  • 6511阅读
  • 28回复
[SandForce]【更新】好吧SF2281成功,好吧ecc数据是检测的其他值,40圈检测过了 [复制链接]
离线qjj2857
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2015-10-06
之前本来想让M大修我的M4的,后来想想反正修好也没啥意思,干脆玩下2281,然后,彻底悲剧。。。。。是不是闪存没焊好的原因?
板子如下,log如下
<?xml version = "1.0"?>
<Genesis_Log>
    <Log_Body>
Overall Summary:
                Start Time: Tue, 10/06/2015 @ 14:29:43
                  End Time: Tue, 10/06/2015 @ 14:29:59
             OverallResult: FAIL
                  ExitCode: (0x10090012:SF_GENESIS_IDENTIFY_ERROR)
Environment Settings:
          Input Parameters:
                  argv[1]: -PROCESS_SSD
                  argv[2]: 5:0:0:0
                  argv[3]: /media/OS/SF/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
                  argv[4]: /media/OS/SF/FW_PPRO_5_2_2_Release.672199.release--0/27080.0.driveconfig
                  argv[5]: 1
                  argv[6]: 12
                  argv[7]: LOG=/media/OS/SF/FW_PPRO_5_2_2_Release.672199.release--0/1st/1_localhost.localdomain_DATETIMESTAMP_5.0.0.0_PROCESS_SSD_RESULT.log
                  Log File: /media/OS/SF/FW_PPRO_5_2_2_Release.672199.release--0/1st/1_localhost.localdomain_DATETIMESTAMP_5.0.0.0_PROCESS_SSD_RESULT.log
                  Hostname: localhost.localdomain
           Host IP Address: 127.0.0.1
               Port Number: 7
                DeviceName: /dev/sg7
        SF_Genesis Version: v1.7.0.01020130612-fc14-32bit
   SF_Core Library Version: v1.7.1.20130612-fc14-32bit
         SF_OS_Information: Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686
Post Processing Device Information:
                   WWN OUI: UNKNOWN
              WWN UniqueID: UNKNOWN
                Serial No.: UNKNOWN
                 Model No.: UNKNOWN
         Firmware Revision: UNKNOWN
              ROM Revision: UNKNOWN
            NAND Page Size: UNKNOWN
     Number Of Chip Enable: UNKNOWN
           Logical Sectors: UNKNOWN
                   NAND ID: UNKNOWN
        Flash Manufacturer: UNKNOWN
              Flash Device: UNKNOWN
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Tue 10/06/2015 14:29:43] - SF_Genesis has been invoked with the following parameters:
                      argv[2]: 5:0:0:0
                      argv[5]: 1
                      argv[6]: 12
[Tue 10/06/2015 14:29:43] - Instructing the operating system to purge any existing cached data for device: '5:0:0:0'
[Tue 10/06/2015 14:29:48] - Issuing a discovery command for device: '5:0:0:0'
[Tue 10/06/2015 14:29:54] - Discovery command completed...
[Tue 10/06/2015 14:29:54] - Waiting 5 seconds for the system to settle...
[Tue 10/06/2015 14:29:59] - Device designation string '5:0:0:0' is mapped to node '/dev/sg7'
[Tue 10/06/2015 14:29:59] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg7
    MFP Package Filename = /media/OS/SF/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
      Configuration File = /media/OS/SF/FW_PPRO_5_2_2_Release.672199.release--0/27080.0.driveconfig
              Serial No. = 1
         World Wide Name = 12
[Tue 10/06/2015 14:29:59] - FATAL_ERROR: Could not get the IDENTIFY data from the drive... (0x11000001:SF_SG_DEVICE_CHECK_CONDITION_ERROR)
Extended Error data:
          ATA COMMAND : 0x00EC  (236)
          ATA FEATURE : 0x0000  (0)
         Device Status: 0x0001  (1)
         Driver Status: 0x0000  (0)
           Host Status: 0x0008  (8)
Sense Data:
  0 -         No Sense: 114 (0x72)    OK
  1 -  Recovered Error:  11 (0x0B)    FAIL
  2 -        Not Ready:   0 (0x00)    OK
  3 -     Medium Error:   0 (0x00)    OK
  4 -   Hardware Error:   0 (0x00)    OK
  5 -  Illegal Request:   0 (0x00)    OK
  6 -   Unit Attention:   0 (0x00)    OK
  7 -     Data Protect:  14 (0x0E)    OK
  8 -      Blank Check:   9 (0x09)    OK
  9 -  Vendor Specific:  12 (0x0C)    OK
10 -     Copy Aborted:   0 (0x00)    OK
11 -  Aborted Command:   0 (0x00)    OK
12 - Equal Comparison:   0 (0x00)    NA
13 -  Volume Overflow:   8 (0x08)    NA
14 -       Miscompare:   0 (0x00)    OK
15 -         Reserved:   1 (0x01)    NA
System Trace:
[  170.721712] sd 5:0:0:0: [sde] Synchronizing SCSI cache
[  170.721772] sd 5:0:0:0: [sde] Stopping disk
[  170.722718] ata6.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[  170.722723] ata6.00: irq_stat 0x40000001
[  170.722728] ata6.00: failed command: STANDBY IMMEDIATE
[  170.722737] ata6.00: cmd e0/00:00:00:00:00/00:00:00:00:00/a0 tag 0
[  170.722740]          res 51/04:00:00:00:00/00:00:00:00:00/a0 Emask 0x1 (device error)
[  170.722744] ata6.00: status: { DRDY ERR }
[  170.722747] ata6.00: error: { ABRT }
[  170.722758] ata6.00: device reported invalid CHS sector 0
[  170.722775] sd 5:0:0:0: [sde] START_STOP FAILED
[  170.722778] sd 5:0:0:0: [sde] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[  170.722783] sd 5:0:0:0: [sde] Sense Key : Aborted Command [current] [descriptor]
[  170.722790] sd 5:0:0:0: [sde] Add. Sense: No additional sense information
[  170.722834] ata6.00: disabled
[  175.717182] ata6: hard resetting link
[  176.020668] ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[  176.020816] ACPI Error (psargs-0359): [DSSP] Namespace lookup failure, AE_NOT_FOUND
[  176.020824] ACPI Error (psparse-0537): Method parse/execution failed [\_SB_.PCI0.SAT0.SPT5._GTF] (Node f683cf60), AE_NOT_FOUND
[  176.021664] ata6.00: ATA-8: SandForce{200026BB}, 20DABBR0, max UDMA/133
[  176.021668] ata6.00: 64 sectors, multi 0: LBA48 NCQ (depth 31/32), AA
[  176.025216] ACPI Error (psargs-0359): [DSSP] Namespace lookup failure, AE_NOT_FOUND
[  176.025224] ACPI Error (psparse-0537): Method parse/execution failed [\_SB_.PCI0.SAT0.SPT5._GTF] (Node f683cf60), AE_NOT_FOUND
[  176.027347] ata6.00: configured for UDMA/133
[  176.027356] ata6: EH complete
[  176.027511] scsi 5:0:0:0: Direct-Access     ATA      SandForce{200026 20DA PQ: 0 ANSI: 5
[  176.028944] sd 5:0:0:0: [sde] 64 512-byte logical blocks: (32.7 kB/32.0 KiB)
[  176.028950] sd 5:0:0:0: [sde] 4096-byte physical blocks
[  176.029027] sd 5:0:0:0: [sde] Write Protect is off
[  176.029031] sd 5:0:0:0: [sde] Mode Sense: 00 3a 00 00
[  176.029053] sd 5:0:0:0: [sde] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[  176.030363] sd 5:0:0:0: Attached scsi generic sg4 type 0
[  176.031062]  sde: unknown partition table
[  176.040290] sd 5:0:0:0: [sde] Attached SCSI disk
[  186.022733] ata16.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[  186.022740] ata16.00: irq_stat 0x40000001
[  186.022746] scsi 15:0:0:0: [sg7] CDB: ATA command pass through(12)/Blank: a1 08 2e 00 01 00 00 00 00 ec 00 00 00 00 00 00
[  186.022771] ata16.00: cmd a0/01:00:00:00:02/00:00:00:00:00/a0 tag 0 dma 512 in
[  186.022773]          res 50/00:08:01:00:00/00:00:00:00:00/00 Emask 0x1 (device error)
[  186.022778] ata16.00: status: { DRDY }
[Tue 10/06/2015 14:29:59] - End of Genesis manufacturing log.
[Tue 10/06/2015 14:29:59] - Exiting...
    </Log_Body>
    <Overall_Summary>
        <Start_Time> Tue, 10/06/2015 @ 14:29:43 </Start_Time>
        <End_Time> Tue, 10/06/2015 @ 14:29:59 </End_Time>
        <Overall_Result> FAIL </Overall_Result>
        <Exit_Code> (0x10090012:SF_GENESIS_IDENTIFY_ERROR) </Exit_Code>
    </Overall_Summary>
    <Environment_Settings>
        <Input_Parameters>
                  argv[2]: 5:0:0:0
                  argv[5]: 1
                  argv[6]: 12
        </Input_Parameters>
        <Log_File> /media/OS/SF/FW_PPRO_5_2_2_Release.672199.release--0/1st/1_localhost.localdomain_DATETIMESTAMP_5.0.0.0_PROCESS_SSD_RESULT.log </Log_File>
        <Hostname> localhost.localdomain </Hostname>
        <Host_IP_Address> 127.0.0.1 </Host_IP_Address>
        <Port_Number> 7 </Port_Number>
        <Device_Name> /dev/sg7 </Device_Name>
        <SF_Genesis_Version> v1.7.0.01020130612-fc14-32bit </SF_Genesis_Version>
        <SF_Core_Library_Version> v1.7.1.20130612-fc14-32bit </SF_Core_Library_Version>
        <SF_OS_Information> Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686 </SF_OS_Information>
    </Environment_Settings>
    <Post_Processing_Device_Info>
        <WWN_OUI> UNKNOWN </WWN_OUI>
        <WWN_UniqueID> UNKNOWN </WWN_UniqueID>
        <Serial_Number> UNKNOWN </Serial_Number>
        <Model_Number> UNKNOWN </Model_Number>
        <Firmware_Revision> UNKNOWN </Firmware_Revision>
        <ROM_Revision> UNKNOWN </ROM_Revision>
        <NAND_Page_Size> UNKNOWN </NAND_Page_Size>
        <Number_Of_Chip_Enable> UNKNOWN </Number_Of_Chip_Enable>
        <Logical_Sectors> UNKNOWN </Logical_Sectors>
        <NAND_ID> UNKNOWN </NAND_ID>
        <Flash_Manufacturer> UNKNOWN </Flash_Manufacturer>
        <Flash_Device> UNKNOWN </Flash_Device>
    </Post_Processing_Device_Info>
</Genesis_Log>
[Tue 10/06/2015 14:29:59] - Overall Result for Device: /dev/sg7 ****** FAIL ******
[ 此帖被qjj2857在2015-10-07 14:19重新编辑 ]
本帖最近打赏记录:共4条打赏M币+11
离线wxgwxg
只看该作者 1楼 发表于: 2015-10-06
本帖最近打赏记录:共1条打赏M币+3
离线qjj2857
只看该作者 2楼 发表于: 2015-10-06
离线wangbinyu123
只看该作者 3楼 发表于: 2015-10-06
本帖最近打赏记录:共1条打赏M币+3
离线perter
只看该作者 4楼 发表于: 2015-10-06
本帖最近打赏记录:共1条打赏M币+3
离线m820426883
只看该作者 5楼 发表于: 2015-10-06
回 wangbinyu123 的帖子
本帖最近打赏记录:共1条打赏M币+3
离线jeff172
只看该作者 6楼 发表于: 2015-10-06
回 m820426883 的帖子
本帖最近打赏记录:共1条打赏M币+3
离线m820426883
只看该作者 7楼 发表于: 2015-10-06
本帖最近打赏记录:共1条打赏M币+3
离线qjj2857
只看该作者 8楼 发表于: 2015-10-06
离线qjj2857
只看该作者 9楼 发表于: 2015-10-06
