  • 8784阅读
  • 8回复
[群联]PS2251-00金士顿U盘变成砖求救 [复制链接]
离线cay
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2016-02-18
 设备描述: [H:]USB 大容量存储设备(2268 PRAM)
 设备类型: 大容量存储设备
 协议版本: USB 2.00
 当前速度: 高速(HighSpeed)
 电力消耗: 50mA
USB设备ID: VID = 13FE PID = 3E00
 设备名称: 2268 PRAM
设备修订版: 0110
 产品型号: 2268 PRAM
产品修订版: 1.00
 主控厂商: Phison(群联)
 主控型号: PS2251-00(PS0000) - F/W 00.00.00 [2000-00-00]
闪存识别码: ADDE94EB - Hynix(海力士) H27UCG8T2BLR [MLC-16K]
 在线资料: http://dl.mydigit.net/special/up/phison.html
可能的闪存型号
[1CE]H27UCG8T2BLR
[1CE]H27UCG8T2BYR
[2CE]H27QDGDUDBLR
[4CE]H27QEGDVEBLR
闪存识别码映射表
[通道 0]    [通道 1]
使用MPALL_F1_9000_v372_0B工具无法识别
使用UPTool_V2.092 能够识别但是量产失败
日志如下
[ 2016-02-18 14:18:46 ]
  OS Version: Win 7
  MP Version: 2.092 (2014.10.24)
  PC Name   :  []
  DUT Slot: 1
  Driver  : H
  IC Type : 1E-0
  ISP Type: 0
  F-Slot  : 1
   0:00.0 -------------------------------------
   0:00.0 New Flow Initial ... 2092
   0:00.0 + INQ:........        2268 SORTER V1.01.00PMAP1234
   0:01.0 + ISP Version : OS68 Ver 1.08k (2014.10.21-1)
   0:01.0 + Flash Unit Index = 353 / (1057) / 649
   0:01.0    - ID:   AD-DE-94-EB-74-44 x 1
   0:01.0    - Mask: FF-FF-FF-FF-FF-3F
   0:01.0    - Flash Parameters : 20nm,x8,2132,256,32, HW.ECC=44,822
   0:01.0      Flash Notes: Hynix 20nm MLC (16K)
   0:01.1 + New CE Mode_3=00, CEMask=01
   0:01.3 + ECC setting : 44, 44, 33
   0:01.3 * Model=1E-0-0
   0:01.3    - UP23N,,H27UCG8T2B(MLC.16K)-8GB[1/1]
   0:01.3 + Total effective blocks = 1 x 1 x 2132 = 2132
   0:01.3 -------------------------------------
   0:01.3 Test & Scan Stage ... 1 FSlot mode
   0:01.3 [ Low Level Format + TestMode=0 ]
   0:01.3   >> SmartEcc=1, Ecc=0
   0:01.3   >> Mode=3, Optimize=0, SizeMode=0
   0:01.3 + Smart Test ... 0000-0000
   0:01.3 + INQ:........        2268 SORTER V1.01.00PMAP1234
   0:01.3 + ISP Version : OS68 Ver 1.08k (2014.10.21-1)
   0:01.3 + GPIO = FF,06,FF,FF
   0:01.3 + New CE Mode_3=00, CEMask=01
   0:01.5 + ECC setting : 44, 44, 36
   0:01.5 + Set Retry Table (HY D2).
   0:01.5 + CE=1, Page Layout Mode = 3, MaxWL=128
   0:01.5 + Total effective blocks = 1 x 1 x 2132 = 2132
   0:01.5 +-----------------------------------------------------+
   0:01.5 + Double Check Block Scan ... 0-2(CCCC), Marker=C2
   0:02.0    + 0-0-0000: ................................................................
   0:02.5    + 0-0-0040: ................................................................
   0:03.0    + 0-0-0080: ................................................................
   0:03.5    + 0-0-00C0: ................................................................
   0:04.1    + 0-0-0100: ................................................................
   0:04.6    + 0-0-0140: ................................................................
   0:05.1    + 0-0-0180: ................................................................
   0:05.6    + 0-0-01C0: ................................................................
   0:06.1    + 0-0-0200: ................................................................
   0:07.1    + 0-0-0240: .................U.U.U.U.U.U.U.U.U.U.U..........................
   0:07.6    + 0-0-0280: ................................................................
   0:08.2    + 0-0-02C0: ................................................................
   0:08.7    + 0-0-0300: ................................................................
   0:09.2    + 0-0-0340: ................................................................
   0:09.7    + 0-0-0380: ................................................................
   0:10.2    + 0-0-03C0: ................................................................
   0:10.7    + 0-0-0400: ................................................................
   0:11.3    + 0-0-0440: ................................................................
   0:11.8    + 0-0-0480: ................................................................
   0:12.3    + 0-0-04C0: ................................................................
   0:12.8    + 0-0-0500: ................................................................
   0:13.4    + 0-0-0540: ...................U............................................
   0:13.9    + 0-0-0580: ................................................................
   0:14.4    + 0-0-05C0: ................................................................
   0:14.9    + 0-0-0600: ................................................................
   0:15.4    + 0-0-0640: ................................................................
   0:16.0    + 0-0-0680: ................................................................
   0:16.5    + 0-0-06C0: ................................................................
   0:17.0    + 0-0-0700: ................................................................
   0:17.5    + 0-0-0740: ................................................................
   0:18.0    + 0-0-0780: ................................................................
   0:18.5    + 0-0-07C0: ................................................................
   0:19.1    + 0-0-0800: ................................................................
   0:19.2    + 0-0-0840: ....................
   0:19.2    - 2132 Block been scanned, 12 New Error Block
   0:26.8 * Erase takes 00:00:07, (Found 0 NoResponse Blocks) 0, Continue Error=0
   0:26.8 + New ISP to Save IB Table.
   0:26.8 + Free PC RAM: 4095/4095 MB
   0:26.8 [DefectBlock] .. C3
   0:26.8 + CE-0(Die-0):0251,0253,0255,0257,0259,025B,025D,025F,0261,0263,0265,0553,
   0:26.8    - Total 12 Bad Blocks
   0:26.8 O.PA[]=OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
   0:26.8 O.SA[]=OOOOOOOOOOOOOOOO
   0:26.8 + Calculate User BIN ... CE(0-0)
   0:26.8    - FW Spare = 32,44
   0:26.8    - Good Page=256, Bad Page=0
   0:26.8    - ce:0,DIE:0, Size= 8503296 =(2120<2120>-44) x (256) x (16-0)
   0:26.8    + Total Size = 8304
   0:26.8 <MaxSize> Physical Size=8304 (MB), Selected Size=8304 (MB)
   0:26.8 + Setup Parameters for IB-Table ... Slot-0
   0:26.8 PA[]=OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
   0:26.8 SA[]=OOOOOOOOOOOOOOOO
   0:26.8    - F0: Total Sector=8, Pages for IB=1
   0:26.8    - EvenZonePage[]=0,1,2,3, OddZonePage[]=0,1,2,3
   0:26.8 + 40(00) / OBC:40(00)
   0:26.8 + Not found OLD IB, Save a newer
   0:26.8 -------------------------------------------
   0:26.8 + Install IB-Table ... Page=16 K, Skip=0000, TM=33, MBC=0, EM=C3
   0:26.8    - SecMapping :0(0),1(1),2(2),3(3),4(4),5(5),6(6),7(7),8(8),9(9),10(10),11(11),12(12),13(13),14(14),15(15),
   0:26.8 + Block Mask=C3...
   0:26.8    - ce:0,DIE:0, Size= 8499200 =(2119<2119>-44) x (256) x (16-0)
   0:26.8    + Total Size = 8300
   0:26.8 <MaxSize> Physical Size=8300 (MB), Selected Size=8300 (MB)
   0:26.8    - Good/Plane=1065,1054,
   0:27.1    *** IB check fail S:0/0(Data:00000000/Spare:FFFF) ***
   0:27.1    *** Warning: Create IB Table fail(CE:0 Block:0 Page:0) failed
   0:27.1    - Good/Plane=1065,1054,
   0:27.2    *** Warning: Create IB Table fail(CE:0 Block:0 Page:0) failed
   0:27.3 + Calculate User BIN ... CE(0-0)
   0:27.3 + Block Mask=C3...
   0:27.3    - FW Spare = 32,44
   0:27.3    - Good Page=256, Bad Page=0
   0:27.3    - ce:0,DIE:0, Size= 8495104 =(2118<2118>-44) x (256) x (16-0)
   0:27.3    + Total Size = 8296
   0:27.3 <MaxSize> Physical Size=8296 (MB), Selected Size=8296 (MB)
   0:27.3    - Good/Plane=1065,1053,
   0:27.6    *** IB check fail S:0/0(Data:00000000/Spare:FFFF) ***
   0:27.6    *** Warning: Create IB Table fail(CE:0 Block:1 Page:0) failed
   0:27.6    - Good/Plane=1065,1053,
   0:27.7    *** Warning: Create IB Table fail(CE:0 Block:1 Page:0) failed
   0:27.7 + Calculate User BIN ... CE(0-0)
   0:27.7 + Block Mask=C3...
   0:27.7    - FW Spare = 32,44
   0:27.7    - Good Page=256, Bad Page=0
   0:27.7    - ce:0,DIE:0, Size= 8491008 =(2117<2117>-44) x (256) x (16-0)
   0:27.7    + Total Size = 8292
   0:27.7 <MaxSize> Physical Size=8292 (MB), Selected Size=8292 (MB)
   0:27.7    - Good/Plane=1064,1053,
   0:28.0    *** IB check fail S:0/0(Data:00000000/Spare:FFFF) ***
   0:28.0    *** Warning: Create IB Table fail(CE:0 Block:2 Page:0) failed
   0:28.0    - Good/Plane=1064,1053,
   0:28.1    *** Warning: Create IB Table fail(CE:0 Block:2 Page:0) failed
   0:28.1 + Calculate User BIN ... CE(0-0)
   0:28.1 + Block Mask=C3...
   0:28.1    - FW Spare = 32,44
   0:28.1    - Good Page=256, Bad Page=0
   0:28.1    - ce:0,DIE:0, Size= 8486912 =(2116<2116>-44) x (256) x (16-0)
   0:28.1    + Total Size = 8288
   0:28.1 <MaxSize> Physical Size=8288 (MB), Selected Size=8288 (MB)
   0:28.1    - Good/Plane=1064,1052,
   0:28.4    *** IB check fail S:0/0(Data:00000000/Spare:FFFF) ***
   0:28.4    *** Warning: Create IB Table fail(CE:0 Block:3 Page:0) failed
   0:28.4    - Good/Plane=1064,1052,
   0:28.5    *** Warning: Create IB Table fail(CE:0 Block:3 Page:0) failed
   0:28.5 + Calculate User BIN ... CE(0-0)
   0:28.5 + Block Mask=C3...
   0:28.5    - FW Spare = 32,44
   0:28.5    - Good Page=256, Bad Page=0
   0:28.5    - ce:0,DIE:0, Size= 8482816 =(2115<2115>-44) x (256) x (16-0)
   0:28.5    + Total Size = 8284
   0:28.5 <MaxSize> Physical Size=8284 (MB), Selected Size=8284 (MB)
   0:28.5    - Good/Plane=1063,1052,
   0:28.9    *** IB check fail S:0/0(Data:00000000/Spare:FFFF) ***
   0:28.9    *** Warning: Create IB Table fail(CE:0 Block:4 Page:0) failed
   0:28.9    - Good/Plane=1063,1052,
   0:29.0    *** Warning: Create IB Table fail(CE:0 Block:4 Page:0) failed
   0:29.0 ### Err: IB-Table create failed (CE=0,DIE=0).
   0:29.0 ### F0-Err:0078 ###
   0:29.0 [RESULT] ErrorCode : 0078
   0:29.0 + Static Summary: B=0   ,P=0   ,S=0   ,Others=0   ,D1B=0   ,D1P=0   ,D1S=0   ,D1Others=0   ,
[ 2016-02-18 14:19:15 ]
[ UPTool takes 00:00:29 ]
目前U盘无法打开,求助更好的办法,谢谢!
离线蔚蓝的家
只看该作者 1楼 发表于: 2016-02-18
离线cay
只看该作者 2楼 发表于: 2016-02-18
离线sujian42007
只看该作者 3楼 发表于: 2016-02-18
本帖最近打赏记录:共3条打赏M币+9
离线cay
只看该作者 4楼 发表于: 2016-02-19
回 sujian42007 的帖子
离线gudanyuzhou
只看该作者 5楼 发表于: 2016-02-20
离线wfnh1022
只看该作者 6楼 发表于: 2016-02-21
离线cay
只看该作者 7楼 发表于: 2016-02-24
回 wfnh1022 的帖子
离线cay
只看该作者 8楼 发表于: 2016-02-24
回 gudanyuzhou 的帖子
