  • 12348阅读
  • 13回复
[SandForce]刚DIY了一个2281加8贴29F64G08CBABA的SSD,速度为什么这么渣呢? [复制链接]
离线hififans
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2015-06-06
请大神帮看一下。
刚DIY了一个2281加8贴29F64G08CBABA的SSD,测了一下速度如图,为什么这么渣呢?
主控是SF-2281-VB1-SDC,F是8贴Micron的29F64G08CBABA,SATA3接口,CPU是i7 4700 ,笔记本电脑
开卡过程文件如下:
Starting command:[/root/soft/2銆丼F_Genesis-v1.7.0.01020130612-RC-fc14-32bit.tar/SF_Genesis-v1.7.0.01020130612-RC-fc14-32bit/SF_Genesis-v1.7.0.01020130612-fc14-32bit/SF_Genesis -PROCESS_SSD 5:0:0:0 "/root/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/FW_PPRO_5_8_2_Release.906190.release.123456.mfp" "/root/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/22333.123456.driveconfig" 123 456  LOG="/root/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/123_fedora_DATETIMESTAMP_5.0.0.0_PROCESS_SSD_RESULT.log"   ]...
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Sun 06/07/2015 01:34:44] - SF_Genesis has been invoked with the following parameters:
                      argv[1]: -PROCESS_SSD
                      argv[2]: 5:0:0:0
                      argv[3]: /root/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/FW_PPRO_5_8_2_Release.906190.release.123456.mfp
                      argv[4]: /root/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/22333.123456.driveconfig
                      argv[5]: 123
                      argv[6]: 456
                      argv[7]: LOG=/root/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/123_fedora_DATETIMESTAMP_5.0.0.0_PROCESS_SSD_RESULT.log
[Sun 06/07/2015 01:34:44] - Instructing the operating system to purge any existing cached data for device: '5:0:0:0'
[Sun 06/07/2015 01:34:49] - Issuing a discovery command for device: '5:0:0:0'
[Sun 06/07/2015 01:34:55] - Discovery command completed...
[Sun 06/07/2015 01:34:55] - Waiting 5 seconds for the system to settle...
[Sun 06/07/2015 01:35:00] - Device designation string '5:0:0:0' is mapped to node '/dev/sg1'
[Sun 06/07/2015 01:35:00] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg1
    MFP Package Filename = /root/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/FW_PPRO_5_8_2_Release.906190.release.123456.mfp
      Configuration File = /root/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/22333.123456.driveconfig
              Serial No. = 123
         World Wide Name = 456
[Sun 06/07/2015 01:35:00] - Successfully received the IDENTIFY data from the drive...
[Sun 06/07/2015 01:35:00] - Validating Manufacturing Firmware Package: /root/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/FW_PPRO_5_8_2_Release.906190.release.123456.mfp
[Sun 06/07/2015 01:35:07] - Successfully opened the package: /root/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/FW_PPRO_5_8_2_Release.906190.release.123456.mfp
[Sun 06/07/2015 01:35:07] - file  /root/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/22333.123456.driveconfig Loaded successfully
[Sun 06/07/2015 01:35:07] - Warning:  Unable to query diagnostics information to perform power management settings check
[Sun 06/07/2015 01:35:07] - B01 Power Management configuration request detected
[Sun 06/07/2015 01:35:07] - Successfully extracted *.DriveConfig file: /root/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/22333.123456.driveconfig
[Sun 06/07/2015 01:35:07] - Extracted Config_ID: 1 (22333) in DriveConfig file: /root/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/22333.123456.driveconfig
[Sun 06/07/2015 01:35:07] - Extracted SerialOutputControl: 0
[Sun 06/07/2015 01:35:07] - Searching for flashware image for configuration 22333
[Sun 06/07/2015 01:35:07] - Manifest found for configuration 22333
[Sun 06/07/2015 01:35:07] - Flashware image extracted: 22333_fw_cl_mlc_MIC_64Gb_MT29F64G08CBABAWPES_2Q_1C_1D_PP_R01106_s512.vic
[Sun 06/07/2015 01:35:07] - Searching for manufacturing image for configuration 22333
[Sun 06/07/2015 01:35:07] - Manufacturing image extracted: 22333_mf_mlc_MIC_64Gb_MT29F64G08CBABAWPES_2Q_1C_1D_PP_R01106_s512.vic
[Sun 06/07/2015 01:35:07] - Proceeding in ROM mode, download feature 3...
[Sun 06/07/2015 01:35:08] - Successfully downloaded MFB to the drive...
[Sun 06/07/2015 01:35:08] - Waiting (5 sec) for the drive to settle...
[Sun 06/07/2015 01:35:13] - Successfully received the IDENTIFY data from the drive...
[Sun 06/07/2015 01:35:13] - Firmware revision reported to be: '582ABBM0'.  This indicates MFB download was successful.
[Sun 06/07/2015 01:35:13] - Successfully enabled SMART capabilities...
[Sun 06/07/2015 01:35:15] - Successfully issued a diagnostic unlock...
[Sun 06/07/2015 01:35:16] - Performing the flash test of block 0 (0x0000)...
[Sun 06/07/2015 01:35:18] - Flash Test Results:
Flash Test Parameters:
               Block Count: 0
                Page Count: 1
                 Bus Count: 2
        Chip Enabled Count: 1
                 Die Count: 1
                Lane Count: 4
               Plane Count: 2
Results Notes:
   N1 - At least one page tested and passed with no bit errors.
   N2 - No test data available.  Test may have aborted, or failed during the testing.
   N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
   N4 - At least  one erased page tested had bit error rate greater than half the correction power.
   N5 - Walking zeros test failed.
   N6 - Walking ones test failed.
   N7 - Block contained factory bad block markings and testing was skipped.
   N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
   N9 - Block in plane 0 was marked as a factory bad block.
  N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
  N11 - Block in plane 1 was marked as a factory bad block.
| Bus  | CE   | Die  | Lane | Value  | Result Notes                               | Overall |
| 0    | 0    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 0    | 0    | 0x0002 | N3                                         | WARNING |
| 1    | 0    | 0    | 1    | 0x0003 | N1,N3                                      | WARNING |
| 1    | 0    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 0    | 3    | 0x0001 | N1                                         |    PASS |
  Total Number of test results: 8
            Number of failures: 0
         Number of Passed with warnings: 2
      No. Passed without warnings: 6
[Sun 06/07/2015 01:35:18] - Performing the FORMAT Command with the following parameters:
         MemoryWearCycleCapability = 0
              CurrentPE_CycleCount = 0
                     LifeInSeconds = 0
                   LogicalCapacity = 107463888
                        SectorSize = 512
             SectorAlignmentOffset = 0
                  ExpectedMemoryID = 25644 (0x642C)
                   ExpectedNumDies = 0
               SerialOutputControl = 0
                           Time[8] = 0x0000000000000000
            MiscFlag_Erase_R_Block = 0
     MiscFlag_PanicHandlingEnabled = 0
        MiscFlag_PanicOnSATA_Error = 0
  MiscFlag_WriteThrottlingTestMode = 0
      MiscFlag_DisableUserBandECCX = 0
                        L_PageSize = 0
                        E_PageSize = 0
              ErrorCorrectionPower = 0
      ConfigDeviceReadDisturbCount = 0
   ConfigDeviceReadDisturbCountLow = 0
                  ExtraOptions_0_1 = 0
[Sun 06/07/2015 01:35:27] - FORMAT command completed...
[Sun 06/07/2015 01:35:27] - Waiting (2 sec) for the drive to settle...
[Sun 06/07/2015 01:35:29] - Setting up the stamp information through CDU command...
[Sun 06/07/2015 01:35:32] - Waiting (2 sec) for the drive to settle...
[Sun 06/07/2015 01:35:34] - Downloading the flashware to the drive... feature 3
[Sun 06/07/2015 01:35:36] - Successfully downloaded flashware to the drive...
[Sun 06/07/2015 01:35:36] - Waiting (15 sec) for the drive to settle...
[Sun 06/07/2015 01:35:51] - Successfully received the IDENTIFY data from the drive...
[Sun 06/07/2015 01:35:51] - Firmware revision reported to be: '582ABBF0'
[Sun 06/07/2015 01:35:51] - Enabling SMART support...
[Sun 06/07/2015 01:35:51] - Issuing a diagnostic unlock to the drive...
[Sun 06/07/2015 01:35:53] - Setting up Max LBA settings...
[Sun 06/07/2015 01:35:57] - Change of sector size is not required, sector size is already set to 512
[Sun 06/07/2015 01:35:58] - Setting the serial number of the drive to: 123
[Sun 06/07/2015 01:36:00] - Setting the World Wide Name (WWN) of the drive to: 456
[Sun 06/07/2015 01:36:03] - Processing completed for device: 123
[Sun 06/07/2015 01:36:03] - Begin collecting the device post-process log/information
[Sun 06/07/2015 01:36:03] - Creating the Log Bundle...
[Sun 06/07/2015 01:36:03] - Plain text identify log created
[Sun 06/07/2015 01:36:04] - Plain text diagnostics identify log created
[Sun 06/07/2015 01:36:05] - Plain text diagnostics information log created
[Sun 06/07/2015 01:36:07] - Plain text format information log created
[Sun 06/07/2015 01:36:07] - Plain text SMART log created
[Sun 06/07/2015 01:36:08] - Plain text manufacturing defect list log created
[Sun 06/07/2015 01:36:09] - Plain text grown defect list log created
[Sun 06/07/2015 01:36:10] - Plain text panic directory listing log created
[Sun 06/07/2015 01:36:10] - Completed collecting all plain text log files.
[Sun 06/07/2015 01:36:10] - End of logs and information collection
[Sun 06/07/2015 01:36:11] - Applying the remaining ConfigUniqueDrive settings...
[Sun 06/07/2015 01:36:12] - Setting Customer ID with value : 123456
[Sun 06/07/2015 01:36:12] - Setting Diagnostic Unlock Key with value supplied
[Sun 06/07/2015 01:36:12] - Setting Max LBA Count for 4096 Plus DIFF Sectors with value : 0
[Sun 06/07/2015 01:36:12] - Setting Max LBA Count for 4096 Sectors with value : 0
[Sun 06/07/2015 01:36:12] - Setting Max LBA Count for 512B Plus DIFF Sectors with value : 0
[Sun 06/07/2015 01:36:12] - Setting Max LBA Count for 512B Sectors with value : 0
[Sun 06/07/2015 01:36:12] - Setting Max LBA Count for 520B Sectors with value : 0
[Sun 06/07/2015 01:36:12] - Setting Max LBA Count for 524B Sectors with value : 0
[Sun 06/07/2015 01:36:12] - Setting Max LBA Count for 528B Sectors with value : 0
[Sun 06/07/2015 01:36:12] - Setting Model No. with value : 123
[Sun 06/07/2015 01:36:12] - Setting Power Management Version with value : 2
[Sun 06/07/2015 01:36:12] - Setting Sensor 1;Device ID with value : 0xFF
[Sun 06/07/2015 01:36:12] - Setting Sensor 2;Device ID with value : 0xFF
[Sun 06/07/2015 01:36:12] - Total of 1 valid MaxLBA settings were setup to be written to the drive.
[Sun 06/07/2015 01:36:15] - Successfully applied the remaining ConfigUniqueDrive settings...
[Sun 06/07/2015 01:36:15] - Issuing an IdleImmediate command to the drive...
[Sun 06/07/2015 01:36:15] - Not an Enterprise drive,so, continuing without setting master password..
[Sun 06/07/2015 01:36:15] - End of Genesis manufacturing log.
[Sun 06/07/2015 01:36:15] - Exiting...
[Sun 06/07/2015 01:36:15] - Overall Result for Device: /dev/sg1 ****** PASS ******
Process exited with code 0
第一次开卡SF2281,还请大神不吝赐教!
本帖最近打赏记录:共7条打赏M币+21
离线chen7610386
只看该作者 1楼 发表于: 2015-06-06
本帖最近打赏记录:共1条打赏M币+3
离线john_chuck
只看该作者 2楼 发表于: 2015-06-06
本帖最近打赏记录:共2条打赏M币+6
离线ph3203485
只看该作者 3楼 发表于: 2015-06-06
本帖最近打赏记录:共1条打赏M币+3
离线luo0271127
只看该作者 4楼 发表于: 2015-06-06
本帖最近打赏记录:共1条打赏M币+3
离线z674163666
只看该作者 5楼 发表于: 2015-06-06
离线fghlw
只看该作者 6楼 发表于: 2015-06-07
本帖最近打赏记录:共1条打赏M币+3
离线gyfhome
只看该作者 7楼 发表于: 2015-06-07
本帖最近打赏记录:共1条打赏M币+3
离线cogae
只看该作者 8楼 发表于: 2015-06-09
离线hififans
只看该作者 9楼 发表于: 2015-06-09
本帖最近打赏记录:共1条打赏M币+3
