  • 5868阅读
  • 11回复
[SandForce]SF2281+CCME2 开卡失败求教 [复制链接]
离线gbf0871
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2015-12-27
8贴,金士顿蓝色板子
选配置文件22217 错误20
[Sun 12/27/2015 21:41:09] - Searching for flashware image for configuration 22217
[Sun 12/27/2015 21:41:09] - Manifest found for configuration 22217
[Sun 12/27/2015 21:41:09] - Flashware image extracted: 22217_fw_cl_ccmlc_Intel_64Gb_JS29F16B08CCME2_2Q_2C_1D_PP_R00426_s512.vic
[Sun 12/27/2015 21:41:09] - Searching for manufacturing image for configuration 22217
[Sun 12/27/2015 21:41:09] - Manufacturing image extracted: 22217_mf_ccmlc_Intel_64Gb_JS29F16B08CCME2_2Q_2C_1D_PP_R00426_s512.vic
[Sun 12/27/2015 21:41:09] - Proceeding in ROM mode, download feature 3...
[Sun 12/27/2015 21:42:15] - FATAL_ERROR: Could not download MFB to the drive...(0x11000001:SF_SG_DEVICE_CHECK_CONDITION_ERROR)
选配置文件22173,CAME1,倒是能download MFB,不过flash test过不去
[Sun 12/27/2015 21:06:58] - Successfully received the IDENTIFY data from the drive...
[Sun 12/27/2015 21:06:58] - Validating Manufacturing Firmware Package: /home/allen/sf/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/FW_PPRO_5_8_2_Release.906190.release.123456.mfp
[Sun 12/27/2015 21:07:01] - Successfully opened the package: /home/allen/sf/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/FW_PPRO_5_8_2_Release.906190.release.123456.mfp
[Sun 12/27/2015 21:07:01] - file  /home/allen/sf/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/22173.123456.driveconfig Loaded successfully
[Sun 12/27/2015 21:07:01] - Warning:  Unable to query diagnostics information to perform power management settings check
[Sun 12/27/2015 21:07:01] - B01 Power Management configuration request detected
[Sun 12/27/2015 21:07:01] - Successfully extracted *.DriveConfig file: /home/allen/sf/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/22173.123456.driveconfig
[Sun 12/27/2015 21:07:01] - Extracted Config_ID: 1 (22173) in DriveConfig file: /home/allen/sf/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/22173.123456.driveconfig
[Sun 12/27/2015 21:07:01] - Extracted SerialOutputControl: 0
[Sun 12/27/2015 21:07:01] - Searching for flashware image for configuration 22173
[Sun 12/27/2015 21:07:01] - Manifest found for configuration 22173
[Sun 12/27/2015 21:07:01] - Flashware image extracted: 22173_fw_cl_mlc_Intel_64Gb_JS29F16B08CAME1_2Q_2C_1D_PP_R00693_s512.vic
[Sun 12/27/2015 21:07:01] - Searching for manufacturing image for configuration 22173
[Sun 12/27/2015 21:07:01] - Manufacturing image extracted: 22173_mf_mlc_Intel_64Gb_JS29F16B08CAME1_2Q_2C_1D_PP_R00693_s512.vic
[Sun 12/27/2015 21:07:01] - Proceeding in ROM mode, download feature 3...
[Sun 12/27/2015 21:07:02] - Successfully downloaded MFB to the drive...
[Sun 12/27/2015 21:07:02] - Waiting (5 sec) for the drive to settle...
[Sun 12/27/2015 21:07:07] - Successfully received the IDENTIFY data from the drive...
[Sun 12/27/2015 21:07:07] - Firmware revision reported to be: '582ABBM0'.  This indicates MFB download was successful.
[Sun 12/27/2015 21:07:07] - Successfully enabled SMART capabilities...
[Sun 12/27/2015 21:07:09] - Successfully issued a diagnostic unlock...
[Sun 12/27/2015 21:07:10] - Performing the flash test of block 0 (0x0000)...
[Sun 12/27/2015 21:07:11] - Flash Test Results:
Flash Test Parameters:
               Block Count: 0
                Page Count: 1
                 Bus Count: 2
        Chip Enabled Count: 2
                 Die Count: 1
                Lane Count: 4
               Plane Count: 2
Results Notes:
   N1 - At least one page tested and passed with no bit errors.
   N2 - No test data available.  Test may have aborted, or failed during the testing.
   N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
   N4 - At least  one erased page tested had bit error rate greater than half the correction power.
   N5 - Walking zeros test failed.
   N6 - Walking ones test failed.
   N7 - Block contained factory bad block markings and testing was skipped.
   N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
   N9 - Block in plane 0 was marked as a factory bad block.
  N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
  N11 - Block in plane 1 was marked as a factory bad block.
| Bus  | CE   | Die  | Lane | Value  | Result Notes                               | Overall |
| 0    | 0    | 0    | 0    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
| 0    | 0    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 2    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
| 0    | 0    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 0    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
| 0    | 1    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 2    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
| 0    | 1    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 0    | 0    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
| 1    | 0    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 0    | 0    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
| 1    | 1    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 0    | 2    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
| 1    | 1    | 0    | 3    | 0x0001 | N1                                         |    PASS |
  Total Number of test results: 16
            Number of failures: 7
         Number of Passed with warnings: 0
      No. Passed without warnings: 9
请问是焊接问题还是跳线问题?
离线gbf0871
只看该作者 1楼 发表于: 2015-12-27
离线k1503
只看该作者 2楼 发表于: 2015-12-28
本帖最近打赏记录:共1条打赏M币+3
离线gbf0871
只看该作者 3楼 发表于: 2015-12-28
本帖最近打赏记录:共1条打赏M币+3
离线perter
只看该作者 4楼 发表于: 2015-12-28
本帖最近打赏记录:共1条打赏M币+3
离线gbf0871
只看该作者 5楼 发表于: 2016-01-07
离线涛娃子
只看该作者 6楼 发表于: 2016-03-09
本帖最近打赏记录:共1条打赏M币+3
离线perter
只看该作者 7楼 发表于: 2016-03-10
回 涛娃子 的帖子
本帖最近打赏记录:共1条打赏M币+3
离线jacythomas
只看该作者 8楼 发表于: 2016-03-10
本帖最近打赏记录:共1条打赏M币+3
离线527945545
只看该作者 9楼 发表于: 2016-03-10
本帖最近打赏记录:共1条打赏M币+3
