  • 2921阅读
  • 6回复
[SandForce]sf2281开卡问题。跪求高手 [复制链接]
离线75106zxs
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2016-03-20
开到了75%。过不去了
<?xml version = "1.0"?>
<Genesis_Log>
    <Log_Body>
Overall Summary:
                Start Time: Sun, 03/20/2016 @ 00:43:39
                  End Time: Sun, 03/20/2016 @ 00:45:16
             OverallResult: FAIL
                  ExitCode: (0x10090009:SF_GENESIS_CDU_ERROR)
Environment Settings:
          Input Parameters:
                  argv[1]: -PROCESS_SSD
                  argv[2]: 0:0:0:0
                  argv[3]: /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
                  argv[4]: /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/22674.0.driveconfig
                  argv[5]: ssd
                  argv[6]: 128g
                  argv[7]: LOG=/root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/ssd_localhost.localdomain_DATETIMESTAMP_0.0.0.0_PROCESS_SSD_RESULT.log
                  Log File: /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/ssd_localhost.localdomain_DATETIMESTAMP_0.0.0.0_PROCESS_SSD_RESULT.log
                  Hostname: localhost.localdomain
           Host IP Address: 127.0.0.1
               Port Number: 0
                DeviceName: /dev/sg0
        SF_Genesis Version: v1.7.2.00220131113-fc14-32bit
   SF_Core Library Version: v1.7.2.20131113-fc14-32bit
         SF_OS_Information: Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686
Post Processing Device Information:
                   WWN OUI: UNKNOWN
              WWN UniqueID: UNKNOWN
                Serial No.: UNKNOWN
                 Model No.: UNKNOWN
         Firmware Revision: UNKNOWN
              ROM Revision: UNKNOWN
            NAND Page Size: UNKNOWN
     Number Of Chip Enable: UNKNOWN
           Logical Sectors: UNKNOWN
                   NAND ID: UNKNOWN
        Flash Manufacturer: UNKNOWN
              Flash Device: UNKNOWN
SandForce Genesis Utility v1.7.2.00220131113-fc14-32bit
SF_Core Library: v1.7.2.20131113-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Sun 03/20/2016 00:43:39] - SF_Genesis has been invoked with the following parameters:
                      argv[2]: 0:0:0:0
                      argv[5]: ssd
                      argv[6]: 128g
[Sun 03/20/2016 00:43:39] - Instructing the operating system to purge any existing cached data for device: '0:0:0:0'
[Sun 03/20/2016 00:43:44] - Issuing a discovery command for device: '0:0:0:0'
[Sun 03/20/2016 00:43:49] - Discovery command completed...
[Sun 03/20/2016 00:43:49] - Waiting 5 seconds for the system to settle...
[Sun 03/20/2016 00:43:54] - Device designation string '0:0:0:0' is mapped to node '/dev/sg0'
[Sun 03/20/2016 00:43:54] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg0
    MFP Package Filename = /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
      Configuration File = /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/22674.0.driveconfig
              Serial No. = ssd
         World Wide Name = 128g
[Sun 03/20/2016 00:43:54] - Successfully received the IDENTIFY data from the drive...
[Sun 03/20/2016 00:43:54] - Validating Manufacturing Firmware Package: /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
[Sun 03/20/2016 00:43:57] - Successfully opened the package: /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
[Sun 03/20/2016 00:43:57] - file  /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/22674.0.driveconfig Loaded successfully
[Sun 03/20/2016 00:43:57] - Warning:  Unable to query diagnostics information to perform power management settings check
[Sun 03/20/2016 00:43:57] - B01 Power Management configuration request detected
[Sun 03/20/2016 00:43:57] - Successfully extracted *.DriveConfig file: /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/22674.0.driveconfig
[Sun 03/20/2016 00:43:57] - Extracted Config_ID: 1 (22674) in DriveConfig file: /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/22674.0.driveconfig
[Sun 03/20/2016 00:43:57] - Extracted SerialOutputControl: 0
[Sun 03/20/2016 00:43:57] - Searching for flashware image for configuration 22674
[Sun 03/20/2016 00:43:57] - Manifest found for configuration 22674
[Sun 03/20/2016 00:43:57] - Flashware image extracted: 22674_fw_cl_ccmlc_Intel_64Gb_JS29F32B08JCME2_1Q_4C_1D_PP_R00427_s512.vic
[Sun 03/20/2016 00:43:57] - Searching for manufacturing image for configuration 22674
[Sun 03/20/2016 00:43:57] - Manufacturing image extracted: 22674_mf_ccmlc_Intel_64Gb_JS29F32B08JCME2_1Q_4C_1D_PP_R00427_s512.vic
[Sun 03/20/2016 00:43:57] - Proceeding in ROM mode, download feature 3...
[Sun 03/20/2016 00:43:58] - Successfully downloaded MFB to the drive...
[Sun 03/20/2016 00:43:58] - Waiting (5 sec) for the drive to settle...
[Sun 03/20/2016 00:44:03] - Successfully received the IDENTIFY data from the drive...
[Sun 03/20/2016 00:44:03] - Firmware revision reported to be: '522ABBM0'.  This indicates MFB download was successful.
[Sun 03/20/2016 00:44:03] - Successfully enabled SMART capabilities...
[Sun 03/20/2016 00:44:05] - Successfully issued a diagnostic unlock...
[Sun 03/20/2016 00:44:06] - Performing the flash test of block 0 (0x0000)...
[Sun 03/20/2016 00:44:07] - Flash Test Results:
Flash Test Parameters:
               Block Count: 0
                Page Count: 1
                 Bus Count: 1
        Chip Enabled Count: 4
                 Die Count: 1
                Lane Count: 3
               Plane Count: 2
Results Notes:
   N1 - At least one page tested and passed with no bit errors.
   N2 - No test data available.  Test may have aborted, or failed during the testing.
   N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
   N4 - At least  one erased page tested had bit error rate greater than half the correction power.
   N5 - Walking zeros test failed.
   N6 - Walking ones test failed.
   N7 - Block contained factory bad block markings and testing was skipped.
   N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
   N9 - Block in plane 0 was marked as a factory bad block.
  N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
  N11 - Block in plane 1 was marked as a factory bad block.
| Bus  | CE   | Die  | Lane | Value  | Result Notes                               | Overall |
| 0    | 0    | 0    | 0    | 0x0002 | N3                                         | WARNING |
| 0    | 0    | 0    | 1    | 0x0022 | N3,N5                                      | WARNING |
| 0    | 0    | 0    | 2    | 0x0002 | N3                                         | WARNING |
| 0    | 1    | 0    | 0    | 0x0022 | N3,N5                                      | WARNING |
| 0    | 1    | 0    | 1    | 0x0002 | N3                                         | WARNING |
| 0    | 1    | 0    | 2    | 0x0002 | N3                                         | WARNING |
| 0    | 2    | 0    | 0    | 0x0042 | N3,N6                                      | WARNING |
| 0    | 2    | 0    | 1    | 0x0002 | N3                                         | WARNING |
| 0    | 2    | 0    | 2    | 0x0043 | N1,N3,N6                                   | WARNING |
| 0    | 3    | 0    | 0    | 0x0002 | N3                                         | WARNING |
| 0    | 3    | 0    | 1    | 0x0002 | N3                                         | WARNING |
| 0    | 3    | 0    | 2    | 0x0002 | N3                                         | WARNING |
  Total Number of test results: 12
            Number of failures: 0
         Number of Passed with warnings: 12
      No. Passed without warnings: 0
[Sun 03/20/2016 00:44:07] - Performing the FORMAT Command with the following parameters:
         MemoryWearCycleCapability = 0
              CurrentPE_CycleCount = 0
                     LifeInSeconds = 0
                   LogicalCapacity = 187557552
                        SectorSize = 512
             SectorAlignmentOffset = 0
                  ExpectedMemoryID = 34953 (0x8889)
                   ExpectedNumDies = 0
               SerialOutputControl = 0
                           Time[8] = 0x0000000000000000
            MiscFlag_Erase_R_Block = 0
     MiscFlag_PanicHandlingEnabled = 0
        MiscFlag_PanicOnSATA_Error = 0
  MiscFlag_WriteThrottlingTestMode = 0
      MiscFlag_DisableUserBandECCX = 1
                        L_PageSize = 0
                        E_PageSize = 0
              ErrorCorrectionPower = 0
      ConfigDeviceReadDisturbCount = 0
   ConfigDeviceReadDisturbCountLow = 0
                  ExtraOptions_0_1 = 0
[Sun 03/20/2016 00:45:14] - FORMAT command completed...
[Sun 03/20/2016 00:45:14] - Waiting (2 sec) for the drive to settle...
[Sun 03/20/2016 00:45:16] - Setting up the stamp information through CDU command...
[Sun 03/20/2016 00:45:16] - FATAL_ERROR: Could not perform the ReadDriveConfigUnique() operation on the drive... (0x12000004:SF_SG_HOST_BAD_TARGET_ERROR)
[Sun 03/20/2016 00:45:16] - End of Genesis manufacturing log.
[Sun 03/20/2016 00:45:16] - Exiting...
    </Log_Body>
    <Overall_Summary>
        <Start_Time> Sun, 03/20/2016 @ 00:43:39 </Start_Time>
        <End_Time> Sun, 03/20/2016 @ 00:45:16 </End_Time>
        <Overall_Result> FAIL </Overall_Result>
        <Exit_Code> (0x10090009:SF_GENESIS_CDU_ERROR) </Exit_Code>
    </Overall_Summary>
    <Environment_Settings>
        <Input_Parameters>
                  argv[2]: 0:0:0:0
                  argv[5]: ssd
                  argv[6]: 128g
        </Input_Parameters>
        <Log_File> /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/ssd_localhost.localdomain_DATETIMESTAMP_0.0.0.0_PROCESS_SSD_RESULT.log </Log_File>
        <Hostname> localhost.localdomain </Hostname>
        <Host_IP_Address> 127.0.0.1 </Host_IP_Address>
        <Port_Number> 0 </Port_Number>
        <Device_Name> /dev/sg0 </Device_Name>
        <SF_Genesis_Version> v1.7.2.00220131113-fc14-32bit </SF_Genesis_Version>
        <SF_Core_Library_Version> v1.7.2.20131113-fc14-32bit </SF_Core_Library_Version>
        <SF_OS_Information> Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686 </SF_OS_Information>
    </Environment_Settings>
    <Post_Processing_Device_Info>
        <WWN_OUI> UNKNOWN </WWN_OUI>
        <WWN_UniqueID> UNKNOWN </WWN_UniqueID>
        <Serial_Number> UNKNOWN </Serial_Number>
        <Model_Number> UNKNOWN </Model_Number>
        <Firmware_Revision> UNKNOWN </Firmware_Revision>
        <ROM_Revision> UNKNOWN </ROM_Revision>
        <NAND_Page_Size> UNKNOWN </NAND_Page_Size>
        <Number_Of_Chip_Enable> UNKNOWN </Number_Of_Chip_Enable>
        <Logical_Sectors> UNKNOWN </Logical_Sectors>
        <NAND_ID> UNKNOWN </NAND_ID>
        <Flash_Manufacturer> UNKNOWN </Flash_Manufacturer>
        <Flash_Device> UNKNOWN </Flash_Device>
    </Post_Processing_Device_Info>
</Genesis_Log>
[Sun 03/20/2016 00:45:16] - Overall Result for Device: /dev/sg0 ****** FAIL ******
本帖最近打赏记录:共1条打赏M币+3
离线k1503
只看该作者 1楼 发表于: 2016-03-20
本帖最近打赏记录:共2条打赏M币+6
离线75106zxs
只看该作者 2楼 发表于: 2016-03-20
本帖最近打赏记录:共2条打赏M币+6
离线john_chuck
只看该作者 3楼 发表于: 2016-03-20
本帖最近打赏记录:共1条打赏M币+3
离线john_chuck
只看该作者 4楼 发表于: 2016-03-20
本帖最近打赏记录:共1条打赏M币+3
离线2017shuma
只看该作者 5楼 发表于: 2017-05-12
离线2017shuma
只看该作者 6楼 发表于: 2017-05-12
