  • 2093阅读
  • 1回复
[鑫创]鑫创3S6692-B5量产USBCDROM失败求助 [复制链接]
离线iqig001
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2015-08-06
 设备描述: [I:]USB Mass Storage Device(Kingston DT 101 G2)
 设备类型: 大容量存储设备
 协议版本: USB 2.00
 当前速度: 高速(HighSpeed)
 电力消耗: 100mA
USB设备ID: VID = 0951 PID = 1642
设备序列号: 001CC07CEEFFFBC0F9262397
设备供应商: Kingston
 设备名称: DataTraveler G3
设备修订版: 0100
产品制造商: Kingston
 产品型号: DT 101 G2
产品修订版: 1.00
 主控厂商: SSS(鑫创)
 主控型号: TC58NC6621/SSS6692-B5
闪存识别码: 98D79432 - Toshiba(东芝) TC58NVG5D2FTA10 - 1CE/单通道 [MLC-8K] -> 总容量 = 4GB
 在线资料: http://dl.mydigit.net/special/up/sss.html
可能的闪存型号
[1CE]TC58NVG5D2FTA00(32nm) x 1片/通道 x 1通道
[1CE]TC58NVG5D2ELA48(43nm) x 1片/通道 x 1通道
[1CE]TC58NVG5D2FTA10(32nm) x 1片/通道 x 1通道
闪存识别码映射表
[通道 0] [通道 1]
98D794327655 --------
以下是量产失败全部数据:
Device 1:0xB5
MP Version:2.182
INI_File_Name:6692_Toshiba 32nm D2 Flash CDROM.INI
Random delay 0 msec
--- Download MP ISP ---
### No support [SCAN_RDY_BSY-0xFF 0x30] !
CE-0, Flash ID=98-D7-94-32-76-55-0D-00
Found BACKUP Table (000000BB-0001)
Defect Table (00000200-0004)
  Original Bad Block - 0:0x0000
  Original Bad Block - 0:0x0108
  Original Bad Block - 0:0x010A
  Original Bad Block - 0:0x0128
  Original Bad Block - 0:0x012A
  Original Bad Block - 0:0x0151
  Original Bad Block - 0:0x0153
  Original Bad Block - 0:0x01E5
  Original Bad Block - 0:0x01E7
  Original Bad Block - 0:0x026C
  Original Bad Block - 0:0x026E
  Original Bad Block - 0:0x03FB
  Original Bad Block - 0:0x0422
  Original Bad Block - 0:0x0494
  Original Bad Block - 0:0x0496
  Original Bad Block - 0:0x0704
  Original Bad Block - 0:0x0706
  Original Bad Block - 0:0x0741
  Original Bad Block - 0:0x0B29
  Original Bad Block - 0:0x0B2B
  Original Bad Block - 0:0x0B72
  Original Bad Block - 0:0x0B74
  Original Bad Block - 0:0x0B75
  Original Bad Block - 0:0x0CBB
  Original Bad Block - 0:0x0D10
  Original Bad Block - 0:0x0D12
  Original Bad Block - 0:0x0D1F
  Original Bad Block - 0:0x0DA5
  Original Bad Block - 0:0x0DA7
  Original Bad Block - 0:0x0DF1
  Original Bad Block - 0:0x0DF3
  Original Bad Block - 0:0x0DF4
  Original Bad Block - 0:0x0DF6
  Original Bad Block - 0:0x0F5F
Defect Table shows 4066 Good blocks, 34 Bad blocks
SafeErase (0,4100)
  Erase failed Block - 0:0:0x0000
  Erase failed Block - 0:0:0x0108
  Erase failed Block - 0:0:0x010A
  Erase failed Block - 0:0:0x0128
  Erase failed Block - 0:0:0x012A
  Erase failed Block - 0:0:0x0151
  Erase failed Block - 0:0:0x0153
  Erase failed Block - 0:0:0x01E5
  Erase failed Block - 0:0:0x01E7
  Erase failed Block - 0:0:0x026C
  Erase failed Block - 0:0:0x026E
  Erase failed Block - 0:0:0x03FB
  Erase failed Block - 0:0:0x0422
  Erase failed Block - 0:0:0x0494
  Erase failed Block - 0:0:0x0496
  Erase failed Block - 0:0:0x0704
  Erase failed Block - 0:0:0x0706
  Erase failed Block - 0:0:0x0741
  Erase failed Block - 0:0:0x0B29
  Erase failed Block - 0:0:0x0B2B
  Erase failed Block - 0:0:0x0B72
  Erase failed Block - 0:0:0x0B74
  Erase failed Block - 0:0:0x0B75
  Erase failed Block - 0:0:0x0CBB
  Erase failed Block - 0:0:0x0D10
  Erase failed Block - 0:0:0x0D12
  Erase failed Block - 0:0:0x0D1F
  Erase failed Block - 0:0:0x0DA5
  Erase failed Block - 0:0:0x0DA7
  Erase failed Block - 0:0:0x0DF1
  Erase failed Block - 0:0:0x0DF3
  Erase failed Block - 0:0:0x0DF4
  Erase failed Block - 0:0:0x0DF6
  Erase failed Block - 0:0:0x0F5F
  ---> Max Bad of Plane (9,8)
  ---> Max BAD/DIE = 9
Total good blocks after SCAN: 4066 / 4100, Bad block=34
==> 2-Plane mode
Max. Bad Block Allowed = 183(34)
Adjust Max LBA = 7823360, 7823296
MaxWindows=2/1910, MaxLBA=7823296, Size=3819 MB
Max BAD of one plane is 9 (45),4100,1,1
RootSector=0xF4B,Sec/Cluster=32, SuperPage=32 ---> Alignment=21
Boot Block=0x0001,0x0002
Lun0(7823296), Lun1(0), Public=7823296, Secure=0, CDROM=0
Special FE Config = 54-0B-00
Defect Table Block=0x0004
--- Download ISP Code:D:\新建文件夹\ISP_CODE\6692_B5-A_20100916_VB10000_63E2.BIN---
--- ISP Code installed.
Public,Secure,CDROM = 7823296,0,0
PHY: E2/E4/E6=72h/36h/04h,  D0/C0/CFG10=DFh/0Bh/87h
SN=C0CB3887AEA9FF806BCF202C
=== Preformat Done ===
Low Level Format DONE
Store INI/ERROR MSG to Block-0x0001:79.
LBATest 10M activate
Total=7823296,CDROM=0, PublicArea=7823168, SecureArea=0
### Err: SECURE failed(32).
离线hzqp
只看该作者 1楼 发表于: 2015-08-07
