  • 9278阅读
  • 11回复
[SandForce]求助 SF2281 开卡时碰到的问题! [复制链接]
离线tt6237
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2015-09-04
朋友赏了一块威刚空板TSOP48的sf2281打算上TC58TEG6D2HTA00不知道几CE16贴
全部焊完开卡这边出现问题!
我是开TC58TEG6D2HTA00可是文档中是出现TH58TEG7D2HTA20
不废话直接LOG,求大神帮忙
Overall Summary:
                Start Time: Fri, 09/04/2015 @ 00:42:49
                  End Time: Fri, 09/04/2015 @ 00:44:16
             OverallResult: FAIL
                  ExitCode: (0x10090012:SF_GENESIS_IDENTIFY_ERROR)
Environment Settings:
          Input Parameters:
                  argv[1]: -PROCESS_SSD
                  argv[2]: 1:0:0:0
                  argv[3]: /home/tt6237/SSD/MPT/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
                  argv[4]: /home/tt6237/SSD/27143.0.driveconfig
                  argv[5]: 0
                  argv[6]: www_123
                  argv[7]: log=/home/tt6237/SSD
                  Log File: SF_Genesis_Main_Log__Fri_09.04.2015_00.42.49.log
                  Hostname: localhost.localdomain
           Host IP Address: 127.0.0.1
               Port Number: 1
                DeviceName: /dev/sg1
        SF_Genesis Version: v1.7.0.01020130612-fc14-32bit
   SF_Core Library Version: v1.7.1.20130612-fc14-32bit
         SF_OS_Information: Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686
Post Processing Device Information:
                   WWN OUI: UNKNOWN
              WWN UniqueID: UNKNOWN
                Serial No.: UNKNOWN
                 Model No.: UNKNOWN
         Firmware Revision: UNKNOWN
              ROM Revision: UNKNOWN
            NAND Page Size: UNKNOWN
     Number Of Chip Enable: UNKNOWN
           Logical Sectors: UNKNOWN
                   NAND ID: UNKNOWN
        Flash Manufacturer: UNKNOWN
              Flash Device: UNKNOWN
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Fri 09/04/2015 00:42:49] - SF_Genesis has been invoked with the following parameters:
                      argv[2]: 1:0:0:0
                      argv[5]: 0
                      argv[6]: www_123
[Fri 09/04/2015 00:42:49] - Instructing the operating system to purge any existing cached data for device: '1:0:0:0'
[Fri 09/04/2015 00:42:54] - Issuing a discovery command for device: '1:0:0:0'
[Fri 09/04/2015 00:42:59] - Discovery command completed...
[Fri 09/04/2015 00:42:59] - Waiting 5 seconds for the system to settle...
[Fri 09/04/2015 00:43:04] - Device designation string '1:0:0:0' is mapped to node '/dev/sg1'
[Fri 09/04/2015 00:43:04] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg1
    MFP Package Filename = /home/tt6237/SSD/MPT/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
      Configuration File = /home/tt6237/SSD/27143.0.driveconfig
              Serial No. = 0
         World Wide Name = www_123
[Fri 09/04/2015 00:43:04] - Successfully received the IDENTIFY data from the drive...
[Fri 09/04/2015 00:43:04] - Validating Manufacturing Firmware Package: /home/tt6237/SSD/MPT/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
[Fri 09/04/2015 00:43:07] - Successfully opened the package: /home/tt6237/SSD/MPT/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
[Fri 09/04/2015 00:43:07] - file  /home/tt6237/SSD/27143.0.driveconfig Loaded successfully
[Fri 09/04/2015 00:43:07] - Warning:  Unable to query diagnostics information to perform power management settings check
[Fri 09/04/2015 00:43:07] - B01 Power Management configuration request detected
[Fri 09/04/2015 00:43:07] - Successfully extracted *.DriveConfig file: /home/tt6237/SSD/27143.0.driveconfig
[Fri 09/04/2015 00:43:07] - Extracted Config_ID: 1 (27143) in DriveConfig file: /home/tt6237/SSD/27143.0.driveconfig
[Fri 09/04/2015 00:43:07] - Extracted SerialOutputControl: 0
[Fri 09/04/2015 00:43:07] - Searching for flashware image for configuration 27143
[Fri 09/04/2015 00:43:07] - Manifest found for configuration 27143
[Fri 09/04/2015 00:43:08] - Flashware image extracted: 27143_fw_cl_mlc_Toshiba_64Gb_TH58TEG7D2HTA20_2Q_2C_1D_S_PP_R01165_s512.vic
[Fri 09/04/2015 00:43:08] - Searching for manufacturing image for configuration 27143
[Fri 09/04/2015 00:43:08] - Manifest found for configuration 27143
[Fri 09/04/2015 00:43:08] - Manufacturing image extracted: 27143_mf_mlc_Toshiba_64Gb_TH58TEG7D2HTA20_2Q_2C_1D_S_PP_R01165_s512.vic
[Fri 09/04/2015 00:43:08] - Proceeding in ROM mode, download feature 3...
[Fri 09/04/2015 00:43:08] - Successfully downloaded MFB to the drive...
[Fri 09/04/2015 00:43:08] - Waiting (5 sec) for the drive to settle...
[Fri 09/04/2015 00:43:13] - Successfully received the IDENTIFY data from the drive...
[Fri 09/04/2015 00:43:13] - Firmware revision reported to be: '522ABBM0'.  This indicates MFB download was successful.
[Fri 09/04/2015 00:43:13] - Successfully enabled SMART capabilities...
[Fri 09/04/2015 00:43:15] - Successfully issued a diagnostic unlock...
[Fri 09/04/2015 00:43:16] - Performing the flash test of block 0 (0x0000)...
[Fri 09/04/2015 00:43:18] - Flash Test Results:
Flash Test Parameters:
               Block Count: 0
                Page Count: 1
                 Bus Count: 2
        Chip Enabled Count: 2
                 Die Count: 1
                Lane Count: 4
               Plane Count: 2
Results Notes:
   N1 - At least one page tested and passed with no bit errors.
   N2 - No test data available.  Test may have aborted, or failed during the testing.
   N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
   N4 - At least  one erased page tested had bit error rate greater than half the correction power.
   N5 - Walking zeros test failed.
   N6 - Walking ones test failed.
   N7 - Block contained factory bad block markings and testing was skipped.
   N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
   N9 - Block in plane 0 was marked as a factory bad block.
  N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
  N11 - Block in plane 1 was marked as a factory bad block.
| Bus  | CE   | Die  | Lane | Value  | Result Notes                               | Overall |
| 0    | 0    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 0    | 3    | 0x0001 | N1                                         |    PASS |
  Total Number of test results: 16
            Number of failures: 0
         Number of Passed with warnings: 0
      No. Passed without warnings: 16
[Fri 09/04/2015 00:43:18] - Performing the FORMAT Command with the following parameters:
         MemoryWearCycleCapability = 0
              CurrentPE_CycleCount = 0
                     LifeInSeconds = 0
                   LogicalCapacity = 234441648
                        SectorSize = 512
             SectorAlignmentOffset = 0
                  ExpectedMemoryID = 56984 (0xDE98)
                   ExpectedNumDies = 0
               SerialOutputControl = 0
                           Time[8] = 0x0000000000000000
            MiscFlag_Erase_R_Block = 0
     MiscFlag_PanicHandlingEnabled = 0
        MiscFlag_PanicOnSATA_Error = 0
  MiscFlag_WriteThrottlingTestMode = 0
      MiscFlag_DisableUserBandECCX = 0
                        L_PageSize = 0
                        E_PageSize = 0
              ErrorCorrectionPower = 0
      ConfigDeviceReadDisturbCount = 0
   ConfigDeviceReadDisturbCountLow = 0
                  ExtraOptions_0_1 = 0
[Fri 09/04/2015 00:43:52] - FORMAT command completed...
[Fri 09/04/2015 00:43:52] - Waiting (2 sec) for the drive to settle...
[Fri 09/04/2015 00:43:54] - Setting up the stamp information through CDU command...
[Fri 09/04/2015 00:43:58] - Waiting (2 sec) for the drive to settle...
[Fri 09/04/2015 00:44:00] - Downloading the flashware to the drive... feature 3
[Fri 09/04/2015 00:44:01] - Successfully downloaded flashware to the drive...
[Fri 09/04/2015 00:44:01] - Waiting (15 sec) for the drive to settle...
[Fri 09/04/2015 00:44:16] - Successfully received the IDENTIFY data from the drive...
[Fri 09/04/2015 00:44:16] - FATAL_ERROR: Did not recieve the correct firmware revision. it is reported to be: '20DABBR0', indicating flashware download has failed.
[Fri 09/04/2015 00:44:16] - End of Genesis manufacturing log.
[Fri 09/04/2015 00:44:16] - Exiting...
[ 此帖被tt6237在2015-09-04 16:01重新编辑 ]
离线m820426883
只看该作者 1楼 发表于: 2015-09-04
本帖最近打赏记录:共2条打赏M币+6
离线perter
只看该作者 2楼 发表于: 2015-09-04
离线tt6237
只看该作者 3楼 发表于: 2015-09-04
离线tt6237
只看该作者 4楼 发表于: 2015-09-04
[ 此帖被tt6237在2015-09-07 10:18重新编辑 ]
离线baibo
只看该作者 5楼 发表于: 2015-09-04
离线baibo
只看该作者 6楼 发表于: 2015-09-04
离线tt6237
只看该作者 7楼 发表于: 2015-09-07
离线ph3203485
只看该作者 8楼 发表于: 2015-09-07
离线tt6237
只看该作者 9楼 发表于: 2015-09-08
回 ph3203485 的帖子
