  • 3783阅读
  • 12回复
[SandForce]sf2281 开卡求助 [复制链接]
离线cosila
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2015-12-06
sf2281开卡遇到问题,求各位大神帮助,谢谢!
板子是Intel 530的板子,F也是530的原装F,原来是8贴120G,想做成6贴96G,
开卡用的是genesis 1.5.21, mfp用的是5.2.2, config 27348,22455都试过,问题一样,在76~78%位置报错
LOG如下:
<?xml version = "1.0"?>
<Genesis_Log>
    <Log_Body>
Overall Summary:
                Start Time: Sun, 12/06/2015 @ 21:53:07
                  End Time: Sun, 12/06/2015 @ 21:53:51
             OverallResult: FAIL
                  ExitCode: (0x10090008:SF_GENESIS_FORMAT_ERROR)
Environment Settings:
          Input Parameters:
                  argv[1]: -PROCESS_SSD
                  argv[2]: 0:0:0:0
                  argv[3]: /home/cosila/SF2000/mpt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
                  argv[4]: /home/cosila/SF2000/mpt/FW_PPRO_5_2_2_Release.672199.release--0/Configuration_Files/22455.0.driveconfig
                  argv[5]: 1231
                  argv[6]: 4561
                  argv[7]: LOG=/home/cosila/SF2000/logs/1231_cosila_DATETIMESTAMP_0.0.0.0_PROCESS_SSD_RESULT.log
                  Log File: /home/cosila/SF2000/logs/1231_cosila_DATETIMESTAMP_0.0.0.0_PROCESS_SSD_RESULT.log
                  Hostname: cosila
           Host IP Address: 192.168.1.104
               Port Number: 0
                DeviceName: /dev/sg0
        SF_Genesis Version: v1.5.21.20110919-fc14-32bit
   SF_Core Library Version: v1.7.0.20110919-fc14-32bit
         SF_OS_Information: Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686
Post Processing Device Information:
                   WWN OUI: UNKNOWN
              WWN UniqueID: UNKNOWN
                Serial No.: UNKNOWN
                 Model No.: UNKNOWN
         Firmware Revision: UNKNOWN
              ROM Revision: UNKNOWN
            NAND Page Size: UNKNOWN
     Number Of Chip Enable: UNKNOWN
           Logical Sectors: UNKNOWN
                   NAND ID: UNKNOWN
        Flash Manufacturer: UNKNOWN
              Flash Device: UNKNOWN
SandForce Genesis Utility v1.5.21.20110919-fc14-32bit
SF_Core Library: v1.7.0.20110919-fc14-32bit
Copyright 2010-2011, SandForce Inc., All Rights Reserved Worldwide.
[Sun 12/06/2015 21:53:07] - SF_Genesis has been invoked with the following parameters:
                      argv[2]: 0:0:0:0
                      argv[5]: 1231
                      argv[6]: 4561
[Sun 12/06/2015 21:53:07] - Instructing the operating system to purge any existing cached data for device: '0:0:0:0'
[Sun 12/06/2015 21:53:12] - Issuing a discovery command for device: '0:0:0:0'
[Sun 12/06/2015 21:53:18] - Discovery command completed...
[Sun 12/06/2015 21:53:18] - Waiting 5 seconds for the system to settle...
[Sun 12/06/2015 21:53:23] - Device designation string '0:0:0:0' is mapped to node '/dev/sg0'
[Sun 12/06/2015 21:53:23] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg0
    MFP Package Filename = /home/cosila/SF2000/mpt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
      Configuration File = /home/cosila/SF2000/mpt/FW_PPRO_5_2_2_Release.672199.release--0/Configuration_Files/22455.0.driveconfig
              Serial No. = 1231
         World Wide Name = 4561
[Sun 12/06/2015 21:53:23] - Successfully received the IDENTIFY data from the drive...
[Sun 12/06/2015 21:53:30] - Successfully opened the package: /home/cosila/SF2000/mpt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
[Sun 12/06/2015 21:53:30] - Successfully extracted *.DriveConfig file: /home/cosila/SF2000/mpt/FW_PPRO_5_2_2_Release.672199.release--0/Configuration_Files/22455.0.driveconfig
[Sun 12/06/2015 21:53:30] - Extracted Config_ID: 1 (22455) in DriveConfig file: /home/cosila/SF2000/mpt/FW_PPRO_5_2_2_Release.672199.release--0/Configuration_Files/22455.0.driveconfig
[Sun 12/06/2015 21:53:30] - Extracted SerialOutputControl: 0
[Sun 12/06/2015 21:53:30] - Successfully extracted Config record: 22455
[Sun 12/06/2015 21:53:30] - Successfully extracted flashware image: 22455_fw_cl_mlc_Intel_64Gb_JS29F16B08CCMF3_2Q_2C_1D_PP_R01425_s512.vic
[Sun 12/06/2015 21:53:30] - Successfully extracted manufacturing image: 22455_mf_mlc_Intel_64Gb_JS29F16B08CCMF3_2Q_2C_1D_PP_R01425_s512.vic
[Sun 12/06/2015 21:53:30] - Proceeding in ROM mode, download feature 1...
[Sun 12/06/2015 21:53:30] - Successfully downloaded MFB to the drive...
[Sun 12/06/2015 21:53:30] - Waiting (5 sec) for the drive to settle...
[Sun 12/06/2015 21:53:35] - Successfully received the IDENTIFY data from the drive...
[Sun 12/06/2015 21:53:35] - Firmware revision reported to be: '522ABBM0'.  This indicates MFB download was successful.
[Sun 12/06/2015 21:53:35] - Successfully enabled SMART capabilities...
[Sun 12/06/2015 21:53:36] - Successfully issued a diagnostic unlock...
[Sun 12/06/2015 21:53:36] - Performing the flash test of block 0 (0x0000)...
[Sun 12/06/2015 21:53:38] - Flash Test Results:
Flash Test Parameters:
               Block Count: 0
                Page Count: 1
                 Bus Count: 2
        Chip Enabled Count: 2
                 Die Count: 1
                Lane Count: 3
               Plane Count: 2
Results Notes:
   N1 - At least one page tested and passed with no bit errors.
   N2 - No test data available.  Test may have aborted, or failed during the testing.
   N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
   N4 - At least  one erased page tested had bit error rate greater than half the correction power.
   N5 - Walking zeros test failed.
   N6 - Walking ones test failed.
   N7 - Block contained factory bad block markings and testing was skipped.
   N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
   N9 - Block in plane 0 was marked as a factory bad block.
  N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
  N11 - Block in plane 1 was marked as a factory bad block.
| Bus  | CE   | Die  | Lane | Value  | Result Notes                               | Overall |
| 0    | 0    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 2    | 0x0002 | N3                                         | WARNING |
| 1    | 0    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 0    | 2    | 0x0001 | N1                                         |    PASS |
  Total Number of test results: 12
            Number of failures: 0
         Number of Passed with warnings: 1
      No. Passed without warnings: 11
[Sun 12/06/2015 21:53:39] - Performing the FORMAT Command with the following parameters:
         MemoryWearCycleCapability = 0
              CurrentPE_CycleCount = 0
                     LifeInSeconds = 0
                   LogicalCapacity = 187557552
                        SectorSize = 512
             SectorAlignmentOffset = 0
                  ExpectedMemoryID = 34953 (0x8889)
                   ExpectedNumDies = 0
               SerialOutputControl = 0
                           Time[8] = 0x0000000000000000
            MiscFlag_Erase_R_Block = 0
     MiscFlag_PanicHandlingEnabled = 0
        MiscFlag_PanicOnSATA_Error = 0
  MiscFlag_WriteThrottlingTestMode = 0
      MiscFlag_DisableUserBandECCX = 1
                        L_PageSize = 0
                        E_PageSize = 0
              ErrorCorrectionPower = 0
      ConfigDeviceReadDisturbCount = 0
   ConfigDeviceReadDisturbCountLow = 0
[Sun 12/06/2015 21:53:51] - FATAL_ERROR: Could not perform the FORMAT() operation on the drive... (0x0000C048:SF_SCT (C048h): Root Creation Failed (MFB format))
[Sun 12/06/2015 21:53:51] - End of Genesis manufacturing log.
[Sun 12/06/2015 21:53:51] - Exiting...
    </Log_Body>
    <Overall_Summary>
        <Start_Time> Sun, 12/06/2015 @ 21:53:07 </Start_Time>
        <End_Time> Sun, 12/06/2015 @ 21:53:51 </End_Time>
        <Overall_Result> FAIL </Overall_Result>
        <Exit_Code> (0x10090008:SF_GENESIS_FORMAT_ERROR) </Exit_Code>
    </Overall_Summary>
    <Environment_Settings>
        <Input_Parameters>
                  argv[2]: 0:0:0:0
                  argv[5]: 1231
                  argv[6]: 4561
        </Input_Parameters>
        <Log_File> /home/cosila/SF2000/logs/1231_cosila_DATETIMESTAMP_0.0.0.0_PROCESS_SSD_RESULT.log </Log_File>
        <Hostname> cosila </Hostname>
        <Host_IP_Address> 192.168.1.104 </Host_IP_Address>
        <Port_Number> 0 </Port_Number>
        <Device_Name> /dev/sg0 </Device_Name>
        <SF_Genesis_Version> v1.5.21.20110919-fc14-32bit </SF_Genesis_Version>
        <SF_Core_Library_Version> v1.7.0.20110919-fc14-32bit </SF_Core_Library_Version>
        <SF_OS_Information> Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686 </SF_OS_Information>
    </Environment_Settings>
    <Post_Processing_Device_Info>
        <WWN_OUI> UNKNOWN </WWN_OUI>
        <WWN_UniqueID> UNKNOWN </WWN_UniqueID>
        <Serial_Number> UNKNOWN </Serial_Number>
        <Model_Number> UNKNOWN </Model_Number>
        <Firmware_Revision> UNKNOWN </Firmware_Revision>
        <ROM_Revision> UNKNOWN </ROM_Revision>
        <NAND_Page_Size> UNKNOWN </NAND_Page_Size>
        <Number_Of_Chip_Enable> UNKNOWN </Number_Of_Chip_Enable>
        <Logical_Sectors> UNKNOWN </Logical_Sectors>
        <NAND_ID> UNKNOWN </NAND_ID>
        <Flash_Manufacturer> UNKNOWN </Flash_Manufacturer>
        <Flash_Device> UNKNOWN </Flash_Device>
    </Post_Processing_Device_Info>
</Genesis_Log>
[Sun 12/06/2015 21:53:51] - Overall Result for Device: /dev/sg0 ****** FAIL ******
请问,
1.这个板子6贴,贴法对么?
2.flash test 6个都算过了吧?
3.这个板子短接的位置在哪?
4.这个问题怎么解,谢谢各位
离线小陈兔
只看该作者 1楼 发表于: 2015-12-06
本帖最近打赏记录:共1条打赏M币+3
离线toltee
只看该作者 2楼 发表于: 2015-12-06
本帖最近打赏记录:共1条打赏M币+3
离线cosila
只看该作者 3楼 发表于: 2015-12-06
回 小陈兔 的帖子
离线cosila
只看该作者 4楼 发表于: 2015-12-06
回 toltee 的帖子
离线onlyu7302
只看该作者 5楼 发表于: 2015-12-06
本帖最近打赏记录:共2条打赏M币+6
离线cosila
只看该作者 6楼 发表于: 2015-12-06
离线onlyu7302
只看该作者 7楼 发表于: 2015-12-07
回 cosila 的帖子
离线k1503
只看该作者 8楼 发表于: 2015-12-07
本帖最近打赏记录:共1条打赏M币+3
离线cosila
只看该作者 9楼 发表于: 2015-12-07
