erase failed Block - 0:0:0x0F7C
Erase failed Block - 0:0:0x0F7D
Erase failed Block - 0:0:0x0F92
Erase failed Block - 0:0:0x0FAC
Erase failed Block - 0:0:0x0FCE
Erase failed Block - 0:0:0x0FD4
Erase failed Block - 0:0:0x0FDE
Erase failed Block - 0:0:0x0FE0
Erase failed Block - 0:0:0x1009
Erase failed Block - 0:0:0x1030
Erase failed Block - 0:0:0x1031
Erase failed Block - 0:0:0x1032
Erase failed Block - 0:0:0x1033
[ 此帖被lulu77baba在2015-05-28 23:17重新编辑 ]
