  • 22684阅读
  • 25回复
[群联]金士顿100 G3 32G ps2251-07主控tlc芯片量产失败求助 [复制链接]
离线irundream
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2015-11-14
以下是日志消息,请大神帮忙看下什么问题,谢了!
207:26.4    - 67BC CP(1) = 0-0-0x0004:0
207:26.4    - CP-0: 0-0-0004/0-0004, S=0, Good=1
207:26.4    - 67BC CP(1) = 0-0-0x0007:0
207:26.4    - CP-1: 0-0-0007/0-0007, S=0, Good=1
207:26.5    - Sector Column:0000,0486,0908,0D8A,120C,168E,1B10,
207:26.5 < CP Data >
207:26.5    0000: 4E 48 98 3A A8 92 76 50-08 14 02 00 00 01 04 00   NH.:..vP........
207:26.5    0010: 00 00 00 00 00 55 00 01-48 00 19 08 44 AA 05 38   .....U..H...D..8
207:26.5    0020: FF FF FF FF FF FF FF FF-FF FF FF FF FF FF FF FF   ................
207:26.5    0030: FF FF FF FF FF FF FF FF-FF FF FF FF FF FF 1D E2   ................
207:26.5 + Install-2 F/W : 2307FW-D1_D3MODE-131008.BIN
207:26.5    + Write CP  (0-0004-0)
207:26.5    + Write CZ  (0-0004-1)
207:26.5    + Write ISP (0-0004-2)
207:26.5    + Write ISP (0-0004-3)
207:26.6    + Write ISP (0-0004-4)
207:26.6    + Write ISP (0-0004-5)
207:26.6    + Write ISP (0-0004-6)
207:26.6    + Write ISP (0-0004-7)
207:26.6    + Write ISP (0-0004-8)
207:26.6    + Write ISP (0-0004-9)
207:26.6    + Write ISP (0-0004-10)
207:26.6    + Write ISP (0-0004-11)
207:26.6    + Write ISP (0-0004-12)
207:26.6    + Write ISP (0-0004-13)
207:26.6    + Write ISP (0-0004-14)
207:26.7    + Write ISP (0-0004-15)
207:26.7    + Write CP  (0-0004-44)
207:26.7    + Write CP  (0-0004-46)
207:26.7    + Write CP  (0-0004-47)
207:26.7    + Write CP  (0-0004-48)
207:26.7    + Write CP  (0-0004-64)
207:26.7    - 0 (0-0004)/(0-0004): Good Count (CP=18, CZ=7, FW=14/14)
207:26.7    - System Block Installed.
207:26.8    - Sector Column:0000,0486,0908,0D8A,120C,168E,1B10,
207:26.8 < CP Data >
207:26.8    0000: 4E 48 98 3A A8 92 76 50-08 14 02 00 00 01 07 00   NH.:..vP........
207:26.8    0010: 00 00 00 00 00 55 00 01-48 00 19 08 44 AA 05 3B   .....U..H...D..;
207:26.8    0020: FF FF FF FF FF FF FF FF-FF FF FF FF FF FF FF FF   ................
207:26.8    0030: FF FF FF FF FF FF FF FF-FF FF FF FF FF FF 1D E2   ................
207:26.8 + Install-2 F/W : 2307FW-D1_D3MODE-131008.BIN
207:26.8    + Write CP  (0-0007-0)
207:26.8    + Write CZ  (0-0007-1)
207:26.8    + Write ISP (0-0007-2)
207:26.8    + Write ISP (0-0007-3)
207:26.9    + Write ISP (0-0007-4)
207:26.9    + Write ISP (0-0007-5)
207:26.9    + Write ISP (0-0007-6)
207:26.9    + Write ISP (0-0007-7)
207:26.9    + Write ISP (0-0007-8)
207:26.9    + Write ISP (0-0007-9)
207:26.9    + Write ISP (0-0007-10)
207:26.9    + Write ISP (0-0007-11)
207:26.9    + Write ISP (0-0007-12)
207:27.0    + Write ISP (0-0007-13)
207:27.0    + Write ISP (0-0007-14)
207:27.0    + Write ISP (0-0007-15)
207:27.0    + Write CP  (0-0007-44)
207:27.0    + Write CP  (0-0007-46)
207:27.0    + Write CP  (0-0007-47)
207:27.0    + Write CP  (0-0007-48)
207:27.0    + Write CP  (0-0007-64)
207:27.1    - 0 (0-0007)/(0-0007): Good Count (CP=18, CZ=7, FW=14/14)
207:27.1    - System Block Installed.
207:27.1 + 2 CP/CZ is OK
207:27.1 + UP307 e-Fuse = 00
207:27.1    - Max CP Block @ 0x001C (=0007 * 4) <= 8735 (Short Search is OK)
207:27.1 + BC[F49F=33]:
207:27.1    - Wait 2 sec.
207:29.1    - Jump ISP ...
210:21.3 ### F0, Err:1125 ###
210:21.3 ### Err: Burner Process2 fail
210:21.3 ### Err(0002): DoPreFormat Error
210:21.3 + CombinMode=00(40-40), CombinSkip=00
210:21.3    - FW Spare = 16,57
210:21.3    - F0: Good(7949,7949)=15898, Unit=2064, Size=32813472, FWSpare=57
210:21.4    - FW Spare = 16,57
210:21.4    - F0: Good(7949,7949)=15898, Unit=2064, Size=32813472, FWSpare=57
210:21.4 [RESULT] ErrorCode : 1125
210:21.4 + Static Summary: B=0   ,P=0   ,S=0   ,Others=0   ,D1B=0   ,D1P=0   ,D1S=0   ,D1Others=0   ,
[ 2015-11-14 18:21:19 ]
[ UPTool takes 03:30:21 ]
离线irundream
只看该作者 1楼 发表于: 2015-11-15
离线kill0929
只看该作者 2楼 发表于: 2015-11-16
离线irundream
只看该作者 3楼 发表于: 2015-11-18
离线做个好梦
只看该作者 4楼 发表于: 2016-03-26
离线bestbuyroc
只看该作者 5楼 发表于: 2016-03-27
回 irundream 的帖子
离线zxjlym
只看该作者 6楼 发表于: 2016-03-27
离线w2w32008
只看该作者 7楼 发表于: 2016-05-06
离线wfnh1022
只看该作者 8楼 发表于: 2016-05-07
离线baosheng00
只看该作者 9楼 发表于: 2016-09-19
