  • 4663阅读
  • 7回复
[SandForce]VM 虚拟机下刷 SF-2281 操作记录, 请各位大侠指点一下! [复制链接]
离线myd0117
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2015-11-26
首先是 lsscsi 查看硬盘设备
[root@localhost YH]# lsscsi
[0:0:0:0]    disk    ATA      VMware Virtual I 0000  /dev/sda    (这个是我的 OCZ ATG 3 的硬盘, 不过在这里显示成这样, )
[1:0:0:0]    cd/dvd  NECVMWar VMware IDE CDR10 1.00  /dev/sr0
[2:0:0:0]    disk    VMware,  VMware Virtual S 1.0   /dev/sdb
下面是开刷, 我的 60G 内存颗粒为 MT29F32G08CBACA
查资料 FW_Worksheet_SFI_SF-2000_140120_Confidential_stand 得知可刷 22220 和 22241
22220    SF-2281    SF-2281 60GB Micron25 MLC TSOP 16xMT29F32G08CBACAWP    Micron    25    MT29F32G08CBACAWP    TSOP
22241    SF-2281    SF-2281 60GB Micron25 MLC TSOP 16xMT29F32G08CBACAWP (RAISE OFF)    Micron    25    MT29F32G08CBACAWP    TSOP
刷写失败, 以下是刷新记录, 麻烦大虾指点一下错误的原因!
[root@localhost SF_Genesis-v1.7]# ./SF_Genesis -PROCESS_SSD 0:0:0:0 /home/YH/SSD/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/FW_PPRO_5_8_2_Release.906190.release.123456.mfp /home/YH/SSD/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22220.123456.driveconfig 12345 www_123 log=/home/YH/SSD/log/ocz60g.log
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Thu 11/26/2015 17:30:02] - SF_Genesis has been invoked with the following parameters:
                      argv[1]: -PROCESS_SSD
                      argv[2]: 0:0:0:0
                      argv[3]: /home/YH/SSD/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/FW_PPRO_5_8_2_Release.906190.release.123456.mfp
                      argv[4]: /home/YH/SSD/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22220.123456.driveconfig
                      argv[5]: 12345
                      argv[6]: www_123
                      argv[7]: log=/home/YH/SSD/log/ocz60g.log
[Thu 11/26/2015 17:30:02] - Instructing the operating system to purge any existing cached data for device: '0:0:0:0'
[Thu 11/26/2015 17:30:07] - Issuing a discovery command for device: '0:0:0:0'
[Thu 11/26/2015 17:30:12] - Discovery command completed...
[Thu 11/26/2015 17:30:12] - Waiting 5 seconds for the system to settle...
[Thu 11/26/2015 17:30:17] - Device designation string '0:0:0:0' is mapped to node '/dev/sg0'
[Thu 11/26/2015 17:30:17] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg0
    MFP Package Filename = /home/YH/SSD/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/FW_PPRO_5_8_2_Release.906190.release.123456.mfp
      Configuration File = /home/YH/SSD/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22220.123456.driveconfig
              Serial No. = 12345
         World Wide Name = www_123
[Thu 11/26/2015 17:30:17] - Successfully received the IDENTIFY data from the drive...
[Thu 11/26/2015 17:30:17] - Validating Manufacturing Firmware Package: /home/YH/SSD/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/FW_PPRO_5_8_2_Release.906190.release.123456.mfp
[Thu 11/26/2015 17:30:25] - Successfully opened the package: /home/YH/SSD/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/FW_PPRO_5_8_2_Release.906190.release.123456.mfp
[Thu 11/26/2015 17:30:25] - file  /home/YH/SSD/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22220.123456.driveconfig Loaded successfully
[Thu 11/26/2015 17:30:25] - Warning:  Unable to query diagnostics information to perform power management settings check
[Thu 11/26/2015 17:30:25] - B01 Power Management configuration request detected
[Thu 11/26/2015 17:30:25] - Successfully extracted *.DriveConfig file: /home/YH/SSD/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22220.123456.driveconfig
[Thu 11/26/2015 17:30:25] - Extracted Config_ID: 1 (22220) in DriveConfig file: /home/YH/SSD/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22220.123456.driveconfig
[Thu 11/26/2015 17:30:25] - Extracted SerialOutputControl: 0
[Thu 11/26/2015 17:30:25] - Searching for flashware image for configuration 22220
[Thu 11/26/2015 17:30:25] - Manifest found for configuration 22220
[Thu 11/26/2015 17:30:25] - Flashware image extracted: 22220_fw_cl_mlc_Micron_32Gb_MT29F128G08CBACAWP_2Q_2C_1D_S_PP_R00755_s512.vic
[Thu 11/26/2015 17:30:25] - Searching for manufacturing image for configuration 22220
[Thu 11/26/2015 17:30:25] - Manufacturing image extracted: 22220_mf_mlc_Micron_32Gb_MT29F128G08CBACAWP_2Q_2C_1D_S_PP_R00755_s512.vic
[Thu 11/26/2015 17:30:25] - Proceeding in non-ROM mode, Download feature 3...
[Thu 11/26/2015 17:30:25] - FATAL_ERROR: Could not download MFB to the drive...(0x11000001:SF_SG_DEVICE_CHECK_CONDITION_ERROR)
Extended Error data:
          ATA COMMAND : 0x0092  (146)
          ATA FEATURE : 0x0003  (3)
         Device Status: 0x0001  (1)
         Driver Status: 0x0000  (0)
           Host Status: 0x0008  (8)
Sense Data:
  0 -         No Sense: 114 (0x72)    OK
  1 -  Recovered Error:  11 (0x0B)    FAIL
  2 -        Not Ready:   0 (0x00)    OK
  3 -     Medium Error:   0 (0x00)    OK
  4 -   Hardware Error:   0 (0x00)    OK
  5 -  Illegal Request:   0 (0x00)    OK
  6 -   Unit Attention:   0 (0x00)    OK
  7 -     Data Protect:  14 (0x0E)    OK
  8 -      Blank Check:   9 (0x09)    OK
  9 -  Vendor Specific:  12 (0x0C)    OK
10 -     Copy Aborted:   0 (0x00)    OK
11 -  Aborted Command:   4 (0x04)    FAIL
12 - Equal Comparison:   0 (0x00)    NA
13 -  Volume Overflow: 128 (0x80)    NA
14 -       Miscompare:   0 (0x00)    OK
15 -         Reserved:   0 (0x00)    NA
System Trace:
[    7.705560] parport_pc 00:08: reported by Plug and Play ACPI
[    7.705635] parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE]
[    7.842509] ENS1371 0000:02:02.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[    7.855320] ppdev: user-space parallel port driver
[   10.386584] EXT4-fs (sdb3): re-mounted. Opts: (null)
[   10.994273] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null)
[   11.003485] SELinux: initialized (dev sdb1, type ext4), uses xattr
[   12.451105] Adding 4194300k swap on /dev/sdb2.  Priority:-1 extents:1 across:4194300k
[   12.462786] SELinux: initialized (dev binfmt_misc, type binfmt_misc), uses genfs_contexts
[   13.479086] NET: Registered protocol family 10
[   13.506462] ip6_tables: (C) 2000-2006 Netfilter Core Team
[   14.671018] powernow-k8: Found 1 AMD Athlon(tm) II X4 630 Processor (2 cpu cores) (version 2.20.00)
[   14.672433] [Firmware Bug]: powernow-k8: No compatible ACPI _PSS objects found.
[   14.672436] [Firmware Bug]: powernow-k8: Try again with latest BIOS.
[   15.656762] SELinux: initialized (dev vmhgfs, type vmhgfs), uses genfs_contexts
[   17.061835] RPC: Registered udp transport module.
[   17.061861] RPC: Registered tcp transport module.
[   17.061871] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   17.075703] SELinux: initialized (dev rpc_pipefs, type rpc_pipefs), uses genfs_contexts
[   17.112189] SELinux: initialized (dev vmblock, type vmblock), uses genfs_contexts
[   21.387465] lp0: using parport0 (interrupt-driven).
[   21.387528] lp0: console ready
[   26.194487] eth0: no IPv6 routers present
[   30.378857] hrtimer: interrupt took 20974009 ns
[   35.693180] fuse init (API version 7.14)
[   35.730239] SELinux: initialized (dev fusectl, type fusectl), uses genfs_contexts
[   35.780540] SELinux: initialized (dev fuse, type fuse), uses genfs_contexts
[ 1919.060512] sd 0:0:0:0: [sda] Stopping disk
[ 1919.061875] ata1.00: disabled
[ 1924.075037] ata1: soft resetting link
[ 1924.228303] ata1.00: ATA-4: VMware Virtual IDE Hard Drive, 00000001, max UDMA/33
[ 1924.228318] ata1.00: 64 sectors, multi 16: LBA
[ 1924.229745] ata1.00: configured for UDMA/33
[ 1924.229860] ata1: EH complete
[ 1924.232789] scsi 0:0:0:0: Direct-Access     ATA      VMware Virtual I 0000 PQ: 0 ANSI: 5
[ 1924.240244] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1924.253875] sd 0:0:0:0: [sda] 64 512-byte logical blocks: (32.7 kB/32.0 KiB)
[ 1924.255069] sd 0:0:0:0: [sda] Write Protect is off
[ 1924.255096] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1924.261228] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 1924.278415]  sda: unknown partition table
[ 1924.284967] sd 0:0:0:0: [sda] Attached SCSI disk
离线sjzjiawei
只看该作者 1楼 发表于: 2015-11-26
本帖最近打赏记录:共2条打赏M币+6
离线perter
只看该作者 2楼 发表于: 2015-11-26
本帖最近打赏记录:共1条打赏M币+3
离线myd0117
只看该作者 3楼 发表于: 2015-11-27
回 sjzjiawei 的帖子
离线jacythomas
只看该作者 4楼 发表于: 2015-11-27
离线jacythomas
只看该作者 5楼 发表于: 2015-11-27
离线sjzjiawei
只看该作者 6楼 发表于: 2015-11-27
回 myd0117 的帖子
离线myd0117
只看该作者 7楼 发表于: 2015-11-27
回 sjzjiawei 的帖子
