  • 5091阅读
  • 15回复
[SandForce]SF-2281 刷卡记录,求大侠指点 [复制链接]
离线myd0117
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2015-11-29
上面的我 OCZ ATG3 60G 的, 闪存 MT29F32G08CBACAWP,查资料得出
这样的话, 刷的就是 22220 或 22241 吧,可是配置文件显示的是
22220_fw_cl_mlc_Micron_32Gb_MT29F128G08CBACAWP_2Q_2C_1D_S_PP_R00755_s512.vic
22220_mf_mlc_Micron_32Gb_MT29F128G08CBACAWP_2Q_2C_1D_S_PP_R00755_s512.vic
22241_fw_cl_mlc_Micron_32Gb_MT29F128G08CBACAWP_2Q_2C_1D_S_PP_R00755_s512.vic
22241_mf_mlc_Micron_32Gb_MT29F128G08CBACAWP_2Q_2C_1D_S_PP_R00755_s512.vic
很明显, 32Gb 不对, MT29F128G08CBACAWP 也不对, 下面是用 22220 刷新
[root@localhost YH]# lsscsi
[0:0:0:0]    disk    ATA      HDS728080PLAT20  PF2O  /dev/sda
[3:0:0:0]    disk    ATA      SandForce{200026 20DA  /dev/sdb  (这是我的待刷新的SSD硬盘)
[root@localhost YH]# cd /home/YH/SSD/SF_Genesis-v1.5
[root@localhost SF_Genesis-v1.5]# ./SF_Genesis -PROCESS_SSD 3:0:0:0 /home/YH/SSD/mpt/FW_SF-2000_MP_3-3-0_Client--123456/FW_SF-2000_MP_3-3-0_Client.123456.mfp /home/YH/SSD/mpt/FW_SF-2000_MP_3-3-0_Client--123456/Configuration_Files/22220.123456.driveconfig 12345 www_123 log=/home/YH/SSD/s60g.log
SandForce Genesis Utility v1.5.21.20110919-fc14-32bit
SF_Core Library: v1.7.0.20110919-fc14-32bit
Copyright 2010-2011, SandForce Inc., All Rights Reserved Worldwide.
[Sun 11/29/2015 19:46:18] - SF_Genesis has been invoked with the following parameters:
                      argv[1]: -PROCESS_SSD
                      argv[2]: 3:0:0:0
                      argv[3]: /home/YH/SSD/mpt/FW_SF-2000_MP_3-3-0_Client--123456/FW_SF-2000_MP_3-3-0_Client.123456.mfp
                      argv[4]: /home/YH/SSD/mpt/FW_SF-2000_MP_3-3-0_Client--123456/Configuration_Files/22220.123456.driveconfig
                      argv[5]: 12345
                      argv[6]: www_123
                      argv[7]: log=/home/YH/SSD/s60g.log
[Sun 11/29/2015 19:46:18] - Instructing the operating system to purge any existing cached data for device: '3:0:0:0'
[Sun 11/29/2015 19:49:29] - Issuing a discovery command for device: '3:0:0:0'
[Sun 11/29/2015 19:49:35] - Discovery command completed...
[Sun 11/29/2015 19:49:35] - Waiting 5 seconds for the system to settle...
[Sun 11/29/2015 19:49:40] - Device designation string '3:0:0:0' is mapped to node '/dev/sg1'
[Sun 11/29/2015 19:49:40] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg1
    MFP Package Filename = /home/YH/SSD/mpt/FW_SF-2000_MP_3-3-0_Client--123456/FW_SF-2000_MP_3-3-0_Client.123456.mfp
      Configuration File = /home/YH/SSD/mpt/FW_SF-2000_MP_3-3-0_Client--123456/Configuration_Files/22220.123456.driveconfig
              Serial No. = 12345
         World Wide Name = www_123
[Sun 11/29/2015 19:49:52] - Successfully received the IDENTIFY data from the drive...
SF_Internal_PackageManager::OpenExisting:
                     HeaderCRC32: -1414484761,(ABB0ACE7)
     _Package.Header.HeaderCRC32: -1414484761,(ABB0ACE7)
                    OverallCRC32: -1611059272,(9FF92FB8)
    _Package.Header.OverallCRC32: -1611059272,(9FF92FB8)
[Sun 11/29/2015 19:49:56] - Successfully opened the package: /home/YH/SSD/mpt/FW_SF-2000_MP_3-3-0_Client--123456/FW_SF-2000_MP_3-3-0_Client.123456.mfp
[Sun 11/29/2015 19:49:56] - Successfully extracted *.DriveConfig file: /home/YH/SSD/mpt/FW_SF-2000_MP_3-3-0_Client--123456/Configuration_Files/22220.123456.driveconfig
[Sun 11/29/2015 19:49:56] - Extracted Config_ID: 1 (22220) in DriveConfig file: /home/YH/SSD/mpt/FW_SF-2000_MP_3-3-0_Client--123456/Configuration_Files/22220.123456.driveconfig
[Sun 11/29/2015 19:49:56] - Extracted SerialOutputControl: 0
[Sun 11/29/2015 19:49:56] - Successfully extracted Config record: 22220
[Sun 11/29/2015 19:49:56] - Successfully extracted flashware image: 22220_fw_cl_mlc_Micron_32Gb_MT29F128G08CBACAWP_2Q_2C_1D_S_PP_R00755_s512.vic
[Sun 11/29/2015 19:49:56] - Successfully extracted manufacturing image: 22220_mf_mlc_Micron_32Gb_MT29F128G08CBACAWP_2Q_2C_1D_S_PP_R00755_s512.vic
[Sun 11/29/2015 19:49:56] - Proceeding in non-ROM mode, Download feature 7...
[Sun 11/29/2015 19:49:56] - FATAL_ERROR: Could not download MFB to the drive...(0x11000001:SF_SG_DEVICE_CHECK_CONDITION_ERROR)
Extended Error data:
          ATA COMMAND : 0x0092  (146)
          ATA FEATURE : 0x0007  (7)
         Device Status: 0x0001  (1)
         Driver Status: 0x0000  (0)
           Host Status: 0x0008  (8)
Sense Data:
  0 -         No Sense: 114 (0x72)    OK
  1 -  Recovered Error:  11 (0x0B)    FAIL
  2 -        Not Ready:   0 (0x00)    OK
  3 -     Medium Error:   0 (0x00)    OK
  4 -   Hardware Error:   0 (0x00)    OK
  5 -  Illegal Request:   0 (0x00)    OK
  6 -   Unit Attention:   0 (0x00)    OK
  7 -     Data Protect:  14 (0x0E)    OK
  8 -      Blank Check:   9 (0x09)    OK
  9 -  Vendor Specific:  12 (0x0C)    OK
10 -     Copy Aborted:   0 (0x00)    OK
11 -  Aborted Command:   4 (0x04)    FAIL
12 - Equal Comparison:   0 (0x00)    NA
13 -  Volume Overflow: 220 (0xDC)    NA
14 -       Miscompare:   0 (0x00)    OK
15 -         Reserved:   1 (0x01)    NA
System Trace:
[  750.369408] ata4.00: 64 sectors, multi 0: LBA48 NCQ (depth 0/32)
[  750.372463] ata4.00: configured for UDMA/133
[  750.372490] ata4: EH complete
[  750.372750] scsi 3:0:0:0: Direct-Access     ATA      SandForce{200026 20DA PQ: 0 ANSI: 5
[  750.381160] sd 3:0:0:0: [sdb] 64 512-byte logical blocks: (32.7 kB/32.0 KiB)
[  750.381170] sd 3:0:0:0: [sdb] 4096-byte physical blocks
[  750.381279] sd 3:0:0:0: [sdb] Write Protect is off
[  750.381287] sd 3:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[  750.381333] sd 3:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[  750.382973]  sdb:
[  750.383654] sd 3:0:0:0: Attached scsi generic sg1 type 0
[  750.392761]  unknown partition table
[  750.393212] sd 3:0:0:0: [sdb] Attached SCSI disk
[  758.016314] ata4: drained 512 bytes to clear DRQ.
[  758.016332] ata4.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 frozen
[  758.016344] ata4.00: failed command: IDENTIFY DEVICE
[  758.016360] ata4.00: cmd ec/00:01:00:00:00/00:00:00:00:00/00 tag 0 pio 512 in
[  758.016364]          res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
[  758.016371] ata4.00: status: { DRDY }
[  758.016385] ata4: hard resetting link
[  758.016390] ata4: nv: skipping hardreset on occupied port
[  758.470147] ata4: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[  758.473468] ata4.00: configured for UDMA/133
[  758.473522] ata4: EH complete
[  766.016273] ata4: drained 512 bytes to clear DRQ.
[  766.016307] ata4.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 frozen
[  766.016319] ata4.00: failed command: IDENTIFY DEVICE
[  766.016335] ata4.00: cmd ec/00:01:00:00:00/00:00:00:00:00/00 tag 0 pio 512 in
[  766.016338]          res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
[  766.016346] ata4.00: status: { DRDY }
[  766.016361] ata4: hard resetting link
[  766.016367] ata4: nv: skipping hardreset on occupied port
[  766.470170] ata4: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[  766.473463] ata4.00: configured for UDMA/133
[  766.473517] ata4: EH complete
[  772.016277] ata4: drained 512 bytes to clear DRQ.
[  772.016296] ata4.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 frozen
[  772.016308] ata4.00: failed command: IDENTIFY DEVICE
[  772.016324] ata4.00: cmd ec/00:01:00:00:00/00:00:00:00:00/00 tag 0 pio 512 in
[  772.016327]          res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
[  772.016335] ata4.00: status: { DRDY }
[  772.016349] ata4: hard resetting link
[  772.016354] ata4: nv: skipping hardreset on occupied port
[  772.470166] ata4: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[  772.473468] ata4.00: configured for UDMA/133
[  772.473522] ata4: EH complete
[Sun 11/29/2015 19:49:56] - End of Genesis manufacturing log.
[Sun 11/29/2015 19:49:56] - Exiting...
[Sun 11/29/2015 19:49:56] - Overall Result for Device: /dev/sg1 ****** FAIL ******
请各位大侠指点一下, 出错了应该怎么刷这个 !! 先谢谢各位大侠了!
本帖最近打赏记录:共1条打赏M币+3
只看该作者 1楼 发表于: 2015-11-30
离线m0294
只看该作者 2楼 发表于: 2015-11-30
离线john_chuck
只看该作者 3楼 发表于: 2015-11-30
本帖最近打赏记录:共1条打赏M币+3
离线luo0271127
只看该作者 4楼 发表于: 2015-12-01
离线myd0117
只看该作者 5楼 发表于: 2015-12-01
回 m0294 的帖子
离线myd0117
只看该作者 6楼 发表于: 2015-12-01
回 luo0271127 的帖子
离线myd0117
只看该作者 7楼 发表于: 2015-12-01
回 john_chuck 的帖子
离线k1503
只看该作者 8楼 发表于: 2015-12-01
离线myd0117
只看该作者 9楼 发表于: 2015-12-01
回 k1503 的帖子
