  • 2443阅读
  • 5回复
[SandForce]sf2281问题 [复制链接]
离线75106zxs
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2016-02-28
<?xml version = "1.0"?>
<Genesis_Log>
    <Log_Body>
Overall Summary:
                Start Time: Sun, 02/28/2016 @ 21:44:25
                  End Time: Sun, 02/28/2016 @ 21:46:07
             OverallResult: FAIL
                  ExitCode: (0x10090014:SF_GENESIS_FW_DOWNLOAD_ERROR)
Environment Settings:
          Input Parameters:
                  argv[1]: -PROCESS_SSD
                  argv[2]: 0:0:0:0
                  argv[3]: /root/pmt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
                  argv[4]: /root/pmt/FW_PPRO_5_2_2_Release.672199.release--0/22069.0.driveconfig
                  argv[5]: 11
                  argv[6]: 22
                  argv[7]: LOG=/root/pmt/FW_PPRO_5_2_2_Release.672199.release--0/11_localhost.localdomain_DATETIMESTAMP_0.0.0.0_PROCESS_SSD_RESULT.log
                  Log File: /root/pmt/FW_PPRO_5_2_2_Release.672199.release--0/11_localhost.localdomain_DATETIMESTAMP_0.0.0.0_PROCESS_SSD_RESULT.log
                  Hostname: localhost.localdomain
           Host IP Address: 127.0.0.1
               Port Number: 0
                DeviceName: /dev/sg0
        SF_Genesis Version: v1.7.0.01020130612-fc14-32bit
   SF_Core Library Version: v1.7.1.20130612-fc14-32bit
         SF_OS_Information: Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686
Post Processing Device Information:
                   WWN OUI: UNKNOWN
              WWN UniqueID: UNKNOWN
                Serial No.: UNKNOWN
                 Model No.: UNKNOWN
         Firmware Revision: UNKNOWN
              ROM Revision: UNKNOWN
            NAND Page Size: UNKNOWN
     Number Of Chip Enable: UNKNOWN
           Logical Sectors: UNKNOWN
                   NAND ID: UNKNOWN
        Flash Manufacturer: UNKNOWN
              Flash Device: UNKNOWN
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Sun 02/28/2016 21:44:25] - SF_Genesis has been invoked with the following parameters:
                      argv[2]: 0:0:0:0
                      argv[5]: 11
                      argv[6]: 22
[Sun 02/28/2016 21:44:25] - Instructing the operating system to purge any existing cached data for device: '0:0:0:0'
[Sun 02/28/2016 21:44:30] - Issuing a discovery command for device: '0:0:0:0'
[Sun 02/28/2016 21:44:35] - Discovery command completed...
[Sun 02/28/2016 21:44:35] - Waiting 5 seconds for the system to settle...
[Sun 02/28/2016 21:44:40] - Device designation string '0:0:0:0' is mapped to node '/dev/sg0'
[Sun 02/28/2016 21:44:40] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg0
    MFP Package Filename = /root/pmt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
      Configuration File = /root/pmt/FW_PPRO_5_2_2_Release.672199.release--0/22069.0.driveconfig
              Serial No. = 11
         World Wide Name = 22
[Sun 02/28/2016 21:45:01] - Successfully received the IDENTIFY data from the drive...
[Sun 02/28/2016 21:45:01] - Validating Manufacturing Firmware Package: /root/pmt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
[Sun 02/28/2016 21:45:06] - Successfully opened the package: /root/pmt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
[Sun 02/28/2016 21:45:06] - file  /root/pmt/FW_PPRO_5_2_2_Release.672199.release--0/22069.0.driveconfig Loaded successfully
[Sun 02/28/2016 21:45:06] - Warning:  Unable to query diagnostics information to perform power management settings check
[Sun 02/28/2016 21:45:06] - B01 Power Management configuration request detected
[Sun 02/28/2016 21:45:06] - Successfully extracted *.DriveConfig file: /root/pmt/FW_PPRO_5_2_2_Release.672199.release--0/22069.0.driveconfig
[Sun 02/28/2016 21:45:06] - Extracted Config_ID: 1 (22069) in DriveConfig file: /root/pmt/FW_PPRO_5_2_2_Release.672199.release--0/22069.0.driveconfig
[Sun 02/28/2016 21:45:06] - Extracted SerialOutputControl: 0
[Sun 02/28/2016 21:45:06] - Searching for flashware image for configuration 22069
[Sun 02/28/2016 21:45:06] - Manifest found for configuration 22069
[Sun 02/28/2016 21:45:06] - Flashware image extracted: 22069_fw_cl_ccmlc_Intel_64Gb_JS29F16B08CCME2_1Q_2C_1D_PP_R00424_s512.vic
[Sun 02/28/2016 21:45:06] - Searching for manufacturing image for configuration 22069
[Sun 02/28/2016 21:45:06] - Manufacturing image extracted: 22069_mf_ccmlc_Intel_64Gb_JS29F16B08CCME2_1Q_2C_1D_PP_R00424_s512.vic
[Sun 02/28/2016 21:45:06] - Proceeding in ROM mode, download feature 3...
[Sun 02/28/2016 21:46:07] - FATAL_ERROR: Could not download MFB to the drive...(0x11000001:SF_SG_DEVICE_CHECK_CONDITION_ERROR)
Extended Error data:
          ATA COMMAND : 0x0092  (146)
          ATA FEATURE : 0x0003  (3)
         Device Status: 0x0001  (1)
         Driver Status: 0x0000  (0)
           Host Status: 0x0008  (8)
Sense Data:
  0 -         No Sense: 114 (0x72)    OK
  1 -  Recovered Error:  11 (0x0B)    FAIL
  2 -        Not Ready:   0 (0x00)    OK
  3 -     Medium Error:   0 (0x00)    OK
  4 -   Hardware Error:   0 (0x00)    OK
  5 -  Illegal Request:   0 (0x00)    OK
  6 -   Unit Attention:   0 (0x00)    OK
  7 -     Data Protect:  14 (0x0E)    OK
  8 -      Blank Check:   9 (0x09)    OK
  9 -  Vendor Specific:  12 (0x0C)    OK
10 -     Copy Aborted:   0 (0x00)    OK
11 -  Aborted Command:   0 (0x00)    OK
12 - Equal Comparison:   0 (0x00)    NA
13 -  Volume Overflow:   0 (0x00)    NA
14 -       Miscompare:   0 (0x00)    OK
15 -         Reserved: 128 (0x80)    NA
System Trace:
[  120.043109] ata1.00: ATA-8: SandForce{200026BB}, 20DABBR0, max UDMA/133
[  120.043114] ata1.00: 64 sectors, multi 0: LBA48 NCQ (depth 31/32), AA
[  120.048794] ata1.00: configured for UDMA/133
[  120.048806] ata1: EH complete
[  120.048980] scsi 0:0:0:0: Direct-Access     ATA      SandForce{200026 20DA PQ: 0 ANSI: 5
[  120.050795] sd 0:0:0:0: [sda] 64 512-byte logical blocks: (32.7 kB/32.0 KiB)
[  120.050800] sd 0:0:0:0: [sda] 4096-byte physical blocks
[  120.050900] sd 0:0:0:0: [sda] Write Protect is off
[  120.050905] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[  120.050948] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[  120.052428] sd 0:0:0:0: Attached scsi generic sg0 type 0
[  120.053653]  sda: unknown partition table
[  120.062897] sd 0:0:0:0: [sda] Attached SCSI disk
[  150.752069] ata1.00: exception Emask 0x0 SAct 0x1 SErr 0x400001 action 0x6 frozen
[  150.752078] ata1: SError: { RecovData Handshk }
[  150.752084] ata1.00: failed command: READ FPDMA QUEUED
[  150.752094] ata1.00: cmd 60/08:00:18:00:00/00:00:00:00:00/40 tag 0 ncq 4096 in
[  150.752096]          res 40/00:00:00:00:00/00:00:00:00:00/40 Emask 0x4 (timeout)
[  150.752102] ata1.00: status: { DRDY }
[  150.752111] ata1: hard resetting link
[  151.057108] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[  151.063799] ata1.00: configured for UDMA/133
[  151.063806] ata1.00: device reported invalid CHS sector 0
[  151.063817] ata1: EH complete
[  156.706507] ata1.00: exception Emask 0x10 SAct 0x0 SErr 0x400100 action 0x6 frozen
[  156.706514] ata1.00: irq_stat 0x08000002, interface fatal error
[  156.706520] ata1: SError: { UnrecovData Handshk }
[  156.706525] ata1.00: failed command: DOWNLOAD MICROCODE
[  156.706535] ata1.00: cmd 92/03:80:00:80:01/00:00:00:00:00/00 tag 0 pio 65536 out
[  156.706537]          res 50/00:00:80:00:00/00:00:00:00:00/e0 Emask 0x10 (ATA bus error)
[  156.706543] ata1.00: status: { DRDY }
[  156.706552] ata1: hard resetting link
[  162.060089] ata1: link is slow to respond, please be patient (ready=0)
[  166.752091] ata1: COMRESET failed (errno=-16)
[  166.752100] ata1: hard resetting link
[  172.106077] ata1: link is slow to respond, please be patient (ready=0)
[  176.798107] ata1: COMRESET failed (errno=-16)
[  176.798115] ata1: hard resetting link
[  182.152094] ata1: link is slow to respond, please be patient (ready=0)
[  211.834156] ata1: COMRESET failed (errno=-16)
[  211.834167] ata1: limiting SATA link speed to 1.5 Gbps
[  211.834171] ata1: hard resetting link
[  216.882103] ata1: COMRESET failed (errno=-16)
[  216.882111] ata1: reset failed, giving up
[  216.882115] ata1.00: disabled
[  216.882136] ata1: EH complete
[Sun 02/28/2016 21:46:07] - End of Genesis manufacturing log.
[Sun 02/28/2016 21:46:07] - Exiting...
    </Log_Body>
    <Overall_Summary>
        <Start_Time> Sun, 02/28/2016 @ 21:44:25 </Start_Time>
        <End_Time> Sun, 02/28/2016 @ 21:46:07 </End_Time>
        <Overall_Result> FAIL </Overall_Result>
        <Exit_Code> (0x10090014:SF_GENESIS_FW_DOWNLOAD_ERROR) </Exit_Code>
    </Overall_Summary>
    <Environment_Settings>
        <Input_Parameters>
                  argv[2]: 0:0:0:0
                  argv[5]: 11
                  argv[6]: 22
        </Input_Parameters>
        <Log_File> /root/pmt/FW_PPRO_5_2_2_Release.672199.release--0/11_localhost.localdomain_DATETIMESTAMP_0.0.0.0_PROCESS_SSD_RESULT.log </Log_File>
        <Hostname> localhost.localdomain </Hostname>
        <Host_IP_Address> 127.0.0.1 </Host_IP_Address>
        <Port_Number> 0 </Port_Number>
        <Device_Name> /dev/sg0 </Device_Name>
        <SF_Genesis_Version> v1.7.0.01020130612-fc14-32bit </SF_Genesis_Version>
        <SF_Core_Library_Version> v1.7.1.20130612-fc14-32bit </SF_Core_Library_Version>
        <SF_OS_Information> Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686 </SF_OS_Information>
    </Environment_Settings>
    <Post_Processing_Device_Info>
        <WWN_OUI> UNKNOWN </WWN_OUI>
        <WWN_UniqueID> UNKNOWN </WWN_UniqueID>
        <Serial_Number> UNKNOWN </Serial_Number>
        <Model_Number> UNKNOWN </Model_Number>
        <Firmware_Revision> UNKNOWN </Firmware_Revision>
        <ROM_Revision> UNKNOWN </ROM_Revision>
        <NAND_Page_Size> UNKNOWN </NAND_Page_Size>
        <Number_Of_Chip_Enable> UNKNOWN </Number_Of_Chip_Enable>
        <Logical_Sectors> UNKNOWN </Logical_Sectors>
        <NAND_ID> UNKNOWN </NAND_ID>
        <Flash_Manufacturer> UNKNOWN </Flash_Manufacturer>
        <Flash_Device> UNKNOWN </Flash_Device>
    </Post_Processing_Device_Info>
</Genesis_Log>
[Sun 02/28/2016 21:46:07] - Overall Result for Device: /dev/sg0 ****** FAIL ******
本帖最近打赏记录:共1条打赏M币+1
离线wxmuzi
只看该作者 1楼 发表于: 2016-02-28
离线perter
只看该作者 2楼 发表于: 2016-02-28
离线onlyu7302
只看该作者 3楼 发表于: 2016-02-28
离线75106zxs
只看该作者 4楼 发表于: 2016-03-08
离线75106zxs
只看该作者 5楼 发表于: 2016-03-08
