  • 8648阅读
  • 10回复
[SandForce]【2281】【已解决】开卡错误-19求救 [复制链接]
离线microamd
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2015-12-30
有一块SSD,手贱想玩玩开卡,结果就给开废了,下面是log,求各位大神指教
Overall Summary:
                Start Time: Wed, 12/30/2015 @ 01:08:31
                  End Time: Wed, 12/30/2015 @ 01:09:36
             OverallResult: FAIL
                  ExitCode: (0x10090009:SF_GENESIS_CDU_ERROR)
Environment Settings:
          Input Parameters:
                  argv[1]: -PROCESS_SSD
                  argv[2]: 0:0:0:0
                  argv[3]: /home/Shayne/kk/mpt/FW_SF-2000_B01_MP1-refresh_3-1-9--123456/FW_SF-2000_B01_MP1-refresh_3-1-9.123456.mfp
                  argv[4]: /home/Shayne/kk/mpt/FW_SF-2000_B01_MP1-refresh_3-1-9--123456/Configuration_Files/22214.123456.12.driveconfig
                  argv[5]: 12345
                  argv[6]: www_123
                  argv[7]: log=/home/Shayne/kk/2281.log
                  Log File: SF_Genesis_Main_Log__Wed_12.30.2015_01.08.31.log
                  Hostname: MicroAMD
           Host IP Address: 192.168.1.9
               Port Number: 0
                DeviceName: /dev/sg0
        SF_Genesis Version: v1.7.0.01020130612-fc14-32bit
   SF_Core Library Version: v1.7.1.20130612-fc14-32bit
         SF_OS_Information: Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686
Post Processing Device Information:
                   WWN OUI: UNKNOWN
              WWN UniqueID: UNKNOWN
                Serial No.: UNKNOWN
                 Model No.: UNKNOWN
         Firmware Revision: UNKNOWN
              ROM Revision: UNKNOWN
            NAND Page Size: UNKNOWN
     Number Of Chip Enable: UNKNOWN
           Logical Sectors: UNKNOWN
                   NAND ID: UNKNOWN
        Flash Manufacturer: UNKNOWN
              Flash Device: UNKNOWN
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Wed 12/30/2015 01:08:31] - SF_Genesis has been invoked with the following parameters:
                      argv[2]: 0:0:0:0
                      argv[5]: 12345
                      argv[6]: www_123
[Wed 12/30/2015 01:08:31] - Instructing the operating system to purge any existing cached data for device: '0:0:0:0'
[Wed 12/30/2015 01:08:36] - Issuing a discovery command for device: '0:0:0:0'
[Wed 12/30/2015 01:08:41] - Discovery command completed...
[Wed 12/30/2015 01:08:41] - Waiting 5 seconds for the system to settle...
[Wed 12/30/2015 01:08:46] - Device designation string '0:0:0:0' is mapped to node '/dev/sg0'
[Wed 12/30/2015 01:08:46] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg0
    MFP Package Filename = /home/Shayne/kk/mpt/FW_SF-2000_B01_MP1-refresh_3-1-9--123456/FW_SF-2000_B01_MP1-refresh_3-1-9.123456.mfp
      Configuration File = /home/Shayne/kk/mpt/FW_SF-2000_B01_MP1-refresh_3-1-9--123456/Configuration_Files/22214.123456.12.driveconfig
              Serial No. = 12345
         World Wide Name = www_123
[Wed 12/30/2015 01:08:46] - Successfully received the IDENTIFY data from the drive...
[Wed 12/30/2015 01:08:46] - Validating Manufacturing Firmware Package: /home/Shayne/kk/mpt/FW_SF-2000_B01_MP1-refresh_3-1-9--123456/FW_SF-2000_B01_MP1-refresh_3-1-9.123456.mfp
[Wed 12/30/2015 01:08:54] - Successfully opened the package: /home/Shayne/kk/mpt/FW_SF-2000_B01_MP1-refresh_3-1-9--123456/FW_SF-2000_B01_MP1-refresh_3-1-9.123456.mfp
[Wed 12/30/2015 01:08:54] - file  /home/Shayne/kk/mpt/FW_SF-2000_B01_MP1-refresh_3-1-9--123456/Configuration_Files/22214.123456.12.driveconfig Loaded successfully
[Wed 12/30/2015 01:08:54] - Warning:  Unable to query diagnostics information to perform power management settings check
[Wed 12/30/2015 01:08:54] - B01 Power Management configuration request detected
[Wed 12/30/2015 01:08:54] - Successfully extracted *.DriveConfig file: /home/Shayne/kk/mpt/FW_SF-2000_B01_MP1-refresh_3-1-9--123456/Configuration_Files/22214.123456.12.driveconfig
[Wed 12/30/2015 01:08:54] - Extracted Config_ID: 1 (22214) in DriveConfig file: /home/Shayne/kk/mpt/FW_SF-2000_B01_MP1-refresh_3-1-9--123456/Configuration_Files/22214.123456.12.driveconfig
[Wed 12/30/2015 01:08:54] - Extracted SerialOutputControl: 0
[Wed 12/30/2015 01:08:54] - Searching for flashware image for configuration 22214
[Wed 12/30/2015 01:08:54] - Manifest found for configuration 22214
[Wed 12/30/2015 01:08:54] - Flashware image extracted: 22214_fw_cl_mlc_Micron_64Gb_MT29F64G08CBAAAWP_2Q_1C_1D_PP_R00751_s512.vic
[Wed 12/30/2015 01:08:54] - Searching for manufacturing image for configuration 22214
[Wed 12/30/2015 01:08:54] - Manufacturing image extracted: 22214_mf_mlc_Micron_64Gb_MT29F64G08CBAAAWP_2Q_1C_1D_PP_R00751_s512.vic
[Wed 12/30/2015 01:08:54] - Proceeding in ROM mode, download feature 3...
[Wed 12/30/2015 01:08:54] - Successfully downloaded MFB to the drive...
[Wed 12/30/2015 01:08:54] - Waiting (5 sec) for the drive to settle...
[Wed 12/30/2015 01:08:59] - Successfully received the IDENTIFY data from the drive...
[Wed 12/30/2015 01:08:59] - Firmware revision reported to be: '319ABBM0'.  This indicates MFB download was successful.
[Wed 12/30/2015 01:08:59] - Successfully enabled SMART capabilities...
[Wed 12/30/2015 01:09:02] - Successfully issued a diagnostic unlock...
[Wed 12/30/2015 01:09:03] - Performing the flash test of block 0 (0x0000)...
[Wed 12/30/2015 01:09:04] - Flash Test Results:
Flash Test Parameters:
               Block Count: 0
                Page Count: 1
                 Bus Count: 2
        Chip Enabled Count: 1
                 Die Count: 1
                Lane Count: 4
               Plane Count: 2
Results Notes:
   N1 - At least one page tested and passed with no bit errors.
   N2 - No test data available.  Test may have aborted, or failed during the testing.
   N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
   N4 - At least  one erased page tested had bit error rate greater than half the correction power.
   N5 - Walking zeros test failed.
   N6 - Walking ones test failed.
   N7 - Block contained factory bad block markings and testing was skipped.
   N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
   N9 - Block in plane 0 was marked as a factory bad block.
  N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
  N11 - Block in plane 1 was marked as a factory bad block.
| Bus  | CE   | Die  | Lane | Value  | Result Notes                               | Overall |
| 0    | 0    | 0    | 0    | 0x0002 | N3                                         | WARNING |
| 0    | 0    | 0    | 1    | 0x0003 | N1,N3                                      | WARNING |
| 0    | 0    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 3    | 0x0003 | N1,N3                                      | WARNING |
| 1    | 0    | 0    | 0    | 0x0003 | N1,N3                                      | WARNING |
| 1    | 0    | 0    | 1    | 0x0003 | N1,N3                                      | WARNING |
| 1    | 0    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 0    | 3    | 0x0003 | N1,N3                                      | WARNING |
  Total Number of test results: 8
            Number of failures: 0
         Number of Passed with warnings: 6
      No. Passed without warnings: 2
[Wed 12/30/2015 01:09:04] - Performing the FORMAT Command with the following parameters:
         MemoryWearCycleCapability = 0
              CurrentPE_CycleCount = 0
                     LifeInSeconds = 0
                   LogicalCapacity = 125045424
                        SectorSize = 512
             SectorAlignmentOffset = 0
                  ExpectedMemoryID = 34860 (0x882C)
                   ExpectedNumDies = 0
               SerialOutputControl = 0
                           Time[8] = 0x0000000000000000
            MiscFlag_Erase_R_Block = 0
     MiscFlag_PanicHandlingEnabled = 0
        MiscFlag_PanicOnSATA_Error = 0
  MiscFlag_WriteThrottlingTestMode = 0
      MiscFlag_DisableUserBandECCX = 1
                        L_PageSize = 0
                        E_PageSize = 0
              ErrorCorrectionPower = 0
      ConfigDeviceReadDisturbCount = 0
   ConfigDeviceReadDisturbCountLow = 0
                  ExtraOptions_0_1 = 0
[Wed 12/30/2015 01:09:23] - FORMAT command completed...
[Wed 12/30/2015 01:09:23] - Waiting (2 sec) for the drive to settle...
[Wed 12/30/2015 01:09:25] - Setting up the stamp information through CDU command...
[Wed 12/30/2015 01:09:36] - FATAL_ERROR: Could not perform the ReadDriveConfigUnique() operation on the drive... (0x11000001:SF_SG_DEVICE_CHECK_CONDITION_ERROR)
Extended Error data:
          ATA COMMAND : 0x00B0  (176)
          ATA FEATURE : 0x00D5  (213)
         Device Status: 0x0001  (1)
         Driver Status: 0x0000  (0)
           Host Status: 0x0008  (8)
Sense Data:
  0 -         No Sense: 114 (0x72)    OK
  1 -  Recovered Error:  11 (0x0B)    FAIL
  2 -        Not Ready:   0 (0x00)    OK
  3 -     Medium Error:   0 (0x00)    OK
  4 -   Hardware Error:   0 (0x00)    OK
  5 -  Illegal Request:   0 (0x00)    OK
  6 -   Unit Attention:   0 (0x00)    OK
  7 -     Data Protect:  14 (0x0E)    OK
  8 -      Blank Check:   9 (0x09)    OK
  9 -  Vendor Specific:  12 (0x0C)    OK
10 -     Copy Aborted:   0 (0x00)    OK
11 -  Aborted Command:   0 (0x00)    OK
12 - Equal Comparison:   0 (0x00)    NA
13 -  Volume Overflow:   7 (0x07)    NA
14 -       Miscompare:   0 (0x00)    OK
15 -         Reserved: 225 (0xE1)    NA
System Trace:
[   86.400815] sd 0:0:0:0: [sda] 64 512-byte logical blocks: (32.7 kB/32.0 KiB)
[   86.400822] sd 0:0:0:0: [sda] 4096-byte physical blocks
[   86.400949] sd 0:0:0:0: [sda] Write Protect is off
[   86.400955] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[   86.401011] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[   86.402517]  sda:
[   86.402811] sd 0:0:0:0: Attached scsi generic sg0 type 0
[   86.414292]  unknown partition table
[   86.416581] sd 0:0:0:0: [sda] Attached SCSI disk
[  136.328613] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 frozen
[  136.328622] ata1.00: ST-ATA: DRQ=0 without device error, dev_stat 0x50
[  136.328630] ata1.00: failed command: SMART
[  136.328642] ata1.00: cmd b0/d5:07:e1:4f:c2/00:00:00:00:00/00 tag 0 pio 3584 in
[  136.328645]          res 50/00:07:e1:4f:c2/00:00:00:00:00/00 Emask 0x202 (HSM violation)
[  136.328652] ata1.00: status: { DRDY }
[  136.328672] ata1: soft resetting link
[  136.498252] ata1.00: model number mismatch 'SandForce{200026BB}' != 'SandForce'
[  136.498287] ata1.00: revalidation failed (errno=-19)
[  141.479091] ata1: soft resetting link
[  141.649283] ata1.00: model number mismatch 'SandForce{200026BB}' != 'SandForce'
[  141.649291] ata1.00: revalidation failed (errno=-19)
[  141.649298] ata1.00: disabled
[  146.630072] ata1: soft resetting link
[  146.800442] ata1.00: failed to read native max address (err_mask=0x1)
[  146.800448] ata1.00: HPA support seems broken, skipping HPA handling
[  146.800458] ata1.00: ATA-9: SandForce, 319ABBM0, max UDMA/133
[  146.800465] ata1.00: 125000000 sectors, multi 16: LBA48 NCQ (depth 0/32)
[  146.819345] ata1.00: configured for UDMA/133
[  146.819374] ata1: EH complete
[  146.819395] ata1.00: detaching (SCSI 0:0:0:0)
[  146.823412] sd 0:0:0:0: [sda] Stopping disk
[  146.823781] scsi 0:0:0:0: Direct-Access     ATA      SandForce        319A PQ: 0 ANSI: 5
[  146.824189] sd 0:0:0:0: Attached scsi generic sg2 type 0
[  146.840068] sd 0:0:0:0: [sda] 125000000 512-byte logical blocks: (64.0 GB/59.6 GiB)
[  146.840147] sd 0:0:0:0: [sda] Write Protect is off
[  146.840151] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[  146.840184] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[  146.840626]  sda:
[  146.840780] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[  146.840785] ata1.00: BMDMA stat 0x25
[  146.840789] ata1.00: failed command: READ DMA
[  146.840797] ata1.00: cmd c8/00:08:00:00:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[  146.840798]          res 51/04:08:00:00:00/00:00:00:00:00/e0 Emask 0x1 (device error)
[  146.840802] ata1.00: status: { DRDY ERR }
[  146.840805] ata1.00: error: { ABRT }
[Wed 12/30/2015 01:09:36] - End of Genesis manufacturing log.
[Wed 12/30/2015 01:09:36] - Exiting...
还望各位大神不吝赐教,谢谢了
[ 此帖被microamd在2015-12-30 14:45重新编辑 ]
本帖最近打赏记录:共1条打赏 ,M币+3
离线cj9487
只看该作者 1楼 发表于: 2015-12-30
离线microamd
只看该作者 2楼 发表于: 2015-12-30
离线microamd
只看该作者 3楼 发表于: 2015-12-30
回 cj9487 的帖子
离线lai013692
只看该作者 4楼 发表于: 2015-12-30
离线windowsxp
只看该作者 5楼 发表于: 2015-12-30
离线shgzyx
只看该作者 6楼 发表于: 2015-12-30
离线whr273666
只看该作者 7楼 发表于: 2015-12-31
回 microamd 的帖子
离线watson
只看该作者 8楼 发表于: 2015-12-31
离线microamd
只看该作者 9楼 发表于: 2015-12-31
回 shgzyx 的帖子
