  • 1587阅读
  • 0回复
[鑫创]SSS6692-b5 量产失败 Error 8,加了ID17=1后,成了Error44 [复制链接]
离线metalheart
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2015-10-12
Device 1:0xB5
    MP Version:2.178
    INI_File_Name:6692——256P_8KB.INI
    Random delay 0 msec
    --- Download MP ISP ---
    Auto CE: 0x00 0x01 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF
    CE-0, Flash ID=2C-88-04-4B-A9-00-00-00
    CE-1, Flash ID=2C-88-04-4B-A9-00-00-00
    Searching SORTING BOARD table ...
    --> Not Found
    Scan (0,4096)
        Original Defect Block - 0:0:0x0000
        Original Defect Block - 0:0:0x0FFF
        ---> Max Bad of Plane (559,590)
    Scan (1,4096)
        Original Defect Block - 1:0:0x0000
        Original Defect Block - 1:0:0x0001
        Original Defect Block - 1:0:0x005A
        Original Defect Block - 1:0:0x005B
        Original Defect Block - 1:0:0x0800
        Original Defect Block - 1:0:0x0801
        ---> Max Bad of Plane (2,2)
        ---> Max BAD/DIE = 590
    Total good blocks after SCAN: 5889 / 8192, Bad block=2303
    ==> 2-Plane mode
    Adjust Max LBA = 23326720, 13238208
    MaxWindows=4/808, MaxLBA=13238208, Size=6463 MB
    Lun0(13238208), Lun1(0), Public=13238208, Secure=0, CDROM=0
    ### Error: No support capacity for XP format. ###
    ### Error: Low level format failed ###SafeErase (0,4096)Erase failed Block - 0:0:0x0000Erase failed Block - 0:0:0x0001
Erase failed Block - 0:0:0x0FFE
        Erase failed Block - 0:0:0x0FFF
    SafeErase (1,4096)
        Erase failed Block - 1:0:0x0000
        Erase failed Block - 1:0:0x0001
        Erase failed Block - 1:0:0x005A
        Erase failed Block - 1:0:0x005B
        Erase failed Block - 1:0:0x0800
        Erase failed Block - 1:0:0x0801
